[GRASS-SVN] r55703 - grass-addons/grass6/raster/r.pastro
svn_grass at osgeo.org
Thu Apr 11 07:40:12 PDT 2013
Author: robertomarzocchi
Date: 2013-04-11 07:40:11 -0700 (Thu, 11 Apr 2013)
New Revision: 55703
Added:
grass-addons/grass6/raster/r.pastro/digit_input.sh
grass-addons/grass6/raster/r.pastro/distanze.f90
grass-addons/grass6/raster/r.pastro/grafico.p
grass-addons/grass6/raster/r.pastro/install_r_pastro.sh
grass-addons/grass6/raster/r.pastro/path_profile.py
grass-addons/grass6/raster/r.pastro/path_profile.sh
grass-addons/grass6/raster/r.pastro/pathgar.sh
grass-addons/grass6/raster/r.pastro/point2path.sh
grass-addons/grass6/raster/r.pastro/point2point.sh
grass-addons/grass6/raster/r.pastro/profilo.f90
grass-addons/grass6/raster/r.pastro/r.pastro
grass-addons/grass6/raster/r.pastro/readme.txt
grass-addons/grass6/raster/r.pastro/region_layout.sh
grass-addons/grass6/raster/r.pastro/region_layout2.sh
grass-addons/grass6/raster/r.pastro/region_zoom.sh
grass-addons/grass6/raster/r.pastro/sheltgar.sh
grass-addons/grass6/raster/r.pastro/space2tab.py
grass-addons/grass6/raster/r.pastro/stragfinder.sh
grass-addons/grass6/raster/r.pastro/uninstall_r_pastro.sh
grass-addons/grass6/raster/r.pastro/velocity.py
pastro codes
Added: grass-addons/grass6/raster/r.pastro/digit_input.sh
--- grass-addons/grass6/raster/r.pastro/digit_input.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/digit_input.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,48 @@
+#!/bin/bash
+# MODULE: "digit_input.sh" per GRASS 6.4 (GRASS Shell Script)
+# AUTHOR: roberto marzocchi(roberto.marzocchi at gmail.com)
+# PURPOSE:
+# Il presente modulo viene solitamente lanciato dallo script pastro.sh.
+# This program is free software under the GNU General Public License (>=v2).
+# Read the file COPYING that comes with GRASS for details.
+d.mon stop=x4 --quiet
+d.mon start=x4
+if (check_image=1); then
+ #v.digit -n map=$input bgcmd="d.shadedmap reliefmap=temp_shade drapemap=$dtm;d.vect map=$paths display=shape type=line layer=1 color=red fcolor=255:255:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c;d.vect map=$shelters display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c"
+ d.shadedmap reliefmap=temp_shade drapemap=$dtm
+ d.vect map=$paths display=shape type=line layer=1 color=red fcolor=255:255:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ #if [! -z $shelters]
+ d.vect map=$shelters display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ #fi
+else
+ #v.digit -n map=$input bgcmd="d.rast map=$image;d.vect map=$paths display=shape type=line layer=1 color=red fcolor=255:255:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c;d.vect map=$shelters display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c"
+ d.rast map=$image
+ #fi
+fi
+g.message -i "*******************************************************"
+g.message -i "....Digita un punto con il tasto sinistro del mouse...."
+g.message -i "...............Con il sinistro esci...................."
+g.message -i "_______________________________________________________"
+d.where --quiet >.tmp_coord.txt
+space2tab.py
+# sed 's/^[ \t]*//;s/[ \t]*$//;s/ /|/' .tmp_coord.txt > tmp_coord2.txt
+v.in.ascii input=tmp_coord2.txt output=digitato fs="|" x=1 y=2 --overwrite --quiet
+rm .tmp_coord.txt
+rm tmp_coord2.txt
+d.mon stop=x4
+exit 1
Added: grass-addons/grass6/raster/r.pastro/distanze.f90
--- grass-addons/grass6/raster/r.pastro/distanze.f90 (rev 0)
+++ grass-addons/grass6/raster/r.pastro/distanze.f90 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,59 @@
+program distanze
+implicit none
+integer::i,j,k
+real::a,dist
+real(kind=8),allocatable::prof(:,:),plot(:,:)
+open(10,FILE='./per_plot2',STATUS='OLD')
+open(11,FILE='./per_plot3',STATUS='OLD')
+open(12,FILE='./info_sentiero',STATUS='OLD')
+!open(13,FILE='./sentiero.txt',STATUS='OLD')
+k=0
+do
+ read(10,*,end=100)a
+ k=k+1
+end do
+100 allocate(prof(k,4))
+allocate(plot(k,4))
+rewind(10)
+do i=1,k
+ read(10,*)(prof(i,j),j=1,4)
+end do
+do i=1,k
+ plot(i,2)=prof(i,3)
+end do
+plot(1,1)=0
+do i=2,k
+ dist=sqrt((prof(i,1)-prof(i-1,1))**2+(prof(i,2)-prof(i-1,2))**2)
+ plot(i,1)=plot(i-1,1)+dist
+ plot(i,3)=(plot(i,2)-plot(i-1,2))/dist
+ ! colonna dove calcolo la velocita in km/h (aggiunta roberto, da mettere in python)
+ !plot(i,4)=3.6*dist/(prof(i,4)-prof(i-1,4))
+end do
+!file per grafico
+do i=1,k
+ write(11,*)(plot(i,j),j=1,2)
+end do
+!file per re-importazione in GRASSS con le velocita'
+!do i=1,k
+! write(13,*)prof(i,1),prof(i,2),prof(i,3),plot(i,4)
+!end do
+! preparazione di un file informativo di output
+write(12,*)
+write(12,*)'---------------------------------------------'
+write(12,*)
+write(12,'(A17,I5,A14)')' Tempo stimato: ',int(prof(k,4)/60),' minuti circa.'
+write(12,*)
+write(12,'(A22,F5.1,A9)')' Lunghezza percorso: ',plot(k,1)/1000,' km circa.'
+write(12,*)
+write(12,'(A20,I4,A7)')' Pendenza massima: ',int(max(abs(maxval(plot(:,3))),abs(minval(plot(:,3))))*100),'% circa.'
+write(12,*)
+write(12,*)
+close(12)
+end
Added: grass-addons/grass6/raster/r.pastro/grafico.p
--- grass-addons/grass6/raster/r.pastro/grafico.p (rev 0)
+++ grass-addons/grass6/raster/r.pastro/grafico.p 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,8 @@
+set grid
+set xlabel 'distanza'
+set ylabel 'H'
+set style line 2 lt 2 lw 2
+set terminal gif notransparent size 1200,300
+set nokey
+set output 'immagini/profilo_altimetrico.gif'
+plot 'per_plot3' using 1:2 with line ls 2
Added: grass-addons/grass6/raster/r.pastro/install_r_pastro.sh
--- grass-addons/grass6/raster/r.pastro/install_r_pastro.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/install_r_pastro.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,72 @@
+#!/bin/bash
+# MODULE: script to install "P.A.S.T.R.O." on GRASS 6.4 (GRASS Shell Script)
+# AUTHOR: Andrea Cervetto (cervoz at hotmail.com)
+# Damiano Natali (damiano.natali at gmail.com)
+# Tiziano Cosso (tiziano.cosso at gter.it)
+# Roberto Marzocchi (roberto.marzocchi at gmail.com)
+# PURPOSE: Utility di calcolo dell'accessibilità in ambito montano
+# COPYRIGHT: This program is free software under the
+# GNU General Public License (>=v2).
+if [ -z "$GISBASE" ]
+then
+ echo ""
+ echo "You must be in GRASS GIS to run this program"
+ echo ""
+ exit 1
+fi
+if [ -d "$GISBASE/etc/fortran_code" ]
+then
+ echo "The directory $GISBASE/etc/fortran_code already exists'"
+else
+ echo "The directory $GISBASE/etc/fortran_code do not yet exists. Created!"
+ mkdir "$GISBASE/etc"/fortran_code
+fi
+#compilo i codici fortan e li copio nella cartella opportuna
+gfortran-4.6 -o profilo_pastro profilo.f90
+gfortran-4.6 -o distanze_pastro distanze.f90
+sudo cp profilo_pastro "$GISBASE/etc/fortran_code"
+sudo cp distanze_pastro "$GISBASE/etc/fortran_code"
+rm profilo_pastro
+rm distanze_pastro
+#copio i vari scripts nella cartella degli scripts GRASS
+sudo cp r.pastro "$GISBASE/scripts"
+sudo cp sheltgar.sh "$GISBASE/scripts"
+sudo cp pathgar.sh "$GISBASE/scripts"
+sudo cp stragfinder.sh "$GISBASE/scripts"
+sudo cp point2point.sh "$GISBASE/scripts"
+sudo cp point2path.sh "$GISBASE/scripts"
+sudo cp path_profile.sh "$GISBASE/scripts"
+sudo cp region_layout.sh "$GISBASE/scripts"
+sudo cp region_zoom.sh "$GISBASE/scripts"
+sudo cp digit_input.sh "$GISBASE/scripts"
+sudo cp grafico.p "$GISBASE/scripts"
+sudo cp space2tab.py "$GISBASE/scripts"
+sudo cp velocity.py "$GISBASE/scripts"
+sudo chmod 777 "$GISBASE/scripts"/r.pastro
+sudo chmod 777 "$GISBASE/scripts"/sheltgar.sh
+sudo chmod 777 "$GISBASE/scripts"/pathgar.sh
+sudo chmod 777 "$GISBASE/scripts"/stragfinder.sh
+sudo chmod 777 "$GISBASE/scripts"/point2point.sh
+sudo chmod 777 "$GISBASE/scripts"/point2path.sh
+sudo chmod 777 "$GISBASE/scripts"/path_profile.sh
+sudo chmod 777 "$GISBASE/scripts"/region_layout.sh
+sudo chmod 777 "$GISBASE/scripts"/region_zoom.sh
+sudo chmod 777 "$GISBASE/scripts"/digit_input.sh
+sudo chmod 777 "$GISBASE/scripts"/grafico.p
+sudo chmod 777 "$GISBASE/scripts"/space2tab.py
+sudo chmod 777 "$GISBASE/scripts"/velocity.py
Added: grass-addons/grass6/raster/r.pastro/path_profile.py
--- grass-addons/grass6/raster/r.pastro/path_profile.py (rev 0)
+++ grass-addons/grass6/raster/r.pastro/path_profile.py 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,179 @@
+#!/usr/bin/env python
+# MODULE: path_profile.py
+# AUTHOR(S): Damiano Natali (damiano.natali at gmail.com) #
+# Converted to Python by Roberto Marzocchi
+# PURPOSE: Script che fornisce l'immagine del profilo altimetrico di un PERCORSO di tracciato
+# COPYRIGHT: (C) 2011 GTER
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# librerie chiamate da python
+import sys
+import os
+import string
+import time
+import shutil,re,glob
+import grass.script as grass
+space = re.compile(r'\s+')
+multiSpace = re.compile(r"\s\s+")
+# gli passo le variabili d'ambiente che attualmente sono definite da script di shell e non da script python!!! sara' da cambiare nella conversione definitiva a python!!!
