[GRASS-SVN] r53241 - grass/branches/releasebranch_6_4/gui/wxpython/core
Thu Sep 20 00:58:26 PDT 2012
Author: annakrat
Date: 2012-09-20 00:58:26 -0700 (Thu, 20 Sep 2012)
New Revision: 53241
   grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
wxGUI: add right mapset to map names in command line
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2012-09-20 07:34:54 UTC (rev 53240)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py	2012-09-20 07:58:26 UTC (rev 53241)
@@ -134,22 +134,26 @@
         if len(params) < 1:
             return mapname, False
-        mapname = params[0][2]
-        mapset = ''
-        if fullyQualified and '@' not in mapname:
-            if layerType in ('raster', 'vector', '3d-raster', 'rgb', 'his'):
-                try:
-                    if layerType in ('raster', 'rgb', 'his'):
-                        findType = 'cell'
-                    else:
-                        findType = layerType
-                    mapset = grass.find_file(mapname, element = findType)['mapset']
-                except AttributeError, e: # not found
-                    return '', False
-                if not mapset:
-                    found = False
-            else:
-                mapset = grass.gisenv()['MAPSET']
+        # need to add mapset for all maps
+        mapsets = {}
+        for i, p, v in params:
+            mapname = v
+            mapset = ''
+            if fullyQualified and '@' not in mapname:
+                if layerType in ('raster', 'vector', '3d-raster', 'rgb', 'his'):
+                    try:
+                        if layerType in ('raster', 'rgb', 'his'):
+                            findType = 'cell'
+                        else:
+                            findType = layerType
+                        mapset = grass.find_file(mapname, element = findType)['mapset']
+                    except AttributeError, e: # not found
+                        return '', False
+                    if not mapset:
+                        found = False
+                else:
+                    mapset = grass.gisenv()['MAPSET']
+            mapsets[i] = mapset
         # update dcmd
@@ -157,8 +161,8 @@
                 dcmd[i] = p + '=' + v
             else:
                 dcmd[i] = v
-            if mapset:
-                dcmd[i] += '@' + mapset
+            if i in mapsets and mapsets[i]:
+                dcmd[i] += '@' + mapsets[i]
         maps = list()
