[GRASS-SVN] r53282 - grass/branches/releasebranch_6_4/vector/v.univar
svn_grass at osgeo.org
Fri Sep 28 05:42:40 PDT 2012
Author: neteler
Date: 2012-09-28 05:42:39 -0700 (Fri, 28 Sep 2012)
New Revision: 53282
grass/branches/releasebranch_6_4/vector/v.univar/main.c
backport of fixes from r53277 (trunk)
Modified: grass/branches/releasebranch_6_4/vector/v.univar/main.c
--- grass/branches/releasebranch_6_4/vector/v.univar/main.c 2012-09-28 12:42:22 UTC (rev 53281)
+++ grass/branches/releasebranch_6_4/vector/v.univar/main.c 2012-09-28 12:42:39 UTC (rev 53282)
@@ -9,35 +9,58 @@
* PURPOSE: Univariate Statistics for attribute
- * COPYRIGHT: (C) 2004-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2010 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
+/* TODO
+ * - add flag to weigh by line/boundary length and area size
+ * Roger Bivand on GRASS devel ml on July 2 2004
+ * http://lists.osgeo.org/pipermail/grass-dev/2004-July/014976.html
+ * "[...] calculating weighted means, weighting by line length
+ * or area surface size [does not make sense]. I think it would be
+ * better to treat each line or area as a discrete, unweighted, unit
+ * unless some reason to the contrary is given, just like points/sites.
+ * It is probably more important to handle missing data gracefully
+ * than weight the means or other statistics, I think. There may be
+ * reasons to weigh sometimes, but most often I see ratios or rates of
+ * two variables, rather than of a single variable and length or area."
+ * - use geodesic distances for the geometry option (distance to closest
+ * other feature)
+ * - use sample instead of population mean/stddev
#include <stdlib.h>
#include <string.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/Vect.h>
#include <grass/dbmi.h>
#include <grass/glocale.h>
-struct GModule *module;
-struct Option *map_opt, *type_opt, *field_opt, *col_opt, *where_opt,
- *percentile;
+static void select_from_geometry(void);
+static void select_from_database(void);
+static void summary(void);
+struct Option *field_opt, *where_opt, *col_opt;
struct Flag *shell_flag, *extended, *geometry;
char *mapset;
struct Map_info Map;
+struct line_cats *Cats;
+struct line_pnts *Points;
struct field_info *Fi;
dbDriver *Driver;
dbCatValArray Cvarr;
-struct line_pnts *Points;
-struct line_cats *Cats;
int otype, ofield;
int compatible = 1; /* types are compatible: point+centroid or line+boundary or area */
-int nrec, ctype, nlines, line, nareas, area;
int nmissing = 0; /* number of missing atttributes */
int nnull = 0; /* number of null values */
int nzero = 0; /* number of zero distances */
@@ -45,8 +68,7 @@
/* Statistics */
int count = 0; /* number of features with non-null attribute */
-int nprim; /* number of primitives */
+int nlines; /* number of primitives */
double sum = 0.0;
double sumsq = 0.0;
double sumcb = 0.0;
@@ -54,8 +76,8 @@
double sum_abs = 0.0;
double min = 0.0 / 0.0; /* init as nan */
double max = 0.0 / 0.0;
-double mean, mean_abs, pop_variance, sample_variance, pop_stdev, sample_stdev,
- pop_coeff_variation, kurtosis, skewness;
+double mean, mean_abs, pop_variance, sample_variance, pop_stdev,
+ sample_stdev, pop_coeff_variation, kurtosis, skewness;
double total_size = 0.0; /* total size: length/area */
/* Extended statistics */
@@ -67,6 +89,10 @@
int main(int argc, char *argv[])
+ struct GModule *module;
+ struct Option *map_opt, *type_opt,
+ *percentile;
module = G_define_module();
module->keywords = _("vector, statistics");
module->description =
@@ -75,8 +101,11 @@
map_opt = G_define_standard_option(G_OPT_V_MAP);
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,area";
+ type_opt->answer = "point,line,area";
col_opt = G_define_option();
col_opt->key = "column";
@@ -111,6 +140,7 @@
geometry->description = _("Calculate geometry distances instead of table data.");
G_gisinit(argv[0]);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -139,7 +169,7 @@
if ((otype & GV_LINES) && (otype & GV_AREA))
compatible = 0;
if (!compatible && geometry->answer)
- compatible = 1; /* distances is copatible with all kinds of geometries */
+ compatible = 1; /* distances is compatible with all kinds of geometries */
if (!compatible) {
G_warning(_("Incompatible vector type(s) specified, only number of features, minimum, maximum and range "
@@ -150,20 +180,23 @@
G_warning(_("Extended statistics is currently supported only for points/centroids"));
- if(geometry->answer)
+ if (geometry->answer)
select_from_geometry();
else
select_from_database();
summary();
Vect_close(&Map);
exit(EXIT_SUCCESS);
- int i, ncats, *cats;
+ int i, j, k, ncats, *cats;
+ int type;
struct line_pnts *iPoints, *jPoints;
iPoints = Vect_new_line_struct();
jPoints = Vect_new_line_struct();
@@ -189,42 +222,53 @@
db_close_database_shutdown_driver(Driver);
+ else
+ ncats = 0;
count = 0;
- nprim = Vect_get_num_primitives(&Map, otype);
+ nlines = Vect_get_num_primitives(&Map, otype);
/* Start calculating the statistics based on distance to all other primitives.
