[GRASS-SVN] r55619 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Thu Apr 4 01:06:12 PDT 2013
Author: martinl
Date: 2013-04-04 01:06:12 -0700 (Thu, 04 Apr 2013)
New Revision: 55619
grass/trunk/imagery/i.segment/main.c
grass/trunk/imagery/i.segment/parse_args.c
i.segment: description cosmetics
Modified: grass/trunk/imagery/i.segment/main.c
--- grass/trunk/imagery/i.segment/main.c 2013-04-04 04:25:29 UTC (rev 55618)
+++ grass/trunk/imagery/i.segment/main.c 2013-04-04 08:06:12 UTC (rev 55619)
@@ -36,7 +36,7 @@
G_add_keyword(_("segmentation"));
G_add_keyword(_("object recognition"));
module->description =
- _("Identify segments (objects) from imagery.");
+ _("Identifies segments (objects) from imagery data.");
parse_args(argc, argv, &globals);
Modified: grass/trunk/imagery/i.segment/parse_args.c
--- grass/trunk/imagery/i.segment/parse_args.c 2013-04-04 04:25:29 UTC (rev 55618)
+++ grass/trunk/imagery/i.segment/parse_args.c 2013-04-04 08:06:12 UTC (rev 55619)
@@ -112,7 +112,7 @@
bounds = G_define_standard_option(G_OPT_R_INPUT);
bounds->key = "bounds";
bounds->required = NO;
- bounds->label = _("Name for input bounding/constraining raster map");
+ bounds->label = _("Name of input bounding/constraining raster map");
bounds->description =
_("Must be integer values, each area will be segmented independent of the others");
