[GRASS-SVN] r55701 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Thu Apr 11 03:17:24 PDT 2013
Author: jradinger
Date: 2013-04-11 03:17:24 -0700 (Thu, 11 Apr 2013)
New Revision: 55701
Added:
grass-addons/grass7/raster/r.fidimo/Makefile
grass-addons/grass7/raster/r.fidimo/r.fidimo.html
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
reworked version for GRASS7, code adapted
executable, depicts the basis for further deeper developement
Added: grass-addons/grass7/raster/r.fidimo/Makefile
--- grass-addons/grass7/raster/r.fidimo/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.fidimo/Makefile 2013-04-11 10:17:24 UTC (rev 55701)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.fidimo
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.fidimo/r.fidimo.html
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.html (rev 0)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.html 2013-04-11 10:17:24 UTC (rev 55701)
@@ -0,0 +1,133 @@
+<h2>NAME</h2>
+<em>r.fidimo</em> performs analysis of fish dispersal based on
+leptokurtic dispersal kernels. It calculates fish dispersal along river
+corridors based on a users stream network input, fish source populations
+and species-specific dispersal parameters.
+<h2>OPTIONS</h2>
+<h3>Stream parameters</h3>
+<dl>
+<dt><b>river</b></dt>
+<dd>Name of input stream network map (thinned raster map) on which the
+calculations of dispersal is performed. In cases of very maeandering rivers
+(with bends narrower than the spatial resolution of the analyis (cell size)
+it is recommended to run v.generalize and r.thin and/or to use
+<em>r.fidimo.river</em> in advance. The stream network should only consist
+of tree like structures, as braiding rivers and networks with two-side
+connected side arms will not work. Check the raster beforehand carefully!
+</dd>
+<dt><b>outflow_point</b></dt>
+<dd>Name of the outflow point txt-file (single point) for the calculation
+of the flow direction within the provided river network. The text-file
+must only contain a single |-separeted coordinate pair (X|Y; same
+coordinate system as the river network raster). The file should not
+contain any headings etc. E.g the content of the file can look like:
+</dd>
+</dl>
+<div class="code"><pre>
+545287.44|1942020.18
+</pre></div>
+<dl>
+<dt><b>barriers</b></dt>
+<dd>Name of input barrier text-file indicating the geographical position
+and permeabilty of barriers e.g. weirs. The file should contain the
+X and Y coordinate and a value for permeability (0-1 where 0 is
+non-permeable and 1 is 100% passable). The values must be |-separated:
+</dd>
+</dl>
+3543350.8001|6064831.9001|1
+3535061.5179|6064457.5321|0.3
+</pre></div>
+<h3>Source populations</h3>
+The source populations can be provided either as random points (flag -r),
+or as fixed source population raster (flag -f).
+<dl>
+<dt><b>n_source</b></dt>
+<dd>For the random locations; number or percentage of cells containing
+source populations. The model selects randomly cell (number specified
+by the user) and assigns a starting density of 1 to each occupied cell.
+</dd>
+<dt><b>source_populations</b></dt>
+<dd>Input raster map indicating the starting density per cell. All
+cells with densities > 0 will act as source populations for the model.
+The raster map must have the resolution as the river raster and all
+source population cells must also be part of the river raster.
+</dd>
+</dl>
+<h3>Dispersal parameters</h3>
+<dl>
+<dt><b>species</b></dt>
+<dd>Selected species with predefined L and AR (see R-package 'fishmove').
+</dd>
+<dt><b>L</b></dt>
+<dd>Length of fish which should be modelled. Increasing L is positively
+correlated with larger dispersal distances. Setting L will overwrite any
+species-settings (see R-package 'fishmove').
+</dd>
+<dt><b>AR</b></dt>
+<dd>Aspect ratio of the caudal fin of a fish which should be modelled.
+Increasing AR is positively correlated with larger dispersal distances.
+etting AR will overwrite any species-settings (see R-package 'fishmove').
+</dd>
+<dt><b>T</b></dt>
+<dd>Time interval for one modelling step. The dispersal kernel is time
+dependent and increasing T is positively correlated with larger dispersal
+istances (see R-package 'fishmove').
+</dd>
+<dt><b>p</b></dt>
+<dd>Share of the stationary component of the population. The value is
+set to 0.67 by default (my Paper).
+</dd>
+</dl>
+<h3>Output</h3>
+<dl>
+<dt><b>output</b></dt>
+<dd>The base name of the output file(s). The output raster files will
+be %output%_fit respectively %output%_lwr and %output%_upr if a
+statistical interval is set.
