[GRASS-SVN] r53257 - in grass/trunk: . include/Make lib/form raster/r.le/r.le.setup/polytocell
Fri Sep 21 03:09:04 PDT 2012
Author: glynn
Date: 2012-09-21 03:09:03 -0700 (Fri, 21 Sep 2012)
New Revision: 53257
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Compile.make
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/lib/form/Makefile
   grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile
Remove configure checks for XDR
Remove remaining references to XDRLIB
Modified: grass/trunk/configure
--- grass/trunk/configure	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/configure	2012-09-21 10:09:03 UTC (rev 53257)
@@ -4444,216 +4444,13 @@
 LIBS="$ac_save_libs"
-# Note: -lxdr -liberty -lws2_32 is for MinGW
-echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4451: checking for xdrmem_create" >&5
-cat > conftest.$ac_ext <<EOF
-#line 4454 "configure"
-#include "confdefs.h"
-/* System header to define __stub macros and hopefully few prototypes,
-    which can conflict with char xdrmem_create(); below.  */
-#include <assert.h>
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char xdrmem_create();
-int main() {
-/* The GNU C library defines this for functions which it implements
-    to always fail with ENOSYS.  Some functions are actually named
-    something starting with __ and the normal name is an alias.  */
-#if defined (__stub_xdrmem_create) || defined (__stub___xdrmem_create)
-choke me
-#else
-xdrmem_create();
-#endif
-; return 0; }
-EOF
-if { (eval echo configure:4477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_func_xdrmem_create=yes"
-else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_func_xdrmem_create=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_func_'xdrmem_create`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-  XDRLIB=
-else
-  echo "$ac_t""no" 1>&6
-echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4495: checking for xdrmem_create in -lsun" >&5
-ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lsun  $LIBS"
-#line 4501 "configure"
-int main() {
-xdrmem_create()
-; return 0; }
-EOF
-if { (eval echo configure:4512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  XDRLIB=-lsun
-else
-echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4531: checking for xdrmem_create in -lnsl" >&5
-ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
-LIBS="-lnsl  $LIBS"
-#line 4537 "configure"
-int main() {
-xdrmem_create()
-; return 0; }
-EOF
-if { (eval echo configure:4548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  XDRLIB=-lnsl
-else
-echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4567: checking for xdrmem_create in -lrpclib" >&5
-ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
-LIBS="-lrpclib  $LIBS"
-#line 4573 "configure"
-int main() {
-xdrmem_create()
-; return 0; }
-EOF
-if { (eval echo configure:4584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  XDRLIB=-lrpclib
-else
-echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4603: checking for xdrmem_create in -lxdr" >&5
-ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
-LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 4609 "configure"
-int main() {
-xdrmem_create()
-; return 0; }
-EOF
-if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  XDRLIB="-lxdr -liberty -lws2_32"
-else
- { echo "configure: error: *** Unable to locate XDR functions." 1>&2; exit 1; }
-fi
-fi
-fi
-fi
-fi
 for ac_func in asprintf
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4654: checking for $ac_func" >&5
+echo "configure:4451: checking for $ac_func" >&5
-#line 4657 "configure"
+#line 4454 "configure"
     which can conflict with char $ac_func(); below.  */
@@ -4676,7 +4473,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4703,10 +4500,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4707: checking for atan" >&5
+echo "configure:4504: checking for atan" >&5
-#line 4710 "configure"
+#line 4507 "configure"
     which can conflict with char atan(); below.  */
@@ -4729,7 +4526,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4747,13 +4544,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4751: checking for atan in -lm" >&5
+echo "configure:4548: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4757 "configure"
+#line 4554 "configure"
@@ -4764,7 +4561,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4791,10 +4588,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4795: checking for dlsym" >&5
+echo "configure:4592: checking for dlsym" >&5
-#line 4798 "configure"
+#line 4595 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4817,7 +4614,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4835,13 +4632,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4839: checking for dlsym in -ldl" >&5
+echo "configure:4636: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4845 "configure"
+#line 4642 "configure"
@@ -4852,7 +4649,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4879,10 +4676,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4883: checking for iconv" >&5
+echo "configure:4680: checking for iconv" >&5
-#line 4886 "configure"
+#line 4683 "configure"
     which can conflict with char iconv(); below.  */
@@ -4905,7 +4702,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4923,13 +4720,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4927: checking for iconv in -liconv" >&5
+echo "configure:4724: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4933 "configure"
+#line 4730 "configure"
@@ -4940,7 +4737,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4959,13 +4756,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4963: checking for iconv in -lgiconv" >&5
+echo "configure:4760: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4969 "configure"
+#line 4766 "configure"
@@ -4976,7 +4773,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4995,10 +4792,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4999: checking for libiconv" >&5
+echo "configure:4796: checking for libiconv" >&5
-#line 5002 "configure"
+#line 4799 "configure"
     which can conflict with char libiconv(); below.  */
@@ -5021,7 +4818,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -5039,13 +4836,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5043: checking for libiconv in -liconv" >&5
+echo "configure:4840: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5049 "configure"
+#line 4846 "configure"
@@ -5056,7 +4853,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5075,13 +4872,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5079: checking for libiconv in -lgiconv" >&5
+echo "configure:4876: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5085 "configure"
+#line 4882 "configure"
@@ -5092,7 +4889,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5129,10 +4926,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5133: checking for socket" >&5
+echo "configure:4930: checking for socket" >&5
-#line 5136 "configure"
+#line 4933 "configure"
     which can conflict with char socket(); below.  */
@@ -5155,7 +4952,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5173,13 +4970,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5177: checking for socket in -lsocket" >&5
+echo "configure:4974: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5183 "configure"
+#line 4980 "configure"
@@ -5190,7 +4987,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5238,7 +5035,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5242: checking for location of zlib includes" >&5
+echo "configure:5039: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5264,15 +5061,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:5268: checking for $ac_hdr" >&5
+echo "configure:5065: checking for $ac_hdr" >&5
-#line 5271 "configure"
+#line 5068 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:5276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5073: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -5306,7 +5103,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5310: checking for location of zlib library" >&5
+echo "configure:5107: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5331,13 +5128,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5335: checking for deflate in -lz" >&5
+echo "configure:5132: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5341 "configure"
+#line 5138 "configure"
@@ -5348,7 +5145,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5396,7 +5193,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5400: checking for location of External PROJ.4 includes" >&5
+echo "configure:5197: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5422,15 +5219,15 @@
 do
-echo "configure:5426: checking for $ac_hdr" >&5
+echo "configure:5223: checking for $ac_hdr" >&5
