[GRASS-SVN] r53175 - in grass/branches/releasebranch_6_4/vector/lidar: lidarlib v.lidar.correction v.lidar.edgedetection v.outlier v.surf.bspline
Wed Sep 12 12:11:17 PDT 2012
Author: neteler
Date: 2012-09-12 12:11:17 -0700 (Wed, 12 Sep 2012)
New Revision: 53175
   grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h
   grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c
   grass/branches/releasebranch_6_4/vector/lidar/lidarlib/zones.c
   grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c
   grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c
   grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
   grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c
   grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
Backport of improvements from G6.5.svn; revert r53173 as no longer needed
Modified: grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h
--- grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/lidarlib/PolimiFunct.h	2012-09-12 19:11:17 UTC (rev 53175)
@@ -161,13 +161,13 @@
 /*tcholBand */
-void tcholDec(double **N, double **T, int n, int BW, int CV);
-void tcholSolve(double **N, double *TN, double *parVect, int n, int BW, int CV);
+void tcholDec(double **N, double **T, int n, int BW);
+void tcholSolve(double **N, double *TN, double *parVect, int n, int BW);
 void tcholSolve2(double **N, double *TN, double **T, double *parVect, int n,
 		 int BW);
-void tcholInv(double **N, double *invNdiag, int n, int BW, int CV);
+void tcholInv(double **N, double *invNdiag, int n, int BW);
 void tcholSolveInv(double **N, double *TN, double *invNdiag, double *parVect,
-		   int n, int BW, int CV);
+		   int n, int BW);
 /*interpSpline */
Modified: grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c
--- grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/lidarlib/TcholBand.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -7,7 +7,7 @@
 /* Cholesky decomposition -> T= Lower Triangular Matrix */
     int i, j, k, end;
     double somma;
@@ -15,7 +15,7 @@
     G_debug(2, "tcholDec(): n=%d  BW=%d", n, BW);
     for (i = 0; i < n; i++) {
-	if (CV == 0) G_percent(i, n, 2);
+	G_percent(i, n, 2);
 	for (j = 0; j < BW; j++) {
 	    somma = N[i][j];
 	    /* start = 1 */
@@ -33,14 +33,14 @@
     return;
 /* Cholesky matrix solution */
     double **T;
@@ -50,7 +50,7 @@
     T = G_alloc_matrix(n, BW);
-    tcholDec(N, T, n, BW, CV);	/* T computation                */
+    tcholDec(N, T, n, BW);	/* T computation                */
     /* Forward substitution */
     parVect[0] = TN[0] / T[0][0];
@@ -121,7 +121,7 @@
 /* Cholesky matrix inversion */
     double **T = NULL;
     double *vect = NULL;
@@ -133,7 +133,7 @@
     vect = G_alloc_vector(n);
     /* T computation                */
     /* T Diagonal invertion */
@@ -168,7 +168,7 @@
 /* Cholesky matrix solution and inversion */
+		   int n, int BW)
     double **T = NULL;
@@ -181,7 +181,7 @@
     /* T computation                */
Modified: grass/branches/releasebranch_6_4/vector/lidar/lidarlib/zones.c
--- grass/branches/releasebranch_6_4/vector/lidar/lidarlib/zones.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/lidarlib/zones.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -226,7 +226,7 @@
     /* Returns the interpolation matrixes BandWidth dimension */
-    if (interpolator == 1) {
+    if (interpolator == P_BILINEAR) {
 	return (2 * nsplines + 1);
     else {
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.correction/main.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -406,7 +406,7 @@
 			       elaboration_reg.south, nterrain, nparameters,
 			       BW);
 		nCorrectGrad(N, lambda, nsplx, nsply, passoE, passoN);
-		tcholSolve(N, TN, parVect, nparameters, BW, 0);
+		tcholSolve(N, TN, parVect, nparameters, BW);
 		G_free_matrix(N);
 		G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.edgedetection/main.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -420,7 +420,7 @@