+</dd>
+<dt><b>statistical_interval</b></dt>
+<dd>Statistical interval (confidence or prediction) derived from the
+regression analyis (see R-package 'fishmove'). If a statistical interval
+is set, three output maps will be created (fit, lwr and upr).
+</dd>
+</dl>
+<h3>Dependencies</h3>
+<ul>
+<li>RPy2</li>
+<li>NumPy</li>
+<li>SciPy</li>
+<li>Sqlite3</li>
+<li>r.stream.order</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.stream.order.html">r.stream.order</a>,
+<a href="r.watershed.html">r.watershed</a>
+</em>
+<h2>REFERENCES</h2>
+<em>Fidimo-paper</em>
+<h2>AUTHOR</h2>
+Johannes Radinger, Leibniz-Institute of Freshwater Ecology and Inland
+Fisheries, Berlin (Germany)
+<p>
+<i>Last changed: (Mo, Sept 20, 2011)</i>
Added: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py (rev 0)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-04-11 10:17:24 UTC (rev 55701)
@@ -0,0 +1,922 @@
+#!/usr/bin/env python
+# MODULE: FIDIMO Fish Dispersal Model for River Networks for GRASS 7
+# AUTHOR(S): Johannes Radinger
+# VERSION: V0.1 Beta
+# DATE: 2013-04-11
+#%Module
+#% description: Calculating fish dispersal in a river network from source populations with species specific dispersal parameters
+#% keywords: Fish Dispersal Model
+#%End
+#%option
+#% key: river
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: River network (raster-file, e.g. output from r.stream.extract or fidimo.river)
+#% required: no
+#% guisection: Stream parameters
+#%end
+#%option
+#% key: coors
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: x,y
+#% description: River networks' outlet coordinates: E,N
+#%End
+#%option
+#% key: barriers
+#% type: string
+#% gisprompt:old,file,input
+#% description: Barrier point file
+#% required: no
+#%end
+#%Flag
+#% key: s
+#% description: Remove small river segments
+#%end
+#%option
+#% key: n_source
+#% type: string
+#% key_desc: number[%]
+#% description: Either: Number of random cells with source populations
+#% required: no
+#% guisection: Source populations
+#%end
+#%option
+#% key: source_populations
+#% type: string
+#% description: Or: Source population raster, e.g output from SDM
+#% required: no
+#%end
+#%Option
+#% key: species
+#% type: string
+#% required: no
+#% multiple: no
+#% options:Custom species,Catostomus commersoni,Moxostoma duquesnii,Moxostoma erythrurum,Ambloplites rupestris,Lepomis auritus,Lepomis cyanellus,Lepomis macrochirus,Lepomis megalotis,Micropterus dolomieui,Micropterus punctulatus,Micropterus salmoides,Pomoxis annularis,Cottus bairdii,Cottus gobio,Abramis brama,Barbus barbus,Cyprinus carpio carpio,Gobio gobio,Leuciscus idus,Rutilus rutilus,Squalius cephalus,Tinca tinca,Esox lucius,Fundulus heteroclitus heteroclitus,Ameiurus natalis,Ictalurus punctatus,Morone americana,Etheostoma flabellare,Etheostoma nigrum,Perca fluviatilis,Percina nigrofasciata,Sander lucioperca,Oncorhynchus mykiss, Oncorhynchus gilae,Salmo salar,Salmo trutta fario,Salvelinus fontinalis,Salvelinus malma malma,Thymallus thymallus,Aplodinotus grunniens,Salmo trutta,Gobio gobio,Rutilus rutilus
+#% description: Select fish species
+#% guisection: Dispersal parameters
+#%End
+#%Option
+#% key: L
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Fish Length (If no species is given)
+#% options: 39-810
+#%End
+#%Option
+#% key: AR
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Aspect Ratio of Caudal Fin (If no species is given) (valid range 0.51 - 2.29)
+#%End
+#%Option
+#% key: T
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Time interval for model step in days
+#% options: 1-3285
+#% answer: 30
+#%End
+#%option
+#% key: p
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Share of the stationary component (valid range 0 - 1)
+#% answer:0.67
+#%End
+#%Flag
+#% key: b
+#% description: Don't keep basic vector maps (source_points, barriers)
+#%end
+#%Flag
+#% key: a
+#% description: Keep all temporal vector and raster maps
+#%end
+#%Option
+#% key: truncation
+#% type: string
+#% required: no
+#% multiple: no
+#% options: 0.9,0.95,0.99,0.995,0.999,0.99999,0.999999999,inf
+#% description: kernel truncation criterion (precision)