-#line 5429 "configure"
+#line 5226 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5231: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5467,7 +5264,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5471: checking External PROJ.4 version" >&5
+echo "configure:5268: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -5475,7 +5272,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 5479 "configure"
+#line 5276 "configure"
 #include <stdio.h>
@@ -5487,7 +5284,7 @@
 EOF
-if { (eval echo configure:5491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5512,7 +5309,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5516: checking for location of External PROJ.4 library" >&5
+echo "configure:5313: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5537,13 +5334,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5541: checking for pj_get_def in -lproj" >&5
+echo "configure:5338: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5547 "configure"
+#line 5344 "configure"
@@ -5554,7 +5351,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5588,7 +5385,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5592: checking for location of External PROJ.4 data files" >&5
+echo "configure:5389: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5612,14 +5409,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5616: checking for epsg" >&5
+echo "configure:5413: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5623: checking for $PROJSHARE/epsg" >&5
+echo "configure:5420: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5651,7 +5448,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:5655: checking for $ac_word" >&5
+echo "configure:5452: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5691,7 +5488,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5695: checking whether to use regex" >&5
+echo "configure:5492: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5711,7 +5508,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5715: checking for location of regex includes" >&5
+echo "configure:5512: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5737,15 +5534,15 @@
 do
-echo "configure:5741: checking for $ac_hdr" >&5
+echo "configure:5538: checking for $ac_hdr" >&5
-#line 5744 "configure"
+#line 5541 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5546: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5779,7 +5576,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5783: checking for location of regex library" >&5
+echo "configure:5580: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5804,10 +5601,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5808: checking for regcomp" >&5
+echo "configure:5605: checking for regcomp" >&5
-#line 5811 "configure"
+#line 5608 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5830,7 +5627,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5857,13 +5654,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5861: checking for regcomp in -lregex" >&5
+echo "configure:5658: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5867 "configure"
+#line 5664 "configure"
@@ -5874,7 +5671,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5924,7 +5721,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5928: checking whether to use Readline" >&5
+echo "configure:5725: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5945,7 +5742,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5949: checking for location of Readline includes" >&5
+echo "configure:5746: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5971,15 +5768,15 @@
 do
-echo "configure:5975: checking for $ac_hdr" >&5
+echo "configure:5772: checking for $ac_hdr" >&5
-#line 5978 "configure"
+#line 5775 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6015,15 +5812,15 @@
 do
-echo "configure:6019: checking for $ac_hdr" >&5
+echo "configure:5816: checking for $ac_hdr" >&5
-#line 6022 "configure"
+#line 5819 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6057,7 +5854,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6061: checking for location of Readline library" >&5
+echo "configure:5858: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6082,13 +5879,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6086: checking for readline in -lreadline" >&5
+echo "configure:5883: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6092 "configure"
+#line 5889 "configure"
@@ -6099,7 +5896,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6134,13 +5931,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6138: checking for add_history in -lhistory" >&5
+echo "configure:5935: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6144 "configure"
+#line 5941 "configure"
@@ -6151,7 +5948,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6193,7 +5990,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6197: checking whether to use GDAL" >&5
+echo "configure:5994: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6211,7 +6008,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6215: checking for $ac_word" >&5
+echo "configure:6012: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6266,14 +6063,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6270 "configure"
+#line 6067 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6282,14 +6079,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6286 "configure"
+#line 6083 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6321,7 +6118,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6325: checking whether to use libLAS" >&5
+echo "configure:6122: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6338,7 +6135,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6342: checking for $ac_word" >&5
+echo "configure:6139: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6386,14 +6183,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6390 "configure"
+#line 6187 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6401,14 +6198,14 @@
   rm -rf conftest*
-#line 6405 "configure"
+#line 6202 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6440,7 +6237,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6444: checking whether to use NetCDF" >&5
+echo "configure:6241: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6457,7 +6254,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6461: checking for $ac_word" >&5
+echo "configure:6258: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6504,14 +6301,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6508 "configure"
+#line 6305 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6519,14 +6316,14 @@
   rm -rf conftest*
-#line 6523 "configure"
+#line 6320 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6557,7 +6354,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6561: checking whether to use GEOS" >&5
+echo "configure:6358: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6575,7 +6372,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6579: checking for $ac_word" >&5
+echo "configure:6376: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6623,15 +6420,15 @@
 do
-echo "configure:6627: checking for $ac_hdr" >&5
+echo "configure:6424: checking for $ac_hdr" >&5
-#line 6630 "configure"
+#line 6427 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6667,13 +6464,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6671: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6468: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 6677 "configure"
+#line 6474 "configure"
@@ -6684,7 +6481,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6720,13 +6517,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6724: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6521: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6730 "configure"
+#line 6527 "configure"
@@ -6737,7 +6534,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6781,7 +6578,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6785: checking whether to use TIFF" >&5
+echo "configure:6582: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6801,7 +6598,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6805: checking for location of TIFF includes" >&5
+echo "configure:6602: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6827,15 +6624,15 @@
 do
-echo "configure:6831: checking for $ac_hdr" >&5
+echo "configure:6628: checking for $ac_hdr" >&5
-#line 6834 "configure"
+#line 6631 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6636: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6869,7 +6666,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6873: checking for location of TIFF library" >&5
