[GRASS-SVN] r55584 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Mon Apr 1 09:01:15 PDT 2013
Author: martinl
Date: 2013-04-01 09:01:15 -0700 (Mon, 01 Apr 2013)
New Revision: 55584
grass/trunk/vector/v.buffer/main.c
v.buffer: verbosity level cosmetics
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2013-04-01 15:18:49 UTC (rev 55583)
+++ grass/trunk/vector/v.buffer/main.c 2013-04-01 16:01:15 UTC (rev 55584)
@@ -308,6 +308,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ verbose = G_verbose();
#if !defined HAVE_GEOS
use_geos = FALSE;
#else
@@ -387,7 +388,9 @@
if (0 > Vect_open_tmp_new(&Buf, NULL, WITHOUT_Z)) {
G_fatal_error(_("Unable to create vector map"));
+ G_set_verbose(0);
Vect_build_partial(&Buf, GV_BUILD_BASE); /* switch to level 2 */
+ G_set_verbose(verbose);
/* check and load attribute column data */
if (bufcol_opt->answer) {
@@ -692,8 +695,6 @@
finishGEOS();
#endif
- verbose = G_verbose();
G_message(_("Cleaning buffers..."));
/* Break lines */
@@ -876,8 +877,6 @@
Vect_spatial_index_destroy(&si);
Vect_close(&Buf);
- G_set_verbose(verbose);
if (cats_flag->answer)
Vect_copy_tables(&In, &Out, field);
