[GRASS-SVN] r53251 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Thu Sep 20 12:30:47 PDT 2012
Author: neteler
Date: 2012-09-20 12:30:46 -0700 (Thu, 20 Sep 2012)
New Revision: 53251
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-09-20 19:30:16 UTC (rev 53250)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-09-20 19:30:46 UTC (rev 53251)
@@ -1734,9 +1734,8 @@
msgstr "Pionowy współczynnik skali"
#: ../misc/m.nviz.image/args.c:503
-#, fuzzy
msgid "Focus to point on surface (from SW corner in map units)"
-msgstr "Szerokość strefy w jednostkach mapy"
+msgstr ""
#: ../misc/m.nviz.image/args.c:513 ../misc/m.nviz.image/args.c:548
#: ../misc/m.nviz.image/args.c:560 ../misc/m.nviz.image/args.c:570
@@ -1805,12 +1804,14 @@
msgstr "Położenie linii wektorowych"
#: ../misc/m.nviz.image/args.c:655
+#, fuzzy
msgid "Volume slice transparency"
-msgstr ""
+msgstr "Położenie linii wektorowych"
#: ../misc/m.nviz.image/args.c:671
+#, fuzzy
msgid "Cutting plane index (0-5)"
-msgstr ""
+msgstr "Oblicza biny"
#: ../misc/m.nviz.image/args.c:672 ../misc/m.nviz.image/args.c:681
#: ../misc/m.nviz.image/args.c:690 ../misc/m.nviz.image/args.c:701
@@ -1829,12 +1830,14 @@
msgstr ""
#: ../misc/m.nviz.image/args.c:702
+#, fuzzy
msgid "Cutting plane tilt"
-msgstr ""
#: ../misc/m.nviz.image/args.c:713
+#, fuzzy
msgid "Cutting plane color (between two surfaces)"
-msgstr ""
+msgstr "Współrzędne początku i końca"
#: ../misc/m.nviz.image/args.c:727
msgid "Light position (x,y,z model coordinates)"
@@ -13755,7 +13758,7 @@
#: ../imagery/i.landsat.acca/algorithm.c:186
#, fuzzy
msgid "Maximum temperature:"
-msgstr "Obiekty"
+msgstr "temperatura"
#: ../imagery/i.landsat.acca/algorithm.c:187
#, c-format
@@ -13923,11 +13926,12 @@
#: ../imagery/i.landsat.toar/main.c:127
#, fuzzy
msgid "Solar elevation in degrees"
-msgstr "Nazwa pliku rastrowego mapy wysokości"
+msgstr "Kąt głównej osi w stopniach"
#: ../imagery/i.landsat.toar/main.c:136
+#, fuzzy
msgid "Image creation date (yyyy-mm-dd)"
-msgstr ""
+msgstr "Niedozwolony format daty: [%s] (rrrr-mm-dd)"
#: ../imagery/i.landsat.toar/main.c:145
msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
@@ -13963,9 +13967,8 @@
#: ../imagery/i.landsat.toar/main.c:241
-#, fuzzy
msgid "Failed to identify satellite"
-msgstr "Nie można wyznaczyć stref buforowych dla rastra."
+msgstr ""
#: ../imagery/i.landsat.toar/main.c:250
#, c-format
@@ -14931,9 +14934,8 @@
msgstr "Ekstrachuje parametry terenu z DEM."
#: ../imagery/i.modis.qc/main.c:98
-#, fuzzy
msgid "Name of input surface reflectance QC layer [bit array]"
-msgstr "Nazwa warstwy rastrowej powierzchni fraktalnej"
+msgstr ""
#: ../imagery/i.modis.qc/main.c:103
#, fuzzy
@@ -18303,7 +18305,7 @@
#: ../display/d.grid/main.c:101
msgid "Font size for gridline coordinate labels"
-msgstr ""
+msgstr "Rozmiar czcionki współrzędnych opisujących siatkę"
#: ../display/d.grid/main.c:106
msgid "Draw geographic grid (referenced to current ellipsoid)"
@@ -22930,11 +22932,11 @@
#: ../vector/v.lrs/v.lrs.create/main.c:121
msgid "Creates Linear Reference System"
-msgstr "Utwórz Linear Reference System"
+msgstr "Tworzy liniowy system odniesienia"
#: ../vector/v.lrs/v.lrs.create/main.c:130
msgid "Output vector map where oriented lines are written"
-msgstr "Wyjściowa mapawektorowa gdzie zapisano linie"
+msgstr "Wyjściowa mapa wektorowa, gdzie zapisano linie"
#: ../vector/v.lrs/v.lrs.create/main.c:135
msgid "Output vector map of errors"
@@ -24356,7 +24358,7 @@
#: ../vector/v.extract/main.c:93
msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-msgstr ""
+msgstr "Wybiera obiekty wektorowe i tworzy nową mapę zawierającą wybrane obiekty."