+echo "configure:6670: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6900,13 +6697,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6904: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6701: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6910 "configure"
+#line 6707 "configure"
@@ -6917,7 +6714,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6936,13 +6733,13 @@
-echo "configure:6940: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6737: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6946 "configure"
+#line 6743 "configure"
@@ -6953,7 +6750,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6972,13 +6769,13 @@
-echo "configure:6976: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6773: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6982 "configure"
+#line 6779 "configure"
@@ -6989,7 +6786,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7008,13 +6805,13 @@
-echo "configure:7012: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6809: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7018 "configure"
+#line 6815 "configure"
@@ -7025,7 +6822,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7044,13 +6841,13 @@
-echo "configure:7048: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6845: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 7054 "configure"
+#line 6851 "configure"
@@ -7061,7 +6858,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7080,13 +6877,13 @@
-echo "configure:7084: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6881: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7090 "configure"
+#line 6887 "configure"
@@ -7097,7 +6894,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7116,13 +6913,13 @@
-echo "configure:7120: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6917: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7126 "configure"
+#line 6923 "configure"
@@ -7133,7 +6930,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7152,13 +6949,13 @@
-echo "configure:7156: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6953: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7162 "configure"
+#line 6959 "configure"
@@ -7169,7 +6966,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7267,7 +7064,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7271: checking whether to use PNG" >&5
+echo "configure:7068: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7286,7 +7083,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7290: checking for location of PNG includes" >&5
+echo "configure:7087: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7312,15 +7109,15 @@
 do
-echo "configure:7316: checking for $ac_hdr" >&5
+echo "configure:7113: checking for $ac_hdr" >&5
-#line 7319 "configure"
+#line 7116 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7324: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7354,7 +7151,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7358: checking for location of PNG library" >&5
+echo "configure:7155: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7379,13 +7176,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7383: checking for png_read_image in -lpng" >&5
+echo "configure:7180: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7389 "configure"
+#line 7186 "configure"
@@ -7396,7 +7193,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7438,7 +7235,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7442: checking whether to use PostgreSQL" >&5
+echo "configure:7239: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7465,7 +7262,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7469: checking for location of PostgreSQL includes" >&5
+echo "configure:7266: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7491,15 +7288,15 @@
 do
-echo "configure:7495: checking for $ac_hdr" >&5
+echo "configure:7292: checking for $ac_hdr" >&5
-#line 7498 "configure"
+#line 7295 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7503: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7300: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7537,7 +7334,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7541: checking for location of PostgreSQL library" >&5
+echo "configure:7338: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7566,13 +7363,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7570: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7367: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7576 "configure"
+#line 7373 "configure"
@@ -7583,7 +7380,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7602,13 +7399,13 @@
-echo "configure:7606: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7403: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7612 "configure"
+#line 7409 "configure"
@@ -7619,7 +7416,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7638,13 +7435,13 @@
-echo "configure:7642: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7439: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7648 "configure"
+#line 7445 "configure"
@@ -7655,7 +7452,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7674,13 +7471,13 @@
-echo "configure:7678: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7475: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7684 "configure"
+#line 7481 "configure"
@@ -7691,7 +7488,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7748,13 +7545,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7752: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7549: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7758 "configure"
+#line 7555 "configure"
@@ -7765,7 +7562,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7787,13 +7584,13 @@
-echo "configure:7791: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7588: checking for PQcmdTuples in -lpq" >&5
-#line 7797 "configure"
+#line 7594 "configure"
@@ -7804,7 +7601,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7847,7 +7644,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7851: checking whether to use MySQL" >&5
+echo "configure:7648: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7867,7 +7664,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7871: checking for location of MySQL includes" >&5
+echo "configure:7668: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7893,15 +7690,15 @@
 do
-echo "configure:7897: checking for $ac_hdr" >&5
+echo "configure:7694: checking for $ac_hdr" >&5
-#line 7900 "configure"
+#line 7697 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7938,7 +7735,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7942: checking for location of MySQL library" >&5
+echo "configure:7739: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7969,13 +7766,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7973: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7770: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7979 "configure"
+#line 7776 "configure"
@@ -7986,7 +7783,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8005,13 +7802,13 @@
-echo "configure:8009: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7806: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8015 "configure"
+#line 7812 "configure"
@@ -8022,7 +7819,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8041,13 +7838,13 @@
-echo "configure:8045: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7842: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8051 "configure"
+#line 7848 "configure"
@@ -8058,7 +7855,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8077,13 +7874,13 @@
-echo "configure:8081: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7878: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8087 "configure"
+#line 7884 "configure"
@@ -8094,7 +7891,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8113,13 +7910,13 @@
-echo "configure:8117: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7914: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8123 "configure"
+#line 7920 "configure"
@@ -8130,7 +7927,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8149,13 +7946,13 @@
-echo "configure:8153: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7950: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8159 "configure"
+#line 7956 "configure"
@@ -8166,7 +7963,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8185,13 +7982,13 @@
-echo "configure:8189: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7986: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8195 "configure"
+#line 7992 "configure"
@@ -8202,7 +7999,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8221,13 +8018,13 @@
-echo "configure:8225: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8022: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8231 "configure"
+#line 8028 "configure"
@@ -8238,7 +8035,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8328,7 +8125,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8332: checking for $ac_word" >&5
