[GRASS-SVN] r55653 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Sun Apr 7 07:18:31 PDT 2013
Author: turek
Date: 2013-04-07 07:18:31 -0700 (Sun, 07 Apr 2013)
New Revision: 55653
grass/trunk/gui/wxpython/mapdisp/main.py
wxGUI d.mon:fix of d.erase and managment of map layers
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2013-04-07 13:26:48 UTC (rev 55652)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2013-04-07 14:18:31 UTC (rev 55653)
@@ -71,6 +71,10 @@
self.cmdfile = cmdfile
+ # list of layers for rendering added from cmd file
+ # TODO temporary solution, layer managment by different tools in GRASS should be resovled
+ self.ownedLayers = []
if mapfile:
self.mapfileCmd = mapfile
self.maskfileCmd = os.path.splitext(mapfile)[0] + '.pgm'
@@ -83,11 +87,19 @@
if not self.cmdfile:
return
nlayers = 0
try:
fd = open(self.cmdfile, 'r')
existingLayers = self.GetListOfLayers()
+ # holds new rendreing order for every layer in existingLayers
+ layersOrder = [-1] * len(self.GetListOfLayers())
+ # next number in rendering order
+ next_layer = 0;
for line in fd.readlines():
cmd = utils.split(line.strip())
ltype = None
@@ -109,15 +121,53 @@
active = False, hidden = True,
opacity = 0)
exists = False
- for layer in existingLayers:
+ for i, layer in enumerate(existingLayers):
if layer.GetCmd(string=True) == tmpMapLayer.GetCmd(string=True):
exists = True
+ if layersOrder[i] == -1:
+ layersOrder[i] = next_layer;
+ next_layer += 1
+ # layer must be put higher in render order (same cmd was insered more times)
+ # TODO delete rendurant cmds from cmd file?
+ else:
+ for j, l_order in enumerate(layersOrder):
+ if l_order > layersOrder[i]:
+ layersOrder[j] -= 1;
+ layersOrder[i] = next_layer - 1;
break
if exists:
continue
- Map.AddLayer(self, ltype = ltype, command = cmd, active = True, name = name)
+ newLayer = Map.AddLayer(self, ltype = ltype, command = cmd, active = True, name = name)
+ existingLayers.append(newLayer)
+ self.ownedLayers.append(newLayer)
+ layersOrder.append(next_layer)
+ next_layer += 1
nlayers += 1
+ reorderedLayers = [-1] * next_layer
+ # owned layer was not found in cmd file -> is deleted
+ if layersOrder[i] == -1 and layer in self.ownedLayers:
+ self.ownedLayers.remove(layer)
+ self.DeleteLayer(layer)
+ # other layer e. g. added by wx.vnet are added to the top
+ elif layersOrder[i] == -1 and layer not in self.ownedLayers:
+ reorderedLayers.append(layer)
+ # owned layer found in cmd file is added into proper rendering position
+ else:
+ reorderedLayers[layersOrder[i]] = layer
+ self.ReorderLayers(reorderedLayers)
except IOError, e:
grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
{ 'cmd' : self.cmdfile, 'det' : e })
@@ -125,8 +175,7 @@
fd.close()
- if nlayers:
- self._giface.updateMap.emit()
+ self._giface.updateMap.emit()
Debug.msg(1, "Map.GetLayersFromCmdFile(): cmdfile=%s" % self.cmdfile)
Debug.msg(1, " nlayers=%d" % nlayers)
