[GRASS-SVN] r55593 - grass/trunk/raster/r.cost
svn_grass at osgeo.org
Tue Apr 2 11:18:59 PDT 2013
Author: neteler
Date: 2013-04-02 11:18:59 -0700 (Tue, 02 Apr 2013)
New Revision: 55593
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
r.cost: +cost allocation explanations; HTML cosmetics
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2013-04-02 16:28:47 UTC (rev 55592)
+++ grass/trunk/raster/r.cost/main.c 2013-04-02 18:18:59 UTC (rev 55593)
@@ -137,6 +137,7 @@
G_add_keyword(_("raster"));
G_add_keyword(_("cost surface"));
G_add_keyword(_("cumulative costs"));
+ G_add_keyword(_("cost allocation"));
module->description =
_("Creates a raster map showing the "
"cumulative cost of moving between different "
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2013-04-02 16:28:47 UTC (rev 55592)
+++ grass/trunk/raster/r.cost/r.cost.html 2013-04-02 18:18:59 UTC (rev 55593)
@@ -1,7 +1,6 @@
<h2>DESCRIPTION</h2>
-<p><em>r.cost</em> determines the cumulative cost of moving to each
+<em>r.cost</em> determines the cumulative cost of moving to each
cell on a <em>cost surface</em> (the <b>input</b> raster map) from
other user-specified cell(s) whose locations are specified by their
geographic coordinate(s). Each cell in the original cost surface map
@@ -22,40 +21,38 @@
represent the surface cost. The <b>output</b> <em>name</em> is the name of the
resultant raster map of cumulative cost. The <b>outdir</b> <em>name</em> is the
name of the resultant raster map of movement directions (see <a href="#move">Movement Direction</a>).
-<p><em>r.cost</em> can be run with three different methods of identifying the
+<p>
+<em>r.cost</em> can be run with three different methods of identifying the
starting point(s). One or more points (geographic coordinate pairs) can be
provided as specified <b>start_coordinate</b> on the command line, from a vector
points file, or from a raster map.
All non-NULL cells are considered to be starting points.
+<p>
Each <em>x,y</em> <b>start_coordinate</b> pair gives the geographic location of a
point from which the transportation cost should be figured. As many points as
desired can be entered by the user. These starting points can also be read
from a vector points file through the <b>start_points</b> option or from a
raster map through the <b>start_rast</b> option.
-<p><em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
+<p>
+<em>r.cost</em> will stop cumulating costs when either <b>max_cost</b> is reached,
or one of the stop points given with <b>stop_coordinate</b> is reached.
Alternatively, the stop points can be read from a vector points file with the
<b>stop_points</b> option. During execution, once the cumulative cost to all
-stopping points has been determined, processing stops.
+stopping points has been determined, processing stops.<br>
Both sites read from a vector points file and those given on the command line
will be processed.
-<p>The null cells in the <b>input</b> map can be assigned a (positive floating
-point) cost with the <b>null_cost</b> option.
-<br>
+<p>
+The null cells in the <b>input</b> map can be assigned a (positive floating
+point) cost with the <b>null_cost</b> option.<br>
When input map null cells are given a cost with the <b>null_cost</b>
option, the corresponding cells in the output map are no longer null
cells. By using the <b>-n</b> flag, the null cells of the input map are
retained as null cells in the output map.
-<p>As <em>r.cost</em> can run for a very long time, it can be useful to
+<p>
+As <em>r.cost</em> can run for a very long time, it can be useful to
use the <b>--v</b> verbose flag to track progress.
-<p>The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
+<p>
+The Knight's move (<b>-k</b> flag) may be used to improve the accuracy of
the output. In the diagram below, the center location (<tt>O</tt>) represents a
grid cell from which cumulative distances are calculated. Those
neighbors marked with an <tt>X</tt> are always considered for cumulative cost
@@ -75,7 +72,7 @@
. . . K . . K . . .
</pre></div>
-<br>
+<p>
Knight's move example:
<center>
<img src="rcost_knightsmove.png" border="1"><br>
@@ -88,19 +85,24 @@
</table>
</center>
+<p>
+If the <em>nearest</em> output parameter is specified, the module will calculate
+for each cell its nearest starting point based on the minimized accumulative cost
+while moving over the cost map.
<h2>NULL CELLS</h2>
-<p>By default null cells in the input raster map are excluded from
+By default null cells in the input raster map are excluded from
the algorithm, and thus retained in the output map.
-<p>If one wants <b>r.cost</b> to transparently cross any region of null cells,
+<p>
+If one wants <b>r.cost</b> to transparently cross any region of null cells,
the <b>null_cost</b>=<tt>0.0</tt> option should be used. Then null cells just
propagate the adjacent costs. These cells can be retained as null cells in the
output map by using the <b>-n</b> flag.
<h2>NOTES</h2>
-<p>Sometimes, when the differences among integer cell category values in the
+Sometimes, when the differences among integer cell category values in the
<em>r.cost</em> cumulative cost surface output are small, this
cumulative cost output cannot accurately be used as input to <em><a href="r.drain.html">r.drain</a></em>
(<em><a href="r.drain.html">r.drain</a></em> will output bad
@@ -118,7 +120,9 @@
<h3>Algorithm notes</h3>
The fundamental approach to calculating minimum travel cost is as
-follows:<p> The user generates a raster map indicating the cost of
+follows:
+<p>
+The user generates a raster map indicating the cost of
traversing each cell in the north-south and east-west directions.
This map, along with a set of starting points are submitted to
<em>r.cost</em>. The starting points are put into a list cells from which
@@ -129,12 +133,14 @@
of selecting the lowest cumulative cost cell, computing costs to the
neighbors, putting the neighbors on the list and removing the
originating cell from the list continues until the list is empty.
-<p>The most time consuming aspect of this algorithm is the management of
+<p>
+The most time consuming aspect of this algorithm is the management of
the list of cells for which cumulative costs have been at least
initially computed. <em>r.cost</em> uses a binary tree with an linked list
at each node in the tree for efficiently holding cells with identical
cumulative costs.
-<p><em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
+<p>
+<em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
maps larger that can fit in available computer memory. As the
algorithm works through the dynamic list of cells it can move almost
randomly around the entire area. <em>r.cost</em> divides the entire area
@@ -224,11 +230,12 @@
<a name="move"></a>
<h2>Movement Direction</h2>
-<p>The movement direction surface is created to record the sequence of
+The movement direction surface is created to record the sequence of
movements that created the cost accumulation surface. Without it
<em><a href="r.drain.html">r.drain</a></em> would not correctly create a path from an end point
back to the start point. The direction of each cell points towards
the next cell. The directions are recorded as degrees CCW from East:
<div class="code"><pre>
112.5 67.5 i.e. a cell with the value 135
157.5 135 90 45 22.5 means the next cell is to the north-west
@@ -237,7 +244,18 @@
247.5 292.5
</pre></div>
-<p>
+<h3>Cost allocation</h3>
+Example: calculation of the cost allocation map "costalloc" and the cumulative
+cost map "costsurf" for given starting points (map "sources") and given
+cost raster map "costs":
+<div class="code"><pre>
+r.cost input=costs start_rast=sources output=costsurf nearest=costalloc
+</pre></div>
+<h3>Find the minimum cost path</h3>
Once <em>r.cost</em> computes the cumulative cost map, <em><a href="r.drain.html">r.drain</a></em>
can be used to find the minimum cost path. Make sure to use the <b>-d</b> flag
and the movement direction raster map when running r.drain to ensure