+#% answer: 0.99
+#% guisection: Optional
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Base name for output raster
+#% guisection: Output
+#% answer: fidimo_out
+#%end
+#%Option
+#% key: statistical_interval
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Statistical Intervals
+#% options:no,Confidence Interval,Prediction Interval
+#% answer:no
+#%end
+# import required base modules
+import sys
+import os
+import atexit
+import time
+import sqlite3
+import math #for function sqrt()
+# import required grass modules
+import grass.script as grass
+import grass.script.setup as gsetup
+import grass.script.array as garray
+#import random
+# import required numpy/scipy modules
+import numpy
+from scipy import stats
+from scipy import optimize
+#import matplotlib.pyplot as plt
+#import matplotlib as mpl
+tmp_map_rast = None
+tmp_map_vect = None
+def cleanup():
+ if (tmp_map_rast or tmp_map_vect) and not flags['a']:
+ grass.run_command("g.remove",
+ rast = [f + str(os.getpid()) for f in tmp_map_rast],
+ vect = [f + str(os.getpid()) for f in tmp_map_vect],
+ quiet = True)
+def main():
+ ############ DEFINITION CLEANUP TEMPORARY FILES ##############
+ #global variables for cleanup
+ global tmp_map_rast
+ global tmp_map_vect
+ tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'shreve_tmp_', 'source_populations_scalar_', 'strahler_tmp_', 'stream_segments_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
+ tmp_map_vect = ['river_points_tmp_', 'river_vector_tmp_', 'river_vector_nocat_tmp_','source_points_']
+ if options['barriers']:
+ tmp_map_rast = tmp_map_rast + ['density_below_barrier_tmp_','distance_barrier_tmp_', 'distance_barrier_downstream_tmp_','distance_from_point_within_segment_tmp_', 'distance_upstream_point_within_segment_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_', 'upstream_density_tmp_', 'upstream_segment_tmp_']
+ tmp_map_vect = tmp_map_vect + ["barriers_",'barriers_tmp_', 'point_within_segment_tmp_']
+ ############ PARAMETER INPUT ##############
+ #Stream parameters input
+ river = options['river']
+ coors = options['coors']
+ input_barriers = options['barriers']
+ #Source population input
+ if (options['source_populations'] and options['n_source']) or (str(options['source_populations']) == '' and str(options['n_source']) == ''):
+ grass.fatal(_("Provide either fixed or random source population"))
+ n_source = options['n_source'] #number of random source points
+ source_populations = options['source_populations']
+ # multiplication value as workaround for very small FLOAT values
+ #imporatant for transformation of source population raster into point vector
+ scalar = 10**200
+ # Statistical interval
+ if (str(options['statistical_interval']) == 'Prediction Interval'):
+ interval = "prediction"
+ else:
+ interval = "confidence"
+ #Output
+ output_fidimo = options['output']
+ if (grass.find_file(name = output_fidimo+"_"+"fit", element = 'cell')['file'] and grass.read_command("g.gisenv", get = "GRASS_OVERWRITE")!=1):
+ grass.fatal(_("Output file exists already, either change output name or set overwrite-flag"))
+ ############ FISHMOVE ##############
+ # import required rpy2 module
+ import rpy2.robjects as robjects
+ from rpy2.robjects.packages import importr
+ fm = importr('fishmove')
+ #Dispersal parameter input
+ if str(options['species']!="Custom species") and (options['L'] or options['AR']):
+ grass.message(_("Species settings will be overwritten with L and AR"))
+ species = str(options['species'])
+ if options['L']:
+ L = float(options['L'])
+ if options['AR']:
+ AR = float(options['AR'])
+ T = float(options['T'])
+ # Setting Stream order to a vector of 1:9 and calculate fishmove for all streamorders at once
+ SO = robjects.IntVector((1,2,3,4,5,6,7,8,9))
+ m = 0 # m-parameter in dispersal function
+ if (float(options['p']) >= 0 and float(options['p']) < 1):
+ p =float(options['p'])
+ else:
+ grass.fatal(_("Valid range for p: 0 - 1"))
+ ##### Calculating 'fishmove' depending on species or L & AR
+ if species == "Custom species":
+ fishmove = fm.fishmove(L=L,AR=AR,SO=SO,T=T,interval=interval)