#: ../vector/v.extract/main.c:98
msgid "Dissolve common boundaries (default is no)"
@@ -27488,7 +27490,7 @@
#: ../vector/v.select/main.c:54
msgid "Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
+msgstr "Wybiera obiekty z mapy wektorowej (A) obiektami z innej mapy wektorowej (B)."
#: ../vector/v.select/main.c:87
msgid "Unknown operator"
@@ -36069,6 +36071,14 @@
msgid "Name of raster map with seed (at least 1 cell > 0)"
msgstr "Nazwa mapy rastrowej która ma być użyta jako maska (co najmniej 1 komórka >0)"
+#, fuzzy
+msgid "Root Means Square (RMS) = %.5lf"
+msgstr "Wyświetl ustawienia bieżącego regionu"
+#, fuzzy
+msgid " lambda | mean | rms |"
+msgstr "Zakres: min max\n"
#~ msgid "Title, in quotes"
#~ msgstr "Tytuł, w cudzysłowiu"
@@ -36452,14 +36462,6 @@
#~ msgid "Create a new vector from the current region."
#~ msgstr "Twórz nowy wektor dla zasięgu bieżącego regionu."
-#, fuzzy
-#~ msgid "Root Means Square (RMS) = %.5lf"
-#~ msgstr "Wyświetl ustawienia bieżącego regionu"
-#, fuzzy
-#~ msgid " lambda | mean | rms |"
-#~ msgstr "Zakres: min max\n"
#~ msgid "Area without centroid (may be OK for island)"
#~ msgstr "Obszar bez centroidu (może być OK dla wysp)"
@@ -36489,3 +36491,23 @@
#~ msgid "4th map for mosaic."
#~ msgstr "Czwarta mapa do mozaiki."
+#, fuzzy
+#~ msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+#~ msgstr "Proszę podać 3 mapy wektorowe 3D [x,y,z]"
+#, fuzzy
+#~ msgid "Use 3D raster mask (if exists) with output map"
+#~ msgstr "Użyj maski 3D (jeżeli istnieje) dla mapy wejściowej"
+#, fuzzy
+#~ msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+#~ msgstr "Ustawienia regionu 2D i 3D różnią się. Region 2D zostanie dostosowany do ustawień regionu 3D"
+#, fuzzy
+#~ msgid "Writing output raster maps..."
+#~ msgstr "Zapis wyjściowej mapy rastrowej %s..."
+#, fuzzy
+#~ msgid "Error writing 3D raster double data"
+#~ msgstr "błąd podczas odczytu danych rastrowych"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pl.po 2012-09-20 19:30:16 UTC (rev 53250)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pl.po 2012-09-20 19:30:46 UTC (rev 53251)
@@ -776,8 +776,9 @@
#: ../gui/wxpython/nviz/tools.py:4718 ../gui/wxpython/nviz/tools.py:4725
#: ../gui/wxpython/nviz/tools.py:4734
+#, fuzzy
msgid "East edge:"
-msgstr ""
+msgstr "Zachodnia granica:"
#: ../gui/wxpython/nviz/tools.py:4720 ../gui/wxpython/nviz/tools.py:4731
#: ../gui/wxpython/nviz/tools.py:4739
@@ -853,8 +854,9 @@
msgstr "Przesuń wierzchołek:"
#: ../gui/wxpython/nviz/preferences.py:227
+#, fuzzy
msgid "Turn exag:"
-msgstr ""
+msgstr "Przesuń wierzchołek:"
#: ../gui/wxpython/nviz/preferences.py:257
#, fuzzy
@@ -1106,12 +1108,12 @@
msgstr "widok 3D"
#: ../gui/wxpython/lmgr/frame.py:336
-#, python-format
+#, fuzzy, python-format
msgid ""
"Location <%s> created.\n"
"\n"
"Do you want to switch to the new location?"
-msgstr ""
+msgstr "Plik projektu <%s> już istnieje. Chcesz go nadpisać?"
#: ../gui/wxpython/lmgr/frame.py:339
#, fuzzy
@@ -1490,8 +1492,9 @@
msgstr "Tworzy histogram obrazu."
#: ../gui/wxpython/lmgr/toolbars.py:231
+#, fuzzy
msgid "Generate command for m.nviz.image based on current state"
-msgstr ""
+msgstr "Tworzy histogram obrazu."