Use the centroid of areas and the first point of lines */
- for(i=1;i <= nprim; i++) {
- int j;
- int ri;
- ri = Vect_read_line(&Map, iPoints, Cats, i);
- if(where_opt->answer) {
- int ok=FALSE;
- for(j=0; j < Cats->n_cats; j++) {
- if(Vect_cat_in_array(Cats->cat[j], cats, ncats)) {
+ for (i = 1; i <= nlines; i++) {
+ type = Vect_read_line(&Map, iPoints, Cats, i);
+ if (!(type & otype))
+ continue;
+ if (where_opt->answer) {
+ int ok = FALSE;
+ for (j = 0; j < Cats->n_cats; j++) {
+ if (Vect_cat_in_array(Cats->cat[j], cats, ncats)) {
ok = TRUE;
break;
- if(!ok)
+ if (!ok)
continue;
- for(j=i+1; j < nprim; j++) {
+ for (j = i + 1; j < nlines; j++) {
/* get distance to this object */
- int rj;
- int k;
- rj = Vect_read_line(&Map, jPoints, Cats, j);
double val = 0.0;
+ type = Vect_read_line(&Map, jPoints, Cats, j);
+ continue;
/* now calculate the min distance between each point in line i with line j */
- for(k=0; k < iPoints->n_points; k++) {
+ for (k = 0; k < iPoints->n_points; k++) {
double dmin = 0.0;
Vect_line_distance(jPoints, iPoints->x[k], iPoints->y[k], iPoints->z[k], 1,
NULL, NULL, NULL, &dmin, NULL, NULL);
if((k == 0) || (dmin < val)) {
val = dmin;
- if(val == 0) {
+ if (val == 0) {
nzero++;
continue;
@@ -252,15 +296,19 @@
+ int nrec, ctype, nlines, line, nareas, area;
+ struct line_pnts *Points;
Fi = Vect_get_field(&Map, ofield);
if (Fi == NULL) {
- G_fatal_error(_("Unable to get layer info for vector map"));
+ G_fatal_error(_(" Database connection not defined for layer <%s>"), field_opt->answer);
Driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (Driver == NULL)
G_fatal_error("Unable to open database <%s> by driver <%s>",
Fi->database, Fi->driver);
/* Note do not check if the column exists in the table because it may be an expression */
db_CatValArray_init(&Cvarr);
nrec =
@@ -277,6 +325,7 @@
+ Points = Vect_new_line_struct();
/* Lines */
nlines = Vect_get_num_lines(&Map);
@@ -446,15 +495,15 @@
else {
double n = count;
- mean = sum / n;
- mean_abs = sum_abs / n;
- pop_variance = (sumsq - sum * sum / n) / n;
+ mean = sum / count;
+ mean_abs = sum_abs / count;
+ pop_variance = (sumsq - sum * sum / count) / count;
pop_stdev = sqrt(pop_variance);
- pop_coeff_variation = pop_stdev / (sqrt(sum * sum) / n);
- sample_variance = (sumsq - sum * sum / n) / (count - 1);
+ pop_coeff_variation = pop_stdev / (sqrt(sum * sum) / count);
+ sample_variance = (sumsq - sum * sum / count) / (count - 1);
sample_stdev = sqrt(sample_variance);
kurtosis =
- (sumqt / n - 4 * sum * sumcb / (n * n) +
+ (sumqt / count - 4 * sum * sumcb / (n * n) +
6 * sum * sum * sumsq / (n * n * n) -
3 * sum * sum * sum * sum / (n * n * n * n))
/ (sample_stdev * sample_stdev * sample_stdev *
@@ -470,7 +519,7 @@
if (shell_flag->answer) {
fprintf(stdout, "n=%d\n", count);
- if(geometry->answer) {
+ if (geometry->answer) {
fprintf(stdout, "nzero=%d\n", nzero);
else {
@@ -499,7 +548,7 @@
else {
- fprintf(stdout, "number of primitives: %d\n", nprim);
+ fprintf(stdout, "number of primitives: %d\n", nlines);
fprintf(stdout, "number of non zero distances: %d\n", count);
fprintf(stdout, "number of zero distances: %d\n", nzero);
@@ -595,4 +644,3 @@