+ else:
+ fishmove = fm.fishmove(species=species,SO=SO,T=T,interval=interval)
+ # using only part of fishmove results (only regression coeffients)
+ fishmove = fishmove[1]
+ nrun = ['fit','lwr','upr']
+ ############ REGION, DB-CONNECTION ##############
+ #Setting region to extent of input River
+ grass.run_command("g.region",
+ flags = "a",
+ rast = river,
+ overwrite = True,
+ save = "region_Fidimo")
+ #Getting resultion, res=cellsize
+ res = int(grass.read_command("g.region",
+ flags = "m").strip().split('\n')[4].split('=')[1])
+ #database-connection
+ env = grass.gisenv()
+ gisdbase = env['GISDBASE']
+ location = env['LOCATION_NAME']
+ mapset = env['MAPSET']
+ grass.run_command("db.connect",
+ driver = "sqlite",
+ database = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db")
+ database = sqlite3.connect(os.path.join(gisdbase, location, mapset, 'sqlite.db'))
+ db = database.cursor()
+ ################ Preparation River Raster (Distance-Raster) ################
+ # Populate input-river (raster) with value of resolution
+ # *1.0 to get float raster instead of integer
+ grass.mapcalc("$river_raster = if($river,$res*1.0)",
+ river_raster = "river_raster_tmp_%d" % os.getpid(),
+ river = river,
+ res = res)
+ # Converting river_raster to river_vector
+ grass.run_command("r.to.vect",
+ overwrite = True,
+ input="river_raster_tmp_%d" % os.getpid(),
+ output="river_vector_tmp_%d" % os.getpid(),
+ type="line")
+ # Converting river_raster to river_point
+ overwrite = True,
+ output="river_points_tmp_%d" % os.getpid(),
+ type="point")
+ #Prepare Barriers/Snap barriers to river_vector
+ grass.run_command("v.in.ascii",
+ flags = "n",
+ overwrite = True,
+ input=input_barriers,
+ output="barriers_tmp_%d" % os.getpid(),
+ columns="x DOUBLE, y DOUBLE, clearance DOUBLE")
+ grass.run_command("v.db.addcolumn",
+ map ="barriers_tmp_%d" % os.getpid(),
+ columns="new_X DOUBLE, new_Y DOUBLE")
+ grass.run_command("v.distance",
+ overwrite = True,
+ _from="barriers_tmp_%d" % os.getpid(),
+ to="river_vector_tmp_%d" % os.getpid(),
+ upload="to_x,to_y",
+ column="new_X,new_Y")
+ grass.run_command("v.in.db",
+ overwrite = True,
+ table="barriers_tmp_%d" % os.getpid(),
+ x="new_X",
+ y="new_Y",
+ key="cat",
+ output="barriers_%d" % os.getpid())
+ map ="barriers_%d" % os.getpid(),
+ columns="dist DOUBLE, affected_barriers DOUBLE") # dist = distance of barrier to segment, affected_barriers = all barriers which are considered to be the scope of a segement
+ #Breaking river_vector at position of barriers to get segments
+ for new_X,new_Y in db.execute('SELECT new_X, new_Y FROM barriers_%d'% os.getpid()):
+ barrier_coors = str(new_X)+","+str(new_Y)
+ grass.run_command("v.edit",
+ map="river_vector_tmp_%d" % os.getpid(),
+ tool="break",
+ thresh="1,0,0",
+ coords=barrier_coors)
+ #Getting category values (ASC) for river_network segements
+ grass.run_command("v.category",
+ overwrite=True,
+ input="river_vector_tmp_%d" % os.getpid(),
+ option="del",
+ output="river_vector_nocat_tmp_%d" % os.getpid())
+ overwrite=True,
+ input="river_vector_nocat_tmp_%d" % os.getpid(),
+ option="add",
+ output="river_vector_tmp_%d" % os.getpid())
+ #Check if outflow coors are on river
+ # For GRASS7 snap coors to river. Check r.stream.snap - add on
+ #Calculation of distance from outflow and flow direction for total river
+ grass.run_command("r.cost",
+ flags = 'n',
+ overwrite = True,
+ input = "river_raster_tmp_%d" % os.getpid(),
+ output = "distance_raster_tmp_%d" % os.getpid(),
+ start_coordinates = coors)
+ grass.run_command("r.watershed",
+ flags = 'm', #depends on memory!!
+ elevation = "distance_raster_tmp_%d" % os.getpid(),
+ drainage = "flow_direction_tmp_%d" % os.getpid(),
+ stream = "stream_segments_tmp_%d" % os.getpid(),
+ threshold = "1",
+ overwrite = True)
+ #!!!! Here Problem when 1 cell river segments is in mainstem: gap in the middle of the river!
+ # Maybe solve with flag to choose either leave or remove small river sections!
+ #Removing small (1 cell) river segments and re-calculate distance raster and flow direction
+ # Why is there a problem with 1 cell river segments?
