[GRASS-SVN] r53245 - in grass/trunk/gui/wxpython: dbmgr gui_core
svn_grass at osgeo.org
Thu Sep 20 03:28:59 PDT 2012
Author: annakrat
Date: 2012-09-20 03:28:58 -0700 (Thu, 20 Sep 2012)
New Revision: 53245
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/gui_core/preferences.py
wxGUI/dbmgr: disable fs option in attribute manager for Windows until better solution is found (merge from releasebranch, r53233)
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2012-09-20 10:27:51 UTC (rev 53244)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2012-09-20 10:28:58 UTC (rev 53245)
@@ -171,37 +171,28 @@
# TODO: more effective way should be implemented...
outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
+ cmdParams = dict(quiet = True,
+ parent = self,
+ flags = 'c')
+ if sys.platform != "win32":
+ cmdParams.update(dict(sep = fs))
if sql:
+ cmdParams.update(dict(sql = sql,
+ output = outFile.name,
+ overwrite = True))
ret = RunCommand('db.select',
- overwrite = True,
- quiet = True,
- parent = self,
- flags = 'c',
- sep = fs,
- sql = sql,
- output = outFile.name)
+ **cmdParams)
else:
+ cmdParams.update(dict(map = self.mapDBInfo.map,
+ layer = layer,
+ where = where,
+ stdout = outFile))
if columns:
- ret = RunCommand('v.db.select',
- quiet = True,
- parent = self,
- flags = 'c',
- map = self.mapDBInfo.map,
- layer = layer,
- columns = ','.join(columns),
- sep = fs,
- where = where,
- stdout = outFile)
- else:
- quiet = True,
- parent = self,
- flags = 'c',
- layer = layer,
- sep = fs,
- where = where,
- stdout = outFile)
+ cmdParams.update(dict(columns = ','.join(columns)))
+ ret = RunCommand('v.db.select',
+ **cmdParams)
# These two should probably be passed to init more cleanly
# setting the numbers of items = number of elements in the dictionary
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2012-09-20 10:27:51 UTC (rev 53244)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2012-09-20 10:28:58 UTC (rev 53245)
@@ -1143,6 +1143,9 @@
flexSizer.Add(label, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(separator, proportion = 0, flag = wx.ALIGN_RIGHT | wx.FIXED_MINSIZE)
+ if sys.platform == "win32":
+ label.Hide()
+ separator.Hide()
# ask on delete record
askOnDeleteRec = wx.CheckBox(parent = panel, id = wx.ID_ANY,