+dtm=os.getenv('dtm')
+folder=os.getenv('folder')
+processid = "%.7f" % time.time()
+def main():
+ #r.mapcalc "tmp_profilo_dtm=if(!isnull(tmp_drainout),$dtm,null())"
+ grass.mapcalc("${out} = if(!isnull(${rast1}),${rast2},null())",
+ out = tmp_profilo_dtm,
+ rast1 = dtm,
+ rast2 = tmp_walkout)
+ #r.mapcalc "tmp_profilo_costo=if(!isnull(tmp_drainout),tmp_walkout,null())"
+ out = tmp_profilo_costo,
+ rast1 = tmp_drainout,
+ #r.mapcalc "tmp_profilo_costo_min=if(!isnull(tmp_drainout),int(tmp_walkout_min),null())"
+ out = tmp_profilo_costo_min,
+ rast2 = tmp_walkout_min)
+ grass.run_command('r.thin', input = tmp_profilo_costo_min, output=tmp_thinout2, iterations=200 , overwrite = True, quiet = True)
+ grass.run_command('r.to.vect', flags='sv' ,input=tmp_thinout2, output = prova_sentiero_costo, feature = line, verwrite = True, quiet = True)
+ grass.run_command('g.remove', rast=tmp_thinout2, quiet = True)
+ profilo_dtm=processid + "_profilo_dtm"
+ costo_profilo=processid + "_costo_profilo"
+ grass.run_command('r.out.xyz', input=tmp_profilo_dtm, output=folder/profilo_dtm, fs=" ", quiet = True)
+ grass.run_command('r.out.xyz', input=tmp_profilo_costo, output=folder/costo_profilo, fs=" ", quiet = True)
+ E=[]
+ N=[]
+ h=[]
+ costo=[]
+ for riga in file("profilo_dtm"):
+ #print riga
+ line = riga
+ a = space.split(line.strip())
+ # print a
+ E.append(float(a[0]))
+ N.append(float(a[1]))
+ h.append(float(a[2]))
+ for riga in file("costo_profilo"):
+ #print riga
+ line = riga
+ # print a
+ costo.append(float(a[2]))
+ zipped=zip(costo,E,N,h)
+ zipped2=sorted(zipped, key=lambda zipped:zipped[0]) # sort by costo
+ costo1, E1, N1, h1 = zip(*zipped2)
+ # distanza tra i punti del profilo
+ dist=[]
+ dist_or=[]
+ dist_progr=[]
+ pendenza=[]
+ from math import sqrt
+ i=0
+ while i<len(E):
+ if i==0:
+ dist.append(0.0)
+ dist_progr.append(0.0)
+ dist_or.append(0.0)
+ pendenza.append(0.0)
+ i+=1
+ # print dist_progr
+ else:
+ dist.append( sqrt( (E1[i]-E1[i-1])**2+ (N1[i]-N1[i-1])**2 + (h1[i]-h1[i-1])**2 ) )
+ dist_or.append( sqrt( (E1[i]-E1[i-1])**2+ (N1[i]-N1[i-1])**2 ) )
+ dist_progr.append(dist_progr[i-1] + dist[i])
+ pendenza.append( (h1[i]-h1[i-1])/dist_or[i] )
+ #print h1[1]
+ #print i,h1[i],h1[i-1],dist_or[i],pendenza[i]
+ if i==(len(E)-1):
+ dist_finale=dist_progr/1000.0 #distanza in km
+ i+=1
+ profilo_grafico=processid + "_profilo_grafico"
+ miofile = open(profilo_grafico,'w')
+ k=0
+ while k<len(E):
+ miofile.write("%.2f %.2f %.2f\n" % (round(dist_progr[k],2),round(h1[k],2),round(pendenza[k],2)))
+ #miofile.write("%.2f %.2f %.2f %.2f %.2f\n" % (round(dist[k],2),round(dist_progr[k],2),round(dist_or[k],2),round(h[k],2),round(pendenza[k],2)))
+ k+=1
+ miofile.close()
+ # cerco la massima pendenza (secondo me non e' il massimo--> discutere con tiziano)
+ pend= max(pendenza)*100
+ #export grafico profilo
+ grafico.gp=processid + "grafico.gp"
+ miofile2 = open(grafico.gp,'w')
+ miofile2.write("set grid\n")
+ miofile2.write("set xlabel 'distanza'\n")
+ miofile2.write("set ylabel 'H'\n")
+ miofile2.write("set style line 2 lt 2 lw 2\n")
+ miofile2.write("set terminal gif notransparent size 1200,300\n")
+ miofile2.write("set nokey\n")
+ miofile2.write("set output 'profilo_altimetrico.gif'\n")
+ miofile2.write("plot '%s_profilo_grafico' using 1:2 with line ls 2\n" % processid)
+ os.getenv('gnuplot' 'miofile') ###check
+ # info sentiero
+ # export xml file con le informanzioni sul sentiero profilo
+ # output informativo
+ grass.message("*****************************************************************")
+ grass.message("* CARATTERISTICHE DEL SENTIERO TROVATO *")
+ grass.message("* *")
+ grass.message("* Tempo stimato: %d minuti circa *"%(M))
+ grass.message("* Lunghezza percorso:%.1f km circa *"%dist_finale)
+ grass.message("* Pendenza massima: %.0f%% circa *"%pend)
+ miofile3 = open(info_sentiero.xml,'w')
+ miofile3.write("<documentbody>\n")
+ miofile3.write("*****************************************************************\n")
+ miofile3.write("* CARATTERISTICHE DEL SENTIERO TROVATO *\n")
+ miofile3.write("* *\n")
+ miofile3.write("* Tempo stimato: %d minuti circa *\n"%(M))
+ miofile3.write("* Lunghezza percorso:%.1f km circa *\n"%dist_finale)
+ miofile3.write("* Pendenza massima: %.0f%% circa *\n"%pend)
+ miofile3.write("</documentbody>")
+ # write cmd history:
+ #grass.raster_history(output)
Added: grass-addons/grass6/raster/r.pastro/path_profile.sh
--- grass-addons/grass6/raster/r.pastro/path_profile.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/path_profile.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,87 @@
+#!/bin/bash
+# MODULE: "PATH_PROFILE SH" per GRASS 6.4 (GRASS Shell Script) #
+# AUTHOR: Damiano Natali (damiano.natali at gmail.com) #
+# Roberto Marzocchi (roberto.marzocchi at gmail.com) #
+# PURPOSE: Script che fornisce l'immagine del profilo altimetrico di un PERCORSO di tracciato #
+# vettoriale imposto dall'utente #
+# This program is free software under the GNU General Public License (>=v2). #
+# Read the file COPYING that comes with GRASS for details. #
+# ritagliamo il dtm e la mappa di costo sul PERCORSO del sentiero
+#echo 'profilo_dtm=if(!isnull(drainout),dtm10,null())' | r.mapcalc
+#echo 'profilo_costo=if(!isnull(drainout),walkout,null())' | r.mapcalc
+r.mapcalc "tmp_profilo_dtm=if(!isnull(tmp_drainout),$dtm,null())"
+r.mapcalc "tmp_profilo_costo=if(!isnull(tmp_drainout),tmp_walkout,null())"
+r.mapcalc "tmp_profilo_costo_min=if(!isnull(tmp_drainout),int(tmp_walkout_min),null())"
+#r.thin input=tmp_profilo_costo_min output=tmp_thinout2 iterations=200 --overwrite --quiet
+#r.to.vect -s -v input=tmp_thinout2 output=prova_sentiero_costo feature=line --overwrite --quiet
+#g.remove rast=tmp_thinout2
+#v.out.ogr format=GML type=line input=prova_sentiero_costo dsn=$folder/costo.gml --quiet
+#g.remove vect=prova_sentiero_costo
+pref=`mcookie` # magic cookie di 32-caratteri.
+# esportiamo il profilo altimetrico e di costo lungo il sentiero
+#g.region res=$res_calcolo
+r.out.xyz input=tmp_profilo_dtm output=$folder/profilo_dtm fs="|" --quiet
+r.out.xyz input=tmp_profilo_costo output=$folder/costo_profilo fs="|" --quiet
+#g.region -a res=$res_calcolo
+# prendiamo solamente la parte di file che ci interessa, ovvero la colonna col valore dei raster
+cat $folder/profilo_dtm | cut -d '|' -f 1 > $folder/profilo_N
+cat $folder/profilo_dtm | cut -d '|' -f 2 > $folder/profilo_E
+cat $folder/profilo_dtm | cut -d '|' -f 3 > $folder/profilo_h
+cat $folder/costo_profilo | cut -d '|' -f 3 > $folder/profilo_costo
+# troviamo il punto più alto del PERCORSO (secondo me non lo fa?????)
+# uniamo i due file in uno unico che abbini l'informazione altimetrica a quella di costo, attraverso un eseguibile in fortran compilato con gfortran e ordiniamolo in base al costo
+# unisco i files di output e creo un file con 4 colonne (N,E,h,costo)
+# quando si installa il file si compilano i files fortran con la seguente sintassi...
+# volendo si potrebbero riscrivere in python ?? che non ha il problema della compilazione ed è anche piu multipiattaforma..
+# gfortran -o profilo_pastro profilo.f90
+# gfortran -o distanze_pastro distanze.f90
+cp "$GISBASE/etc/fortran_code"/profilo_pastro "$folder"
+cp "$GISBASE/etc/fortran_code"/distanze_pastro "$folder"
+cp "$GISBASE/scripts"/grafico.p "$folder"
+cd $folder
+touch per_plot
+./profilo_pastro
+#ordino il file in funzione del costo
+sort -n -k 4,4 per_plot > per_plot2
+touch per_plot3
+touch info_sentiero
+touch sentiero.txt
+./distanze_pastro
+# output informativo
+g.message -i "*****************************************************************"
+g.message -i "* CARATTERISTICHE DEL SENTIERO TROVATO *"
+g.message -i "* *"
+g.message -i "* *"
+cat info_sentiero
+# chiamo uno script python che inserisco tra gli script di grass che mi crea uno shapefile con una polilinea e,
+# per ogni tratto di sentiero, la corrispondente velocita' in km/h
+velocity.py
+v.in.ogr -o -e dsn=sentiero.shp output=tmp_sentiero_trovato --overwrite --quiet
+# stampiamo l'andamento altimetrico usando gnuplot
+#cd $folder
+gnuplot grafico.p
+#echo "load 'grafico.p'"|gnuplot
+#echo 'exit'|gnuplot
+eog immagini/profilo_altimetrico.gif
+cd ..