 			       elaboration_reg.south, npoints, nparameters,
 			       BW);
 		nCorrectGrad(N, lambda_B, nsplx, nsply, passoE, passoN);
-		tcholSolve(N, TN, parVect_bilin, nparameters, BW, 0);
+		tcholSolve(N, TN, parVect_bilin, nparameters, BW);
 		G_free_matrix(N);
 		for (tn = 0; tn < nparameters; tn++)
@@ -437,7 +437,7 @@
 				 BW);
 		nCorrectLapl(N, lambda_F, nsplx, nsply, passoE, passoN);
-		tcholSolve(N, TN, parVect_bicub, nparameters, BW, 0);
+		tcholSolve(N, TN, parVect_bicub, nparameters, BW);
 		G_free_matrix(N);
 		G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.outlier/main.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -396,7 +396,7 @@
 			       BW);
 		G_free_matrix(N);
 		G_free_vector(TN);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/crosscorr.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -36,7 +36,7 @@
 int cross_correlation(struct Map_info *Map, double passWE, double passNS)
-       Map: Map in which cross crorrelation will take values
+       Map: Vector map from which cross-crorrelation will take values
        passWE: spline step in West-East direction
        passNS: spline step in North-South direction
@@ -49,8 +49,11 @@
     int nsplx, nsply, nparam_spl, ndata;
     double *mean, *rms, *stdev, rms_min, stdev_min;
-    /* double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.01, 0.1, 1.0, 10.0 }; */	/* Fixed values (by the moment) */
-    double lambda[PARAM_LAMBDA] = { 0.01, 0.05, 0.1, 0.2, 0.3, 0.4 };	/* Fixed values (by the moment) */
+    /* double lambda[PARAM_LAMBDA] = { 0.0001, 0.001, 0.01, 0.1, 1.0, 10.0 }; */	/* Fixed values (at the moment) */
+    double lambda[PARAM_LAMBDA] = { 0.01, 0.05, 0.1, 0.2, 0.3, 0.4 };	/* Fixed values (at the moment) */
+    /* a more exhaustive search:
+       #define PARAM_LAMBDA 11
+       double lambda[PARAM_LAMBDA] = { 0.0001, 0.0005, 0.001, 0.005, 0.01, 0.05, 0.1, 0.5, 1.0, 5.0, 10.0 }; */
     double *TN, *Q, *parVect;	/* Interpolation and least-square vectors */
     double **N, **obsVect;	/* Interpolation and least-square matrix */
@@ -97,7 +100,7 @@
 	int BW, lbd_min;	/* lbd_min: index where minimun is found */
 	double mean_reg, *obs_mean;
-	int nrec, ctype = 0;
+	int nrec, ctype = 0, verbosity;
 	struct field_info *Fi;
 	dbDriver *driver_cats;
@@ -105,6 +108,8 @@
 	rms = G_alloc_vector(PARAM_LAMBDA);	/* number of parameter used used for cross validation */
 	stdev = G_alloc_vector(PARAM_LAMBDA);
+	verbosity = G_verbose(); /* store for later reset */
 	/* Working with attributes */
 	if (bspline_field > 0) {
 	    db_CatValArray_init(&cvarr);
@@ -159,7 +164,7 @@
 	TN = G_alloc_vector(nparam_spl);	/* vector */
 	parVect = G_alloc_vector(nparam_spl);	/* Parameters vector */
 	obsVect = G_alloc_matrix(ndata, 3);	/* Observation vector */
-	Q = G_alloc_vector(ndata);	/* "a priori" var-cov matrix */
+	Q = G_alloc_vector(ndata);		/* "a priori" var-cov matrix */
 	obs_mean = G_alloc_vector(ndata);
 	stat_vect = alloc_Stats(ndata);
@@ -167,22 +172,23 @@
 	for (lbd = 0; lbd < PARAM_LAMBDA; lbd++) {	/* For each lambda value */
 	    G_message(_("Beginning cross validation with "
-			"lambda_i=%.4f..."), lambda[lbd]);
+			"lambda_i=%.4f ... (%d of %d)"), lambda[lbd],
+			lbd+1, PARAM_LAMBDA);
-	       How cross correlation algorithm is done:
-	       For each cicle, only the first ndata-1 "observ" elements are considered for the
+	       How the cross correlation algorithm is done:
+	       For each cycle, only the first ndata-1 "observ" elements are considered for the
 	       interpolation. Within every interpolation mean is calculated to lowering border
-	       errors. The point let out will be used for an estimation. The error between the
+	       errors. The point left out will be used for an estimation. The error between the
 	       estimation and the observation is recorded for further statistics.
