[GRASS-SVN] r53272 - in grass-addons/grass6/raster: . r.traveltime
svn_grass at osgeo.org
Wed Sep 26 06:24:24 PDT 2012
Author: mlennert
Date: 2012-09-26 06:24:24 -0700 (Wed, 26 Sep 2012)
New Revision: 53272
Added:
grass-addons/grass6/raster/r.traveltime/
grass-addons/grass6/raster/r.traveltime/Makefile
grass-addons/grass6/raster/r.traveltime/description.html
grass-addons/grass6/raster/r.traveltime/main.c
First check-in of Kristian Foerster's r.traveltim module
Added: grass-addons/grass6/raster/r.traveltime/Makefile
--- grass-addons/grass6/raster/r.traveltime/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.traveltime/Makefile 2012-09-26 13:24:24 UTC (rev 53272)
@@ -0,0 +1,13 @@
+# Uncoment and fix MODULE_TOPDIR line OR provide MODULE_TOPDIR variable for make
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+#MODULE_TOPDIR = ../..
+PGM = r.traveltime
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass6/raster/r.traveltime/description.html
--- grass-addons/grass6/raster/r.traveltime/description.html (rev 0)
+++ grass-addons/grass6/raster/r.traveltime/description.html 2012-09-26 13:24:24 UTC (rev 53272)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2>
+<em>r.traveltime</em> computes the travel time of surface runoff to an
+outlet. The program starts at the basin outlet and calculates the travel
+time at each raster cell recursively. A drainage area related threhold
+considers even surface and also channel runoff. Travel times are
+derived by assuming kinematic wave approximation.<br>
+To derive channel flow velocities an equilibrium discharge for each
+cell is calculated (Q=Area*Excess_Prcipitation, Assumption: storm
+duration >= time of concentration). This assumption may result
+in overestimated velocities. Therefor a factor is implemented to reduce
+velocities biased towards too large values.<br>
+The results can be used to derive a time-area function. This might be
+usefull for precipitation-runoff calculations (estimation of flood
+predictions) with a lumped hydrologic model (user-specified unit
+hydrograph).
+<h2>REMARKS</h2>
+The program ist restricted to SI units (meters). The algorithm is
+recursive. Maybe it will not work with extensive datasets. It is
+assumed that the minimum slope is 0.001. For smaller gradients the
+program uses this value.
+<h2>KNOWN ISSUES</h2>
+The program does not work correctly if Manning's roughness grid is
+defined as double (float expected). To define a simple uniform
+roughness distribution try: r.mapcalc 'roughness=0.1f'
+<br>
+The region has to be set one row and column larger than the elevation
+map. See the example below to see how to do that with g.region.
+<h2>EXAMPLE</h2>
+<i>This example uses the North Carolina sample dataset.</i>
+<p>
+<div class="code"><pre>
+ g.region rast=elev_lid792_1m n=n+1 s=s-1 w=w-1 e=e+1 -p
+ r.watershed elev_lid792_1m thresh=5000 accum=accum_5K drain=draindir_5K
+ r.fill.dir elev_lid792_1m elev=elev_filled dir=elev_dir
+ r.mapcalc rough=0.1f
+ r.traveltime --overwrite dir=draindir_5K at user1 accu=accum_5K at user1 \
+ dtm=elev_filled at user1 manningsn=rough out_x=638741.43125 \
+ out_y=220269.7 threshold=1 b=1 nchannel=0.1 ep=40 fdis=1 \
+ out=travel_time
+</pre></div>
+</p>
+<h2>SEE ALSO</h2>
+<em><a href="r.watershed.html">r.watershed</a>,
+ <a href="r.fill.dir.html">r.fill.dir</a>
+ <br>
+ <br>
+ <a href="http://jesbergwetter.twoday.net/stories/4845555/">http://jesbergwetter.twoday.net/stories/4845555/</a>
+ <h2>REFERENCES</h2>
+ <li>Kilgore, J. L. (1997): <em>Development and evaluation of a GIS-based
+spatially distributed unit hydrograph model</em>, master thesis,