#: ../gui/wxpython/lmgr/toolbars.py:233
msgid "3D view mode settings"
@@ -1518,8 +1521,9 @@
msgstr "Linkowanie rastrów"
#: ../gui/wxpython/lmgr/layertree.py:54
+#, fuzzy
msgid "Set raster output format"
-msgstr ""
+msgstr "Wybierz czcionkę wyjściową"
#: ../gui/wxpython/lmgr/layertree.py:56
#: ../gui/wxpython/gui_core/dialogs.py:1675 ../gui/wxpython/menustrings.py:56
@@ -1532,8 +1536,9 @@
msgstr "Linkowanie wektorów"
#: ../gui/wxpython/lmgr/layertree.py:60
+#, fuzzy
msgid "Set vector output format"
-msgstr ""
#: ../gui/wxpython/lmgr/layertree.py:62
msgid "Add command layer"
@@ -1965,9 +1970,9 @@
msgstr "Zaimportowano mapę wektorową <%(name)s>."
#: ../gui/wxpython/gis_set.py:471
-#, python-format
msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
-msgstr ""
+msgstr "Import mapy wektorowej <%(name)s> nie powiódł się."
#: ../gui/wxpython/gis_set.py:475
#, python-format
@@ -2965,8 +2970,9 @@
msgstr "Ustawienia językowe"
#: ../gui/wxpython/gui_core/preferences.py:440
+#, fuzzy
msgid "Choose language (requires to save and GRASS restart):"
-msgstr ""
+msgstr "Styl menu (wymaga restartu GUI):"
#: ../gui/wxpython/gui_core/preferences.py:460
msgid "Appearance settings"
@@ -3032,8 +3038,9 @@
msgstr ""
#: ../gui/wxpython/gui_core/preferences.py:750
+#, fuzzy
msgid "Mouse scrolling direction:"
-msgstr ""
+msgstr "Wybierz katalog wejściowy"
#: ../gui/wxpython/gui_core/preferences.py:782
#: ../gui/wxpython/gmodeler/dialogs.py:136
@@ -3392,7 +3399,7 @@
#: ../gui/wxpython/gui_core/toolbars.py:34
msgid "Render map"
-msgstr "Renderowanie mapy"
+msgstr "Renderuj mapę"
#: ../gui/wxpython/gui_core/toolbars.py:35
msgid "Force re-rendering all map layers"
@@ -3435,9 +3442,8 @@
msgstr "Opcje powiększania"
#: ../gui/wxpython/gui_core/toolbars.py:51
-#, fuzzy
msgid "Zoom to computational, default, saved region, ..."
-msgstr "Przybliż do regionu obliczeniowego (ustawionego przez g.region)"
+msgstr "Przybliż do regionu obliczeniowego, domyślnego, zapisanego, ..."
#: ../gui/wxpython/gui_core/toolbars.py:53
msgid "Zoom to selected map layer(s)"
@@ -3486,9 +3492,8 @@
msgstr "Wyświetl na mapie takie elementy jak skala i legenda"
#: ../gui/wxpython/gui_core/toolbars.py:75
-#, fuzzy
msgid "Create histogram with d.histogram"
-msgstr "Utwórz histogram obrazu lub pliku rastrowego"
+msgstr "Utwórz histogram (d.histogram)"
#: ../gui/wxpython/gui_core/ghelp.py:56 ../gui/wxpython/gui_core/ghelp.py:64
msgid "description"
@@ -3559,8 +3564,9 @@
msgstr "Konsola Pythona:"
#: ../gui/wxpython/gui_core/ghelp.py:462
+#, fuzzy
msgid "wxPython:"
-msgstr ""
+msgstr "Konsola Pythona:"
#: ../gui/wxpython/gui_core/ghelp.py:477
msgid "Language:"
@@ -3794,20 +3800,23 @@
msgstr "Wyczyść &wynik"
#: ../gui/wxpython/gui_core/goutput.py:261
+#, fuzzy
msgid "Clear command prompt content"
-msgstr ""
+msgstr "Wynik polecenia"
#: ../gui/wxpython/gui_core/goutput.py:263
+#, fuzzy
msgid "Save output window content to the file"
-msgstr ""
+msgstr "Wyczyść &wynik"
#: ../gui/wxpython/gui_core/goutput.py:265
msgid "Abort running command"
msgstr "Zatrzymaj bieżącą komendę"
#: ../gui/wxpython/gui_core/goutput.py:268
+#, fuzzy
msgid "&Protocol"
-msgstr ""
+msgstr "Protokół"
#: ../gui/wxpython/gui_core/goutput.py:270
msgid "Toggle to save list of executed commands into file; content saved when switching off."