+g.remove rast=tmp_profilo_dtm,tmp_profilo_costo --quiet
Added: grass-addons/grass6/raster/r.pastro/pathgar.sh
--- grass-addons/grass6/raster/r.pastro/pathgar.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/pathgar.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,104 @@
+#!/bin/bash
+# MODULE: "PATHGAR SH" per GRASS 6.4 (GRASS Shell Script) #
+# AUTHOR: Andrea Cervetto (cervoz at hotmail.com) #
+# Damiano Natali(damiano.natali at gmail.com) #
+# PURPOSE: Calcolo del presidio del territorio offerto dalla rete sentieristica presente; #
+# Il presente modulo viene solitamente lanciato dallo script pastro.sh. #
+#nome della cartella delle mappe
+#mappe='/home/damiano/spin-off/provincia_spezia/webgis/mappe'
+#nome della cartella temporanea
+#percorso='/home/damiano/spin-off/provincia_spezia/webgis/tmp'
+# creazione di un report relativo alla regione corrente
+#FILELOG='/home/damiano/spin-off/provincia_spezia/webgis/tmp/filelog/sheltgar.txt'
+FILELOG="$folder/pathgar.txt"
+# valutazione del percorso della location
+eval `g.gisenv`
+: ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
+clear
+g.message -i "********************************************************************************"
+g.message -i "| PATHGAR. SH |"
+g.message -i "| Calcolo del presidio del territorio offertodalla rete sentieristica presente |"
+### e' realmente necessario????
+# zoommiamo sull'area di interesse attraverso uno script apposito
+#region_zoom.sh
+# conversione del file vettoriale rappresentante la rete sentieristica da tipo linea a tipo punti:
+# 1) rasterizzazione della mappa dei sentieri
+v.to.rast input=$paths output="tmp_rast"$paths use=val type=line --overwrite --quiet
+# 2) vettorializzazione della mappa dei sentieri come punti
+#r.to.vect input="tmp_rast"$paths output="tmp_punti"$paths feature=point --overwrite --quiet
+# cosi' si velocizza molto il procedimento
+#point_dist=$(($res_calcolo*4))
+#if [$point_dist > 50 ]
+#then
+# point_dist=50
+#fi
+point_dist=50
+v.to.points input=$paths output="tmp_punti"$paths type=line dmax=$point_dist --overwrite --quiet
+# Creazione della mappa delle friction
+r.slope.aspect elevation=$dtm slope=tmp_slope_percentuale aspect=tmp_aspect format=percent prec=float zfactor=1.0 min_slp_allowed=0.0 --overwrite --quiet
+# echo 'friction_pendenze=if(slope_percentuale<0.32,2,if(0.32<=slope_percentuale<=0.56,7.5,20))' | r.mapcalc
+## frane e no_guado devono essere definite ??? obbligatori opzionali????
+#r.mapcalc 'tmp_friction_offroad=if(!isnull(tmp_frane),2,if(!isnull(tmp_no_guado),5,if(tmp_slope_percentuale>77,5,1)))'
+r.mapcalc 'tmp_friction_offroad=if(tmp_slope_percentuale>77,5,if(!isnull(tmp_no_guado),5,if(!isnull(tmp_frane),2,1)))'
+#r.mapcalc "tmp_friction_offroad=if(tmp_slope_percentuale>0.77,5,1)" # carta temporanea
+# echo 'friction=if(!isnull("tmp_"$paths"rast"),0,friction_offroad)' | r.mapcalc
+r.mapcalc "tmp_friction=if(!isnull(tmp_rast$paths),0,tmp_friction_offroad)"
+# Calcolo delle aree raggiungibili a partire dai ripari esistenti in meno di tot minuti
+#echo
+#while ! [ $tmax ]
+# do echo -n 'Digita la distanza massima in minuti a partire dalla rete sentieristica esistente che si desidera considerare: '
+# read tmax
+#done
+g.message -i "La distanza massima dai sentieri e' pari a $tmax minuti, ossia $(($tmax*60)) s"
+r.walk -k elevation=$dtm friction=tmp_friction output=tmp_walkout start_points=tmp_punti$paths max_cost=$(($tmax*60)) percent_memory=10 walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+#echo 'tmp_walkout=if(tmp_walkout<='$((tmax*60))',tmp_walkout,null())'|r.mapcalc
+#echo 'tmp_walkout_min=walkout/60' | r.mapcalc
+r.mapcalc 'tmp_walkout=if(tmp_walkout>'$(($tmax*60))',null(),tmp_walkout)'
+#r.mapcalc 'tmp_walkout=if(tmp_walkout<='$(($tmax*60.0))',tmp_walkout,null())'
+r.mapcalc 'tmp_walkout_min=tmp_walkout/60.0'
+# visualizziamo a monitor le mappe create, dando la possibilità di interrogarle, e le salviamo nella cartella
+# /home/damiano/searching/gis&web/mobilita_ambito_montano/tmp
+#region_layout.sh
+g.remove rast=tmp_walkout,tmp_friction,tmp_friction_offroad,"tmp_rast"$paths,tmp_slope_percentuale,tmp_aspect,tmp_frane,tmp_no_guado vect="tmp_punti"$paths --quiet
+g.rename rast=tmp_walkout_min,$output --quiet
+#g.message -i "PATHGAR module correctly termined"
+g.message -i "Il modulo PATHGAR e' terminato correttamente"
+g.message -i "____________________________________________"
+# torniamo al menù principale
+#pastro.sh
Added: grass-addons/grass6/raster/r.pastro/point2path.sh
--- grass-addons/grass6/raster/r.pastro/point2path.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/point2path.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,103 @@
+#!/bin/bash
+# MODULE: "POINT2PATH SH" per GRASS 6.4 (GRASS Shell Script) #
+# Damiano Natali (damiano.natali at gmail.com) #
+# PURPOSE: Individua il percorso ottimale tra da due punti e ne calcola il tempo di percorrenza #
+FILELOG="$folder/sheltgar.txt"
+eval `g.gisenv`
+clear
+g.message -i "|************************************************************|"
+g.message -i "|.......................POINT2PATH.SH........................|"
+g.message -i "| Calcolo del percorso ottimale tra un sentiero ed un punto |"
+#region_zoom.sh
+##### DA QUA PULITO
+v.to.rast input=$paths output=tmp_rast$paths use=val type=line --overwrite --quiet
+#r.mapcalc 'tmp_friction_offroad=if(!isnull(frane),2,if(!isnull(no_guado),5,if(slope_percentuale>0.77,5,1)))'
+# calcolo mappa di costo
+r.walk -k elevation=$dtm friction=tmp_friction output=tmp_walkout start_points=$partenza max_cost=0 percent_memory=100 nseg=4 walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+r.fill.dir -f input=tmp_walkout elevation=tmp_walkout_filled direction=tmp_walkout_dir areas=tmp_areas_walkout --overwrite --quiet
+r.mapcalc "tmp_walkout_min=tmp_walkout/60"
+# ritagliamo la mappa di costo sul vettoriale dei sentieri e troviamone il minimo
+r.mapcalc "tmp_costo_sentiero=if(!isnull(tmp_rast$paths),tmp_walkout,null())"
+#echo 'costo_sentiero=if(!isnull(tmp_$paths_rast),tmp_walkout,null())' | r.mapcalc
+r.info -r map=tmp_costo_sentiero > $folder/info1
+cut $folder/info1 -d \= -f 2 > $folder/info2
+ris=$(cat $folder/info2)
+min=$(echo $ris | cut -d ' ' -f 1)
+cost_max=$(echo $ris | cut -d ' ' -f 2)
+min1=$(echo $min | cut -d \. -f 1)
+min_approx=$(expr $min1 + 1)
+r.mapcalc "tmp_punto_minimo_rast=if(tmp_costo_sentiero<=$min_approx,tmp_costo_sentiero,null())"
+# echo 'tmp_punto_minimo_rast=if(costo_sentiero<='$min_approx',tmp_costo_sentiero,null())'|r.mapcalc
+# trasformiamo il punto di minimo da raster a vettoriale
+r.to.vect input=tmp_punto_minimo_rast output=tmp_stop_point feature=point --overwrite --quiet
+# calcola il percorso a minima energia
+r.drain -c input=tmp_walkout_filled output=tmp_drainout vector_points=tmp_stop_point --overwrite --quiet
+g.remove rast=tmp_walkout_filled,tmp_walkout_dir,tmp_areas_walkout --quiet
+# creazione del vettoriale del percorso
+r.thin input=tmp_drainout output=tmp_thinout iterations=200 --overwrite --quiet
+r.to.vect -s input=tmp_thinout output=tmp_sentiero_trovato feature=line --overwrite --quiet
+# creiamo il profilo del sentiero e stampiamolo con gnuplot, salvando poi l'immagine: tutto questo attraverso un modulo dedicato
+path_profile.sh
+region_layout2.sh
+# Esportiamo quanto visualizzato sul monitor come immagine, in modo che possa essere visualizzata ad esempio su un browser
+#rm $folder/immagini/immagine.png
+#d.out.file output=$folder/immagini/immagine format=png resolution=2 compression=9 quality=75 paper=a4 ps_level=2
+g.remove rast=tmp_walkout,tmp_walkout_min,tmp_friction,tmp_friction_offroad,tmp_rast$paths,tmp_slope_percentuale,tmp_aspect --quiet
+g.remove rast=tmp_drainout,tmp_thinout,tmp_punto_minimo_rast,tmp_costo_sentiero vect=tmp_stop_point,tmp_frane,tmp_no_guado --quiet
+g.rename vect=tmp_sentiero_trovato,$output --quiet
+g.remove vect=tmp_partenza --quiet
+g.message -i "Il modulo POINT2PATH e' terminato correttamente"
+g.message -i "_______________________________________________"
+#pastro.sh
Added: grass-addons/grass6/raster/r.pastro/point2point.sh
--- grass-addons/grass6/raster/r.pastro/point2point.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/point2point.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,106 @@
+#!/bin/bash
+# MODULE: "POINT2POINT SH" per GRASS 6.4 (GRASS Shell Script) #
+# PURPOSE: Individua il PERCORSO ottimale tra da due punti e ne calcola il tempo di percorrenza #
+eval `g.gisenv`
+clear
+g.message -i "*********************************"
+g.message -i "| POINT2POINT.SH |"
+g.message -i "| Calcolo del PERCORSO ottimale |"
+g.message -i "| tra due punti imposti |"
+# creazione della mappa delle friction
+#r.mapcalc 'tmp_friction_offroad=if(!isnull(frane),2,if(tmp_slope_percentuale>0.77,5,1))'
+# echo 'tmp_friction_offroad=if(tmp_slope_percentuale>0.77,5,1)' | r.mapcalc
+# echo 'tmp_friction=if(!isnull(tmp_sentieri_rast),0,tmp_friction_offroad)' | r.mapcalc
+#####DEBUG ROBERTO #########
+#conviene aggiungere un filling perche' per percorsi lunghi i sink del dtm creano dei problemi...
