[GRASS-SVN] r55721 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Fri Apr 12 15:23:21 PDT 2013
Author: huhabla
Date: 2013-04-12 15:23:21 -0700 (Fri, 12 Apr 2013)
New Revision: 55721
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
Fixed temporal topology check
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-12 18:51:27 UTC (rev 55720)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-12 22:23:21 UTC (rev 55721)
@@ -196,7 +196,7 @@
return temporal_type, semantic_type, title, description
def get_granularity(self):
- """!Return the granularity
+ """!Return the granularity of the space time dataset
Granularity can be of absolute time or relative time.
In case of absolute time a string containing an integer
@@ -341,7 +341,7 @@
maps = self.get_registered_maps_as_objects(
where=None, order="start_time", dbif=dbif)
- print_temporal_topology_relationships(maps, maps)
+ print_temporal_topology_relationships(maps)
def count_temporal_relations(self, maps=None, dbif=None):
"""!Count the temporal relations between the registered maps.
@@ -359,16 +359,17 @@
- return count_temporal_topology_relationships(maps, maps)
+ return count_temporal_topology_relationships(maps)
def check_temporal_topology(self, maps=None, dbif=None):
- """!Check the temporal topology
+ """!Check the temporal topology of all maps of the current space time dataset or
+ of an optional list of maps
Correct topology means, that time intervals are not overlap or
that intervals does not contain other intervals.
Equal time intervals are not allowed.
- The map list must be ordered by start time
+ The optional map list must be ordered by start time
Allowed and not allowed temporal relationships for correct topology:
@verbatim
@@ -388,7 +389,7 @@
- finished -> not allowed
@endverbatim
- @param maps: A sorted (start_time) list of AbstractDataset objects
+ @param maps: An optional list of AbstractDataset objects, in case of None all maps of the space time dataset are checked
@param dbif: The database interface to be used
@return True if topology is correct
@@ -396,31 +397,34 @@
- relations = count_temporal_topology_relationships(maps, maps)
+ relations = count_temporal_topology_relationships(maps)
+ if relations == None:
+ return False
map_time = self.get_map_time()
if map_time == "interval" or map_time == "mixed":
- if "equivalent" in relations:
+ if "equal" in relations and relations["equal"] > 0:
return False
- if "during" in relations:
+ if "during" in relations and relations["during"] > 0:
return False
- if "contains" in relations:
+ if "contains" in relations and relations["contains"] > 0:
return False
- if "overlaps" in relations:
+ if "overlaps" in relations and relations["overlaps"] > 0:
return False
- if "overlapped" in relations:
+ if "overlapped" in relations and relations["overlapped"] > 0:
return False
- if "starts" in relations:
+ if "starts" in relations and relations["starts"] > 0:
return False
- if "finishes" in relations:
+ if "finishes" in relations and relations["finishes"] > 0:
return False
- if "started" in relations:
+ if "started" in relations and relations["started"] > 0:
return False
- if "finished" in relations:
+ if "finished" in relations and relations["finished"] > 0:
return False
elif map_time == "point":
return False
else:
return False
Property changes on: grass/trunk/lib/python/temporal/abstract_temporal_dataset.py
___________________________________________________________________
Added: svn:mime-type
+ text/python
Added: svn:eol-style
+ native