@@ -3877,9 +3886,9 @@
#: ../gui/wxpython/gui_core/goutput.py:790
-#, python-format
msgid "Commands protocol saved into '%s'"
-msgstr ""
#: ../gui/wxpython/gui_core/goutput.py:845
#, python-format
@@ -3988,13 +3997,12 @@
msgstr "Zapisz region:"
#: ../gui/wxpython/gui_core/dialogs.py:529
-#, fuzzy
msgid "Set size and position"
-msgstr "Rozmiar i pozycja"
+msgstr "Ustaw rozmiar i pozycję"
#: ../gui/wxpython/gui_core/dialogs.py:530
msgid "Click and drag on the map display to set legend size and position and then press OK"
-msgstr ""
+msgstr "Kliknij i przeciągnij na płótnie mapy aby usyawić rozmiar i pozycję a następnie wciśnij OK"
#: ../gui/wxpython/gui_core/dialogs.py:541
#, python-format
@@ -4019,9 +4027,8 @@
msgstr "Legenda mapy rastrowej <%s>"
#: ../gui/wxpython/gui_core/dialogs.py:730
-#, fuzzy
msgid "Show text object"
-msgstr "Pokaż bieżący region"
+msgstr "Pokaż obiekt tekstowy"
#: ../gui/wxpython/gui_core/dialogs.py:740
#: ../gui/wxpython/psmap/dialogs.py:3713
@@ -4037,56 +4044,49 @@
"Dwuklik dla zmiany opcji."
#: ../gui/wxpython/gui_core/dialogs.py:861
-#, fuzzy
msgid "Create or edit imagery groups"
msgstr "Utwórz/edytuj grupę"
#: ../gui/wxpython/gui_core/dialogs.py:879
-#, fuzzy
msgid "Apply changes to selected group and close dialog"
msgstr "Zastosuj zmiany i zamknij okno"
#: ../gui/wxpython/gui_core/dialogs.py:880
-#, fuzzy
msgid "Apply changes to selected group"
-msgstr "Zastosuj zmiany dla bieżącej sesji"
+msgstr "Zastosuj zmiany dla wybranej grupy"
#: ../gui/wxpython/gui_core/dialogs.py:881
-#, fuzzy
msgid "Close dialog, changes are not applied"
-msgstr "Zamknij okno po wykonaniu"
+msgstr "Zamknij okno bez zastosowania zmian"
#: ../gui/wxpython/gui_core/dialogs.py:922
msgid "Select the group you want to edit or enter name of new group:"
-msgstr ""
+msgstr "Wybierz grupę do edycji lub wprowadź nazwę nowej grupy:"
#: ../gui/wxpython/gui_core/dialogs.py:933
-#, fuzzy
msgid "Layers in selected group:"
-msgstr "Wybór warstw"
+msgstr "Warstwy wybranej grupy:"
#: ../gui/wxpython/gui_core/dialogs.py:945
msgid "Select map layers and add them to the list."
-msgstr ""
+msgstr "Wybierz warstwy mapy i dodaj je do listy."
#: ../gui/wxpython/gui_core/dialogs.py:949
-#, fuzzy
msgid "Remove selected layer(s) from list."
-msgstr "Czy chcesz usunąć wybraną warstwę mapy z listy warstw?"
+msgstr "Usuń wybrane warstwy z listy warstw."
#: ../gui/wxpython/gui_core/dialogs.py:959
msgid "Define also sub-group (same name as group)"
-msgstr ""
+msgstr "Definiuj również sub-grupy (o tej samej nazwie co grupa)"
#: ../gui/wxpython/gui_core/dialogs.py:974
-#, fuzzy
msgid "Add selected map layers into group"
-msgstr "Dodaj wybrane warstwy do listy warstw"
+msgstr "Dodaj wybrane warstwy mapy do grupy"
#: ../gui/wxpython/gui_core/dialogs.py:1008
#, python-format
msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
+msgstr "Grupa <%s> została zmieniona, czy chcesz zatwierdzić zmiany?"
#: ../gui/wxpython/gui_core/dialogs.py:1010
msgid "Unapplied changes"
@@ -4095,27 +4095,27 @@
#: ../gui/wxpython/gui_core/dialogs.py:1092
#, python-format
msgid "No changes to apply in group <%s>."
-msgstr ""
+msgstr "Brak zmian w grupie <%s>."
#: ../gui/wxpython/gui_core/dialogs.py:1095
#, python-format
msgid "Group <%s> was successfully created."
-msgstr ""
+msgstr "Grupa <%s> została pomyślnie utworzona."
#: ../gui/wxpython/gui_core/dialogs.py:1097
#, python-format
msgid "Group <%s> was successfully changed."
-msgstr ""
+msgstr "Grupa <%s> została pomyślnie zmieniona."
#: ../gui/wxpython/gui_core/dialogs.py:1100
#, python-format
msgid "Creating of new group <%s> failed."
-msgstr ""
+msgstr "Tworzenie nowej grupy <%s> nie powiodło się."
#: ../gui/wxpython/gui_core/dialogs.py:1102
#, python-format
msgid "Changing of group <%s> failed."
-msgstr ""
+msgstr "Zmiana grypy <%s> nie powiodła się."
