[GRASS-SVN] r53215 - grass/trunk/lib/init
Tue Sep 18 13:32:10 PDT 2012
Author: glynn
Date: 2012-09-18 13:32:10 -0700 (Tue, 18 Sep 2012)
New Revision: 53215
   grass/trunk/lib/init/clean_temp.c
   grass/trunk/lib/init/lock.c
Don't attempt to declare errno
Modified: grass/trunk/lib/init/clean_temp.c
--- grass/trunk/lib/init/clean_temp.c	2012-09-18 19:05:40 UTC (rev 53214)
+++ grass/trunk/lib/init/clean_temp.c	2012-09-18 20:32:10 UTC (rev 53215)
@@ -32,8 +32,6 @@
 #define BUF_MAX 4096
 #endif
-extern int errno;
 #define SLEEP 30		/* 30 seconds */
 /* Recursively scan the directory pathname, removing directory and files */
Modified: grass/trunk/lib/init/lock.c
--- grass/trunk/lib/init/lock.c	2012-09-18 19:05:40 UTC (rev 53214)
+++ grass/trunk/lib/init/lock.c	2012-09-18 20:32:10 UTC (rev 53215)
@@ -26,7 +26,6 @@
 #include <errno.h>
-extern int errno;
 int main(int argc, char *argv[])
