[GRASS-SVN] r53217 - grass/branches/develbranch_6/raster/r.surf.contour
Tue Sep 18 13:39:14 PDT 2012
Author: neteler
Date: 2012-09-18 13:39:11 -0700 (Tue, 18 Sep 2012)
New Revision: 53217
   grass/branches/develbranch_6/raster/r.surf.contour/description.html
new example
Modified: grass/branches/develbranch_6/raster/r.surf.contour/description.html
--- grass/branches/develbranch_6/raster/r.surf.contour/description.html	2012-09-18 20:39:02 UTC (rev 53216)
+++ grass/branches/develbranch_6/raster/r.surf.contour/description.html	2012-09-18 20:39:11 UTC (rev 53217)
@@ -60,7 +60,6 @@
 the output map.  Run <em> <a href="r.slope.aspect.html">r.slope.aspect</a>
 </em> on <em>r.surf.contour</em> results to locate potential anomalies.
 <p>
 The running of <em>r.surf.contour</em> is very sensitive to the resolution of
 rasterized vector map.  If multiple contour lines go through the same raster,
@@ -69,6 +68,37 @@
 raster cells).  Since a flood fill algorithm is used, the program's running
 time will grow exponentially with the distance between contour lines.
+<h2>EXAMPLE</h2>
+Example to create contour lines from elevation model, then recreating DEM
+from these contour lines along with differences analysis (North Carolina
+sample data set):
+<div class="code"><pre>
+g.region rast=elevation -p
+# get minimum elevation value
+r.univar elevation
+# generate vector contour lines
+r.contour input=elevation output=contours_5m step=5 minlevel=50
+# rasterize contour lines
+v.info -c contours_5m
+v.to.rast input=contours_5m output=contours_5m use=attr column=level
+# generate DEM from rasterized contour lines
+r.surf.contour input=contours_5m output=elevation_from_cont5m
+# calculate difference map
+r.mapcalc "diff = elevation - elevation_from_cont5m"
+r.colors diff color=differences
+# analyze differences statistically
+r.univar diff
+</pre></div>
 <h2>SEE ALSO</h2>
 <em><a href="r.mapcalc.html">r.mapcalc</a></em>,
