[GRASS-SVN] r55699 - in grass/trunk: lib/vector/Vlib vector/v.out.ascii
Thu Apr 11 02:20:15 PDT 2013
Author: martinl
Date: 2013-04-11 02:20:14 -0700 (Thu, 11 Apr 2013)
New Revision: 55699
   grass/trunk/lib/vector/Vlib/ascii.c
   grass/trunk/vector/v.out.ascii/args.c
v.out.ascii: more guisections
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c	2013-04-11 09:18:10 UTC (rev 55698)
+++ grass/trunk/lib/vector/Vlib/ascii.c	2013-04-11 09:20:14 UTC (rev 55699)
@@ -5,7 +5,7 @@
   Higher level functions for reading/writing/manipulating vectors.
-  (C) 2001-2009, 2011-2012 by the GRASS Development Team
+  (C) 2001-2009, 2011-2013 by the GRASS Development Team
   This program is free software under the GNU General Public License
   (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -284,6 +284,8 @@
   \brief Write data to GRASS ASCII vector format
+  Prints message if some features without category are skipped.
   \param[out] ascii  pointer to the output ASCII file
   \param[out] att    att file (< version 5 only)
   \param Map    pointer to Map_info structure
@@ -317,7 +319,7 @@
     size_t xsize, ysize, zsize;
     struct Cell_head window;
     struct ilist *fcats;
-    int count;
+    int count, n_skipped;
     /* where || columns */
     struct field_info *Fi;
@@ -477,7 +479,7 @@
     Vect_rewind(Map);
-    line = 0;
+    n_skipped = line = 0;
     while (TRUE) {
 	ltype = Vect_read_next_line(Map, Points, Cats);
 	if (ltype == -1 ) {      /* failure */
@@ -530,9 +532,13 @@
-	if (!found)
+	if (!found) {
+            if (Cats->n_cats < 1)
+                n_skipped++;
 	    continue;
 	if (ver < 5) {
 	    Vect_cat_get(Cats, 1, &cat);
@@ -822,6 +828,10 @@
+    if (n_skipped > 0)
+        G_important_message(_("%d features without category skipped. To export also "
+                              "features without category use '%s=-1'."), n_skipped, "layer");
     Vect_destroy_line_struct(Points);
     Vect_destroy_cats_struct(Cats);
     Vect_destroy_cats_struct(ACats);
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c	2013-04-11 09:18:10 UTC (rev 55698)
+++ grass/trunk/vector/v.out.ascii/args.c	2013-04-11 09:20:14 UTC (rev 55699)
@@ -32,7 +32,8 @@
 			  "or ASCII vector name if '-o' is defined");
     output_opt->description = _("If not given or '-' then standard output");
     output_opt->required = NO;
+    output_opt->guisection = _("Output");
     column_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
     column_opt->label = _("Name of attribute column(s) to be exported (point mode)");
     column_opt->description = _("\"*\" for all columns");
@@ -77,6 +78,7 @@
     old_flag = G_define_flag();
     old_flag->key = 'o';
     old_flag->description = _("Create old (version 4) ASCII file");
+    old_flag->guisection = _("Output");
     header_flag = G_define_flag();
     header_flag->key = 'c';