+#direi che ora funziona tutto bene
+r.fill.dir -f input=$dtm elevation=tmp_dtm_filled direction=tmp_dtm_dir areas=tmp_areas_dtm --overwrite --quiet
+# calcolo mappa di costo in secondi e in minuti
+#r.walk -k elevation=$dtm friction=tmp_friction output=tmp_walkout start_points=$partenza stop_points=$arrivo max_cost=0 percent_memory=100 nseg=4 walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+r.mapcalc "tmp_friction2=tmp_friction*30"
+r.walk -k elevation=tmp_dtm_filled friction=tmp_friction output=tmp_walkout start_points=$partenza stop_points=$arrivo max_cost=0 percent_memory=100 nseg=4 walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+g.remove rast=tmp_dtm_filled,tmp_dtm_dir,tmp_areas_dtm --quiet
+#conviene aggiungere un filling perche' per percorsi lunghi sembrano crearsi dei sink...la ragione non e' chiarissima --> forse e' il caso di approfondire
+#r.fill.dir input=tmp_walkout elevation=tmp_walkout_filled direction=tmp_walkout_dir --overwrite --quiet
+r.mapcalc 'tmp_walkout_min=tmp_walkout/60'
+#echo 'walkout_min=walkout/60' | r.mapcalc
+# calcola il PERCORSO a minima energia
+#nuovo filling (solo sulle unrisolved areas!!!)
+r.drain -c input=tmp_walkout_filled output=tmp_drainout vector_points=$arrivo --overwrite --quiet
+r.mapcalc "tmp_drainout2=if(!isnull(tmp_drainout),if(!isnull(tmp_rast$paths),1,2),null())"
+# creazione del vettoriale del PERCORSO (messo dentro path_profile.sh)
+#r.thin input=tmp_drainout2 output=tmp_thinout iterations=200 --overwrite --quiet
+#r.to.vect -s -v input=tmp_thinout output=tmp_sentiero_trovato feature=line --overwrite --quiet
+path_profile.sh
+# $folder/tmp
+region_layout.sh
+g.remove rast=tmp_walkout,tmp_walkout_min,tmp_friction,tmp_friction_offroad --quiet
+g.remove rast="tmp_rast"$paths,tmp_slope_percentuale,tmp_aspect,tmp_drainout,tmp_thinout,tmp_frane,tmp_no_guado --quiet
+g.remove vect=tmp_arrivo,tmp_partenza --quiet
+g.rename vect=tmp_sentiero_trovato,$output --quiet --overwrite
+g.message -i "Il modulo POINT2POINT e' terminato correttamente"
+g.message -i "________________________________________________"
+#pastro.sh
Added: grass-addons/grass6/raster/r.pastro/profilo.f90
--- grass-addons/grass6/raster/r.pastro/profilo.f90 (rev 0)
+++ grass-addons/grass6/raster/r.pastro/profilo.f90 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,31 @@
+program profilo
+implicit none
+integer::i,j,k
+real::a,dist
+open(8,FILE='./profilo_N',STATUS='OLD')
+open(9,FILE='./profilo_E',STATUS='OLD')
+open(10,FILE='./profilo_h',STATUS='OLD')
+open(11,FILE='./profilo_costo',STATUS='OLD')
+open(12,FILE='./per_plot',STATUS='OLD')
+k=0
+do
+ read(8,*,end=100)a
+ k=k+1
+end do
+allocate(plot(k,2))
+rewind(8)
+do i=1,k
+ read(8,*)prof(i,1)
+ read(9,*)prof(i,2)
+ read(10,*)prof(i,3)
+ read(11,*)prof(i,4)
+end do
+do i=2,k
+ write(12,'(F12.3,2X,F12.3,2X,F12.3,2X,F12.3)')prof(i,1),prof(i,2),prof(i,3),prof(i,4)
+end do
+end
Added: grass-addons/grass6/raster/r.pastro/r.pastro
--- grass-addons/grass6/raster/r.pastro/r.pastro (rev 0)
+++ grass-addons/grass6/raster/r.pastro/r.pastro 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,866 @@
+#!/bin/sh
+# MODULE: "P.A.S.T.R.O." per GRASS 6.4 (GRASS Shell Script)
+#%Module
+#% description: Tools for the management of mobility in the mountain environment
+#%End
+# Tolto il required yes si puo' dare il nome alla guisection
+#%option
+#%guisection:P.A.S.T.R.O.general
+#% key: DTM
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input DTM (richiesto)
+#% required : no
+#%end
+#%option
+#% key: PATHS
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Carta dei sentieri (richiesta)
+#% required : no
+#%end
+#%option
+#% key: SHELTERS
+#% type: string
+#% description: Carta dei rifugi esistenti
+#% required : no
+#%end
+#%option
+#% key: FUNCTION
+#% type: string
+#% description: selezione modulo P.A.S.T.R.O.
+#% options:1 - Calcolo dell'area presidiata dall'attuale insieme di rifugi (SHELTGAR),2 - Calcolo dell'area presidiata dall'attuale rete sentieristica (PATHGAR),3 - Calcolo della porzione di territorio raggiungibile da un punto (STRAGFINDER),4 - Calcolo del percorso ottimale tra due punti (POINT2POINT),5 - Calcolo del percorso ottimale tra un punto e un sentiero (POINT2PATH)
+## 6 - Calcolo della lunghezza e tempo di percorrenza di un assegnato sentiero [manca script]
+#% answer:1 - Calcolo dell'area presidiata dall'attuale insieme di rifugi (SHELTGAR)
+#% required : no
+#%end
+#%option
+#% key: FOLDER
+#% type: string
+#% gisprompt: folder,output
+#% description: Output folder (required)
+#% required : no
+#%end
+## 0 - general options
+#%option
+#% key: FRANE
+#% type: string
+#% description: Carta con le aree in frana (opzionale)
+#% required : no
+#%end
+#%option
+#% key: FIUMI_NO_GUADO
+#% type: string
+#% description: Carta raster con i fiumi non guadabili (opzionale)
+#% required : no
+#%end
+#%option
+#% key: IMAGE
+#% type: string
+#% description: Background image
+#% required : no
+#%end
+#%option
+#% key: RES
+#% type: integer
+#% gisprompt: new
+#% description: a quale risoluzione effettuare il calcolo [di default usa quella iniziale]
+#% required : no
+#%end
+#%option
+#% key: WALK_COEFF_A
+#% type: double
+#% description: r.walk coefficient (a)
+#% answer: 0.72
+#% required : no
+#%end
+#%option
+#% key: WALK_COEFF_B
+#% type: double
+#% description: r.walk coefficient (b)
+#% answer: 6.0
+#% required : no
+#%end
+#%option
+#% key: WALK_COEFF_C
+#% type: double
+#% description: r.walk coefficient (c)
+#% answer: 1.9998
+#% required : no
+#%end
+#%option
+#% key: WALK_COEFF_D
+#% type: double
+#% description: r.walk coefficient (d)
+#% answer: -1.9998
+#% required : no
+#%end
+#%option
+#% key: WALK_COEFF_S_F
+#% type: double
+#% description: r.walk slope factor coefficient (s_f)
+#% answer: -0.2125
+#% required : no
+#%end
+## 1 - sheltgar
+#%option
+#%guisection:SHELTGAR
+#% key: TMAX_SHELTGAR
+#% type: string
+#% description: Distanza massima in minuti a partire dai ripari esistenti che si desidera considerare
+#% required : no
+#%end
+#%option
+#% key: OUT_SHELTGAR
+#% type: string
+#% gisprompt: new
+#% description: Nome della mappa contenente la distanza in minuti dai ripari esistenti
+#% required : no
+#%end
+## 2 - pathgar
+#%option
+#%guisection:PATHGAR
+#% key: TMAX_PATHGAR
+#% type: string
+#% description: Distanza massima in minuti a partire dalla rete sentieristica che si desidera considerare
+#% required : no
+#%end
+#%option
+#% key: OUT_PATHGAR
+#% type: string
+#% gisprompt: new
+#% description: Nome della mappa contenente la distanza in minuti dalla rete sentieristica
+#% required : no
+#%end
+## 3 - stragfinder
+#%flag
+#%guisection:STRAGFINDER
+#% key: s
+#% description: Immissione interattiva del punto in cui e' avvenuta la scomparsa
+#%end
+#%option
+#% key: LAST_OBS_KML
+#% type: string
+#% gisprompt: old_file,file,input
+#% description: KML file del punto dell'ultimo avvistamento
+#% required : no
+#%end
+#%option
+#% key: LAST_OBS
+#% type: string
+#% description: Punto dell'ultimo avvistamento
+#% required : no
+#%end
+#%option
+#% key: DAY
+#% type: string
+#% description: giorno dell'ultimo avvistamento [oggi/ieri/altroieri]
+#% options: oggi,ieri,altroieri
+#% answer: oggi
+#% required : no
+#%end
+#%option
+#% key: HH
+#% type: double
