[GRASS-SVN] r55646 - grass/trunk/raster/r.watershed/seg
svn_grass at osgeo.org
Sat Apr 6 13:37:05 PDT 2013
Author: mmetz
Date: 2013-04-06 13:37:05 -0700 (Sat, 06 Apr 2013)
New Revision: 55646
grass/trunk/raster/r.watershed/seg/close_maps.c
grass/trunk/raster/r.watershed/seg/do_astar.c
r.watershed.seg fix diagonal flow bias, fix aspect colors
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c 2013-04-06 13:38:18 UTC (rev 55645)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c 2013-04-06 20:37:05 UTC (rev 55646)
@@ -233,7 +233,7 @@
Rast_close(fd);
Rast_init_colors(&colors);
- Rast_make_grey_scale_colors(&colors, 1, 8);
+ Rast_make_aspect_colors(&colors, -8, 8);
Rast_write_colors(asp_name, this_mapset, &colors);
seg_close(&aspflag);
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c 2013-04-06 13:38:18 UTC (rev 55645)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c 2013-04-06 20:37:05 UTC (rev 55646)
@@ -4,9 +4,7 @@
#include "do_astar.h"
HEAP_PNT drop_pt(void);
-int sift_up(GW_LARGE_INT, HEAP_PNT);
-int cmp_pnt(HEAP_PNT *a, HEAP_PNT *b);
-double get_slope2(CELL, CELL, double);
+static double get_slope2(CELL, CELL, double);
int do_astar(void)
@@ -106,32 +104,34 @@
- /* add neighbour as new point if not in the list */
- if (is_in_list == 0 && skip_diag == 0) {
- /* set flow direction */
- af.asp = drain[upr - r + 1][upc - c + 1];
- add_pt(upr, upc, alt_nbr[ct_dir]);
- FLAG_SET(af.flag, INLISTFLAG);
- seg_put(&aspflag, (char *)&af, upr, upc);
- else if (is_in_list && is_worked == 0 &&
- FLAG_GET(af.flag, EDGEFLAG)) {
- /* neighbour is edge in list, not yet worked */
- if (af.asp < 0) {
- /* adjust flow direction for edge cell */
+ if (!skip_diag) {
+ /* add neighbour as new point if not in the list */
+ if (is_in_list == 0) {
+ /* set flow direction */
+ add_pt(upr, upc, alt_nbr[ct_dir]);
+ FLAG_SET(af.flag, INLISTFLAG);
- seg_get(&watalt, (char *)&wa, r, c);
- if (wa.wat > 0) {
- wa.wat = -wa.wat;
- seg_put(&watalt, (char *)&wa, r, c);
+ else if (is_in_list && is_worked == 0 &&
+ FLAG_GET(af.flag, EDGEFLAG)) {
+ /* neighbour is edge in list, not yet worked */
+ if (af.asp < 0) {
+ /* adjust flow direction for edge cell */
+ af.asp = drain[upr - r + 1][upc - c + 1];
+ seg_put(&aspflag, (char *)&af, upr, upc);
+ seg_get(&watalt, (char *)&wa, r, c);
+ if (wa.wat > 0) {
+ wa.wat = -wa.wat;
+ seg_put(&watalt, (char *)&wa, r, c);
+ /* neighbour is inside real depression, not yet worked */
+ else if (af.asp == 0) {
- /* neighbour is inside real depression, not yet worked */
- else if (af.asp == 0) {
@@ -155,17 +155,45 @@
/* compare two heap points */
/* return 1 if a < b else 0 */
-int cmp_pnt(HEAP_PNT * a, HEAP_PNT * b)
+static int cmp_pnt(HEAP_PNT * a, HEAP_PNT * b)
if (a->ele < b->ele)
return 1;
else if (a->ele == b->ele) {
- if (a->added < b->added)
- return 1;
+ return (a->added < b->added);
return 0;
+/* standard sift-up routine for d-ary min heap */
+static int sift_up(GW_LARGE_INT start, HEAP_PNT child_p)
+ GW_LARGE_INT parent, child;
+ HEAP_PNT heap_p;
+ child = start;
+ while (child > 1) {
+ parent = GET_PARENT(child);
+ seg_get(&search_heap, (char *)&heap_p, 0, parent);
+ /* push parent point down if child is smaller */
+ if (cmp_pnt(&child_p, &heap_p)) {
+ seg_put(&search_heap, (char *)&heap_p, 0, child);
+ child = parent;
+ /* no more sifting up, found slot for child */
+ else
+ break;
+ /* add child to heap */
+ seg_put(&search_heap, (char *)&child_p, 0, child);
+ return 0;
/* add point routine for min heap */
int add_pt(int r, int c, CELL ele)
@@ -235,37 +263,9 @@
return root_p;
-/* standard sift-up routine for d-ary min heap */
-int sift_up(GW_LARGE_INT start, HEAP_PNT child_p)
+double get_slope(int r, int c, int downr, int downc, CELL ele,
+ CELL downe)
- GW_LARGE_INT parent, child;
- HEAP_PNT heap_p;
- child = start;
- while (child > 1) {
- parent = GET_PARENT(child);
- seg_get(&search_heap, (char *)&heap_p, 0, parent);
- /* push parent point down if child is smaller */
- if (cmp_pnt(&child_p, &heap_p)) {
- seg_put(&search_heap, (char *)&heap_p, 0, child);
- child = parent;
- /* no more sifting up, found slot for child */
- else
- break;
- /* add child to heap */
- seg_put(&search_heap, (char *)&child_p, 0, child);
- return 0;
-double
-get_slope(int r, int c, int downr, int downc, CELL ele, CELL downe)
double slope;
if (r == downr)
@@ -279,7 +279,7 @@
return (slope);
-double get_slope2(CELL ele, CELL up_ele, double dist)
+static double get_slope2(CELL ele, CELL up_ele, double dist)
if (ele >= up_ele)
return 0.0;