#: ../gui/wxpython/gui_core/dialogs.py:1131
msgid "No group selected."
@@ -4128,7 +4128,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1200
#, python-format
msgid "Dynamic series (%s)"
-msgstr ""
+msgstr "Dynamiczne serie (%s)"
#: ../gui/wxpython/gui_core/dialogs.py:1238
msgid "Map type:"
@@ -4137,7 +4137,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:1261
#, fuzzy
msgid "Select toggle"
-msgstr "Wybierz wiszące"
+msgstr "Wybierz "
#: ../gui/wxpython/gui_core/dialogs.py:1268
msgid "Mapset:"
@@ -4277,7 +4277,7 @@
#: ../gui/wxpython/gui_core/dialogs.py:2261
msgid "Symbol directory:"
-msgstr ""
+msgstr "Ścieżka do symboli:"
#: ../gui/wxpython/gui_core/dialogs.py:2269
msgid "Symbol name:"
@@ -4603,7 +4603,7 @@
#: ../gui/wxpython/menustrings.py:87
#, fuzzy
msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
-msgstr "Importuje trójwymiarowe pliki Vis5D (np. plik v5d z 1 zmienną i 1 znacznikiem czasu)"
+msgstr "Importuje trójwymiarowe pliki Vis5D (np. plik V5D z 1 zmienną i 1 krokiem czasu)"
#: ../gui/wxpython/menustrings.py:88
msgid "Import database table"
@@ -4744,11 +4744,11 @@
#: ../gui/wxpython/menustrings.py:122
msgid "Pack raster map"
-msgstr ""
+msgstr "Spakuj mapę rastrową"
#: ../gui/wxpython/menustrings.py:123
msgid "Packs up a raster map and support files for copying."
-msgstr ""
+msgstr "Pakuje mapę rastrową i pliki skojarzone w celu ich kopiowania."
#: ../gui/wxpython/menustrings.py:124
msgid "Export vector map"
@@ -4990,13 +4990,12 @@
msgstr "NVIZ - narzędzie do wizualizacji i animacji danych GRASS-a."
#: ../gui/wxpython/menustrings.py:192
-#, fuzzy
msgid "3D image rendering"
-msgstr "Włącz auto-rendering"
+msgstr "Renderowanie obrazu 3D"
#: ../gui/wxpython/menustrings.py:193
msgid "Creates a 3D rendering of GIS data."
-msgstr ""
+msgstr "Tworzy trójwymiarowe renderowanie danych GIS."
#: ../gui/wxpython/menustrings.py:194
msgid "Bearing/distance to coordinates"
@@ -5115,14 +5114,12 @@
msgstr "Utwórz nową lokację"
#: ../gui/wxpython/menustrings.py:226
-#, fuzzy
msgid "Launches location wizard to create new GRASS location."
-msgstr "Czy chcesz utworzyć lokację GRASS-a <%s>?"
+msgstr "Uruchamia kreatora lokacji w celu utworzenia nowej."
#: ../gui/wxpython/menustrings.py:228
-#, fuzzy
msgid "Creates new mapset in the current location, changes current mapset."
-msgstr "Zmienia bieżącą lokację i mapset."
+msgstr "Tworzy nowy mapset w bieżącej lokacji, zmienia bieżący mapset."
#: ../gui/wxpython/menustrings.py:229
msgid "Version"
@@ -5462,7 +5459,7 @@
msgid "Overlay rasters"
msgstr "Nakładanie rastrów"
-# poprzecznego?
+# poprzecznego? skośnego ;) tworzy unikalne wartości kategorii ze znalezionych w danym punkcie na wszystkich mapach. Produkt przecięcia kategorii?
#: ../gui/wxpython/menustrings.py:321
#, fuzzy
msgid "Cross product"
@@ -5470,7 +5467,7 @@
#: ../gui/wxpython/menustrings.py:322
msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr "Tworzy produkt przejściowy wartości kategorii ze złożonych warstw map rastrowych"
+msgstr "Tworzy produkt łączący wartości kategorii z wielu warstw map rastrowych."
#: ../gui/wxpython/menustrings.py:323
msgid "Raster series"
@@ -5770,16 +5767,15 @@
#: ../gui/wxpython/menustrings.py:396
msgid "Analyze patches"
-msgstr "Analiza mapy"
+msgstr "Analiza pokrycia"
#: ../gui/wxpython/menustrings.py:397
msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
#: ../gui/wxpython/menustrings.py:398
-#, fuzzy
msgid "Summary and display (requires XTerm)"
-msgstr "Ustawienia (wymaga XTerm)"
+msgstr "Podsumowanie i wyświetlenie (wymaga XTerm)"
#: ../gui/wxpython/menustrings.py:399
msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
@@ -5891,13 +5887,11 @@
#: ../gui/wxpython/menustrings.py:427
msgid "Shape index"
-msgstr ""
+msgstr "Wskaźnik kształtu"
-# wskąźnik kształtu?