+#% description: ora dell'ultimo avvistamento [24 h]
+#% options: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: MM
+#% type: double
+#% description: minuto dell'ultimo avvistamento
+#% options: 00,01,02,03,04,05,06,07,08,09,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59
+#% answer: 00
+#% required : no
+#%end
+#%option
+#% key: OUT_STRAGFINDER
+#% type: string
+#% gisprompt: new
+#% required : no
+#%end
+## 4 - point2point
+#%flag
+#%guisection:POINT2POINT
+#% key: p
+#% description: Immissione interattiva dei punti di inizio e fine del sentiero
+#%end
+#%option
+#% key: START_POINT_KML
+#% type: string
+#% description: KML del punto da cui si vuole fare partire il sentiero
+#% required : no
+#%end
+#%option
+#% key: END_POINT_KML
+#% type: string
+#% description: KML del punto in cui deve arrivare il sentiero
+#% required : no
+#%end
+#%option
+#% type: string
+#% description: Punto da cui si vuole fare partire il sentiero
+#% required : no
+#%end
+#%option
+#% key: END_POINT
+#% type: string
+#% description: Punto in cui deve arrivare il sentiero
+#% required : no
+#%end
+#%option
+#% key: OUT_POINT2POINT
+#% type: string
+#% gisprompt: new
+#% description: Nome della mappa contenente il percorso trovato fra i due punti
+#% required : no
+#%end
+## 5 - point2path
+###input eventuali (si veda stragfinder)
+#%flag
+#%guisection:POINT2PATH
+#% key: z
+#% description: Immissione interattiva dei punti da cui si vuole raggiungere la rete sentieristica
+#%end
+#%option
+#% key: START_POINT2_KML
+#% type: string
+#% required : no
+#%end
+#%option
+#% type: string
+#% required : no
+#%end
+#%option
+#% key: OUT_POINT2PATH
+#% type: string
+#% gisprompt: new
+#% required : no
+#%end
+then
+ echo ""
+ echo ""
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+$GRASS_VERBOSE
+PROG=`basename $0`
+#request control & test (only for imput map)
+if [ -z "$GIS_OPT_DTM" ] ; then
+ g.message -e "ERROR: DTM not specified"
+ exit 1
+fi
+#directory corrente
+act_dir=`pwd`
+ #g.message -e "ERROR: DTM not specified"
+ g.message -e "ERRORE: DTM non specificato"
+ exit 1
+fi
+if [ -z "$GIS_OPT_PATHS" ] ; then
+ #g.message -e "ERROR: Paths map not specified"
+ g.message -e "ERRORE: carta dei sentieri non specificata"
+ exit 1
+fi
+if [ -z "$GIS_OPT_SHELTERS" ] ; then
+ g.message " "
+else
+ shelters="$GIS_OPT_SHELTERS"
+fi
+export a
+export b
+export c
+export d
+export s_f
+export tmp_frane
+export tmp_no_guado
+if [ -z "$GIS_OPT_FRANE" ] ; then
+ r.mapcalc 'tmp_frane=null()'
+ g.message -w "Non è stata definita una carta delle frane"
+else
+ tmp_frane="$GIS_OPT_FRANE"
+ g.copy rast=$tmp_frane,tmp_frane
+fi
+if [ -z "$GIS_OPT_FIUMI_NO_GUADO" ] ; then
+ r.mapcalc 'tmp_no_guado=null()'
+ g.message -w "Non è stata definita una carta con i fiumi non guadabili"
+else
+ tmp_no_guado="$GIS_OPT_FIUMI_NO_GUADO"
+ g.copy rast=$tmp_no_guado,tmp_no_guado
+fi
+if [ -z "$GIS_OPT_WALK_COEFF_A" ] ; then
+ a=0.72
+ g.message -w "Il coefficiente a di r.walk non e'stato specificato, per cui verra' utilizzato il valore di default $a"
+else
+ a="$GIS_OPT_WALK_COEFF_A"
+fi
+if [ -z "$GIS_OPT_WALK_COEFF_B" ] ; then
+ b=6.0
+ g.message -w "Il coefficiente a di r.walk non e'stato specificato, per cui verra' utilizzato il valore di default $b"
+else
+ b="$GIS_OPT_WALK_COEFF_B"
+fi
+if [ -z "$GIS_OPT_WALK_COEFF_C" ] ; then
+ c=1.9998
+ g.message -w "Il coefficiente a di r.walk non e'stato specificato, per cui verra' utilizzato il valore di default $c"
+else
+ c="$GIS_OPT_WALK_COEFF_C"
+fi
+if [ -z "$GIS_OPT_WALK_COEFF_D" ] ; then
+ d=6.0
+ g.message -w "Il coefficiente a di r.walk non e'stato specificato, per cui verra' utilizzato il valore di default $d"
+else
+ d="$GIS_OPT_WALK_COEFF_D"
+fi
+ d=-1.9998
+else
+fi
+if [ -z "$GIS_OPT_WALK_COEFF_S_F" ] ; then
+ s_f=-0.2125
+ g.message -w "Il coefficiente a di r.walk non e'stato specificato, per cui verra' utilizzato il valore di default $s_f"
+else
+ s_f="$GIS_OPT_WALK_COEFF_S_F"
+fi
+g.message -i "************"
+g.message -i "P.A.S.T.R.O."
+#Assegnazione delle variabili globali (dette anche d'ambiente) - lo faro' dopo anche per i singoli scripts
+#echo "dtm="$dtm";export dtm">>$HOME/.bash_profile
+export dtm
+#echo "paths="$paths";export paths">>$HOME/.bash_profile
+export paths
+#echo "shelters="$shelters";export shelters">>$HOME/.bash_profile
+export shelters
+#echo "folder="$folder";export folder">>$HOME/.bash_profile
+export folder
+# le definisco
+dtm="$GIS_OPT_DTM"
+paths="$GIS_OPT_PATHS"
+if [ -z "$GIS_OPT_FOLDER" ]
+ then
+ #g.message -w "Output map is not defined, no output map is written"
+ g.message -w "La cartella dove salvare i files di output non e' definita"
+ folder="PASTRO_output_folder"
+ g.message -w "La carta di output sara' chiamata $output e se esistente verra' sovrascritta di default"
+else
+ folder="$GIS_OPT_FOLDER"
+fi
+#optional control:assignement default value
+#echo "res_calcolo="$res_calcolo";export res_calcolo" >> $HOME/.bash_profile
+#echo "image="$image";export image" >> $HOME/.bash_profile
+#echo "check_image="$check_image";export check_image" >> $HOME/.bash_profile
+export res_calcolo
+export image
+export check_image
+if [ -n "$GIS_OPT_IMAGE" ]
+then
+ check_image=2
+ image="$GIS_OPT_IMAGE"
+else # metto la shaded relief???
+ g.region save=tmp_curr_reg --overwrite
+ g.region rast=$dtm save=tmpdtm --overwrite
+ r.shaded.relief map=$dtm shadedmap=temp_shade --overwrite --quiet
+ g.region region=tmp_curr_reg
+ g.remove region=tmpdtm --quiet
+ check_image=1
+ image="$GIS_OPT_DTM"
+fi
+#creo una carta della regione corrente che eventualmente si puo' visualizzare a monitor
+v.in.region --overwrite --quiet output=temp_regione type=line
+#g.message -i "Sul monitor sono rappresentati i limiti della regione corrente"
+#Risoluzione di calcolo
+g.region -p > .resolution.txt
+exec 6<&0
+exec < .resolution.txt
+read a1 b1
+read a2 b2
+read a3 b3
+read a4 b4
+read a5 b5
+read a6 b6
+read a7 b7
+read a8 b8
+read a9 b9
+exec 0<&6 6<&-
+resolution=$b9
+if [ -n "$GIS_OPT_RES" ]
+then
+ res_calcolo="$GIS_OPT_RES"
+ g.message -i "Come desiderato i calcoli saranno effettuati a una risoluzione pari a $res_calcolo metri"
+ g.region -a res=$res_calcolo
+else
+ res_calcolo=$resolution
+ g.message -i "Da default i calcoli saranno effettuati con la risoluzione iniziale pari a $resolution metri"
+fi
+g.region -a res=$res_calcolo
+#Assegnazione globale delle variabili
+#echo "mappe="$mappe";export mappe">>$HOME/.bash_profile
+#echo "percorso"$percorso";export percorso">>$HOME/.bash_profile
+export mappe
+export percorso
+if [ -d $folder ] # Verifica l’esistenza della directory indicata.
+then
+ #g.message -w "The $folder directory is yet present, the output files will be overwritten" # esiste la directory --> warning sui file di output che verranno sovrascritti
+ g.message -w "La cartella $folder esiste gia', per cui verra' sovrascritta"
+ #g.message -i "The output file will be written in the $folder directory"
+ g.message -i "Eventuali outputs saranno pertanto salvati nella cartella $folder, secondo quanto prescelto"
+else
+ mkdir $folder # non esiste la directory --> la creo
+ mappe="$folder/mappe"
+ percorso="$folder/tmp"
+ mkdir $mappe
+ mkdir $percorso
+ mkdir $folder/"immagini"
+fi
+#exit 0
+# valutazione del percorso della location(SERVE QUA???)
