[GRASS-SVN] r55697 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Apr 10 15:53:26 PDT 2013
Author: mmetz
Date: 2013-04-10 15:53:25 -0700 (Wed, 10 Apr 2013)
New Revision: 55697
grass/trunk/lib/vector/Vlib/ascii.c
Vlib: ascii export all features for field < 1
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2013-04-10 21:20:23 UTC (rev 55696)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2013-04-10 22:53:25 UTC (rev 55697)
@@ -362,7 +362,7 @@
xstring = ystring = zstring = NULL;
cats = NULL;
- if (where || column_names) {
+ if (field > 0 && (where || column_names)) {
Fi = Vect_get_field(Map, field);
if (!Fi) {
G_fatal_error(_("Database connection not defined for layer %d"),
@@ -513,7 +513,7 @@
found = get_cat(Cats, Clist, cats, ncats, field, &cat);
- if (!found && ltype == GV_BOUNDARY &&
+ if (!found && field > 0 && ltype == GV_BOUNDARY &&
type & GV_AREA && Vect_level(Map) > 1) {
Vect_get_line_areas(Map, line, &left, &right);
if (left < 0)
@@ -868,6 +868,9 @@
*cat = -1;
+ if (field < 1)
+ return TRUE;
if (Clist && Clist->field == field) {
for (i = 0; i < Cats->n_cats; i++) {
if (Cats->field[i] == field &&
