[GRASS-SVN] r55638 - grass-addons/grass6/raster/r.fidimo
Fri Apr 5 01:49:07 PDT 2013
Author: jradinger
Date: 2013-04-05 01:49:06 -0700 (Fri, 05 Apr 2013)
New Revision: 55638
   grass-addons/grass6/raster/r.fidimo/r.fidimo.py
Problem: when first processed barrier is impermeable then no probability is left for more upstream barriers although the are "affected". Problem solved. Not solved for the case when remaining upstream probablity is less the computational lower boundary (smallest number that can be assigned to a raster).
Modified: grass-addons/grass6/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-04-05 05:09:01 UTC (rev 55637)
+++ grass-addons/grass6/raster/r.fidimo/r.fidimo.py	2013-04-05 08:49:06 UTC (rev 55638)
@@ -141,7 +141,7 @@
 #% key_desc: name
 #% description: Statistical Intervals
 #% guisection: Output
-#% options:no,Confidence Interval,Predicition Interval
+#% options:no,Confidence Interval,Prediction Interval
 #% answer:no
 #%end
@@ -198,7 +198,7 @@
 	if options['barriers']:
-		tmp_map_rast = tmp_map_rast + ['density_below_barrier_tmp_','distance_barrier_tmp_', 'distance_barrier_downstream_tmp','distance_from_point_within_segment_tmp_', 'distance_upstream_point_within_segment_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_',  'upstream_density_tmp_', 'upstream_segment_tmp_']
+		tmp_map_rast = tmp_map_rast + ['density_below_barrier_tmp_','distance_barrier_tmp_', 'distance_barrier_downstream_tmp_','distance_from_point_within_segment_tmp_', 'distance_upstream_point_within_segment_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_',  'upstream_density_tmp_', 'upstream_segment_tmp_']
 		tmp_map_vect = tmp_map_vect + ["barriers_",'barriers_tmp_', 'point_within_segment_tmp_']
@@ -390,6 +390,7 @@
 	#Check if outflow coors are on river
+	# For GRASS7 snap coors to river. Check r.stream.snap - add on
@@ -539,17 +540,19 @@
 		# Loop over Segments
 		for Segment in sorted(list(set(db.execute('SELECT Segment FROM source_points_%d ORDER BY Segment ASC' % os.getpid())))):
-			grass.message("this is Segement Nr.: " +str(Segment))
+			grass.debug(_("this is Segement Nr.: " +str(Segment)))
+			segment_cat = str(Segment[0])
 			mapcalc_list_A = []
-			# Loop over Source points
-			for cat,X,Y,prob,Strahler in db.execute('SELECT cat, X, Y, prob, Strahler FROM source_points_%d WHERE Segment=?' % os.getpid(), (str(Segment[0]),)):
+			# Loop over Source points
+			source_points_loop = db.execute('SELECT cat, X, Y, prob, Strahler FROM source_points_%d WHERE Segment=?' % os.getpid(), (str(Segment[0]),))
+			for cat,X,Y,prob,Strahler in source_points_loop:
+				grass.debug(_("Start looping over source points"))
 				coors = str(X)+","+str(Y)
-				segment_cat = str(Segment[0])
 				#Select dispersal parameters
 				SO = 'SO='+str(Strahler)
 				sigma_stat = fishmove.rx(i,'sigma_stat',1,1,SO,1)
@@ -565,8 +568,9 @@
 					truncation = float(options['truncation'])
 					max_dist = int(optimize.zeros.newton(func, 1., args=(sigma_stat,sigma_mob,m,truncation,p)))
-				grass.message("The maximum spread distance for this source point is: "+str(max_dist))
+				grass.debug(_("Distance from each source point is calculated up to a treshold of: "+str(max_dist)))
 				grass.run_command("r.cost",
 							  flags = 'n',
 							  overwrite = True,
@@ -574,7 +578,9 @@
 							  output = "distance_from_point_tmp_%d" % os.getpid(),
 							  coordinate = coors,
 							  max_cost = max_dist)
 				# Getting upper and lower distance (cell boundaries) based on the fact that there are different flow lenghts through a cell depending on the direction (diagonal-orthogonal)
 				grass.mapcalc("$upper_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point+($ds/2.0), $distance_from_point+($dd/2.0))",
 							upper_distance = "upper_distance_tmp_%d" % os.getpid(),
@@ -591,8 +597,10 @@
 							dd = math.sqrt(2)*res)
+				# MAIN PART: leptokurtic probability density kernel based on fishmove
+				grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
-				# MAIN PART: leptokurtic probability density kernel based on fishmove
 				def cdf(x):
 					return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob
@@ -608,9 +616,9 @@
 				x2.read("upper_distance_tmp_%d" % os.getpid())
 				Density = garray.array()
 				Density[...] = cdf(x2) - cdf(x1)
+				grass.debug(_("Write density from point to garray. unmasked"))
 				Density.write("density_from_point_unmasked_tmp_%d" % os.getpid())
 				# Mask density output because Density.write doesn't provide nulls()