+eval `g.gisenv`
+# LANCIO IL MODULO P.A.S.T.R.O. PRESCELTO
+# rendiamo la variabile "FUNCTION" una variabile d'ambiente, in modo da poterla richiamare anche negli script successivi
+#Definisco e controllo anche le altre variabili d'ambiente e poi entro nel singolo modulo
+g.message -i "__________________________________________"
+g.message -i "Ho selezionato l'opzione $GIS_OPT_FUNCTION"
+#echo "FUNCTION="$FUNCTION";export FUNCTION">>$HOME/.bash_profile
+export FUNCTION
+export output
+#source $HOME/.bash_profile
+# SHELTGAR Calcolo dell'area presidiata dall'attuale insieme di rifugi
+if [ "$GIS_OPT_FUNCTION" = "1 - Calcolo dell'area presidiata dall'attuale insieme di rifugi (SHELTGAR)" ]
+ then
+ FUNCTION=1
+ #echo "tmax="$tmax";export tmax">>$HOME/.bash_profile
+ #echo "output="$output";export output">>$HOME/.bash_profile
+ export tmax
+ export output
+ if [ -z "$GIS_OPT_SHELTERS" ] ; then
+ #g.message -e "ERROR: Shelters map not specified"
+ g.message -e "ERRORE: carta dei rifugi non specificata"
+ exit 1
+ fi
+ if [ -z "$GIS_OPT_TMAX_SHELTGAR" ] ; then
+ #g.message -e "ERROR: the distance from the shelters is not defined"
+ #g.message -i "Please set a specific distance from the shelters and restart the module"
+ g.message -e "ERRORE: la massima distanza dai rifugi non e' stata definita"
+ g.message -i "Per cortesia inserisci tale valore e lancia nuovamente il comando"
+ exit 1
+ fi
+ if [ -z "$GIS_OPT_OUT_SHELTGAR" ]
+ then
+ g.message -w "Il nome della mappa di output non e' definito"
+ output="output_sheltgar"
+ g.remove rast=$output --quiet
+ else
+ output="$GIS_OPT_OUT_SHELTGAR"
+ fi
+ tmax="$GIS_OPT_TMAX_SHELTGAR"
+ sheltgar.sh
+fi
+# PATHGAR - Calcolo dell'area presidiata dall'attuale rete sentieristica
+if [ "$GIS_OPT_FUNCTION" = "2 - Calcolo dell'area presidiata dall'attuale rete sentieristica (PATHGAR)" ]
+ then
+ g.message -i "OK"
+ FUNCTION=2
+ export tmax
+ export output
+ if [ -z "$GIS_OPT_TMAX_PATHGAR" ] ; then
+ #g.message -e "ERROR: the distance from the paths is not defined"
+ #g.message -i "Please set a specific distance from the paths and restart the module"
+ g.message -e "ERRORE: la massima distanza dai sentieri non e' stata definita"
+ exit 1
+ fi
+ if [ -z "$GIS_OPT_OUT_PATHGAR" ]
+ then
+ output="output_pathgar"
+ else
+ output="$GIS_OPT_OUT_PATHGAR"
+ fi
+ tmax="$GIS_OPT_TMAX_PATHGAR"
+ pathgar.sh
+fi
+# Calcolo dell'area raggiungibile da un punto
+if [ "$GIS_OPT_FUNCTION" = "3 - Calcolo della porzione di territorio raggiungibile da un punto (STRAGFINDER)" ] ; then
+ FUNCTION=3
+ #echo "last_obs="$last_obs";export last_obs" >> $HOME/.bash_profile
+ export last_obs
+ # flag e eventualmente richiama la funzione
+ #test flag
+ if [ "$GIS_FLAG_s" -eq 1 ] ; then
+ # Impostazione della risoluzione di calcolo
+ #g.region res=$RES_DTM
+ g.message -i "Acquisizione del punto e dell'orario in cui è stato visto per l'ultima volta il disperso"
+ #echo "input"$input";export input">>$HOME/.bash_profile
+ export input
+ digit_input.sh
+ last_obs=digitato
+ else
+ if [ ! -z "$GIS_OPT_LAST_OBS_KML" ] ; then
+ input_kml="$GIS_OPT_LAST_OBS_KML"
+ g.proj -w > .current_loc.wtk
+ ogr2ogr -s_srs "EPSG:4326" -t_srs '".current_loc.wtk"' tmp_output.kml $input_kml
+ v.in.ogr -z -o -e dsn=tmp_output.kml output=last_obs_kml --overwrite --quiet
+ rm .current_loc.wtk
+ rm -r tmp_output.kml
+ last_obs=last_obs_kml
+ else
+ if [ -z "$GIS_OPT_LAST_OBS" ] ; then
+ #g.message -e "ERROR: the point of the last observation is not defined"
+ #g.message -i "Please set a vector map or create it interatvely using the specific flag (i)"
+ g.message -e "ERRORE: il punto dove si e' visto per l'ultima volta il disperso non e' stato definito"
+ g.message -i "Per cortesia specifica un input e lancia nuovamente il comando"
+ exit 1
+ else
+ last_obs="$GIS_OPT_LAST_OBS"
+ fi
+ fi
+ fi
+ if [ -z "$GIS_OPT_DAY" ] ; then
+ #g.message -e "ERROR: the day option is not defined"
+ g.message -e "ERRORE: il giorno in cui si e' visto per l'ultima volta il disperso non e' specificato"
+ g.message -i "Per cortesia specificalo e lancia nuovamente il comando"
+ exit 1
+ fi
+ if [ -z "$GIS_OPT_HH" ]
+ then
+ #g.message -e "Hour of last observation is not defined"
+ #g.message -i "Please set an hour (24 h mode)"
+ g.message -e "ERRORE: l'ora in cui si e' visto per l'ultima volta il disperso non e' specificata"
+ g.message -i "Per cortesia specificala e lancia nuovamente il comando"
+ exit 1
+ fi
+ if [ -z "$GIS_OPT_MM" ]
+ then
+ #g.message -i "Please set a minute (00-60)"
+ g.message -e "ERRORE: il minuto in cui si e' visto per l'ultima volta il disperso non e' specificat0"
+ g.message -i "Per cortesia specificalo (00-60) e lancia nuovamente il comando"
+ exit 1
+ fi
+ #echo "giorno="$giorno";export giorno">>$HOME/.bash_profile
+ #echo "ora="$ora";export ora">>$HOME/.bash_profile
+ #echo "minuti="$minuti";export minuti">>$HOME/.bash_profile
+ export giorno
+ export ora
+ export minuti
+ giorno="$GIS_OPT_DAY"
+ ora="$GIS_OPT_HH"
+ minuti="$GIS_OPT_MM"
+ export output
+ if [ -z "$GIS_OPT_OUT_STRAGFINDER" ]
+ then
+ output="output_stragfinder"
+ else
+ output="$GIS_OPT_OUT_STRAGFINDER"
+ fi
+ stragfinder.sh
+fi
+# Calcolo del percorso ottimale tra due punti
+if [ "$GIS_OPT_FUNCTION" = "4 - Calcolo del percorso ottimale tra due punti (POINT2POINT)" ] ; then
+ FUNCTION=4
+ #echo "partenza="$partenza";export partenza" >> $HOME/.bash_profile
+ #echo "arrivo="$arrivo";export arrivo" >> $HOME/.bash_profile
+ export partenza
+ export arrivo
+ if [ "$GIS_FLAG_p" -eq 1 ] ; then
+ g.message -i "********************************************* "
+ g.message -i "Acquisizione interattiva del punto di partenza"
+ digit_input.sh
+ g.rename vect=digitato,partenza_digit --overwrite
+ partenza=partenza_digit
+ g.message -i "Punto di partenza acquisito "
+ g.message -i "_______________________________________________"
+ g.message -i "Acquisizione interattiva del punto di arrivo: "
+ digit_input.sh
+ g.rename vect=digitato,arrivo_digit --overwrite
+ arrivo=arrivo_digit
+ g.message -i "Punto di arrivo acquisito "
+ else
+ if [ ! -z "$GIS_OPT_START_POINT_KML" ] ; then
+ input_kml="$GIS_OPT_START_POINT_KML"
+ g.proj -w > current_loc.wtk
+ ogr2ogr -s_srs "EPSG:4326" -t_srs '"current_loc.wtk"' tmp_output.kml $input_kml
+ v.in.ogr -z -o -e dsn=tmp_output.kml output=partenza_kml --overwrite --quiet
+ partenza=partenza_kml
+ rm current_loc.wtk
+ else
+ if [ -z "$GIS_OPT_START_POINT" ] ; then
+ #g.message -i "Please set a vector map or create it interatvely using the specific flag (p)"
+ g.message -e "ERRORE: il punto di partenza non e' definito"
+ g.message -i "Per cortesia indica un input vettoriale, un file kml o specifica interattivamente i punti con il flag (p)"
+ exit 1
+ else
+ partenza="$GIS_OPT_START_POINT"
+ fi
+ fi
+ if [ ! -z "$GIS_OPT_END_POINT_KML" ] ; then
+ input2_kml="$GIS_OPT_END_POINT_KML"
+ ogr2ogr -s_srs "EPSG:4326" -t_srs '"current_loc.wtk"' tmp_output.kml $input2_kml
+ v.in.ogr -z -o -e dsn=tmp_output.kml output=arrivo_kml
+ arrivo=arrivo_kml
+ else
+ if [ -z "$GIS_OPT_END_POINT" ] ; then
+ g.message -e "ERRORE: il punto d'arrivo non e' definito"
+ exit 1
+ else
+ arrivo="$GIS_OPT_END_POINT"
+ fi
+ fi
+ fi
+ if [ -z "$GIS_OPT_OUT_POINT2POINT" ]
+ then
+ output="output_point2point"
+ else
+ output="$GIS_OPT_OUT_POINT2POINT"
+ fi
+ point2point.sh
+fi
+# Calcolo del percorso ottimale tra un punto ed un sentiero
+if [ "$GIS_OPT_FUNCTION" = "5 - Calcolo del percorso ottimale tra un punto e un sentiero (POINT2PATH)" ] ; then
+ FUNCTION=5
+ export partenza
+ if [ "$GIS_FLAG_z" -eq 1 ] ; then
+ digit_input.sh
+ g.rename vect=digitato,partenza_point2path_digit --overwrite
+ partenza=partenza_point2path_digit
+ else
+ if [ ! -z "$GIS_OPT_START_POINT2_KML" ] ; then
+ input_kml="$GIS_OPT_START_POINT2_KML"
+ ogr2ogr -s_srs "EPSG:4326" -t_srs "current_loc.wtk" tmp_output.kml $input_kml
+ else
+ if [ -z "$GIS_OPT_START_POINT2" ] ; then
+ g.message -i "Per cortesia indica un input vettoriale, un file kml o specifica interattivamente i punti con il flag (z)"
+ exit 1
+ else
+ partenza="$GIS_OPT_START_POINT2"
+ fi
+ fi
+ fi
+ if [ -z "$GIS_OPT_OUT_POINT2PATH" ]
+ then
+ output="output_point2path"
+ else
+ output="$GIS_OPT_OUT_POINT2PATH"
+ fi
+ point2path.sh
+fi
+#done
+# reimposto la risoluzione della regione iniziale
+g.region region=tmp_curr_reg
+#rimuovo carta temporanea
+g.remove rast="temp_shade" --quiet
+g.remove vect="temp_regione" --quiet
+g.remove region=tmp_curr_reg --quiet
+g.message -i "Eventuali immagini o output testuali creati sono presenti nella cartella $act_dir/$folder"
+#rm $HOME/.bash_profile
+#d.mon stop=x3
+exit 0
Added: grass-addons/grass6/raster/r.pastro/readme.txt
--- grass-addons/grass6/raster/r.pastro/readme.txt (rev 0)
+++ grass-addons/grass6/raster/r.pastro/readme.txt 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,31 @@
+r.pastro is a command written by Gter srl (www.gter.it)
+This is a developement version of r.pastro command for GRASS 6.4.x (use of x monitors that is depracated in GRASS 7)
+It requires:
+- gfortran-4.6
+- python (>=2.6)
+- python-pyshp
+- gnuplot
+To install it run the script install_r_pastro.sh as sudo user directly from GRASS and uninstall_r_pastro.sh to completely remove the script.
+E.g in a debian Linux version:
+sudo sh install_r_pastro.sh
+For any information about the command don't hesitate to contact the responsible of its developement within the Gter company.