+Virginia
+Polytechnic Institute and State University.</li>
+<li>Melesse, A. M., Graham, W. D. (2004):<em> Storm runoff predicition
+based on a
+spatially distributed travel time method utilizing remote sensing and
+GIS</em>, Journal of the American Water Resources Association, 8,
+863-879.</li>
+<li>Muzik, I. (1996): <em>Flood modelling with GIS-derived distributed
+ unit hydrographs</em>, Hydrological Processes, 10, 1401-1409.</li>
+<h2>AUTHOR</h2>
+Kristian Foerster<br>
+<p><i>Last changed: $Date: 2012/09/26 15:00 $</i>
+</p>
Property changes on: grass-addons/grass6/raster/r.traveltime/description.html
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass6/raster/r.traveltime/main.c
--- grass-addons/grass6/raster/r.traveltime/main.c (rev 0)
+++ grass-addons/grass6/raster/r.traveltime/main.c 2012-09-26 13:24:24 UTC (rev 53272)
@@ -0,0 +1,558 @@
+/* main.c for r.traveltime, December 2007
+ * # MODULE: r.traveltime
+ * # AUTHOR(S): Kristian Foerster
+ * # PURPOSE: This programm calculates traveltimes from a digital
+ * # terrain model, a roughness grid and some output
+ * # files from r.watershed. The aim of this tool is to
+ * # estimate a unit hydrograph for precipitation-runoff
+ * # prediction
+ * # COPYRIGHT: (c) 2007 Kristian Foerster
+ * # This program is free software under the GNU General Public
+ * # License
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <limits.h>
+#include <float.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/config.h>
+ * global declarations
+extern CELL f_c(CELL);
+extern FCELL f_f(FCELL);
+extern DCELL f_d(DCELL);
+double res_x, res_y;
+void *inrast_accu, *inrast_dtm, *inrast_n, *inrast_dir; /* input buffer */
+unsigned char *outrast; /* output buffer */
+int in_accu, in_dir, in_n, in_dtm, outfd; /* file descriptor */
+RASTER_MAP_TYPE data_type_accu, data_type_dtm, data_type_n, data_type_dir; /* type of the map (CELL/DCELL/...) */
+double **array_out;
+int ac_thres;
+double nc, b, ep, fdis;
+ * the function inflow checks if an adjacent cell discharges in the active cell
+int inflow(int loc_x, int loc_y, int vec_x, int vec_y)
+ int x_exp, y_exp;
+ int value;
+ if (G_get_raster_row(in_dir, inrast_dir, loc_y, data_type_dir) < 0)
+ G_fatal_error(_("Could not read from map"));
+ value = ((CELL *) inrast_dir)[loc_x];
+ // conversions of the flow direction classification to vectors
+ switch (value) {
+ case 1:
+ x_exp = 1;
+ y_exp = -1;
+ break;
+ case 2:
+ x_exp = 0;
+ y_exp = -1;
+ break;
+ case 3:
+ x_exp = -1;
+ y_exp = -1;
+ break;
+ case 4:
+ x_exp = -1;
+ y_exp = 0;
+ break;
+ case 5:
+ x_exp = -1;
+ y_exp = 1;
+ break;
+ case 6:
+ x_exp = 0;
+ y_exp = 1;
+ break;
+ case 7:
+ x_exp = 1;
+ y_exp = 1;
+ break;
+ case 8:
+ x_exp = 1;
+ y_exp = 0;
+ break;
+ default:
+ x_exp = 1;
+ y_exp = 0;
+ break;
+ if ((vec_x == x_exp * (-1)) & (vec_y == y_exp * (-1)))
+ return 1;
+ else
+ return 0;
+ * traveltime calculates traveltimes from one cell to another
+double traveltime(double length, double slope, double manning,
+ double drainage)
+ double slope_min = 0.001;
+ double t;
+ double Q;
+ if (slope < slope_min)
+ slope = slope_min;
+ /* for areas with drainage accumulation < threshold surface runoff will be calculated
+ * areas with larger drainage accumulation the channel formula is used instead
+ if (drainage < ac_thres) {
+ t = pow(length, 0.6) * pow(manning, 0.6) / pow(ep / 1000.0 / 3600.0, 0.4) / pow(slope, 0.3); //surface runoff
+ else {
+ Q = fdis * drainage * res_x * res_y * ep / 1000.0 / 3600.0; //equilibrium runoff
+ t = length / pow(sqrt(slope) / nc * pow(Q / b, (2.0 / 3.0)), 0.6); // channel runoff
