[GRASS-SVN] r55691 - grass/trunk/gui/wxpython/gcp
svn_grass at osgeo.org
Wed Apr 10 11:38:57 PDT 2013
Author: annakrat
Date: 2013-04-10 11:38:57 -0700 (Wed, 10 Apr 2013)
New Revision: 55691
grass/trunk/gui/wxpython/gcp/manager.py
wxGUI/gcp: fix various issues with wx 2.9
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py 2013-04-10 15:52:45 UTC (rev 55690)
+++ grass/trunk/gui/wxpython/gcp/manager.py 2013-04-10 18:38:57 UTC (rev 55691)
@@ -320,7 +320,6 @@
# layout
- self.sizer.AddGrowableCol(2)
# map type
self.rb_maptype = wx.RadioBox(parent=self, id=wx.ID_ANY,
label=' %s ' % _("Map type to georectify"),
@@ -348,6 +347,7 @@
self.sizer.Add(item=self.cb_mapset,
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5,
pos=(3,2))
+ self.sizer.AddGrowableCol(2)
# bindings
@@ -442,7 +442,6 @@
# layout
# group
self.sizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=_('Select group:')),
@@ -481,6 +480,7 @@
pos=(3, 2))
# bindings
@@ -527,7 +527,7 @@
self.OnEnterPage()
def OnExtension(self, event):
- self.extension = event.GetString()
+ self.extension = self.ext_txt.GetValue()
def OnPageChanging(self, event=None):
if event.GetDirection() and self.xygroup == '':
@@ -655,12 +655,12 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wx.EVT_CLOSE, self.parent.Cleanup)
- def OnSrcSelection(self,event):
+ def OnSrcSelection(self, event):
"""!Source map to display selected"""
global src_map
global maptype
- src_map = event.GetString()
+ src_map = self.srcselection.GetValue()
if src_map == '':
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
@@ -680,17 +680,17 @@
except:
pass
- def OnTgtRastSelection(self,event):
+ def OnTgtRastSelection(self, event):
global tgt_map
- tgt_map['raster'] = event.GetString()
+ tgt_map['raster'] = self.tgtrastselection.GetValue()
def OnTgtVectSelection(self,event):
global tgt_map
- tgt_map['vector'] = event.GetString()
+ tgt_map['vector'] = self.tgtvectselection.GetValue()
global src_map
@@ -2622,7 +2622,6 @@
# interpolation method
gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
- gridSizer.AddGrowableCol(1)
gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY, label=_('Select interpolation method:')),
pos=(0,0), flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5)
self.grmethod = wx.Choice(parent=panel, id=wx.ID_ANY,
@@ -2630,6 +2629,7 @@
gridSizer.Add(item=self.grmethod, pos=(0,1),
flag=wx.ALIGN_RIGHT, border=5)
self.grmethod.SetStringSelection(self.parent.gr_method)
+ gridSizer.AddGrowableCol(1)
sizer.Add(item=gridSizer, flag=wx.EXPAND | wx.ALL, border=5)
# clip to region
@@ -2668,9 +2668,10 @@
def OnSDFactor(self,event):
"""!New factor for RMS threshold = M + SD * factor"""
- self.sdfactor = float(event.GetString())
+ try:
+ self.sdfactor = float(self.rmsWin.GetValue())
+ except ValueError:
+ return
if self.sdfactor <= 0:
GError(parent = self,
message=_('RMS threshold factor must be > 0'))
@@ -2683,7 +2684,7 @@
global src_map
- tmp_map = event.GetString()
+ tmp_map = self.srcselection.GetValue()
if not tmp_map == '' and not tmp_map == src_map:
self.new_src_map = tmp_map
@@ -2692,17 +2693,13 @@
"""!Target map to display selected"""
global tgt_map
- self.new_tgt_map['raster'] = event.GetString()
- if self.new_tgt_map['raster'] is None:
- self.new_tgt_map['raster'] = ''
+ self.new_tgt_map['raster'] = self.tgtrastselection.GetValue()
global tgt_map
- self.new_tgt_map['vector'] = event.GetString()
- if self.new_tgt_map['vector'] is None:
- self.new_tgt_map['vector'] = ''
+ self.new_tgt_map['vector'] = self.tgtvectselection.GetValue()
def OnMethod(self, event):
self.parent.gr_method = self.methods[event.GetSelection()]
@@ -2711,7 +2708,7 @@
self.parent.clip_to_region = event.IsChecked()
- self.parent.extension = event.GetString()
+ self.parent.extension = self.ext_txt.GetValue()
def UpdateSettings(self):
global src_map