+ if flags['s']:
+ grass.mapcalc("$river_raster = if($stream_segments>=0, $river_raster, null())",
+ stream_segments = "stream_segments_tmp_%d" % os.getpid())
+ flags = 'n',
+ overwrite = True,
+ overwrite = True)
+ #Calculation of stream order (Shreve/Strahler)
+ grass.run_command("r.stream.order",
+ streams = "stream_segments_tmp_%d" % os.getpid(),
+ dirs = "flow_direction_tmp_%d" % os.getpid(),
+ shreve = "shreve_tmp_%d" % os.getpid(),
+ strahler = "strahler_tmp_%d" % os.getpid(),
+ overwrite = True)
+ ################ Preparation Source Populations ################
+ #Defining source points either as random points in river or from input raster
+ if options['n_source']:
+ grass.run_command("r.random",
+ overwrite=True,
+ n = n_source,
+ vector_output="source_points_%d" % os.getpid())
+ map = "source_points_%d" % os.getpid(),
+ columns = "prob DOUBLE")
+ # Set starting propability of occurence to 1.0*scalar for all random source_points
+ grass.write_command("db.execute", input="-",
+ stdin = 'UPDATE source_points_%d SET prob=%d' % (os.getpid(),scalar*1.0))
+ #if source population raster is provided, then use it, transform raster in vector points
+ #create an attribute column "prob" and update it with the values from the raster map
+ if options['source_populations']:
+ #Multiplying source probability with very large scalar to avoid problems
+ #with very small floating points (problem: precision of FLOAT); needs retransforamtion in the end
+ grass.mapcalc("$source_populations_scalar = $source_populations*$scalar",
+ source_populations = source_populations,
+ source_populations_scalar = "source_populations_scalar_%d" % os.getpid(),
+ scalar = scalar)
+ #Exclude source Populations that are outside the river_raster
+ grass.mapcalc("$source_populations_scalar_corrected = if($river_raster_tmp,$source_populations_scalar)",
+ source_populations_scalar_corrected = "source_populations_scalar_corrected_%d" % os.getpid(),
+ river_raster_tmp = "river_raster_tmp_%d" % os.getpid(),
+ source_populations_scalar = "source_populations_scalar_%d" % os.getpid())
+ # Convert to source population points
+ overwrite = True,
+ input = "source_populations_scalar_corrected_%d" % os.getpid(),
+ output = "source_points_%d" % os.getpid(),
+ type = "point")
+ #populate sample prob from input prob-raster (multiplied by scalar)
+ grass.run_command("v.what.rast",
+ raster = "source_populations_scalar_%d" % os.getpid(),
+ column = "prob")
+ #Adding columns and coordinates to source points
+ columns = "X DOUBLE, Y DOUBLE, Segment INT, Strahler INT")
+ grass.run_command("v.to.db",
+ type = "point",
+ option = "coor",
+ columns = "X,Y")
+ #Convert river from vector to raster format and get cat-value
+ grass.run_command("v.to.rast",
+ input = "river_vector_tmp_%d" % os.getpid(),
+ overwrite = True,
+ output = "river_raster_cat_tmp_%d" % os.getpid(),
+ use = "cat")
+ #Adding information of segment to source points
+ raster = "river_raster_cat_tmp_%d" % os.getpid(),
+ column = "Segment")
+ #Adding information of Strahler stream order to source points
+ raster = "strahler_tmp_%d" % os.getpid(),
+ column = "Strahler")
+ ########### Looping over nrun, over segements, over source points ##########
+ if str(options['statistical_interval']) == "no":
+ nrun = ['fit']
+ else:
+ for i in nrun:
+ #update database-connection
+ mapcalc_list_B = []
+ # Loop over Segments
+ for Segment in sorted(list(set(db.execute('SELECT Segment FROM source_points_%d ORDER BY Segment ASC' % os.getpid())))):
+ grass.debug(_("This is segment nr.: " +str(Segment)))
+ segment_cat = str(Segment[0])
+ mapcalc_list_A = []
+ # Loop over Source points
+ source_points_loop = db.execute('SELECT cat, X, Y, prob, Strahler FROM source_points_%d WHERE Segment=?' % os.getpid(), (str(Segment[0]),))
+ for cat,X,Y,prob,Strahler in source_points_loop:
+ grass.debug(_("Start looping over source points"))
+ coors = str(X)+","+str(Y)
+ grass.debug(_("Source point coors:"+coors+" in segment nr: " +str(Segment)))
+ #Select dispersal parameters
+ SO = 'SO='+str(Strahler)
+ grass.debug(_("This is i:"+str(i)))