#: ../gui/wxpython/menustrings.py:428
-#, fuzzy
msgid "Calculates shape index on a raster map"
-msgstr "Oblicza shape index z mapy rastrowej GRASS"
+msgstr "Oblicza wskaźnik kształtu z mapy rastrowej"
#: ../gui/wxpython/menustrings.py:429
msgid "Wildfire modeling"
@@ -6002,7 +5996,7 @@
#: ../gui/wxpython/menustrings.py:454
msgid "Generate surfaces"
-msgstr "Utwórz powierzchnie"
+msgstr "Utwórz powierzchnię"
#: ../gui/wxpython/menustrings.py:455
msgid "Fractal surface"
@@ -6094,11 +6088,11 @@
#: ../gui/wxpython/menustrings.py:478
msgid "Raster contours"
-msgstr "Raster do wektora"
+msgstr "Powierzchnia z linii rastrowych"
#: ../gui/wxpython/menustrings.py:479
msgid "Surface generation program from rasterized contours."
-msgstr "Oszacowanie powierzchni obszaru dla map rastrowych."
+msgstr "Generowanie powierzchni ze zrasteryzowanych izolinii."
#: ../gui/wxpython/menustrings.py:480
msgid "Regularized spline tension"
@@ -6122,7 +6116,7 @@
#: ../gui/wxpython/menustrings.py:485
msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
+msgstr "Wypełnia obszary rastra bez danych przy pomocy interpolacji splajn."
#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:763
msgid "Report and statistics"
@@ -6451,22 +6445,20 @@
msgstr "Wybór obiektów"
#: ../gui/wxpython/menustrings.py:573
-#, fuzzy
msgid "Attribute query"
-msgstr "Atrybuty"
+msgstr "Odpytaj atrybuty"
#: ../gui/wxpython/menustrings.py:574
-msgstr ""
#: ../gui/wxpython/menustrings.py:575
-#, fuzzy
msgid "Spatial query"
-msgstr "Zapytanie SQL"
+msgstr "Zapytanie przestrzenne"
#: ../gui/wxpython/menustrings.py:576
-msgstr ""
#: ../gui/wxpython/menustrings.py:586
msgid "Buffer vectors"
@@ -6506,25 +6498,24 @@
#: ../gui/wxpython/menustrings.py:595
msgid "Linear referencing"
-msgstr "Regresja liniowa"
+msgstr "Wymiarowanie obiektów liniowych"
#: ../gui/wxpython/menustrings.py:596
msgid "Create LRS"
-msgstr "Utwórz LRS"
+msgstr "Utwórz liniowy system odniesienia"
#: ../gui/wxpython/menustrings.py:597
-#, fuzzy
msgid "Create Linear Reference System"
#: ../gui/wxpython/menustrings.py:598
#, fuzzy
msgid "Create stationing"
-msgstr "Utwórz stationing"
+msgstr "Utwórz pikietaż"
#: ../gui/wxpython/menustrings.py:599
msgid "Create stationing from input lines, and linear reference system"
-msgstr ""
+msgstr "Tworzy pikietaż z linii wejściowych oraz liniowy system odniesienia"
#: ../gui/wxpython/menustrings.py:600
msgid "Create points/segments"
@@ -8702,10 +8693,11 @@
msgstr ""
#: ../gui/wxpython/psmap/dialogs.py:4299
+#, fuzzy
msgid ""
"PIL\n"
"missing"
-msgstr ""
+msgstr "Emisja"
#: ../gui/wxpython/psmap/dialogs.py:4316
@@ -9078,8 +9070,9 @@
msgstr "Wczytaj"
#: ../gui/wxpython/modules/colorrules.py:396
+#, fuzzy
msgid "Type filename or click to choose file and load color table"
-msgstr ""
+msgstr "Wybierz plik GRC"
#: ../gui/wxpython/modules/colorrules.py:402
#, fuzzy
@@ -9092,8 +9085,9 @@
msgstr "Wybierz plik do zapisania"
#: ../gui/wxpython/modules/colorrules.py:404
+#, fuzzy
msgid "Type filename or click to choose file and save color table"
-msgstr ""
+msgstr "Wybierz plik do zapisania"
#: ../gui/wxpython/modules/colorrules.py:410
#, fuzzy
@@ -9147,8 +9141,9 @@
#: ../gui/wxpython/modules/colorrules.py:937
#: ../gui/wxpython/modules/colorrules.py:1462
+#, fuzzy
msgid "Enter vector attribute values or percents:"
-msgstr ""
+msgstr "Odpytaj tabelę mapy wektorowej"
#: ../gui/wxpython/modules/colorrules.py:939
#: ../gui/wxpython/modules/colorrules.py:1464
@@ -9157,8 +9152,9 @@
#: ../gui/wxpython/modules/colorrules.py:950
+#, fuzzy
msgid "Select vector columns"
-msgstr ""
+msgstr "Wybierz mapę wektorową"
#: ../gui/wxpython/modules/colorrules.py:952
msgid "Layer:"
@@ -9169,24 +9165,29 @@
msgstr "Kolumna atrybutów:"
#: ../gui/wxpython/modules/colorrules.py:957
+#, fuzzy
msgid "Load color from column:"
-msgstr ""
+msgstr "Zapisz tabelę kolorów w pliku"
+#, fuzzy
msgid "Save color to column:"
-msgstr ""
+msgstr "Kolumna z RGB:"
#: ../gui/wxpython/modules/colorrules.py:959
+#, fuzzy
msgid "Load size from column:"
-msgstr ""
+msgstr "Otwiera model z pliku."