-	       At the end of the cicle, the last point, that is, the ndata-1 index, and the point
+	       At the end of the cycle, the last point, that is, the ndata-1 index, and the point
 	       with j index are swapped.
 	    for (j = 0; j < ndata; j++) {	/* Cross Correlation will use all ndata points */
-		double out_x, out_y, out_z;	/* This point is let out */
+		double out_x, out_y, out_z;	/* This point is left out */
 		for (i = 0; i < ndata; i++) {	/* Each time, only the first ndata-1 points */
-		    double dval;	/* are considered in the interpolation */
+		    double dval;		/* are considered in the interpolation */
 		    /* Setting obsVect vector & Q matrix */
 		    Q[i] = 1;	/* Q=I */
@@ -233,7 +239,7 @@
 		    obsVect[i][2] -= mean_reg;
-		/* This is let out */
+		/* This is left out */
 		out_x = observ[ndata - 1].coordX;
 		out_y = observ[ndata - 1].coordY;
 		out_z = obsVect[ndata - 1][2];
@@ -257,7 +263,9 @@
 		   if (bilin) interpolation (&interp, P_BILINEAR);
 		   else interpolation (&interp, P_BICUBIC);
-		tcholSolve(N, TN, parVect, nparam_spl, BW, 1);
+		G_set_verbose(G_verbose_min());
+		tcholSolve(N, TN, parVect, nparam_spl, BW);
+		G_set_verbose(verbosity);
 		/* Estimation of j-point */
 		if (bilin)
@@ -272,12 +280,15 @@
 					     nsplx, nsply, region.west,
 					     region.south, parVect);
-		/*Difference between estimated and observated i-point */
+		/* Difference between estimated and observated i-point */
 		stat_vect.error[j] = out_z - stat_vect.estima[j];
 		G_debug(1, "CrossCorrelation: stat_vect.error[%d]  =  %lf", j,
 			stat_vect.error[j]);
-		observ = swap(observ, j, ndata - 1);	/* Once the last value is let out, it is swap with j-value */
+		/* Once the last value is left out, it is swaped with j-value */
+		observ = swap(observ, j, ndata - 1);
+		G_percent(j, ndata, 2);
 	    mean[lbd] = calc_mean(stat_vect.error, stat_vect.n_points);
@@ -287,8 +298,9 @@
 		calc_standard_deviation(stat_vect.error, stat_vect.n_points);
 	    G_message(_("Mean = %.5lf"), mean[lbd]);
-	    G_message(_("Root Means Square (RMS) = %.5lf"),
+	    G_message(_("Root Mean Square (RMS) = %.5lf"),
 		      rms[lbd]);
+	    G_message("---");
 	}			/* ENDFOR each lambda value */
 	G_free_matrix(N);
@@ -298,7 +310,7 @@
 	G_free_vector(parVect);
 #ifdef nodef
 	/*TODO: if the minimum lambda is wanted, the function declaration must be changed */
-	/*At this moment, consider rms only */
+	/* At this moment, consider rms only */
 	rms_min = find_minimum(rms, &lbd_min);
 	stdev_min = find_minimum(stdev, &lbd_min);
@@ -313,11 +325,11 @@
 	*lambda_min = lambda[lbd_min];
 #endif
-	G_message(_("Results into a table:"));
-	G_message(_(" lambda    | mean        | rms         |"));
+	G_message(_("Table of results:"));
+	fprintf(stdout, _("    lambda |       mean |        rms |\n"));
-	    G_message(_(" %-10.5f| %-12.4f| %-12.4f|"), lambda[lbd],
-		      mean[lbd], rms[lbd]);
+	    fprintf(stdout, " %9.5f | %10.4f | %10.4f |\n", lambda[lbd],
+		    mean[lbd], rms[lbd]);
 	G_free_vector(mean);
@@ -433,8 +445,8 @@
 struct Point *swap(struct Point *point, int a, int b)
-    SWAP(point[a].coordX, point[b].coordX);	/* Once the last value is let out, it is swap with j-value */
+    SWAP(point[a].coordX, point[b].coordX);
     SWAP(point[a].coordY, point[b].coordY);
     SWAP(point[a].coordZ, point[b].coordZ);