+ return t / 60.0; //seconds to minutes
+ * ttime is a recursive function starting at the outlet moving up to the watershed boundary
+ * calling the inflow and traveltime functions
+int ttime(double ftime, int x, int y, int dx, int dy)
+ double thist = 0;
+ double L, J;
+ int i, j, v, accu, dir;
+ double z1, z2;
+ double manningsn;
+ if (G_get_raster_row(in_dir, inrast_dir, y, data_type_dir) < 0)
+ dir = ((CELL *) inrast_dir)[x];
+ if (G_get_raster_row(in_accu, inrast_accu, y, data_type_accu) < 0)
+ accu = ((CELL *) inrast_accu)[x];
+ if (G_get_raster_row(in_n, inrast_n, y, data_type_n) < 0)
+ switch (data_type_n) {
+ case DCELL_TYPE:
+ manningsn = (double)((DCELL *) inrast_n)[x];
+ break;
+ case FCELL_TYPE:
+ manningsn = (double)((FCELL *) inrast_n)[x];
+ break;
+ if (G_get_raster_row(in_dtm, inrast_dtm, y, data_type_dtm) < 0)
+ switch (data_type_dtm) {
+ case CELL_TYPE:
+ z2 = (double)((CELL *) inrast_dtm)[x];
+ break;
+ case DCELL_TYPE:
+ z2 = (double)((DCELL *) inrast_dtm)[x];
+ break;
+ case FCELL_TYPE:
+ z2 = (double)((FCELL *) inrast_dtm)[x];
+ break;
+ if (G_get_raster_row(in_dtm, inrast_dtm, y - dy, data_type_dtm) < 0)
+ case CELL_TYPE:
+ z1 = (double)((CELL *) inrast_dtm)[x - dx];
+ break;
+ case DCELL_TYPE:
+ z1 = (double)((DCELL *) inrast_dtm)[x - dx];
+ break;
+ case FCELL_TYPE:
+ z1 = (double)((FCELL *) inrast_dtm)[x - dx];
+ break;
+ for (i = -1; i < 2; i++) {
+ for (j = -1; j < 2; j++) {
+ if (inflow(x + i, y + j, i, j) > 0) {
+ L = sqrt(pow(i * res_x, 2.0) + pow(j * res_y, 2.0));
+ J = 1.0 * (z2 - z1) / L;
+ // time from here to outlet
+ thist = ftime + traveltime(L, J, manningsn, accu);
+ array_out[y + j][x + i] = thist;
+ int r = ttime(thist, x + i, y + j, i, j);
+ v = 1;
+ else {
+ v = 0;
+ return v;
+ * main function
+int main(int argc, char *argv[])
+ struct Cell_head cellhd_accu, cellhd_dir, cellhd_dtm, cellhd_n; /* it stores region information,
+ and header information of rasters */
+ char *map_accu; /* input accu map */
+ char *map_n; /* input manning's n map */
+ char *map_dtm; /* input terrain model */
+ char *map_dir; /* input flow direction map */
+ char *result; /* output travel time map */
+ char *mapset; /* mapset name */
+ double outx, outy;
+ int nrows, ncols;
+ int row, col;
+ int verbose;
+ int cx, cy, x, y;
+ double factor;
+ struct Cell_head window;
+ struct GModule *module; /* GRASS module for parsing arguments */
+ /* options */
+ struct Option *input_dir, *input_accu, *input_dtm, *input_n, *output,
+ *input_outlet_x, *input_outlet_y, *input_thres, *input_nc, *input_b,
+ *input_ep, *input_fdis;
+ /* initialize GIS environment */
+ G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
+ /* initialize module */
+ module = G_define_module();
+ module->description = _("Estimation of travel times/isochrones");
+ /* Define the different options as defined in gis.h */
+ input_dir = G_define_standard_option(G_OPT_R_INPUT);
+ input_dir->key = "dir";
+ input_dir->description =
+ "Flow direction map (e.g. derived by r.watershed)";
+ input_accu = G_define_standard_option(G_OPT_R_INPUT);
+ input_accu->key = "accu";
+ input_accu->description =
+ "Flow accumulation map (e.g. derived by r.watershed)";
+ input_dtm = G_define_standard_option(G_OPT_R_INPUT);
+ input_dtm->key = "dtm";
+ input_dtm->description =
+ "Depressionless, filled terrain model (e.g. derived by r.fill.dir)";
+ input_n = G_define_standard_option(G_OPT_R_INPUT);
+ input_n->key = "manningsn";
+ input_n->description = "Map with Manning's n value for surface roughness";
+ input_outlet_x = G_define_option();