+echo "configure:8129: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8377,10 +8174,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8381: checking for mysql_server_init" >&5
+echo "configure:8178: checking for mysql_server_init" >&5
-#line 8384 "configure"
+#line 8181 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8406,7 +8203,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8458,7 +8255,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8462: checking whether to use SQLite" >&5
+echo "configure:8259: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8478,7 +8275,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8482: checking for location of SQLite includes" >&5
+echo "configure:8279: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8504,15 +8301,15 @@
 do
-echo "configure:8508: checking for $ac_hdr" >&5
+echo "configure:8305: checking for $ac_hdr" >&5
-#line 8511 "configure"
+#line 8308 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8516: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8555,7 +8352,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8559: checking for location of SQLite library" >&5
+echo "configure:8356: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8584,13 +8381,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8588: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8385: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8594 "configure"
+#line 8391 "configure"
@@ -8601,7 +8398,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8620,13 +8417,13 @@
-echo "configure:8624: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8421: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8630 "configure"
+#line 8427 "configure"
@@ -8637,7 +8434,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8656,13 +8453,13 @@
-echo "configure:8660: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8457: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8666 "configure"
+#line 8463 "configure"
@@ -8673,7 +8470,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8692,13 +8489,13 @@
-echo "configure:8696: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8493: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8702 "configure"
+#line 8499 "configure"
@@ -8709,7 +8506,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8778,7 +8575,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8782: checking whether to use FFMPEG" >&5
+echo "configure:8579: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8798,7 +8595,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8802: checking for location of FFMPEG includes" >&5
+echo "configure:8599: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8824,15 +8621,15 @@
 do
-echo "configure:8828: checking for $ac_hdr" >&5
+echo "configure:8625: checking for $ac_hdr" >&5
-#line 8831 "configure"
+#line 8628 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8868,15 +8665,15 @@
 do
-echo "configure:8872: checking for $ac_hdr" >&5
+echo "configure:8669: checking for $ac_hdr" >&5
-#line 8875 "configure"
+#line 8672 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8677: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8912,15 +8709,15 @@
 do
-echo "configure:8916: checking for $ac_hdr" >&5
+echo "configure:8713: checking for $ac_hdr" >&5
-#line 8919 "configure"
+#line 8716 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8924: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8963,7 +8760,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8967: checking for location of FFMPEG library" >&5
+echo "configure:8764: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8990,13 +8787,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8994: checking for av_free in -lavutil" >&5
+echo "configure:8791: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 9000 "configure"
+#line 8797 "configure"
@@ -9007,7 +8804,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9026,13 +8823,13 @@
-echo "configure:9030: checking for av_free in -lavutil" >&5
+echo "configure:8827: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 9036 "configure"
+#line 8833 "configure"
@@ -9043,7 +8840,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:9047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9088,13 +8885,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9092: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8889: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 9098 "configure"
+#line 8895 "configure"
@@ -9105,7 +8902,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9124,13 +8921,13 @@
-echo "configure:9128: checking for avcodec_init in -lavcodec" >&5
+echo "configure:8925: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9134 "configure"
+#line 8931 "configure"
@@ -9141,7 +8938,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9186,13 +8983,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9190: checking for av_set_parameters in -lavformat" >&5
+echo "configure:8987: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9196 "configure"
+#line 8993 "configure"
@@ -9203,7 +9000,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9222,13 +9019,13 @@
-echo "configure:9226: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9023: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9232 "configure"
+#line 9029 "configure"
@@ -9239,7 +9036,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9298,7 +9095,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9302: checking whether to use OpenGL" >&5
+echo "configure:9099: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9332,7 +9129,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9336: checking for location of OpenGL includes" >&5
+echo "configure:9133: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9358,15 +9155,15 @@
 do
-echo "configure:9362: checking for $ac_hdr" >&5
+echo "configure:9159: checking for $ac_hdr" >&5
-#line 9365 "configure"
+#line 9162 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9167: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9400,7 +9197,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9404: checking for location of OpenGL library" >&5
+echo "configure:9201: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9429,13 +9226,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9433: checking for glBegin in -lGL" >&5
+echo "configure:9230: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9439 "configure"
+#line 9236 "configure"
@@ -9446,7 +9243,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9465,13 +9262,13 @@
-echo "configure:9469: checking for glBegin in -lGL" >&5
+echo "configure:9266: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 9475 "configure"
+#line 9272 "configure"
 #include "confdefs.h"
@@ -9482,7 +9279,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9501,13 +9298,13 @@
-echo "configure:9505: checking for glBegin in -lGL" >&5
+echo "configure:9302: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9511 "configure"
+#line 9308 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -9518,7 +9315,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9537,13 +9334,13 @@
-echo "configure:9541: checking for glBegin in -lGL" >&5
+echo "configure:9338: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9547 "configure"
+#line 9344 "configure"
@@ -9554,7 +9351,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -9616,13 +9413,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9620: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9417: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9626 "configure"
+#line 9423 "configure"
@@ -9633,7 +9430,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9652,13 +9449,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:9656: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9453: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9662 "configure"
+#line 9459 "configure"
@@ -9669,7 +9466,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9716,10 +9513,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9720: checking for glXCreatePbuffer" >&5
+echo "configure:9517: checking for glXCreatePbuffer" >&5
-#line 9723 "configure"
+#line 9520 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9742,7 +9539,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9779,10 +9576,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9783: checking for glXCreateGLXPixmap" >&5
+echo "configure:9580: checking for glXCreateGLXPixmap" >&5
-#line 9786 "configure"
+#line 9583 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9805,7 +9602,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9848,7 +9645,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9852: checking for location of OpenGL framework" >&5