 				grass.mapcalc("$density_from_point = if($distance_from_point>=0, $density_from_point_unmasked, null())",
 							density_from_point = "density_from_point_tmp_%d" % os.getpid(),
@@ -618,8 +626,9 @@
 							density_from_point_unmasked = "density_from_point_unmasked_tmp_%d" % os.getpid())
+				# Defining up and downstream of source point
+				grass.debug(_("Defining up and downstream of source point"))
 				# Defining area upstream source point
 				grass.run_command("r.stream.basins",
 							  overwrite = True,
@@ -634,7 +643,10 @@
 								overwrite = True,
 								coordinate = coors)
-				# Applying upstream split at network nodes based on inverse shreve stream order
+				# Applying upstream split at network nodes based on inverse shreve stream order
+				grass.debug(_("Applying upstream split at network nodes based on inverse shreve stream order"))
 				grass.mapcalc("$upstream_shreve = if($upstream_part, $shreve)",
 							upstream_shreve = "upstream_shreve_tmp_%d" % os.getpid(),
 							upstream_part = "upstream_part_tmp_%d" % os.getpid(),
@@ -674,10 +686,12 @@
 			################### Barriers ########################
 				grass.run_command("r.mask",
 							flags="o",
 							input = "river_raster_cat_tmp_%d" % os.getpid(),
 							maskcats = segment_cat)
 				#Create one single random point within analyzed segment
 				grass.run_command("r.random",
@@ -706,7 +720,11 @@
 							  overwrite = True,
 							  input = "river_raster_tmp_%d" % os.getpid(),
 							  output = "distance_from_point_within_segment_tmp_%d" % os.getpid(),
-							  start_points = "point_within_segment_tmp_%d" % os.getpid())
+							  start_points = "point_within_segment_tmp_%d" % os.getpid())
+				#Remove "point within segment"
+				grass.run_command("g.remove", vect = "point_within_segment_tmp_%d" % os.getpid())
 				grass.mapcalc("$distance_upstream_point_within_segment = if($upstream_segment, $distance_from_point_within_segment, null())",
 								distance_upstream_point_within_segment = "distance_upstream_point_within_segment_tmp_%d" % os.getpid(),
@@ -733,9 +751,12 @@
 				# Loop over the affected barriers (from most downstream barrier to most upstream barrier)
+				# Initally affected = all barriers where density > 0
 				for cat,X,Y,dist,clearance in db.execute('SELECT cat, X, Y, dist, clearance FROM barriers_%d WHERE affected_barriers > 0 AND dist > 0 ORDER BY dist' % os.getpid()):
 					coors_barriers = str(X)+","+str(Y)
+					grass.debug(_("Starting with corrections for barriers"))
 					#Defining upstream the barrier
 								  overwrite = True,
@@ -747,12 +768,15 @@
 					grass.mapcalc("$upstream_density = if($upstream_barrier, $density_segment, null())",
 								upstream_density = "upstream_density_tmp_%d" % os.getpid(),
 								upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
-								density_segment = "density_segment_"+str(Segment[0]))
+								density_segment = "density_segment_"+segment_cat)
 					#Getting sum of upstream density and density to relocate downstream
 					d = {'n':5, 'min': 6, 'max': 7, 'mean': 9, 'sum': 14, 'median':16, 'range':8}
 					univar = grass.read_command("r.univar", map = "upstream_density_tmp_%d" % os.getpid(), flags = 'e')
-					upstream_density = float(univar.split('\n')[d['sum']].split(':')[1])
+					if univar:
+						upstream_density = float(univar.split('\n')[d['sum']].split(':')[1])
+					else:
+						grass.fatal(_("Error with upstream density/barriers. The error is for coors_barriers (X,Y): "+coors_barriers))
 					density_for_downstream = upstream_density*(1-clearance)
@@ -806,16 +830,19 @@
 								clearance=clearance)
 					if dist == last_barrier :
-						grass.run_command("r.null", map="density_segment_"+str(Segment[0]), null="0")
+						grass.run_command("r.null", map="density_segment_"+segment_cat, null="0")
 					else:
-						grass.run_command("r.null", map="density_segment_"+str(Segment[0]), setnull="0")
+						grass.run_command("r.null", map="density_segment_"+segment_cat, setnull="0")
+					#If the barrier in the loop was impermeable (clearance=0)
+					#than no more upstream barriers need to be considered --> break
+					if clearance == 0:
+						break
-			grass.run_command("r.null", map="density_segment_"+str(Segment[0]), null="0") # Final density map per segment without barriers
+			grass.run_command("r.null", map="density_segment_"+segment_cat, null="0") # Final density map per segment
-			mapcalc_list_B.append("density_segment_"+str(Segment[0]))
+			mapcalc_list_B.append("density_segment_"+segment_cat)