+ grass.debug(_("This is "+str(SO)))
+ sigma_stat = fishmove.rx(i,'sigma_stat',1,1,SO,1)
+ sigma_mob = fishmove.rx(i,'sigma_mob',1,1,SO,1)
+ # Getting maximum distance (cutting distance) based on truncation criterion
+ def func(x,sigma_stat,sigma_mob,m,truncation,p):
+ return p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob) - truncation
+ if options['truncation'] == "inf":
+ max_dist = 0
+ else:
+ truncation = float(options['truncation'])
+ max_dist = int(optimize.zeros.newton(func, 1., args=(sigma_stat,sigma_mob,m,truncation,p)))
+ grass.debug(_("Distance from each source point is calculated up to a treshold of: "+str(max_dist)))
+ flags = 'n',
+ overwrite = True,
+ output = "distance_from_point_tmp_%d" % os.getpid(),
+ start_coordinates = coors,
+ max_cost = max_dist)
+ # Getting upper and lower distance (cell boundaries) based on the fact that there are different flow lenghts through a cell depending on the direction (diagonal-orthogonal)
+ grass.mapcalc("$upper_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point+($ds/2.0), $distance_from_point+($dd/2.0))",
+ upper_distance = "upper_distance_tmp_%d" % os.getpid(),
+ flow_direction = "flow_direction_tmp_%d" % os.getpid(),
+ distance_from_point = "distance_from_point_tmp_%d" % os.getpid(),
+ ds = res,
+ dd = math.sqrt(2)*res,
+ overwrite = True)
+ grass.mapcalc("$lower_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point-($ds/2.0), $distance_from_point-($dd/2.0))",
+ lower_distance = "lower_distance_tmp_%d" % os.getpid(),
+ ds = res,
+ overwrite = True)
+ # MAIN PART: leptokurtic probability density kernel based on fishmove
+ grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
+ grass.debug(_("Dispersal parameters: prob="+str(prob)+", sigma_stat="+str(sigma_stat)+", sigma_mob="+str(sigma_mob)+", p="+str(p)))
+ def cdf(x):
+ return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob
+ #Calculation Kernel Density from Distance Raster
+ #only for m=0 because of cdf-function
+ if grass.find_file(name = "density_from_point_unmasked_tmp_%d" % os.getpid(), element = 'cell')['file']:
+ grass.run_command("g.remove", rast = "density_from_point_unmasked_tmp_%d" % os.getpid())
+ x1 = garray.array()
+ x1.read("lower_distance_tmp_%d" % os.getpid())
+ x2 = garray.array()
+ x2.read("upper_distance_tmp_%d" % os.getpid())
+ Density = garray.array()
+ Density[...] = cdf(x2) - cdf(x1)
+ grass.debug(_("Write density from point to garray. unmasked"))
+ Density.write("density_from_point_unmasked_tmp_%d" % os.getpid())
+ # Mask density output because Density.write doesn't provide nulls()
+ grass.mapcalc("$density_from_point = if($distance_from_point>=0, $density_from_point_unmasked, null())",
+ density_from_point = "density_from_point_tmp_%d" % os.getpid(),
+ density_from_point_unmasked = "density_from_point_unmasked_tmp_%d" % os.getpid(),
+ overwrite = True)
+ # Defining up and downstream of source point
+ grass.debug(_("Defining up and downstream of source point"))
+ # Defining area upstream source point
+ grass.run_command("r.stream.basins",
+ overwrite = True,
+ coors = coors,
+ basins = "upstream_part_tmp_%d" % os.getpid())
+ # Defining area downstream source point
+ grass.run_command("r.drain",
+ input = "distance_raster_tmp_%d" % os.getpid(),
+ output = "downstream_drain_tmp_%d" % os.getpid(),
+ overwrite = True,
+ # Applying upstream split at network nodes based on inverse shreve stream order
+ grass.debug(_("Applying upstream split at network nodes based on inverse shreve stream order"))
+ grass.mapcalc("$upstream_shreve = if($upstream_part, $shreve)",
+ upstream_shreve = "upstream_shreve_tmp_%d" % os.getpid(),
+ upstream_part = "upstream_part_tmp_%d" % os.getpid(),
+ overwrite = True)
+ max_shreve = grass.raster_info("upstream_shreve_tmp_%d" % os.getpid())['max']
+ grass.mapcalc("$rel_upstream_shreve = $upstream_shreve / $max_shreve",
+ rel_upstream_shreve = "rel_upstream_shreve_tmp_%d" % os.getpid(),
+ max_shreve = max_shreve,
+ overwrite = True)
+ grass.mapcalc("$division_overlay = if(isnull($downstream_drain), $rel_upstream_shreve, $downstream_drain)",