+echo "configure:9649: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9872,15 +9669,15 @@
 do
-echo "configure:9876: checking for $ac_hdr" >&5
+echo "configure:9673: checking for $ac_hdr" >&5
-#line 9879 "configure"
+#line 9676 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9916,10 +9713,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9920: checking for glBegin" >&5
+echo "configure:9717: checking for glBegin" >&5
-#line 9923 "configure"
+#line 9720 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9942,7 +9739,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9979,10 +9776,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9983: checking for gluBeginCurve" >&5
+echo "configure:9780: checking for gluBeginCurve" >&5
-#line 9986 "configure"
+#line 9783 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -10005,7 +9802,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -10053,7 +9850,7 @@
-echo "configure:10057: checking for location of OpenGL includes" >&5
+echo "configure:9854: checking for location of OpenGL includes" >&5
@@ -10079,15 +9876,15 @@
 do
-echo "configure:10083: checking for $ac_hdr" >&5
+echo "configure:9880: checking for $ac_hdr" >&5
-#line 10086 "configure"
+#line 9883 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10091: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10121,7 +9918,7 @@
-echo "configure:10125: checking for location of OpenGL library" >&5
+echo "configure:9922: checking for location of OpenGL library" >&5
@@ -10146,18 +9943,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10150: checking for OpenGL library" >&5
+echo "configure:9947: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10154 "configure"
+#line 9951 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10181,18 +9978,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10185: checking for GLU library" >&5
+echo "configure:9982: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10189 "configure"
+#line 9986 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10241,7 +10038,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10245: checking whether to use Tcl/Tk" >&5
+echo "configure:10042: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -10261,7 +10058,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10265: checking for location of Tcl/Tk includes" >&5
+echo "configure:10062: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10287,15 +10084,15 @@
 do
-echo "configure:10291: checking for $ac_hdr" >&5
+echo "configure:10088: checking for $ac_hdr" >&5
-#line 10294 "configure"
+#line 10091 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10096: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10332,15 +10129,15 @@
 do
-echo "configure:10336: checking for $ac_hdr" >&5
+echo "configure:10133: checking for $ac_hdr" >&5
-#line 10339 "configure"
+#line 10136 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10374,7 +10171,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10378: checking Tcl version" >&5
+echo "configure:10175: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
@@ -10382,7 +10179,7 @@
 else
-#line 10386 "configure"
+#line 10183 "configure"
 #include <stdio.h>
@@ -10394,7 +10191,7 @@
 EOF
-if { (eval echo configure:10398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -10412,7 +10209,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10416: checking Tk version" >&5
+echo "configure:10213: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10420,7 +10217,7 @@
 else
-#line 10424 "configure"
+#line 10221 "configure"
 #include <stdio.h>
@@ -10432,7 +10229,7 @@
 EOF
-if { (eval echo configure:10436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -10461,7 +10258,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10465: checking for location of Tcl/Tk library" >&5
+echo "configure:10262: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10501,13 +10298,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10505: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10302: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 10511 "configure"
+#line 10308 "configure"
@@ -10518,7 +10315,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10537,13 +10334,13 @@
-echo "configure:10541: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10338: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10547 "configure"
+#line 10344 "configure"
@@ -10554,7 +10351,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10581,13 +10378,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10585: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10382: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10591 "configure"
+#line 10388 "configure"
@@ -10598,7 +10395,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10617,13 +10414,13 @@
-echo "configure:10621: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10418: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10627 "configure"
+#line 10424 "configure"
@@ -10634,7 +10431,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10661,13 +10458,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10665: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10462: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10671 "configure"
+#line 10468 "configure"
@@ -10678,7 +10475,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10697,13 +10494,13 @@
-echo "configure:10701: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10498: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10707 "configure"
+#line 10504 "configure"
@@ -10714,7 +10511,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10792,13 +10589,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10796: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10593: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10802 "configure"
+#line 10599 "configure"
@@ -10809,7 +10606,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10828,13 +10625,13 @@
-echo "configure:10832: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10629: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10838 "configure"
+#line 10635 "configure"
@@ -10845,7 +10642,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10872,13 +10669,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10876: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10673: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10882 "configure"
+#line 10679 "configure"
@@ -10889,7 +10686,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10908,13 +10705,13 @@
-echo "configure:10912: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10709: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10918 "configure"
+#line 10715 "configure"
@@ -10925,7 +10722,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10952,13 +10749,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10956: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10753: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10962 "configure"
+#line 10759 "configure"
@@ -10969,7 +10766,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10988,13 +10785,13 @@
-echo "configure:10992: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10789: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10998 "configure"
+#line 10795 "configure"
@@ -11005,7 +10802,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:11009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11095,13 +10892,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11099: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:10896: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11105 "configure"
+#line 10902 "configure"
@@ -11112,7 +10909,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11162,7 +10959,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11166: checking whether to use ODBC" >&5
+echo "configure:10963: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11181,7 +10978,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11185: checking for location of ODBC includes" >&5
+echo "configure:10982: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11207,15 +11004,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11211: checking for $ac_hdr" >&5
+echo "configure:11008: checking for $ac_hdr" >&5
-#line 11214 "configure"
+#line 11011 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11219: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11249,7 +11046,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11253: checking for location of ODBC library" >&5
+echo "configure:11050: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11274,13 +11071,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11278: checking for SQLConnect in -lodbc" >&5