+Roberto Marzocchi
+R&D coordinator
+Gter srl Innovazione in Geomatica, Gnss e Gis
+University of Genova spin-off company
+Via Greto di Cornigliano 6r - 16152 Genova
+P.IVA/CF 01998770992
+ph: 010-8694830 Fax: 010-8694737
+E-mail: roberto.marzocchi at gter.it
+www.gter.it
+www.twitter.com/Gteronline
+www.facebook.com/Gteronline
Added: grass-addons/grass6/raster/r.pastro/region_layout.sh
--- grass-addons/grass6/raster/r.pastro/region_layout.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/region_layout.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,118 @@
+#!/bin/bash
+# MODULE: "REGION_LAYOUT SH" per GRASS 6.4 (GRASS Shell Script) #
+# PURPOSE: Script di servizio che gestisce il dialogo per la visualizzazione, l'interrogazione #
+# ed il salvataggio delle mappe #
+# Visualizziamo su un monitor la mappa di sfondo comune a tutti i moduli, ovvero l'ortofoto
+d.mon stop=x3 --quiet
+d.mon start=x3
+d.erase
+# se non c'e' l'ortofoto si potrebbe mettere l'aspect sotto al dtm con una trasparenza
+else
+ d.rast map=$image
+fi
+# Visualizziamo le altre mappe in base al modulo che si è lanciato
+if [ "$FUNCTION" = "1" ]||[ "$FUNCTION" = "2" ]
+ then d.rast -o map=tmp_walkout_min
+ d.vect map=$paths display=shape type=line layer=1 color=red fcolor=255:165:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ d.vect map=$shelters display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+elif [ "$FUNCTION" = "3" ]
+ d.vect map=$paths type=line color=255:165:0 width=1
+ d.vect map=$shelters display=shape type=point layer=1 color=blue fcolor=0:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ d.vect map=$last_obs type=point width=2 color=0:0:0 fcolor=255:255:0 icon=basic/circle size=8
+ rm $folder/immagini/immagine_stragfinder.png
+ d.out.file output=$folder/immagini/immagine_stragfinder format=png resolution=2 compression=9 quality=75 paper=a4 ps_level=2 --quiet
+elif [ "$FUNCTION" = "5" ]
+ then d.vect map=$partenza display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ d.vect map=tmp_sentiero_trovato display=shape type=line layer=1 color=green fcolor=255:255:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ rm $folder/immagini/immagine_point2path.png
+ d.out.file output=$folder/immagini/immagine_point2path format=png resolution=2 compression=9 quality=75 paper=a4 ps_level=2 --quiet
+### caso 4
+else
+ d.vect map=$partenza display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ d.vect map=$arrivo display=shape type=point layer=1 color=blue fcolor=255:255:0 rgb_column=GRASSRGB zcolor=terrain width=0 wscale=1 icon=basic/circle size=8 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ d.vect map=tmp_sentiero_trovato display=shape type=line layer=1 color=black fcolor=255:255:0 width=2 wscale=1 icon=basic/x size=5 llayer=1 lcolor=red bgcolor=none bcolor=none lsize=8 xref=left yref=center render=c
+ # Esportiamo quanto visualizzato sul monitor come immagine, in modo che possa essere visualizzata ad esempio su un browser
+ rm $folder/immagini/immagine_point2point.png
+ d.out.file output=$folder/immagini/immagine_point2point format=png resolution=2 compression=9 quality=75 paper=a4 ps_level=2 --quiet
+fi
+# visualizziamo la barra di scala
+d.barscale bcolor=white tcolor=black at=0.2,90
+# interroghiamo la mappa (annesse le istruzioni per ogni caso---> da conrollare se van bene)
+#echo
+ then
+ g.message -i "E' ora possibile interrogare la mappa sul display X3 e avere il valore in minuti di percorrenza dal piu' vicino riparo"
+ d.text -b text="sheltgar output" bgcolor=yellow
+elif [ "$FUNCTION" = "2" ]
+ then
+ g.message -i "E' ora possibile interrogare la mappa sul display X3 e avere il valore in minuti di percorrenza dal sentiero piu' vicino"
+ d.text -b text="Pathgar output" bgcolor=yellow
+ then
+ g.message -i "Sono visibili sul diplay X3 le aree raggiungibili dal disperso di $giorno alle $ora:$minuti"
+ g.message -i "E' possibile interrogare la mappa sul display X3 e avere il valore in minuti percorribile"
+ d.text -b text="Stragfinder output" bgcolor=yellow
+elif [ "$FUNCTION" = "4" ]
+ then
+ g.message -i "E' visualizzato sulla mappa il percorso ottimale fra i 2 punti prescelti"
+ g.message -i "Interrrogando la mappa sul display X3 si puo' avere il valore in minuti di percorrenza dal punto di partenza" ## da verificare che sia questo
+ d.text -b text="point2point output" bgcolor=yellow
+else
+ g.message -i "E' visualizzato sulla mappa il percorso ottimale fra il punto di partenza scelto e la rete sentieristica"
+ d.text -b text="point2path output" bgcolor=yellow
+fi
+d.what.rast map=tmp_walkout_min
+##### DISCUTERE SE SERVE E EVENTUALMENTE COME METTERLO
+#while [ "$RISP" != "u" ]
+# do echo
+# echo -n 'Vuoi cambiare regione? ("s" per cambiare regione, "u" per uscire e salvare la mappa) '
+# read RISP
+# if [ "$RISP" == "s" ]
+# then d.zoom -f
+# d.what.rast map=walkout_min
+# fi
+#done
+# Esportiamo, nei casi in cui ciò serve, il sentiero trovato come file .gpx da caricare direttamente su un ricevitore
+if [ "$FUNCTION" = "4" ]||[ "$FUNCTION" = "5" ]; then
+ rm $folder/TRACK.gpx
+ v.out.gpsbabel -t input=tmp_sentiero_trovato type=line output=$folder/TRACK.gpx --quiet
+ ### planimetria? non si capisce a cosa si riferisce (distinguere caso 3 da 4???)
+ rm $folder/immagini/planimetria_sentiero.png
+ g.region save=temp_calcoli --overwrite
+ g.region vect=tmp_sentiero_trovato save=tmp2_pastro res=$res_calcolo --overwrite
+ d.out.file output=$folder/immagini/planimetria_sentiero format=png resolution=2 compression=9 quality=75 paper=a4 ps_level=2 --quiet
+ g.region region=temp_calcoli
+ g.remove region=tmp2_pastro --quiet
+ g.remove region=temp_calcoli --quiet
+fi
+# d.mon stop=x3
+#exit 0
Added: grass-addons/grass6/raster/r.pastro/region_layout2.sh
--- grass-addons/grass6/raster/r.pastro/region_layout2.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/region_layout2.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,38 @@
+#!/bin/bash
+ rm $folder/TRACK.gml
+ rm $folder/TRACK.xsd
+ #v.out.gpsbabel -t input=tmp_sentiero_trovato type=line output=$folder/TRACK.gpx --quiet
+ v.out.ogr format=GML type=line input=tmp_sentiero_trovato dsn=$folder/TRACK.gml --quiet
+fi
+# d.mon stop=x3
+#exit 0
Added: grass-addons/grass6/raster/r.pastro/region_zoom.sh
--- grass-addons/grass6/raster/r.pastro/region_zoom.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/region_zoom.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,68 @@
+#!/bin/bash
+# MODULE: "REGION_ZOOM SH" per GRASS 6.4 (GRASS Shell Script) #
+# PURPOSE: Script di servizio che gestisce il dialogo per l'individuazione della regione attiva #
+echo "Usa il mouse per selezionare l'area di interesse"
+echo
+d.zoom -f
+while [ "$RISP" != "s" ]
+ do echo
+ echo -n "La regione selezionata è quella desiderata? [s/n] "
+ if [ "$RISP" == "n" ]
+ then d.zoom -f
+ fi
+ read RISP
+done
+echo
+echo 'La regione attuale ha queste caratteristiche'
+echo
+g.region -p
+echo
+# Valutiamo i parametri della nuova regione
+# eval `g.region -g`
+# : ${n?} ${s?} ${w?} ${e?} ${nsres?}
+# echo -n 'Limite nord della nuova regione? '
+# read lim_n
+# if ! [ $lim_n ]
+# then lim_n=$n
+# fi
+# echo -n 'Limite sud della nuova regione? '
+# read lim_s
+# if ! [ $lim_s ]
+# then lim_s=$s
+# fi
+# echo -n 'Limite est della nuova regione? '
+# read lim_e
+# if ! [ $lim_e ]
+# then lim_e=$e
+# fi
+# echo -n 'Limite ovest della nuova regione? '
+# read lim_w
+# if ! [ $lim_w ]
+# then lim_w=$w
+# fi
+while ! [ $RISOL ]; do
+ echo -n 'Risoluzione della nuova regione? '
+ read RISOL
+done
+echo
+echo 'La regione di calcolo è'
+g.region -p res=$RISOL
+# g.region -p n=$lim_n s=$lim_s e=$lim_e w=$lim_w res=$risol
+echo
+exit 0
Added: grass-addons/grass6/raster/r.pastro/sheltgar.sh
--- grass-addons/grass6/raster/r.pastro/sheltgar.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/sheltgar.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,117 @@
+#!/bin/bash
+# MODULE: "SHELTGAR SH" per GRASS 6.4 (GRASS Shell Script) #
+# PURPOSE: Calcolo del presidio del territorio offerto dai rifugi presenti; #
+#FILELOG="$folder/sheltgar.txt"
+g.message -i "La cartella $folder e' stata creata"
+eval `g.gisenv`
+# redirigere lo standard output dallo schermo al file di log
+exec 7>&1
+exec > "$folder/sheltgar.txt"
+#r.univar map=$output > "$folder/sheltgar.txt"
+r.univar map=$dtm > "$folder/sheltgar.txt"
+# redirigere lo standard output dal file di log allo schermo, chiudendo il file di log
+exec 1<&7 7<&-
+# redirigere lo standard input dalla tastiera al file di log
+exec 6<&0
+exec < "$folder/sheltgar.txt"
+read -n31
+read numero_celle_tot
+read ; read ; read ; read ; read -n3
+read numero_celle
+# redirigere lo standard input dal file di log alla tastiera, chiudendo il file di log, e calcolo della percentuale di area coperta
+exec 0<&6 6<&-
+area_coperta=$(echo "scale=2; ($numero_celle/$numero_celle_tot)*100.0" | bc)
+clear
+g.message -i "*******************************************************************"
+g.message -i "...........................SHELTGAR.SH............................."
+g.message -i "..Calcolo del presidio del territorio offerto dai rifugi presenti.."
+#region_zoom.sh
+v.to.rast input=$paths output="tmp_rast$paths" use=val type=line --overwrite --quiet
+#echo 'tmp_friction_offroad=if(!isnull(frane),2,if(!isnull(no_guado),5,if(slope_percentuale>0.77,5,1)))' | r.mapcalc
+#r.mapcalc 'tmp_friction_offroad=if(!isnull(frane),2,if(!isnull(no_guado),5,if(tmp_slope_percentuale>0.77,5,1)))'
+#echo 'tmp_friction=if(!isnull("tmp"$path"_rast"),0,tmp_friction_offroad)' | r.mapcalc
+r.mapcalc 'tmp_friction=if(!isnull(tmp_rast'$paths'),0,tmp_friction_offroad)'
+# calcolo delle aree raggiungibili a partire dai ripari esistenti in meno di tot minuti (parametroda inserire nella pastro_GUI -->sezione sheltgar
+#echo
+#while ! [ $tmax ]
+# do echo -n 'Digita la distanza massima in minuti a partire dai ripari esistenti che si desidera considerare: '
+# read tmax
+#done
+#g.message -i "The distance from the shelters is$(($tmax*60))s"
+g.message -i "La distanza massima dai rifugi e' pari a $tmax minuti, ossia $(($tmax*60)) s"
+#echo 'premi un tasto'
+#read
+r.walk -k --overwrite elevation=$dtm friction=tmp_friction output=tmp_walkout start_points=$shelters max_cost=$(($tmax*60)) walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+#echo 'tmp_walkout=if(tmp_walkout>'$(($tmax*60))',null(),tmp_walkout)' | r.mapcalc
+#echo 'tmp_walkout_min=tmp_walkout/60.0' | r.mapcalc
+#### si potrebbe fare un contour per facilitare la visione? o anche no...