+#, fuzzy
msgid "Save size to column:"
-msgstr ""
+msgstr "Seria map rastrowych do mapy rastrowej 3D"
#: ../gui/wxpython/modules/colorrules.py:961
+#, fuzzy
msgid "Load width from column:"
-msgstr ""
msgid "Save width to column:"
@@ -9197,8 +9198,9 @@
msgstr ""
#: ../gui/wxpython/modules/colorrules.py:980
+#, fuzzy
msgid "Add GRASSRGB column to current attribute table."
-msgstr ""
+msgstr "Usuwa kolummnę z wybranej tabeli atrybutów"
#: ../gui/wxpython/modules/colorrules.py:1035
#: ../gui/wxpython/modules/colorrules.py:1084
@@ -9245,18 +9247,19 @@
msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1457
-#, python-format
msgid "Enter vector attribute values or percents %s:"
-msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1459
-#, python-format
msgid "Enter vector attribute values %s:"
-msgstr ""
#: ../gui/wxpython/modules/colorrules.py:1596
+#, fuzzy
msgid "Please select column to save values to."
-msgstr ""
+msgstr "Narzędzia do usuwania topologii mapy wektorowej."
#: ../gui/wxpython/modules/colorrules.py:1633
#, fuzzy
@@ -10113,8 +10116,9 @@
msgstr "Kopiuj bieżącą komendę do schowka (Ctrl+C)"
#: ../gui/wxpython/wxplot/dialogs.py:189
+#, fuzzy
msgid "Regression statistics copied to clipboard"
-msgstr ""
+msgstr "Kopiuj bieżącą komendę do schowka (Ctrl+C)"
#: ../gui/wxpython/wxplot/dialogs.py:251
msgid "Profile title:"
@@ -10764,7 +10768,7 @@
#: ../gui/wxpython/mapdisp/frame.py:1098
msgid "scale object"
-msgstr "skaluj obiekt"
+msgstr "skalę"
#: ../gui/wxpython/mapdisp/frame.py:1127
msgid "Show/hide legend"
@@ -10772,7 +10776,7 @@
#: ../gui/wxpython/mapdisp/frame.py:1128
msgid "legend object"
-msgstr "legenda"
+msgstr "legendę"
#: ../gui/wxpython/mapdisp/frame.py:1150
#: ../gui/wxpython/mapdisp/toolbars.py:46
@@ -10829,9 +10833,8 @@
msgstr ""
#: ../gui/wxpython/mapdisp/toolbars.py:54
-#, fuzzy
msgid "Drag with mouse to rotate 3D scene"
-msgstr "Przeciągnij myszą by wyświetlić całą mapę"
+msgstr "Przeciągnij myszą by obracać sceną 3D"
#: ../gui/wxpython/mapdisp/toolbars.py:57
msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
@@ -11005,18 +11008,18 @@
msgstr "Uwaga"
#: ../gui/wxpython/mapdisp/main.py:116
-#, python-format
msgid "Starting map display <%s>..."
-msgstr ""
+msgstr "Otwórz nowe okno mapy"
#: ../gui/wxpython/mapdisp/main.py:123
msgid "GRASS GIS Map Display: "
msgstr "Okno Mapy GRASS GIS: "
#: ../gui/wxpython/mapdisp/main.py:129
-#, python-format
msgid "Stopping map display <%s>..."
-msgstr ""
#: ../gui/wxpython/mapdisp/gprint.py:285
msgid ""
@@ -11431,12 +11434,14 @@
msgstr "Wyjdź z digitizera i zapisz zmiany"
#: ../gui/wxpython/vdigit/toolbars.py:125
+#, fuzzy
msgid "Vector Digitizer manual"
-msgstr ""
+msgstr "Błąd digitizera"
#: ../gui/wxpython/vdigit/toolbars.py:126
+#, fuzzy
msgid "Show Vector Digitizer manual"
-msgstr ""
#: ../gui/wxpython/vdigit/toolbars.py:128
msgid "Additional tools (copy, flip, connect, etc.)"
