[GRASS-SVN] r55677 - in grass/trunk/gui/wxpython: gcp gui_core modules vdigit
Tue Apr 9 14:13:17 PDT 2013
Author: annakrat
Date: 2013-04-09 14:13:17 -0700 (Tue, 09 Apr 2013)
New Revision: 55677
   grass/trunk/gui/wxpython/gcp/manager.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/toolbars.py
   grass/trunk/gui/wxpython/modules/mcalc_builder.py
   grass/trunk/gui/wxpython/vdigit/wxdigit.py
   grass/trunk/gui/wxpython/vdigit/wxdisplay.py
wxGUI: remove tabs (except of gui for v.clean)
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/gcp/manager.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -1972,7 +1972,7 @@
         self.ResizeColumns()
         self.render = True
         self.EnsureVisible(self.selected)
     def OnCheckItem(self, index, flag):
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -588,7 +588,7 @@
                              min(height, 500)))
         # fix goutput's pane size (required for Mac OSX)
-        if self.goutput:
+        if self.goutput:
             self.goutput.SetSashPosition(int(self.GetSize()[1] * .75))
     def updateValuesHook(self, event = None):
Modified: grass/trunk/gui/wxpython/gui_core/toolbars.py
--- grass/trunk/gui/wxpython/gui_core/toolbars.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/gui_core/toolbars.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -81,16 +81,16 @@
     Following code shows how to create new basic toolbar:
     @code
-	class MyToolbar(BaseToolbar):
-	    def __init__(self, parent):
-	        BaseToolbar.__init__(self, parent)
-	        self.InitToolbar(self._toolbarData())
-	        self.Realize()
-	    def _toolbarData(self):
-	        return self._getToolbarData((("help", Icons["help"],
-	                                      self.parent.OnHelp),
+        class MyToolbar(BaseToolbar):
+            def __init__(self, parent):
+                BaseToolbar.__init__(self, parent)
+                self.InitToolbar(self._toolbarData())
+                self.Realize()
+            def _toolbarData(self):
+                return self._getToolbarData((("help", Icons["help"],
+                                              self.parent.OnHelp),
     @endcode
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -260,8 +260,8 @@
         self.SetMinSize(self.GetBestSize())
     def _return_funct(self,event):
-	i = event.GetString()
-	self._addSomething(self.funct_dict[i])
+        i = event.GetString()
+        self._addSomething(self.funct_dict[i])
     def _layout(self):
         sizer = wx.BoxSizer(wx.VERTICAL)
@@ -323,7 +323,7 @@
         threebutton.Add(item = self.btn_clear, pos = (0,2),
                          span = (1,1), flag = wx.ALIGN_RIGHT)
         buttonSizer3.Add(item = threebutton, pos = (4,0),
-	                 span = (1,1), flag = wx.ALIGN_CENTER)
+                         span = (1,1), flag = wx.ALIGN_CENTER)
         buttonSizer4 = wx.BoxSizer(wx.HORIZONTAL)
         buttonSizer4.Add(item = self.btn_load,
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -223,7 +223,7 @@
         self.poBgMapInfo = pointer(self.bgMapInfo)
         self.popoBgMapInfo = pointer(self.poBgMapInfo)
-	if Vect_open_old(self.poBgMapInfo, name, mapset) == -1:
+        if Vect_open_old(self.poBgMapInfo, name, mapset) == -1:
             self.poBgMapInfo = self.popoBgMapInfo = None
             self._error.NoMap(bgmap)
             return
@@ -304,7 +304,7 @@
         for i in range(listLine.contents.n_values):
             lineBreak = listLine.contents.id[i]
             if lineBreak == line:
-		continue
+                continue
             ltype = Vect_read_line(self.poMapInfo, pointsCheck, None, lineBreak)
             if not (ltype & GV_LINES):
@@ -1016,7 +1016,7 @@
             Vect_append_point(self.poPoints, x2, y2, z1)
             Vect_append_point(self.poPoints, x1, y2, z2)
             Vect_append_point(self.poPoints, x1, y1, z1)
             Vect_select_lines_by_polygon(self.poMapInfo, self.poPoints, 0, None,
                                          ftype, poList)
@@ -1148,7 +1148,7 @@
         if line == -1:
             update = True
             line = self._display.selected['ids'][0]
         if not Vect_line_alive(self.poMapInfo, line):
             return -1
@@ -1349,7 +1349,7 @@
         for field, cat in self.cats.iteritems():
             if cat == None:
                 self.cats[field] = 0 # first category 1
-	    Debug.msg(3, "wxDigit.InitCats(): layer=%d, cat=%d", field, self.cats[field])
+            Debug.msg(3, "wxDigit.InitCats(): layer=%d, cat=%d", field, self.cats[field])
     def _checkMap(self):
         """!Check if map is open
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2013-04-09 18:48:30 UTC (rev 55676)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2013-04-09 21:13:17 UTC (rev 55677)
@@ -621,24 +621,24 @@
         pz = c_double()
         if not self._validLine(lineNearest):
             return { 'line' : -1, 'point': None }
-	ftype = Vect_read_line(poMapInfo, self.poPoints, self.poCats, lineNearest)
-	Vect_line_distance (self.poPoints, point[0], point[1], 0.0, self.is3D,
-			    byref(px), byref(py), byref(pz),
-			    None, None, None)
-	# check for duplicates
-	if self.settings['highlightDupl']['enabled']:
+        ftype = Vect_read_line(poMapInfo, self.poPoints, self.poCats, lineNearest)
+        Vect_line_distance(self.poPoints, point[0], point[1], 0.0, self.is3D,
+                           byref(px), byref(py), byref(pz),
+                           None, None, None)
+        # check for duplicates
+        if self.settings['highlightDupl']['enabled']:
             found = poFound.contents
-	    for i in range(found.n_values):
-		line = found.value[i]
-		if line != lineNearest:
+            for i in range(found.n_values):
+                line = found.value[i]
+                if line != lineNearest:
                     self.selected['ids'].append(line)
             self.GetDuplicates()
-		if line != lineNearest and not self._isDuplicated(line):
+                if line != lineNearest and not self._isDuplicated(line):
                     self.selected['ids'].remove(line)
         Vect_destroy_list(poFound)
@@ -804,7 +804,7 @@
     def GetRegionSelected(self):
         """!Get minimal region extent of selected features
         @return n,s,w,e
         regionBox = bound_box()
@@ -1002,7 +1002,7 @@
                     continue
                 Vect_read_line(self.poMapInfo, BPoints, None, line2)
                 if Vect_line_check_duplicate(APoints, BPoints, WITHOUT_Z):
                     if i not in ids:
                         ids[i] = list()