+ input_outlet_x->key = "out_x";
+ input_outlet_x->type = TYPE_STRING;
+ input_outlet_x->required = YES;
+ input_outlet_x->description = "x coordinate of basin outlet";
+ input_outlet_x->gisprompt = "old,cell,raster";
+ input_outlet_y = G_define_option();
+ input_outlet_y->key = "out_y";
+ input_outlet_y->type = TYPE_STRING;
+ input_outlet_y->required = YES;
+ input_outlet_y->description = "y coordinate of basin outlet";
+ input_outlet_y->gisprompt = "old,cell,raster";
+ input_thres = G_define_option();
+ input_thres->key = "threshold";
+ input_thres->type = TYPE_STRING;
+ input_thres->required = YES;
+ input_thres->description =
+ "Minimum number of cells (threshold) that classify cell as channel";
+ input_thres->gisprompt = "old,cell,raster";
+ input_b = G_define_option();
+ input_b->key = "b";
+ input_b->type = TYPE_STRING;
+ input_b->required = YES;
+ input_b->description = "Channel width";
+ input_b->gisprompt = "old,cell,raster";
+ input_nc = G_define_option();
+ input_nc->key = "nchannel";
+ input_nc->type = TYPE_STRING;
+ input_nc->required = YES;
+ input_nc->description = "Channel roughness (Manning's n)";
+ input_nc->gisprompt = "old,cell,raster";
+ input_ep = G_define_option();
+ input_ep->key = "ep";
+ input_ep->type = TYPE_STRING;
+ input_ep->required = YES;
+ input_ep->description = "Excess precipitation [mm/h]";
+ input_ep->gisprompt = "old,cell,raster";
+ input_fdis = G_define_option();
+ input_fdis->key = "fdis";
+ input_fdis->type = TYPE_STRING;
+ input_fdis->required = YES;
+ input_fdis->description =
+ "Reduction factor for equilibrium discharge, 0.0 < f <= 1.0 (default=1)";
+ input_fdis->gisprompt = "old,cell,raster";
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ output->key = "out";
+ output->description = "Output travel time map [minutes]";
+ /* options and flags pareser */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ /* stores options and flags to variables */
+ map_accu = input_accu->answer;
+ map_dir = input_dir->answer;
+ map_dtm = input_dtm->answer;
+ map_n = input_n->answer;
+ sscanf(input_outlet_x->answer, "%lf", &outx);
+ sscanf(input_outlet_y->answer, "%lf", &outy);
+ sscanf(input_thres->answer, "%d", &ac_thres);
+ sscanf(input_b->answer, "%lf", &b);
+ sscanf(input_nc->answer, "%lf", &nc);
+ sscanf(input_ep->answer, "%lf", &ep);
+ sscanf(input_fdis->answer, "%lf", &factor);
+ result = output->answer;
+ if (factor > 0 & factor <= 1.0)
+ fdis = factor;
+ else {
+ printf("\nWARNING! Reduction factor is not valid!\n");
+ /* returns NULL if the map was not found in any mapset,
+ * mapset name otherwise */
+ mapset = G_find_cell2(map_dir, "");
+ if (mapset == NULL)
+ G_fatal_error(_("cell file [%s] not found"), map_dir);
+ mapset = G_find_cell2(map_accu, "");
+ G_fatal_error(_("cell file [%s] not found"), map_accu);
+ mapset = G_find_cell2(map_dtm, "");
+ G_fatal_error(_("cell file [%s] not found"), map_dtm);
+ mapset = G_find_cell2(map_n, "");
+ G_fatal_error(_("cell file [%s] not found"), map_n);
+ if (G_legal_filename(result) < 0)
+ G_fatal_error(_("[%s] is an illegal name"), result);
+ /* determine the inputmap type (CELL/FCELL/DCELL) */
+ data_type_dir = G_raster_map_type(map_dir, mapset);
+ data_type_accu = G_raster_map_type(map_accu, mapset);
+ data_type_n = G_raster_map_type(map_n, mapset);
+ data_type_dtm = G_raster_map_type(map_dtm, mapset);
+ /* G_open_cell_old - returns file destriptor (>0) */
+ if ((in_dir = G_open_cell_old(map_dir, mapset)) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"), map_dir);
+ if ((in_accu = G_open_cell_old(map_accu, mapset)) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"), map_accu);