@@ -11651,8 +11656,9 @@
#: ../gui/wxpython/gmodeler/frame.py:181
#: ../gui/wxpython/gmodeler/frame.py:1602
+#, fuzzy
msgid "Python script is up-to-date"
-msgstr ""
+msgstr "Skrypt pythona (*.py)|*.py"
#: ../gui/wxpython/gmodeler/frame.py:196
msgid "Redrawing model..."
@@ -11672,8 +11678,9 @@
msgstr "Wyjdź z modelera"
#: ../gui/wxpython/gmodeler/frame.py:300
+#, fuzzy
msgid "No intermediate data to delete."
-msgstr ""
+msgstr "Usuń dane tymczasowe"
#: ../gui/wxpython/gmodeler/frame.py:304
#, python-format
@@ -11880,9 +11887,9 @@
msgstr ""
#: ../gui/wxpython/gmodeler/frame.py:1500
-#, python-format
msgid "Unable to launch Python script. %s"
-msgstr ""
+msgstr "Nie można przełączyć na mapset <%s>."
#: ../gui/wxpython/gmodeler/frame.py:1525
msgid "Choose file to save"
@@ -13104,6 +13111,27 @@
msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
msgstr ""
+msgid "RGB color column:"
+msgid "Emission"
+msgstr "Emisja"
+msgid "Unable to switch to mapset <%s>."
+#, fuzzy
+msgid "Choose a working directory"
+#, fuzzy
+msgid "Drops a column from selected attribute table."
+#, fuzzy
+msgid "Plot text settings saved to file '%s'."
+msgstr "Ustawienia profilu zapisano w pliku '%s'."
#~ msgid "Choose GIS Data Directory:"
#~ msgstr "Wybierz katalog danych GIS:"
@@ -13553,9 +13581,6 @@
#~ msgid "Save color table to file"
#~ msgstr "Zapisz tabelę kolorów w pliku"
-#~ msgid "RGB color column:"
-#~ msgstr "Kolumna z RGB:"
#~ msgid "&Clear output"
#~ msgstr "Wyczyść &wynik"
@@ -13599,9 +13624,6 @@
#~ msgid "Look at:"
#~ msgstr "Patrz na:"
-#~ msgid "Emission"
-#~ msgstr "Emisja"
#~ msgid "Coarse:"
#~ msgstr "niskiej jakości"
@@ -13746,9 +13768,6 @@
#~ msgid "Settings named '%s' not found"
#~ msgstr "Ustawienia o nazwie '%s' nie odnalezione"
-#~ msgid "Unable to switch to mapset <%s>."
-#~ msgstr "Nie można przełączyć na mapset <%s>."
#~ msgid "List all database drivers."
#~ msgstr "Wyświetla listę wszystkich sterowników baz danych."
@@ -13765,10 +13784,6 @@
#~ msgstr "Dodaj pasek skali"
#, fuzzy
-#~ msgid "Choose a working directory"
-#~ msgstr "Wybierz katalog wejściowy"
-#, fuzzy
#~ msgid ""
#~ "Unable to launch \"Supervised Classification Tool\".\n"
#~ "\n"
@@ -13987,10 +14002,6 @@
#~ msgstr "Definiuje użytkownika/hasło dla sterownika/bazy danych."
#, fuzzy
-#~ msgid "Drops a column from selected attribute table."
-#~ msgstr "Usuwa kolummnę z wybranej tabeli atrybutów"
-#, fuzzy
#~ msgid "GRASS GIS Cartographic Composer"
#~ msgstr "Graficzny modeler GRASS GIS"
@@ -14182,10 +14193,6 @@
#~ msgstr "Typ histogramu"
#, fuzzy
-#~ msgid "Plot text settings saved to file '%s'."
-#~ msgstr "Ustawienia profilu zapisano w pliku '%s'."
-#, fuzzy
#~ msgid "No map or image group selected to plot."
#~ msgstr "Nie wybrano warstwy mapy"
@@ -14313,3 +14320,15 @@
#, fuzzy
#~ msgid "Extract quality control parameters from Modis QC layers"
#~ msgstr "Wpisz parametry dla"
+#, fuzzy
+#~ msgid "Plot text sizes saved to file '%s'."
+#~ msgstr "Ustawienia profilu zapisano w pliku '%s'."
+#, fuzzy
+#~ msgid "Settings for selected map"
+#~ msgstr "Ustaw zasięg wybranych map jako region obliczeniowy"
+#, fuzzy
+#~ msgid "Scale"
+#~ msgstr "Skala:"
