[GRASS-SVN] r55656 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Mon Apr 8 05:54:15 PDT 2013
Author: mic
Date: 2013-04-08 05:54:15 -0700 (Mon, 08 Apr 2013)
New Revision: 55656
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/tests/test_playground.py
adding string coordinate converter
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-04-08 09:27:09 UTC (rev 55655)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-04-08 12:54:15 UTC (rev 55656)
@@ -23,6 +23,25 @@
self.region = dict()
self.setregion(1,1)
+ def stringcoordinate(self, x, y):
+ Convert string coordinates to float coordinates.
+ @param x string x coordinate
+ @param y string y coordinate
+ @return position as a list of floats
+ try:
+ # try to convert the string value to a float
+ x = float(x)
+ y = float(y)
+ # also catch 'inf' and 'nan' ..
+ if ( x == x ) and ( y == y ) and ( x + y - 1 != x + y ):
+ return [float(x), float(y)]
+ else:
+ return []
+ except ValueError:
+ return []
def setregion(self, rows, cols):
Set the geometry of the playground, based only on the number
Modified: grass-addons/grass7/raster/r.agent/tests/test_playground.py
--- grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-04-08 09:27:09 UTC (rev 55655)
+++ grass-addons/grass7/raster/r.agent/tests/test_playground.py 2013-04-08 12:54:15 UTC (rev 55656)
@@ -8,6 +8,11 @@
def setUp(self):
self.pg = playground.Playground()
+ def test_stringcoordinate(self):
+ self.assertEqual(self.pg.stringcoordinate("foo","bar"), [])
+ self.assertEqual(self.pg.stringcoordinate("inf","nan"), [])
+ self.assertEqual(self.pg.stringcoordinate("2","3"), [2,3])
def test_setregion(self):
self.assertTrue(self.pg.region["rows"] == 1)
self.pg.setregion(2,1)