+echo "configure:11075: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11284 "configure"
+#line 11081 "configure"
@@ -11291,7 +11088,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11316,13 +11113,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11320: checking for SQLConnect in -liodbc" >&5
+echo "configure:11117: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11326 "configure"
+#line 11123 "configure"
@@ -11333,7 +11130,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11358,11 +11155,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11362: checking for ODBC library" >&5
+echo "configure:11159: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 11366 "configure"
+#line 11163 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -11370,7 +11167,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:11374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11419,7 +11216,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11423: checking whether to use FFTW" >&5
+echo "configure:11220: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11438,7 +11235,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11442: checking for location of FFTW includes" >&5
+echo "configure:11239: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11464,15 +11261,15 @@
 do
-echo "configure:11468: checking for $ac_hdr" >&5
+echo "configure:11265: checking for $ac_hdr" >&5
-#line 11471 "configure"
+#line 11268 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11500,15 +11297,15 @@
 do
-echo "configure:11504: checking for $ac_hdr" >&5
+echo "configure:11301: checking for $ac_hdr" >&5
-#line 11507 "configure"
+#line 11304 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11536,15 +11333,15 @@
 do
-echo "configure:11540: checking for $ac_hdr" >&5
+echo "configure:11337: checking for $ac_hdr" >&5
-#line 11543 "configure"
+#line 11340 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11590,7 +11387,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11594: checking for location of FFTW library" >&5
+echo "configure:11391: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11615,13 +11412,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11619: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11416: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11625 "configure"
+#line 11422 "configure"
@@ -11632,7 +11429,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11657,13 +11454,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11661: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11458: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 11667 "configure"
+#line 11464 "configure"
@@ -11674,7 +11471,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11699,13 +11496,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11703: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11500: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11709 "configure"
+#line 11506 "configure"
@@ -11716,7 +11513,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11773,7 +11570,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11777: checking whether to use BLAS" >&5
+echo "configure:11574: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11794,7 +11591,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11798: checking for location of BLAS includes" >&5
+echo "configure:11595: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11814,7 +11611,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11818: checking for location of BLAS library" >&5
+echo "configure:11615: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11840,15 +11637,15 @@
 do
-echo "configure:11844: checking for $ac_hdr" >&5
+echo "configure:11641: checking for $ac_hdr" >&5
-#line 11847 "configure"
+#line 11644 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11883,13 +11680,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11887: checking for dnrm2_ in -lblas" >&5
+echo "configure:11684: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 11893 "configure"
+#line 11690 "configure"
@@ -11900,7 +11697,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11919,13 +11716,13 @@
-echo "configure:11923: checking for dnrm2_ in -lblas" >&5
+echo "configure:11720: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11929 "configure"
+#line 11726 "configure"
@@ -11936,7 +11733,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11980,13 +11777,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11984: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11781: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 11990 "configure"
+#line 11787 "configure"
@@ -11997,7 +11794,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:12001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12012,13 +11809,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12016: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11813: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 12022 "configure"
+#line 11819 "configure"
@@ -12029,7 +11826,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12044,13 +11841,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12048: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11845: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12054 "configure"
+#line 11851 "configure"
@@ -12061,7 +11858,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:12065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12107,16 +11904,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12111: checking for sgemm in $vlib_flags" >&5
+echo "configure:11908: checking for sgemm in $vlib_flags" >&5
-#line 12113 "configure"
+#line 11910 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:12120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12134,13 +11931,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12138: checking for sgemm_ in -lblas" >&5
+echo "configure:11935: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12144 "configure"
+#line 11941 "configure"
@@ -12151,7 +11948,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12166,13 +11963,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12170: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11967: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12176 "configure"
+#line 11973 "configure"
@@ -12183,7 +11980,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12198,13 +11995,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12202: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11999: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12208 "configure"
+#line 12005 "configure"
@@ -12215,7 +12012,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12249,13 +12046,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12253: checking for acosp in -lsunmath" >&5
+echo "configure:12050: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12259 "configure"
+#line 12056 "configure"
@@ -12266,7 +12063,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12281,13 +12078,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12285: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12082: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12291 "configure"
+#line 12088 "configure"
@@ -12298,7 +12095,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12328,13 +12125,13 @@
 # Generic BLAS library
-echo "configure:12332: checking for sgemm_ in -lblas" >&5
+echo "configure:12129: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 12338 "configure"
+#line 12135 "configure"
@@ -12345,7 +12142,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12384,7 +12181,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12388: checking whether to use LAPACK" >&5
+echo "configure:12185: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12409,7 +12206,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12413: checking for location of LAPACK includes" >&5
+echo "configure:12210: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12429,7 +12226,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12433: checking for location of LAPACK library" >&5
+echo "configure:12230: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12455,15 +12252,15 @@
 do
-echo "configure:12459: checking for $ac_hdr" >&5
+echo "configure:12256: checking for $ac_hdr" >&5
-#line 12462 "configure"
+#line 12259 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12495,10 +12292,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12499: checking for dsegv_" >&5
+echo "configure:12296: checking for dsegv_" >&5
-#line 12502 "configure"
+#line 12299 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12521,7 +12318,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12548,13 +12345,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12552: checking for desgv_ in -llapack" >&5
