[GRASS-SVN] r55580 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Apr 1 07:06:43 PDT 2013
Author: martinl
Date: 2013-04-01 07:06:43 -0700 (Mon, 01 Apr 2013)
New Revision: 55580
grass/trunk/lib/vector/Vlib/box.c
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/level_two.c
grass/trunk/lib/vector/Vlib/select.c
vlib: Vect_get_line|area|isle_box() return -1 on error
doxygen update - note requested built level
formatting issues
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c 2013-04-01 13:04:57 UTC (rev 55579)
+++ grass/trunk/lib/vector/Vlib/box.c 2013-04-01 14:06:43 UTC (rev 55580)
@@ -128,9 +128,7 @@
* \return 1 if any clipping occured
* \return 0 otherwise
-int
-Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const struct bound_box *Box)
+int Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const struct bound_box *Box)
int mod;
@@ -192,12 +190,16 @@
\brief Get bounding box of given feature
+ Vector map must be open at topological level and built with level
+ >= GV_BUILD_BASE.
\param Map vector map
\param line feature id
\param[out] Box bounding box
\return 1 on success
\return 0 line is dead
+ \return -1 on error
int Vect_get_line_box(const struct Map_info *Map, int line, struct bound_box *Box)
@@ -206,9 +208,13 @@
int type;
static struct line_pnts *Points = NULL;
- Plus = (struct Plus_head *)&(Map->plus);
+ Plus = (struct Plus_head *) &(Map->plus);
+ if (line < 1 || line > Plus->n_lines) {
+ G_warning(_("Attempt to access feature with invalid id (%d)"), line);
+ return -1;
Line = Plus->Line[line];
if (Line == NULL) { /* dead */
Box->N = Box->S = Box->E = Box->W = Box->T = Box->B = 0. / 0.;
return 0;
@@ -218,10 +224,11 @@
/* GV_LINES: retrieve box from spatial index */
if (type & GV_LINES) {
- if (dig_find_line_box(Plus, line, Box) == 0)
- G_fatal_error(_("Unable to find bbox for feature %d"), line);
+ if (dig_find_line_box(Plus, line, Box) == 0) {
+ G_warning(_("Unable to determine bbox for feature %d"), line);
+ return -1;
if (!Vect_is_3d(Map)) {
Box->T = PORT_DOUBLE_MAX;
Box->B = -PORT_DOUBLE_MAX;
@@ -249,19 +256,28 @@
\brief Get bounding box of area
+ >= GV_BUILD_AREAS.
\param area area id
\return 0 area is dead
int Vect_get_area_box(const struct Map_info *Map, int area, struct bound_box *Box)
struct Plus_head *Plus;
struct P_area *Area;
+ if (area < 1 || area > Plus->n_areas) {
+ G_warning(_("Attempt to access area with invalid id (%d)"), area);
+ return -1;
Area = Plus->Area[area];
if (Area == NULL) { /* dead */
@@ -269,8 +285,10 @@
return 0;
- if (dig_find_area_box(Plus, area, Box) == 0)
- G_fatal_error(_("Unable to get bounding box for area %d"), area);
+ if (dig_find_area_box(Plus, area, Box) == 0) {
+ G_warning(_("Unable to determine bbox for area %d"), area);
+ return -1;
@@ -283,19 +301,29 @@
\brief Get bounding box of isle
\param isle isle id
\return 0 isle is dead / bounding box not found
int Vect_get_isle_box(const struct Map_info *Map, int isle, struct bound_box *Box)
struct P_isle *Isle;
+ if (isle < 1 || isle > Plus->n_isles) {
+ G_warning(_("Attempt to access area with invalid id (%d)"), isle);
+ return -1;
Isle = Plus->Isle[isle];
if (Isle == NULL) { /* dead */
@@ -303,8 +331,10 @@
return 0;
- if (dig_find_isle_box(Plus, isle, Box) == 0)
- G_fatal_error(_("Could not find isle box"));
+ if (dig_find_isle_box(Plus, isle, Box) == 0) {
+ G_warning(_("Unable to determine bbox for isle %d"), isle);
+ return -1;
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2013-04-01 13:04:57 UTC (rev 55579)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2013-04-01 14:06:43 UTC (rev 55580)
@@ -29,12 +29,8 @@
\param Map input vector map
\param type feature type
\param[out] Err vector map where points at intersections will be written or NULL
- \return
-void
-Vect_break_lines(struct Map_info *Map, int type, struct Map_info *Err)
+void Vect_break_lines(struct Map_info *Map, int type, struct Map_info *Err)
break_lines(Map, NULL, NULL, type, Err, 0);
@@ -61,12 +57,11 @@
\return number of intersections
-int
-Vect_break_lines_list(struct Map_info *Map, struct ilist *List_break,
- struct ilist *List_ref, int type,
- struct Map_info *Err)
+int Vect_break_lines_list(struct Map_info *Map, struct ilist *List_break,
+ struct ilist *List_ref, int type,
+ struct Map_info *Err)
return break_lines(Map, List_break, List_ref, type, Err, 0);
@@ -74,17 +69,15 @@
\brief Check for and count intersecting lines, do not break.
