[GRASS-SVN] r53219 - in grass/trunk: include/defs lib/gis lib/raster
svn_grass at osgeo.org
Tue Sep 18 14:03:13 PDT 2012
Author: glynn
Date: 2012-09-18 14:03:13 -0700 (Tue, 18 Sep 2012)
New Revision: 53219
Added:
grass/trunk/lib/gis/xdr.c
Removed:
grass/trunk/lib/raster/xdr.c
grass/trunk/include/defs/gis.h
grass/trunk/include/defs/raster.h
grass/trunk/lib/gis/G.h
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/raster/R.h
grass/trunk/lib/raster/get_row.c
grass/trunk/lib/raster/init.c
grass/trunk/lib/raster/put_row.c
grass/trunk/lib/raster/range.c
Move XDR functions from lib/raster to lib/gis
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/include/defs/gis.h 2012-09-18 21:03:13 UTC (rev 53219)
@@ -724,6 +724,12 @@
/* writ_zeros.c */
void G_write_zeros(int, size_t);
+/* xdr.c */
+void G_xdr_get_float(float *, const void *);
+void G_xdr_put_float(void *, const float *);
+void G_xdr_get_double(double *, const void *);
+void G_xdr_put_double(void *, const double *);
/* zero.c */
void G_zero(void *, int);
Modified: grass/trunk/include/defs/raster.h
--- grass/trunk/include/defs/raster.h 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/include/defs/raster.h 2012-09-18 21:03:13 UTC (rev 53219)
@@ -578,12 +578,6 @@
void Rast__create_window_mapping(int);
int Rast_row_repeat_nomask(int, int);
-/* xdr.c */
-void Rast_xdr_get_float(float *, const void *);
-void Rast_xdr_put_float(void *, const float *);
-void Rast_xdr_get_double(double *, const void *);
-void Rast_xdr_put_double(void *, const double *);
/* zero_cell.c */
void Rast_zero_buf(void *, RASTER_MAP_TYPE);
void Rast_zero_input_buf(void *, RASTER_MAP_TYPE);
Modified: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/gis/G.h 2012-09-18 21:03:13 UTC (rev 53219)
@@ -5,6 +5,7 @@
struct Cell_head window; /* Contains the current window */
int window_set; /* Flag: window set? */
+ int little_endian; /* Flag denoting little-endian architecture */
extern struct G__ G__; /* allocated in gisinit */
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/gis/gisinit.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -108,6 +108,9 @@
/* Mark window as not set */
G__.window_set = 0;
+ /* byte order */
+ G__.little_endian = G_is_little_endian();
initialized = 1;
setlocale(LC_NUMERIC, "C");
Copied: grass/trunk/lib/gis/xdr.c (from rev 53215, grass/trunk/lib/raster/xdr.c)
--- grass/trunk/lib/gis/xdr.c (rev 0)
+++ grass/trunk/lib/gis/xdr.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -0,0 +1,57 @@
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include "G.h"
+static void swap_float(void *dstp, const void *srcp) {
+ unsigned char *dst = (unsigned char *) dstp;
+ const unsigned char *src = (const unsigned char *) srcp;
+ if (G__.little_endian) {
+ dst[0] = src[3];
+ dst[1] = src[2];
+ dst[2] = src[1];
+ dst[3] = src[0];
+ else
+ memcpy(dst, src, 4);
+static void swap_double(void *dstp, const void *srcp) {
+ dst[0] = src[7];
+ dst[1] = src[6];
+ dst[2] = src[5];
+ dst[3] = src[4];
+ dst[4] = src[3];
+ dst[5] = src[2];
+ dst[6] = src[1];
+ dst[7] = src[0];
+ else
+ memcpy(dst, src, 8);
+void G_xdr_get_float(float *dst, const void *src)
+ swap_float(dst, src);
+void G_xdr_put_float(void *dst, const float *src)
+void G_xdr_get_double(double *dst, const void *src)
+ swap_double(dst, src);
+void G_xdr_put_double(void *dst, const double *src)
Modified: grass/trunk/lib/raster/R.h