+echo "configure:12349: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12558 "configure"
+#line 12355 "configure"
@@ -12565,7 +12362,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12597,13 +12394,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12601: checking for dgesv_ in -llapack" >&5
+echo "configure:12398: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 12607 "configure"
+#line 12404 "configure"
@@ -12614,7 +12411,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12633,13 +12430,13 @@
-echo "configure:12637: checking for dgesv_ in -llapack" >&5
+echo "configure:12434: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12643 "configure"
+#line 12440 "configure"
@@ -12650,7 +12447,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12706,7 +12503,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12710: checking whether to use Cairo" >&5
+echo "configure:12507: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -12738,7 +12535,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12742: checking for location of cairo includes" >&5
+echo "configure:12539: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12764,15 +12561,15 @@
 do
-echo "configure:12768: checking for $ac_hdr" >&5
+echo "configure:12565: checking for $ac_hdr" >&5
-#line 12771 "configure"
+#line 12568 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12776: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12808,7 +12605,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12812: checking for location of cairo library" >&5
+echo "configure:12609: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12828,7 +12625,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12832: checking for cairo linking flags" >&5
+echo "configure:12629: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12844,10 +12641,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12848: checking for cairo_create" >&5
+echo "configure:12645: checking for cairo_create" >&5
-#line 12851 "configure"
+#line 12648 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12870,7 +12667,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -12904,10 +12701,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12908: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12705: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12911 "configure"
+#line 12708 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -12930,7 +12727,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -12963,10 +12760,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12967: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12764: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12970 "configure"
+#line 12767 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -12989,7 +12786,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -13031,7 +12828,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13035: checking whether to use FreeType" >&5
+echo "configure:12832: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13050,7 +12847,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13054: checking for location of FreeType includes" >&5
+echo "configure:12851: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13076,15 +12873,15 @@
 do
-echo "configure:13080: checking for $ac_hdr" >&5
+echo "configure:12877: checking for $ac_hdr" >&5
-#line 13083 "configure"
+#line 12880 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13118,7 +12915,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13122: checking for location of FreeType library" >&5
+echo "configure:12919: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13143,13 +12940,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13147: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12944: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13153 "configure"
+#line 12950 "configure"
@@ -13160,7 +12957,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13201,7 +12998,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13205: checking whether to use NLS" >&5
+echo "configure:13002: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13221,10 +13018,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13225: checking for gettext" >&5
+echo "configure:13022: checking for gettext" >&5
-#line 13228 "configure"
+#line 13025 "configure"
     which can conflict with char gettext(); below.  */
@@ -13247,7 +13044,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13265,13 +13062,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13269: checking for gettext in -lintl" >&5
+echo "configure:13066: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13275 "configure"
+#line 13072 "configure"
@@ -13282,7 +13079,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13317,7 +13114,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13321: checking whether to use C++" >&5
+echo "configure:13118: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13333,7 +13130,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13337: checking for $ac_word" >&5
+echo "configure:13134: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13362,7 +13159,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13366: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13163: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13373,12 +13170,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13377 "configure"
+#line 13174 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13404,19 +13201,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13408: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13205: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13413: checking whether we are using GNU C++" >&5
+echo "configure:13210: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13217: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13434,7 +13231,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13438: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13235: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13475,7 +13272,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13479: checking whether to use openDWG" >&5
+echo "configure:13276: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13495,7 +13292,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13499: checking for location of openDGW includes" >&5
+echo "configure:13296: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13521,15 +13318,15 @@
 do
-echo "configure:13525: checking for $ac_hdr" >&5
+echo "configure:13322: checking for $ac_hdr" >&5
-#line 13528 "configure"
+#line 13325 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13563,7 +13360,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13567: checking for location of openDWG library" >&5
+echo "configure:13364: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13604,7 +13401,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13608: checking whether to use POSIX threads" >&5
+echo "configure:13405: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13624,7 +13421,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13628: checking for location of POSIX threads includes" >&5
+echo "configure:13425: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13650,15 +13447,15 @@
 do
-echo "configure:13654: checking for $ac_hdr" >&5
+echo "configure:13451: checking for $ac_hdr" >&5
-#line 13657 "configure"
+#line 13454 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13459: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13692,7 +13489,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13696: checking for location of POSIX threads library" >&5
+echo "configure:13493: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13717,10 +13514,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13721: checking for pthread_create" >&5
+echo "configure:13518: checking for pthread_create" >&5
-#line 13724 "configure"
+#line 13521 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -13743,7 +13540,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13770,13 +13567,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13774: checking for pthread_create in -lpthread" >&5
+echo "configure:13571: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13780 "configure"
+#line 13577 "configure"
@@ -13787,7 +13584,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13837,7 +13634,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13841: checking whether to use OpenMP" >&5
+echo "configure:13638: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -13858,7 +13655,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13862: checking for location of OpenMP includes" >&5
