[GRASS-SVN] r55597 - grass/trunk/raster/r.tile
svn_grass at osgeo.org
Wed Apr 3 01:13:45 PDT 2013
Author: zarch
Date: 2013-04-03 01:13:44 -0700 (Wed, 03 Apr 2013)
New Revision: 55597
grass/trunk/raster/r.tile/main.c
Add overlap option to r.tile
Modified: grass/trunk/raster/r.tile/main.c
--- grass/trunk/raster/r.tile/main.c 2013-04-03 08:13:38 UTC (rev 55596)
+++ grass/trunk/raster/r.tile/main.c 2013-04-03 08:13:44 UTC (rev 55597)
@@ -19,20 +19,20 @@
static struct
- struct Option *rastin, *rastout, *width, *height;
+ struct Option *rastin, *rastout, *width, *height, *overlap;
} parm;
-static struct Cell_head dst_w, src_w;
+static struct Cell_head dst_w, src_w, ovl_w;
static int xtiles, ytiles;
static RASTER_MAP_TYPE map_type;
-static void write_support_files(int xtile, int ytile);
+static void write_support_files(int xtile, int ytile, int overlap);
int main(int argc, char *argv[])
struct GModule *module;
int infile;
- size_t xtile_size;
- int ytile, xtile, y;
+ size_t xtile_size, cell_size;
+ int ytile, xtile, y, overlap;
int *outfiles;
void *inbuf;
@@ -67,10 +67,18 @@
parm.height->multiple = NO;
parm.height->description = _("Height of tiles");
+ parm.overlap = G_define_option();
+ parm.overlap->key = "overlap";
+ parm.overlap->type = TYPE_INTEGER;
+ parm.overlap->required = NO;
+ parm.overlap->multiple = NO;
+ parm.overlap->description = _("Overlap of tiles");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
G_get_set_window(&src_w);
+ overlap = parm.overlap->answer ? atoi(parm.overlap->answer) : 0;
/* set window to old map */
Rast_get_cellhd(parm.rastin->answer, "", &src_w);
@@ -85,17 +93,26 @@
G_debug(1, "X: %d * %d, Y: %d * %d",
xtiles, dst_w.cols, ytiles, dst_w.rows);
- src_w.cols = xtiles * dst_w.cols;
- src_w.rows = ytiles * dst_w.rows;
- src_w.east = src_w.west + src_w.cols * src_w.ew_res;
- src_w.south = src_w.north - src_w.rows * src_w.ns_res;
+ src_w.cols = xtiles * dst_w.cols + 2 * overlap;
+ src_w.rows = ytiles * dst_w.rows + 2 * overlap;
+ src_w.west = src_w.west - overlap * src_w.ew_res;
+ src_w.east = src_w.west + (src_w.cols + 2 * overlap) * src_w.ew_res;
+ src_w.north = src_w.north + overlap * src_w.ns_res;
+ src_w.south = src_w.north - (src_w.rows + 2 * overlap) * src_w.ns_res;
Rast_set_input_window(&src_w);
- Rast_set_output_window(&dst_w);
+ /* set the output region */
+ ovl_w = dst_w;
+ ovl_w.cols = ovl_w.cols + 2 * overlap;
+ ovl_w.rows = ovl_w.rows + 2 * overlap;
+ G_adjust_Cell_head(&ovl_w, 1, 1);
+ Rast_set_output_window(&ovl_w);
infile = Rast_open_old(parm.rastin->answer, "");
map_type = Rast_get_map_type(infile);
- xtile_size = dst_w.cols * Rast_cell_size(map_type);
+ cell_size = Rast_cell_size(map_type);
inbuf = Rast_allocate_input_buf(map_type);
@@ -111,20 +128,22 @@
sprintf(name, "%s-%03d-%03d", parm.rastout->answer, ytile, xtile);
outfiles[xtile] = Rast_open_new(name, map_type);
- for (y = 0; y < dst_w.rows; y++) {
+ for (y = 0; y < ovl_w.rows; y++) {
int row = ytile * dst_w.rows + y;
G_debug(1, "reading row: %d", row);
Rast_get_row(infile, inbuf, row, map_type);
for (xtile = 0; xtile < xtiles; xtile++) {
- void *ptr = G_incr_void_ptr(inbuf, xtile * xtile_size);
+ int cells = xtile * dst_w.cols;
+ void *ptr = G_incr_void_ptr(inbuf, cells * cell_size);
Rast_put_row(outfiles[xtile], ptr, map_type);
Rast_close(outfiles[xtile]);
- write_support_files(xtile, ytile);
+ write_support_files(xtile, ytile, overlap);
@@ -133,27 +152,33 @@
return EXIT_SUCCESS;
char name[GNAME_MAX];
struct Cell_head cellhd;
char title[64];
struct History history;
struct Colors colors;
+ struct Categories cats;
Rast_get_cellhd(name, G_mapset(), &cellhd);
cellhd.north = src_w.north - ytile * dst_w.rows * src_w.ns_res;
- cellhd.south = cellhd.north - dst_w.rows * src_w.ns_res;
+ cellhd.south = cellhd.north - (dst_w.rows + 2 * overlap) * src_w.ns_res;
cellhd.west = src_w.west + xtile * dst_w.cols * src_w.ew_res;
- cellhd.east = cellhd.west + dst_w.cols * src_w.ew_res;
+ cellhd.east = cellhd.west + (dst_w.cols + 2 * overlap) * src_w.ew_res;
Rast_put_cellhd(name, &cellhd);
+ /* copy cats from source map */
+ if (Rast_read_cats(parm.rastin->answer, "", &cats) < 0)
+ G_fatal_error(_("Unable to read cats for %s"),
+ parm.rastin->answer);
+ Rast_write_cats(name, &cats);
/* record map metadata/history info */
sprintf(title, "Tile %d,%d of %s", xtile, ytile, parm.rastin->answer);
Rast_put_cell_title(parm.rastout->answer, title);