+ division_overlay = "division_overlay_tmp_%d" % os.getpid(),
+ downstream_drain = "downstream_drain_tmp_%d" % os.getpid(),
+ overwrite = True)
+ grass.mapcalc("$density = if($density_from_point, $density_from_point*$division_overlay, null())",
+ density = "density_"+str(cat),
+ overwrite = True)
+ grass.run_command("r.null", map="density_"+str(cat), null="0")
+ mapcalc_list_A.append("density_"+str(cat))
+ mapcalc_string_A1 = "+".join(mapcalc_list_A)
+ mapcalc_string_A2 = ",".join(mapcalc_list_A)
+ grass.mapcalc("$density_segment = $mapcalc_string_A1",
+ density_segment = "density_segment_"+segment_cat,
+ mapcalc_string_A1 = mapcalc_string_A1,
+ overwrite = True)
+ grass.run_command("r.null", map="density_segment_"+segment_cat, setnull="0") # Final density map per segment without barriers
+ grass.run_command("g.remove", rast = mapcalc_string_A2, flags ="f")
+ ################### Barriers ########################
+ grass.run_command("r.mask",
+ flags="o",
+ input = "river_raster_cat_tmp_%d" % os.getpid(),
+ maskcats = segment_cat)
+ #Create one single random point within analyzed segment
+ overwrite=True,
+ n = 1,
+ cover="MASK",
+ vector_output="point_within_segment_tmp_%d" % os.getpid())
+ #Important to remove mask after calculation
+ grass.run_command("g.remove", rast = "MASK")
+ # Getting pseudo-flowdirection for defining upstream area
+ overwrite = True,
+ points = "point_within_segment_tmp_%d" % os.getpid(),
+ basins = "upstream_segment_tmp_%d" % os.getpid())
+ #Defining area upstream analyzed segment
+ flags = 'n',
+ overwrite = True,
+ output = "distance_from_point_within_segment_tmp_%d" % os.getpid(),
+ start_points = "point_within_segment_tmp_%d" % os.getpid())
+ #Remove "point within segment"
+ grass.run_command("g.remove", vect = "point_within_segment_tmp_%d" % os.getpid())
+ grass.mapcalc("$distance_upstream_point_within_segment = if($upstream_segment, $distance_from_point_within_segment, null())",
+ distance_upstream_point_within_segment = "distance_upstream_point_within_segment_tmp_%d" % os.getpid(),
+ upstream_segment ="upstream_segment_tmp_%d" % os.getpid(),
+ distance_from_point_within_segment = "distance_from_point_within_segment_tmp_%d" % os.getpid(),
+ overwrite = True)
+ #Getting distance of barriers from segment and information if barrier is involved/affected
+ map = "barriers_%d" % os.getpid(),
+ raster = "distance_upstream_point_within_segment_tmp_%d" % os.getpid(),
+ column = "dist")
+ raster = "density_segment_"+segment_cat,
+ column = "affected_barriers")
+ #To find out if a loop over the affected barriers is the last loop (find the upstream most barrier)
+ db.execute('SELECT MAX(dist) FROM barriers_%d WHERE affected_barriers > 0 AND dist > 0 ORDER BY dist' % os.getpid())
+ last_barrier = db.fetchone()[0]
+ # Loop over the affected barriers (from most downstream barrier to most upstream barrier)
+ # Initally affected = all barriers where density > 0
+ for cat,X,Y,dist,clearance in db.execute('SELECT cat, X, Y, dist, clearance FROM barriers_%d WHERE affected_barriers > 0 AND dist > 0 ORDER BY dist' % os.getpid()):
+ coors_barriers = str(X)+","+str(Y)
+ grass.debug(_("Starting with corrections for barriers"))
+ #Defining upstream the barrier
+ overwrite = True,
+ coors = coors_barriers,
+ basins = "upstream_barrier_tmp_%d" % os.getpid())
+ #Getting density upstream barrier only
+ grass.mapcalc("$upstream_density = if($upstream_barrier, $density_segment, null())",
+ upstream_density = "upstream_density_tmp_%d" % os.getpid(),
+ upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
+ overwrite = True)
+ #Getting sum of upstream density and density to relocate downstream
+ d = {'n':5, 'min': 6, 'max': 7, 'mean': 9, 'sum': 14, 'median':16, 'range':8}
+ univar = grass.read_command("r.univar", map = "upstream_density_tmp_%d" % os.getpid(), flags = 'e')
+ if univar:
+ upstream_density = float(univar.split('\n')[d['sum']].split(':')[1])
+ else:
+ grass.fatal(_("Error with upstream density/barriers. The error is for coors_barriers (X,Y): "+coors_barriers))
+ density_for_downstream = upstream_density*(1-clearance)