+echo "configure:13659: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13884,15 +13681,15 @@
 do
-echo "configure:13888: checking for $ac_hdr" >&5
+echo "configure:13685: checking for $ac_hdr" >&5
-#line 13891 "configure"
+#line 13688 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13930,7 +13727,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13934: checking for location of OpenMP library" >&5
+echo "configure:13731: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -13955,10 +13752,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13959: checking for GOMP_parallel_start" >&5
+echo "configure:13756: checking for GOMP_parallel_start" >&5
-#line 13962 "configure"
+#line 13759 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -13981,7 +13778,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -14008,13 +13805,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:14012: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13809: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 14018 "configure"
+#line 13815 "configure"
@@ -14025,7 +13822,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14104,7 +13901,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14108: checking for special C compiler options needed for large files" >&5
+echo "configure:13905: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14112,7 +13909,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14116 "configure"
+#line 13913 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14128,7 +13925,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13929: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -14137,7 +13934,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14141 "configure"
+#line 13938 "configure"
@@ -14153,7 +13950,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14157: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13954: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14173,11 +13970,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14177: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13974: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14181 "configure"
+#line 13978 "configure"
@@ -14193,14 +13990,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14197: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
   cat > conftest.$ac_ext <<EOF
-#line 14204 "configure"
+#line 14001 "configure"
 #include "confdefs.h"
 #define _FILE_OFFSET_BITS 64
@@ -14218,7 +14015,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14019: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14237,11 +14034,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14241: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14038: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14245 "configure"
+#line 14042 "configure"
@@ -14257,14 +14054,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14261: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14058: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14268 "configure"
+#line 14065 "configure"
 #define _LARGE_FILES 1
@@ -14282,7 +14079,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14286: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14083: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14301,25 +14098,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14305: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14102: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14309 "configure"
+#line 14106 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14316: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14113: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14323 "configure"
+#line 14120 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14328,7 +14125,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14332: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14349,25 +14146,25 @@
    fi
-echo "configure:14353: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14150: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14357 "configure"
+#line 14154 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14161: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14371 "configure"
+#line 14168 "configure"
 #include <stdio.h>
@@ -14376,7 +14173,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14177: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -14399,18 +14196,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14403: checking for fseeko" >&5
+echo "configure:14200: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 14407 "configure"
+#line 14204 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14427,10 +14224,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14431: checking if system supports Large Files at all" >&5
+echo "configure:14228: checking if system supports Large Files at all" >&5
-#line 14434 "configure"
+#line 14231 "configure"
 #include <stdio.h>
@@ -14462,7 +14259,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14466: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14263: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14491,7 +14288,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14495: checking whether to use wxWidgets" >&5
+echo "configure:14292: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14512,7 +14309,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14516: checking for $ac_word" >&5
+echo "configure:14313: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14560,7 +14357,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14564: checking wxWidgets version" >&5
+echo "configure:14361: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14583,15 +14380,15 @@
 do
-echo "configure:14587: checking for $ac_hdr" >&5
+echo "configure:14384: checking for $ac_hdr" >&5
-#line 14590 "configure"
+#line 14387 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14595: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14392: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14820,7 +14617,6 @@
 s%@XTLIB@%$XTLIB%g
 s%@USE_X11@%$USE_X11%g
 s%@DBMIEXTRALIB@%$DBMIEXTRALIB%g
-s%@XDRLIB@%$XDRLIB%g
 s%@HAVE_ASPRINTF@%$HAVE_ASPRINTF%g
 s%@MATHLIB@%$MATHLIB%g
 s%@DLLIB@%$DLLIB%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/configure.in	2012-09-21 10:09:03 UTC (rev 53257)
@@ -518,17 +518,6 @@
 LIBS="$ac_save_libs"
 AC_SUBST(DBMIEXTRALIB)
-# Note: -lxdr -liberty -lws2_32 is for MinGW
-AC_CHECK_FUNC(xdrmem_create, XDRLIB=, [
-AC_CHECK_LIB(sun, xdrmem_create, XDRLIB=-lsun, [
-AC_CHECK_LIB(nsl, xdrmem_create, XDRLIB=-lnsl, [
-AC_CHECK_LIB(rpclib, xdrmem_create, XDRLIB=-lrpclib, [
-AC_CHECK_LIB(xdr, xdrmem_create, XDRLIB="-lxdr -liberty -lws2_32" ,
-   [ AC_MSG_ERROR([*** Unable to locate XDR functions.]) ], -liberty -lws2_32 )
-AC_SUBST(XDRLIB)
 AC_CHECK_FUNCS(asprintf)
 AC_SUBST(HAVE_ASPRINTF)
Modified: grass/trunk/include/Make/Compile.make
--- grass/trunk/include/Make/Compile.make	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/include/Make/Compile.make	2012-09-21 10:09:03 UTC (rev 53257)
@@ -15,7 +15,7 @@
 endif
 linker_base = $(PRELINK) && $(1) $(2) -o $@ $(filter %.o,$^) $(filter %.res,$^) $(3)
-linker_x = $(call linker_base,$(1),$(LDFLAGS) $(EXTRA_LDFLAGS),$(FMODE_OBJ) $(MANIFEST_OBJ) $(LIBES) $(EXTRA_LIBS) $(MATHLIB) $(XDRLIB))
+linker_x = $(call linker_base,$(1),$(LDFLAGS) $(EXTRA_LDFLAGS),$(FMODE_OBJ) $(MANIFEST_OBJ) $(LIBES) $(EXTRA_LIBS) $(MATHLIB))
 linker_c = $(call linker_x,$(CC))
 linker_cxx = $(call linker_x,$(CXX))
 linker = $(call linker_x,$(LINK))
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/include/Make/Platform.make.in	2012-09-21 10:09:03 UTC (rev 53257)
@@ -89,7 +89,6 @@
 USE_X11             = @USE_X11@
 MATHLIB             = @MATHLIB@
-XDRLIB              = @XDRLIB@
 ICONVLIB            = @ICONVLIB@
 INTLLIB             = @INTLLIB@
 SOCKLIB             = @SOCKLIB@
Modified: grass/trunk/lib/form/Makefile
--- grass/trunk/lib/form/Makefile	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/lib/form/Makefile	2012-09-21 10:09:03 UTC (rev 53257)
@@ -26,7 +26,7 @@
 endif
 LIBES = $(DBMILIB) $(GISLIB) $(DATETIMELIB) $(TCLTKLIBPATH) $(TCLTKLIBS) \
-	$(MATHLIB) $(XDRLIB)
+	$(MATHLIB)
 default: lib $(GTCLTKFORM)
Modified: grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile
--- grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile	2012-09-21 09:55:13 UTC (rev 53256)
+++ grass/trunk/raster/r.le/r.le.setup/polytocell/Makefile	2012-09-21 10:09:03 UTC (rev 53257)
@@ -17,7 +17,7 @@
 default: $(ETC)/bmif_to_cell $(ETC)/poly_to_bmif
 $(ETC)/bmif_to_cell: $(OBJDIR)/bmf_to_cll.o $(DEPENDENCIES)
-	$(CC) $(LDFLAGS) -o $@ $< $(FMODE_OBJ) $(LIBES) $(MATHLIB) $(XDRLIB)
+	$(CC) $(LDFLAGS) -o $@ $< $(FMODE_OBJ) $(LIBES) $(MATHLIB)
 $(ETC)/poly_to_bmif: $(OBJS)
 	$(CC) $(LDFLAGS) -o $@ $^ $(FMODE_OBJ)