- For details see Vect_break_lines_list().
+ For details see Vect_check_line_breaks_list().
- \return
-int
-Vect_check_line_breaks(struct Map_info *Map, int type, struct Map_info *Err)
+ \return number for intersections
+int Vect_check_line_breaks(struct Map_info *Map, int type, struct Map_info *Err)
return break_lines(Map, NULL, NULL, type, Err, 1);
@@ -105,10 +98,8 @@
-int
-Vect_check_line_breaks_list(struct Map_info *Map, struct ilist *List_break,
+int Vect_check_line_breaks_list(struct Map_info *Map, struct ilist *List_break,
@@ -149,10 +140,9 @@
-int
-break_lines(struct Map_info *Map, struct ilist *List_break,
- struct Map_info *Err, int check)
+int break_lines(struct Map_info *Map, struct ilist *List_break,
+ struct Map_info *Err, int check)
struct line_pnts *APoints, *BPoints, *Points;
struct line_pnts **AXLines, **BXLines;
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2013-04-01 13:04:57 UTC (rev 55579)
+++ grass/trunk/lib/vector/Vlib/build.c 2013-04-01 14:06:43 UTC (rev 55580)
@@ -543,7 +543,7 @@
topo->area = sel_area;
if (sel_area != orig_area && plus->uplist.do_uplist)
- dig_line_add_updated(plus, centr);
+ dig_line_add_updated(plus, centr);
else if (Area->centroid != centr) { /* duplicate centroid */
/* Note: it cannot happen that Area->centroid == centr, because the centroid
@@ -552,7 +552,7 @@
topo->area = -sel_area;
if (-sel_area != orig_area && plus->uplist.do_uplist)
@@ -848,8 +848,8 @@
/* If topology is already build (map on > level 2), set level to 1
* so that lines will be read by V1_read_ (all lines) */
- Map->level = 1; /* may be not needed, because V1_read is used
- directly by Vect_build_ */
+ Map->level = LEVEL_1; /* may be not needed, because V1_read is used
+ directly by Vect_build_ */
if (Map->format != GV_FORMAT_OGR_DIRECT)
Map->support_updated = TRUE;
@@ -870,7 +870,6 @@
ret = ((*Build_array[Map->format]) (Map, build));
if (ret == 0) {
return 0;
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c 2013-04-01 13:04:57 UTC (rev 55579)
+++ grass/trunk/lib/vector/Vlib/level_two.c 2013-04-01 14:06:43 UTC (rev 55580)
@@ -231,6 +231,8 @@
Note: Vect_set_updated() must be called to maintain list of updated
features
+ Negative id indicates deleted node.
\param Map pointer to Map_info struct
\param idx index
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2013-04-01 13:04:57 UTC (rev 55579)
+++ grass/trunk/lib/vector/Vlib/select.c 2013-04-01 14:06:43 UTC (rev 55580)
@@ -133,9 +133,8 @@
\return number of selected items
-int
-Vect_spatial_index_select(const struct spatial_index * si, const struct bound_box * box,
- struct ilist *list)
+int Vect_spatial_index_select(const struct spatial_index * si, const struct bound_box * box,
+ struct ilist *list)
static struct RTree_Rect rect;
static int rect_init = 0;
@@ -145,8 +144,6 @@
rect_init = si->si_tree->nsides_alloc;
- G_debug(3, "Vect_spatial_index_select()");
Vect_reset_list(list);
rect.boundary[0] = box->W;
@@ -157,7 +154,7 @@
rect.boundary[5] = box->T;
RTreeSearch(si->si_tree, &rect, (void *)_add_item, list);
- G_debug(3, " %d items selected", list->n_values);
+ G_debug(3, "Vect_spatial_index_select(): %d items selected", list->n_values);
- return (list->n_values);
+ return list->n_values;