     SWAP(point[a].cat, point[b].cat);
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c	2012-09-12 19:03:34 UTC (rev 53174)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/main.c	2012-09-12 19:11:17 UTC (rev 53175)
@@ -263,13 +263,8 @@
     /* Open input ext vector */
-    if (!in_ext_opt->answer) {
-	ext = FALSE;
-	G_message(_("No vector map of sparse points to interpolate was specified. "
-		    "Interpolation will be done with <%s> vector map"),
-		  in_opt->answer);
-    else {
+    ext = FALSE;
+    if (in_ext_opt->answer) {
 	ext = TRUE;
 	G_message(_("Vector map <%s> of sparse points will be interpolated"),
 		  in_ext_opt->answer);
@@ -308,6 +303,9 @@
 	    Vect_hist_copy(&In_ext, &Out);
 	Vect_hist_command(&Out);
+	G_message(_("Points in input vector map <%s> will be interpolated"),
+		  vector);
     /* raster output */
@@ -318,6 +316,9 @@
 	if ((raster = G_open_fp_cell_new(out_map_opt->answer)) < 0)
 	    G_fatal_error(_("Unable to create raster map <%s>"),
 			  out_map_opt->answer);
+	G_message(_("Cells for raster map <%s> will be interpolated"),
+		  map);
     /* read z values from attribute table */
@@ -473,6 +474,10 @@
 	while (last_column == FALSE) {	/* For each subregion column */
 	    int npoints = 0;
+	    /* needed for sparse points interpolation */
+	    int npoints_ext, *lineVect_ext = NULL;
+	    double **obsVect_ext;	/*, mean_ext = .0; */
+	    struct Point *observ_ext;
 	    subregion_col++;
 	    subregion++;
@@ -513,14 +518,31 @@
 	    /* reading points in interpolation region */
 	    dim_vect = nsplx * nsply;
-	    observ =
-		P_Read_Vector_Region_Map(&In, &elaboration_reg, &npoints,
-					 dim_vect, bspline_field);
+	    if (grid == FALSE && ext == TRUE) {
+		observ_ext =
+		    P_Read_Vector_Region_Map(&In_ext,
+					     &elaboration_reg,
+					     &npoints_ext, dim_vect,
+					     1);
+	    else
+		npoints_ext = 1;
+	    observ = NULL;
+	    if (npoints_ext > 0) {
+		observ =
+		    P_Read_Vector_Region_Map(&In, &elaboration_reg, &npoints,
+					     dim_vect, bspline_field);
+	    else
+		npoints = 0;
 	    G_debug(1,
 		    "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d",
 		    subregion_row, subregion_col, npoints);
-	    if (npoints > 0) {	/*  */
+	    /* only interpolate if there are any points in current subregion */
+	    if (npoints > 0 && npoints_ext > 0) {
 		int i;
 		nparameters = nsplx * nsply;
@@ -610,7 +632,7 @@
-		tcholSolve(N, TN, parVect, nparameters, BW, cross_corr_flag->answer);
 		G_free_matrix(N);
 		G_free_vector(TN);
@@ -637,8 +659,11 @@
 					table_name);
 		    else {	/* FLAG_EXT == TRUE */
+			/* done that earlier */
-			double **obsVect_ext;	/*, mean_ext = .0; */
 			observ_ext =
@@ -646,6 +671,7 @@
 						     &elaboration_reg,
 						     1);
 			obsVect_ext = G_alloc_matrix(npoints_ext, 3);	/* Observation vector_ext */
 			lineVect_ext = G_alloc_ivector(npoints_ext);
@@ -677,9 +703,11 @@
 		G_free_ivector(lineVect);
 	    else {
-		G_free(observ);
-		G_warning(_("No data within this subregion. "
-			    "Consider changing the spline step."));
+		if (observ)
+		    G_free(observ);
+		if (npoints == 0)
+		    G_warning(_("No data within this subregion. "
+				"Consider increasing spline step values."));
 	}			/*! END WHILE; last_column = TRUE */
     }				/*! END WHILE; last_row = TRUE */
