[GRASS-SVN] r53186 - grass/trunk/lib/python
svn_grass at osgeo.org
Sun Sep 16 05:18:26 PDT 2012
Author: martinl
Date: 2012-09-16 05:18:26 -0700 (Sun, 16 Sep 2012)
New Revision: 53186
grass/trunk/lib/python/db.py
pythonlib: fs -> sep
Modified: grass/trunk/lib/python/db.py
--- grass/trunk/lib/python/db.py 2012-09-16 10:56:32 UTC (rev 53185)
+++ grass/trunk/lib/python/db.py 2012-09-16 12:18:26 UTC (rev 53186)
@@ -135,8 +135,8 @@
fatal(_("Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided") %
{'sql': 'sql', 'filename': 'filename', 'table': 'table'} )
- if 'fs' not in args:
- args['fs'] = '|'
+ if 'sep' not in args:
+ args['sep'] = '|'
ret = run_command('db.select', quiet = True,
flags = 'c',
@@ -147,7 +147,7 @@
fatal(_("Fetching data failed"))
ofile = open(fname)
- result = map(lambda x: tuple(x.rstrip(os.linesep).split(args['fs'])),
+ result = map(lambda x: tuple(x.rstrip(os.linesep).split(args['sep'])),
ofile.readlines())
ofile.close()
try_remove(fname)