--- grass/trunk/lib/raster/R.h 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/R.h 2012-09-18 21:03:13 UTC (rev 53219)
@@ -71,7 +71,6 @@
struct R__ /* Structure of library globals */
- int little_endian; /* Flag denoting little-endian architecture */
RASTER_MAP_TYPE fp_type; /* type for writing floating maps */
int mask_fd; /* File descriptor for automatic mask */
int auto_mask; /* Flag denoting automatic masking */
Modified: grass/trunk/lib/raster/get_row.c
--- grass/trunk/lib/raster/get_row.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/get_row.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -292,7 +292,7 @@
continue;
- Rast_xdr_get_float(&c[i], &work_buf[cmap[i]-1]);
+ G_xdr_get_float(&c[i], &work_buf[cmap[i]-1]);
@@ -311,7 +311,7 @@
continue;
- Rast_xdr_get_double(&c[i], &work_buf[cmap[i]-1]);
+ G_xdr_get_double(&c[i], &work_buf[cmap[i]-1]);
Modified: grass/trunk/lib/raster/init.c
--- grass/trunk/lib/raster/init.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/init.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -79,9 +79,6 @@
Rast__init_window();
- /* byte order */
- R__.little_endian = G_is_little_endian();
/* no histograms */
R__.want_histogram = 0;
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/put_row.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -154,7 +154,7 @@
else
f = rast[i];
- Rast_xdr_put_float(&work_buf[i], &f);
+ G_xdr_put_float(&work_buf[i], &f);
@@ -174,7 +174,7 @@
else
d = rast[i];
- Rast_xdr_put_double(&work_buf[i], &d);
+ G_xdr_put_double(&work_buf[i], &d);
Modified: grass/trunk/lib/raster/range.c
--- grass/trunk/lib/raster/range.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/range.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -112,8 +112,8 @@
return 2;
- Rast_xdr_get_double(&dcell1, xdr_buf[0]);
- Rast_xdr_get_double(&dcell2, xdr_buf[1]);
+ G_xdr_get_double(&dcell1, xdr_buf[0]);
+ G_xdr_get_double(&dcell2, xdr_buf[1]);
Rast_update_fp_range(dcell1, drange);
Rast_update_fp_range(dcell2, drange);
@@ -303,8 +303,8 @@
return;
- Rast_xdr_put_double(xdr_buf[0], &range->min);
- Rast_xdr_put_double(xdr_buf[1], &range->max);
+ G_xdr_put_double(xdr_buf[0], &range->min);
+ G_xdr_put_double(xdr_buf[1], &range->max);
if (write(fd, xdr_buf, sizeof(xdr_buf)) != sizeof(xdr_buf)) {
G_remove_misc("cell_misc", "f_range", name);
Deleted: grass/trunk/lib/raster/xdr.c
--- grass/trunk/lib/raster/xdr.c 2012-09-18 20:39:43 UTC (rev 53218)
+++ grass/trunk/lib/raster/xdr.c 2012-09-18 21:03:13 UTC (rev 53219)
@@ -1,57 +0,0 @@
-#include <stdlib.h>
-#include <string.h>
-#include <grass/raster.h>
-#include "R.h"
-static void swap_float(void *dstp, const void *srcp) {
- unsigned char *dst = (unsigned char *) dstp;
- const unsigned char *src = (const unsigned char *) srcp;
- if (R__.little_endian) {
- dst[0] = src[3];
- dst[1] = src[2];
- dst[2] = src[1];
- dst[3] = src[0];
- else
- memcpy(dst, src, 4);
-static void swap_double(void *dstp, const void *srcp) {
- dst[0] = src[7];
- dst[1] = src[6];
- dst[2] = src[5];
- dst[3] = src[4];
- dst[4] = src[3];
- dst[5] = src[2];
- dst[6] = src[1];
- dst[7] = src[0];
- else
- memcpy(dst, src, 8);
-void Rast_xdr_get_float(float *dst, const void *src)
- swap_float(dst, src);
-void Rast_xdr_put_float(void *dst, const float *src)
-void Rast_xdr_get_double(double *dst, const void *src)
- swap_double(dst, src);
-void Rast_xdr_put_double(void *dst, const double *src)