+ if ((in_n = G_open_cell_old(map_n, mapset)) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"), map_n);
+ if ((in_dtm = G_open_cell_old(map_dtm, mapset)) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"), map_dtm);
+ /* controlling, if we can open input raster */
+ if (G_get_cellhd(map_accu, mapset, &cellhd_accu) < 0)
+ G_fatal_error(_("Cannot read file header of [%s]"), map_accu);
+ if (G_get_cellhd(map_dir, mapset, &cellhd_dir) < 0)
+ G_fatal_error(_("Cannot read file header of [%s]"), map_dir);
+ if (G_get_cellhd(map_dtm, mapset, &cellhd_dtm) < 0)
+ G_fatal_error(_("Cannot read file header of [%s]"), map_dtm);
+ if (G_get_cellhd(map_n, mapset, &cellhd_n) < 0)
+ G_fatal_error(_("Cannot read file header of [%s]"), map_n);
+ G_debug(3, "number of rows %d", cellhd_accu.rows);
+ G_debug(3, "number of rows %d", cellhd_dir.rows);
+ G_debug(3, "number of rows %d", cellhd_dtm.rows);
+ G_debug(3, "number of rows %d", cellhd_n.rows);
+ /* Allocate input buffer */
+ inrast_accu = G_allocate_raster_buf(data_type_accu);
+ inrast_dir = G_allocate_raster_buf(data_type_dir);
+ inrast_n = G_allocate_raster_buf(data_type_n);
+ inrast_dtm = G_allocate_raster_buf(data_type_dtm);
+ /* Allocate output buffer, use input map data_type */
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ outrast = G_allocate_raster_buf(FCELL_TYPE);
+ /* controlling, if we can write the raster */
+ if ((outfd = G_open_raster_new(result, FCELL_TYPE)) < 0)
+ G_fatal_error(_("Could not open <%s>"), result);
+ /* output array */
+ array_out = (double **)malloc(nrows * sizeof(double *));
+ if ((NULL == array_out)) {
+ printf("out of memory ... !");
+ int i, j;
+ for (i = 0; i < nrows; i++) {
+ array_out[i] = (double *)malloc(ncols * sizeof(double));
+ if ((NULL == array_out[i])) {
+ for (j = 0; j < ncols; j++) {
+ array_out[i][j] = DBL_MAX;
+ * terrain analysis begins here ...
+ if (G_get_window(&window) < 0) {
+ sprintf(map_dir, "can't read current window parameters");
+ G_fatal_error(map_dir);
+ // map units to matrix locations
+ cx = G_scan_easting(*input_outlet_x->answers, &outx, G_projection());
+ cy = G_scan_northing(*input_outlet_y->answers, &outy, G_projection());
+ if (!cx) {
+ array_out[y][x] = 0.0;
+ fprintf(stderr, "Illegal east coordinate <%s>\n",
+ *input_outlet_y->answer);
+ G_usage();
+ if (!cy) {
+ fprintf(stderr, "Illegal north coordinate <%s>\n",
+ G_usage();
+ if (outx < window.west || outx > window.east || outy < window.south ||
+ outy > window.north) {
+ fprintf(stderr, "Warning, ignoring point outside window: \n");
+ fprintf(stderr, " %.4f,%.4f\n", outx, outy);
+ res_x = window.ew_res;
+ res_y = window.ns_res;
+ cy = (window.north - outy) / res_y;
+ cx = (outx - window.west) / res_x;
+ if (verbose)
+ printf
+ ("\ngrid location of outlet x=%d, y=%d\n(resolution %.0fx%.0f map units, meters expected)\n",
+ cx, cy, res_x, res_y);
+ x = cx;
+ y = cy;
+ * first call of traveltime function
+ int m = ttime(0, x, y, 0, 0);
+ /* output */
+ for (row = 0; row < nrows; row++) {
+ for (col = 0; col < ncols; col++) {
+ ((CELL *) outrast)[col] = array_out[row][col];
+ /* write raster row to output raster file */
+ if (G_put_raster_row(outfd, outrast, CELL_TYPE) < 0)
+ G_fatal_error(_("Cannot write to <%s>"), result);
+ /* memory cleanup */
+ G_free(inrast_accu);
+ G_free(inrast_dir);
+ G_free(inrast_dtm);
+ G_free(inrast_n);
+ G_free(outrast);
+ /* closing raster files */
+ G_close_cell(inrast_accu);
+ G_close_cell(inrast_dir);
+ G_close_cell(inrast_dtm);
+ G_close_cell(inrast_n);
+ G_close_cell(outfd);
+ return 0;