+#region_layout.sh
+g.remove rast=tmp_walkout,tmp_friction,tmp_friction_offroad,"tmp_rast"$paths,tmp_slope_percentuale,tmp_aspect,tmp_frane,tmp_no_guado --quiet
+#g.message -i "SHELTGAR module correctly termined"
+g.message -i "il modulo SHELTGAR e' concluso correttamente"
+# pastro.sh
+exit 0
Added: grass-addons/grass6/raster/r.pastro/space2tab.py
--- grass-addons/grass6/raster/r.pastro/space2tab.py (rev 0)
+++ grass-addons/grass6/raster/r.pastro/space2tab.py 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,41 @@
+#-*- coding:utf-8 -*-
+# MODULE:
+# AUTHOR(S): Roberto Marzocchi (roberto.marzocchi at gmail.com)
+# PURPOSE: text file formatting
+# COPYLEFT:
+# COMMENT: ...a lot of comments to be easy-to-read for/by beginners
+import os,sys,shutil,re,glob
+nomefile1=".tmp_coord.txt"
+nomefile2="tmp_coord2.txt"
+# legge dal file coordinate
+E=[]
+N=[]
+for riga in file(nomefile1): # modifica con nome generico
+ #print riga
+ line = riga
+ # print a
+k=0
+miofile = open(nomefile2,'w')
+while k<len(E):
+ #scrivi = "%d %d %d" % E_point[k], % N_point[k], % res[k]
+ #print "%.2f %.2f %.2f\n" % (round(E_point[k],2),round(N_point[k],2),round(res[k],2))
+ miofile.write("%.2f|%.2f\n" % (round(E[k],2),round(N[k],2)))
+ k+=1
+miofile.close()
Added: grass-addons/grass6/raster/r.pastro/stragfinder.sh
--- grass-addons/grass6/raster/r.pastro/stragfinder.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/stragfinder.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,147 @@
+#!/bin/sh
+# MODULE: "STRAGFINDER SH" per GRASS 6.4 (GRASS Shell Script)
+# PURPOSE: Calcolo dell'area raggiungibile in tot tempo da una persona a piedi.
+#°°°°°°DA VERIFICARE SE SERVE E NEL CASO RENDERLI PERCORSI GENERICI°°°°°#
+eval `g.gisenv`
+clear
+g.message -i "| STRAGFINDER.SH |"
+g.message -i "| Utility per il ritrovamento di dispersi |"
+#testa inputs obbligatori
+#echo -n "Ora approssimativa dell'ultimo avvistamento? [ora.minuti] "
+#echo
+#°°°°°°°°°°°°°°°°°°PUNTO DI ULTIMO AVVISTAMENTO - TIZIANO°°°°°°°°°°°°°°°°°
+# secondo me non serve c'e gia' nella gUI
+#if [ -n "$GIS_OPT_IMAGE" ]
+#then
+# image="$GIS_OPT_IMAGE"
+#else
+# image="$GIS_OPT_DTM"
+#fi
+#### verifica se serve (mi sembra un po inutile messo qua)
+#d.rast.leg map=$dtm
+# image solo se c'è
+#d.rast map=$image
+#read ora_minuti
+#### non so perche ma non funziona (risolto nella GUI se non ci piace vediamo di farlo funzionare)
+#ora=${ora_minuti:0:2}
+#minuti=${ora_minuti:3:2}
+# messo nella GUI
+#while [ "$giorno" != "oggi" ] && [ "$giorno" != "ieri" ] && [ "$giorno" != "altroieri" ]; do
+# echo -n "di che giorno? [oggi/ieri/altroieri] "
+# read giorno
+#done
+if [ "$giorno" = "oggi" ]
+ then stringa_old=$(date +%Y-%m-%d' '$ora:$minuti':00 UTC')
+elif [ "$giorno" = "ieri" ]
+ then stringa_old=$(date --date=yesterday +%Y-%m-%d' '$ora:$minuti':00 UTC')
+elif [ "$giorno" = "altroieri" ]
+ then stringa_old=$(date --date='today - 2 days' +%Y-%m-%d|echo' '$ora:$minuti':00 UTC')
+fi
+# echo $stringa_old
+# read
+#calcolo il tempo in secondi che intercorre fra l'ultimo avvistamento e l'ora attuale
+sec_old=$(date --date="$stringa_old" +%s)
+stringa_new=$(date +%Y-%m-%d' '%H:%M:%S' UTC')
+sec_new=$(date --date="$stringa_new" +%s)
+delta_t=$(($sec_new-$sec_old))
+g.message -i "L'ultimo avvistamento e' avvenuto $giorno alle $ora:$minuti , ossia $delta_t secondi fa"
+if [ "$delta_t" -lt 0 ] ; then
+ g.message -e "The last sighting is after the actual date and time"
+ g.message -e "Please check the input date and time"
+ exit 1
+fi
+#°°°°°°°°GIA' MESSO NELLA GUI°°°°°°°°°
+# Impostazione della risoluzione di calcolo
+#echo -n "A quale risoluzione vuoi effettuare il calcolo? [m]"
+#echo
+#read res_calcolo
+#echo 'friction_offroad=if(!isnull(frane),2,if(slope_percentuale>0.77,5,1))' | r.mapcalc
+#echo 'friction=if(!isnull(tmp_rast"$paths"),0,friction_offroad)' | r.mapcalc
+# calcolo delle aree raggiungibili a partire dal punto selezionato fino a questo momento
+r.walk -k elevation=$dtm friction=tmp_friction output=tmp_walkout start_points=$last_obs max_cost=$delta_t walk_coeff=$a,$b,$c,$d lambda=1.0 slope_factor=$s_f --overwrite --quiet
+# questa volta non lo faccio in minuti ma solo in secondi...e' corretto o e' una dimenticanza
+region_layout.sh
+g.remove rast=tmp_friction,tmp_friction_offroad,tmp_rast$paths,tmp_slope_percentuale,tmp_aspect,tmp_frane,tmp_no_guado,tmp_walkout --quiet
+g.message -i "Il modulo STRAGFINDER e' terminato correttamente"
+#pastro.sh
+exit 0
Added: grass-addons/grass6/raster/r.pastro/uninstall_r_pastro.sh
--- grass-addons/grass6/raster/r.pastro/uninstall_r_pastro.sh (rev 0)
+++ grass-addons/grass6/raster/r.pastro/uninstall_r_pastro.sh 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,45 @@
+#!/bin/bash
+#!/bin/bash
+# MODULE: script to uninstall "P.A.S.T.R.O." on GRASS 6.4 (GRASS Shell Script)
+# AUTHOR: Tiziano Cosso (tiziano.cosso at gter.it)
+# PURPOSE: Utility di calcolo dell'accessibilità in ambito montano
+# COPYRIGHT: This program is free software under the
+# GNU General Public License (>=v2).
+if [ -z "$GISBASE" ]
+then
+ echo ""
+ echo "You must be in GRASS GIS to run this program"
+ echo ""
+ exit 1
+fi
+#rm the fortran codes
+rm "$GISBASE/etc/fortran_code"/profilo_pastro
+rm "$GISBASE/etc/fortran_code"/distanze_pastro
+#rm profilo_pastro
+#rm distanze_pastro
+rm "$GISBASE/scripts"/r.pastro
+rm "$GISBASE/scripts"/sheltgar.sh
+rm "$GISBASE/scripts"/pathgar.sh
+rm "$GISBASE/scripts"/stragfinder.sh
+rm "$GISBASE/scripts"/point2point.sh
+rm "$GISBASE/scripts"/point2path.sh
+rm "$GISBASE/scripts"/path_profile.sh
+rm "$GISBASE/scripts"/region_layout.sh
+rm "$GISBASE/scripts"/region_zoom.sh
+rm "$GISBASE/scripts"/digit_input.sh
+rm "$GISBASE/scripts"/grafico.p
+rm "$GISBASE/scripts"/space2tab.py
+rm "$GISBASE/scripts"/velocity.py
Added: grass-addons/grass6/raster/r.pastro/velocity.py
--- grass-addons/grass6/raster/r.pastro/velocity.py (rev 0)
+++ grass-addons/grass6/raster/r.pastro/velocity.py 2013-04-11 14:40:11 UTC (rev 55703)
@@ -0,0 +1,91 @@
+# MODULE:
+# AUTHOR(S): Roberto Marzocchi (roberto.marzocchi at gter.it)
+# PURPOSE: create a shapefile with a polyline with velocity evaluated with the r.walk grass command
+# COPYLEFT:
+import math
+# come dipendenze scarica e installa (sudo python setup.py install) la libreria pyshp
+# Pure Python read/write support for ESRI Shapefile format
+# http://pypi.python.org/pypi/pyshp
+import shapefile
+nomefile1="per_plot2"
+nomefile2="sentiero"
+E=[]
+N=[]
+z=[]
+costo=[]
+ #print riga
+ line = riga
+ # print a
+ z.append(float(a[2]))
+ costo.append(float(a[3]))
+dist=[]
+vel=[]
+dif_costo=[]
+i=0
+while i<len(E):
+ if i==0:
+ dist.append(0.0)
+ vel.append(0.0)
+ dif_costo.append(0.0)
+ i+=1
+ else:
+ dist.append( math.sqrt( (E[i]-E[i-1])**2+ (N[i]-N[i-1])**2 + (z[i]-z[i-1])**2 ) )
+ dif_costo.append(costo[i]-costo[i-1])
+ vel.append(min(9.99,3.6*dist[i]/dif_costo[i]))
+ i+=1
+w = shapefile.Writer(shapefile.POLYLINE)
+w.field("ID","N",8,0)
+w.field("V_km_h","N",8,2)
+# Create new shapefile
+# Add points to line
+#lon_idx, lat_idx = header['Longitude'], header['Latitude']
+k=1
+while k<len(E)-1:
+ E1=E[k-1]
+ N1=N[k-1]
+ E2=E[k]
+ N2=N[k]
+ w.line(parts=[[[E1,N1],[E2,N2]]])
+ vv=round(vel[k],2)
+ w.record(ID=k,V_km_h=vv)
+ k+=1
+ #print k,E2,vv
+#print "ok"
+w.save(nomefile2)
