[GRASS-SVN] r55625 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Thu Apr 4 10:35:28 PDT 2013
Author: mmetz
Date: 2013-04-04 10:35:28 -0700 (Thu, 04 Apr 2013)
New Revision: 55625
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: fix r55611; import GDT_Float64 as DCELL_TYPE
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2013-04-04 15:05:24 UTC (rev 55624)
+++ grass/trunk/raster/r.in.gdal/main.c 2013-04-04 17:35:28 UTC (rev 55625)
@@ -345,7 +345,7 @@
else {
if (0 != G_make_location(parm.outloc->answer, &cellhd,
- proj_info, proj_units)) {
+ proj_info, proj_units, NULL)) {
G_fatal_error(_("Unable to create new location <%s>"),
parm.outloc->answer);
@@ -737,8 +737,8 @@
int row, nrows, ncols, complex;
int cf, cfR, cfI, bNoDataEnabled;
int indx;
- CELL *cell, *cellReal, *cellImg;
- float *bufComplex;
+ void *cell, *cellReal, *cellImg;
+ void *bufComplex;
double dfNoData;
char outputReal[GNAME_MAX], outputImg[GNAME_MAX];
char *nullFlags = NULL;
@@ -754,12 +754,17 @@
switch (eRawGDT) {
case GDT_Float32:
- case GDT_Float64:
data_type = FCELL_TYPE;
eGDT = GDT_Float32;
complex = FALSE;
break;
+ case GDT_Float64:
+ data_type = DCELL_TYPE;
+ eGDT = GDT_Float64;
+ complex = FALSE;
+ break;
case GDT_Byte:
data_type = CELL_TYPE;
eGDT = GDT_Int32;
@@ -798,7 +803,10 @@
cellReal = Rast_allocate_buf(data_type);
cellImg = Rast_allocate_buf(data_type);
- bufComplex = (float *)G_malloc(sizeof(float) * ncols * 2);
+ if (eGDT == GDT_Float64)
+ bufComplex = (double *)G_malloc(sizeof(double) * ncols * 2);
+ else
+ bufComplex = (float *)G_malloc(sizeof(float) * ncols * 2);
if (group_ref != NULL) {
I_add_file_to_group_ref(outputReal, G_mapset(), group_ref);
@@ -836,17 +844,23 @@
for (indx = ncols - 1; indx >= 0; indx--) { /* CEOS: flip east-west during import - MN */
if (eGDT == GDT_Int32) {
- ((GInt32 *) cellReal)[ncols - indx] =
+ ((CELL *) cellReal)[ncols - indx] =
((GInt32 *) bufComplex)[indx * 2];
- ((GInt32 *) cellImg)[ncols - indx] =
+ ((CELL *) cellImg)[ncols - indx] =
((GInt32 *) bufComplex)[indx * 2 + 1];
- else {
- ((float *)cellReal)[ncols - indx] =
- bufComplex[indx * 2];
- ((float *)cellImg)[ncols - indx] =
- bufComplex[indx * 2 + 1];
+ else if (eGDT == GDT_Float32) {
+ ((FCELL *)cellReal)[ncols - indx] =
+ ((float *)bufComplex)[indx * 2];
+ ((FCELL *)cellImg)[ncols - indx] =
+ ((float *)bufComplex)[indx * 2 + 1];
+ else if (eGDT == GDT_Float64) {
+ ((DCELL *)cellReal)[ncols - indx] =
+ ((double *)bufComplex)[indx * 2];
+ ((DCELL *)cellImg)[ncols - indx] =
+ ((double *)bufComplex)[indx * 2 + 1];
Rast_put_row(cfR, cellReal, data_type);
Rast_put_row(cfI, cellImg, data_type);
@@ -860,18 +874,25 @@
for (indx = 0; indx < ncols; indx++) {
- if (((GInt32 *) cell)[indx] == (GInt32) dfNoData) {
+ if (((CELL *) cell)[indx] == (GInt32) dfNoData) {
nullFlags[indx] = 1;
- if (((float *)cell)[indx] == (float)dfNoData) {
+ if (((FCELL *)cell)[indx] == (float)dfNoData) {
+ for (indx = 0; indx < ncols; indx++) {
+ if (((DCELL *)cell)[indx] == dfNoData) {
+ nullFlags[indx] = 1;
Rast_insert_null_values(cell, nullFlags, ncols, data_type);
@@ -879,7 +900,7 @@
Rast_put_row(cf, cell, data_type);
} /* end of not complex */
- G_percent(row, nrows, 2);
+ G_percent(row - 1, nrows, 2);
} /* for loop */
} /* end of not AVHRR */
else {
@@ -893,18 +914,25 @@
+ if (((CELL *) cell)[indx] == (CELL) dfNoData) {
+ if (((FCELL *)cell)[indx] == (FCELL)dfNoData) {
@@ -931,6 +959,8 @@
Rast_write_history((char *)outputImg, &history);
G_free(bufComplex);
+ G_free(cellReal);
+ G_free(cellImg);
else {
G_debug(1, "Creating support files for %s", output);
@@ -938,6 +968,8 @@
Rast_short_history((char *)output, "raster", &history);
Rast_command_history(&history);
Rast_write_history((char *)output, &history);
+ G_free(cell);
if (nullFlags != NULL)