+ # barrier_effect = Length of Effect of barriers (linear decrease up to max (barrier_effect)
+ barrier_effect=200 #units as in mapset (m)
+ # Calculating distance from barriers (up- and downstream)
+ overwrite = True,
+ output = "distance_barrier_tmp_%d" % os.getpid(),
+ start_coordinates = coors_barriers,
+ max_cost=barrier_effect)
+ # Getting distance map for downstream of barrier only
+ grass.mapcalc("$distance_barrier_downstream = if(isnull($upstream_barrier) && $distance_barrier < $barrier_effect, $distance_barrier, null())",
+ distance_barrier_downstream = "distance_barrier_downstream_tmp_%d" % os.getpid(),
+ distance_barrier = "distance_barrier_tmp_%d" % os.getpid(),
+ barrier_effect = barrier_effect,
+ overwrite = True)
+ # Getting parameters for distance weighted relocation of densities below the barrier (linear decrease)
+ univar = grass.read_command("r.univar", map = "distance_barrier_downstream_tmp_%d" % os.getpid(), flags = 'e')
+ sum_distance_downstream_barrier = float(univar.split('\n')[d['sum']].split(':')[1])
+ number_distance_downstream_barrier = float(univar.split('\n')[d['n']].split(':')[1])
+ max_distance_downstream_barrier = float(univar.split('\n')[d['max']].split(':')[1])
+ a = density_for_downstream/(number_distance_downstream_barrier-sum_distance_downstream_barrier/max_distance_downstream_barrier)
+ #Remove any old density_below_barrier map
+ grass.run_command("g.remove", rast = "density_below_barrier_tmp_%d" % os.getpid())
+ #Calculation Kernel Density downstream the barrier
+ grass.mapcalc("$density_below_barrier = $a-($a/$distance_max)*$distance_barrier_downstream",
+ density_below_barrier = "density_below_barrier_tmp_%d" % os.getpid(),
+ a = a,
+ distance_max = max_distance_downstream_barrier,
+ overwrite = True)
+ # Combination upstream and downstream density from barrier
+ grass.run_command("r.null", map="density_segment_"+str(Segment[0]), null="0")
+ grass.run_command("r.null", map="density_below_barrier_tmp_%d" % os.getpid(), null="0")
+ grass.mapcalc("$density_segment = if(isnull($upstream_barrier), $density_below_barrier+$density_segment, $upstream_density*$clearance)",
+ density_segment = "density_segment_"+str(Segment[0]),
+ clearance=clearance,
+ overwrite = True)
+ if dist == last_barrier :
+ grass.run_command("r.null", map="density_segment_"+segment_cat, null="0")
+ else:
+ #If the barrier in the loop was impermeable (clearance=0)
+ #than no more upstream barriers need to be considered --> break
+ if clearance == 0:
+ break
+ grass.run_command("r.null", map="density_segment_"+segment_cat, null="0") # Final density map per segment
+ mapcalc_list_B.append("density_segment_"+segment_cat)
+ mapcalc_string_B1 = "+".join(mapcalc_list_B)
+ mapcalc_string_B2 = ",".join(mapcalc_list_B)
+ # Final raster map, Final map is sum of all
+ # density maps (for each segement), All contirbuting maps (string_B2) are deleted
+ # in the end.
+ grass.mapcalc("$density_final = $mapcalc_string_B1",
+ density_final = "density_final_%d" % os.getpid(),
+ mapcalc_string_B1 = mapcalc_string_B1,
+ overwrite = True)
+ # backtransformation (divide by scalar which was defined before)
+ grass.mapcalc("$density_final_corrected = $density_final/$scalar",
+ density_final_corrected = "density_final_corrected_%d" % os.getpid(),
+ scalar = scalar)
+ grass.run_command("g.copy",
+ rast = "density_final_corrected_%d" % os.getpid() + "," + output_fidimo+"_"+i)
+ # Set all 0-values to NULL, Backgroundvalues
+ grass.run_command("r.null", map=output_fidimo+"_"+i, setnull="0")
+ grass.run_command("g.remove", rast = mapcalc_string_B2, flags ="f")
+ # Make source_points and barriers permanent
+ vect = "source_points_%d" % os.getpid() + "," + output + "_source_points")
+ vect = "barriers_%d" % os.getpid() + "," + output + "_barriers")
+ if flags['b']:
+ grass.run_command("g.remove", vect = output + "_source_points", flags ="f")
+ grass.run_command("g.remove", vect = output + "_barriers", flags ="f")
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
___________________________________________________________________
Added: svn:executable
