[GRASS-SVN] r55728 - grass/branches/releasebranch_6_4/display/d.colortable
svn_grass at osgeo.org
Sat Apr 13 02:58:33 PDT 2013
Author: hamish
Date: 2013-04-13 02:58:32 -0700 (Sat, 13 Apr 2013)
New Revision: 55728
grass/branches/releasebranch_6_4/display/d.colortable/main.c
add flag to skip showing NULL color for FP maps, ie fill the box (merge r39106 from devbr6)
Modified: grass/branches/releasebranch_6_4/display/d.colortable/main.c
--- grass/branches/releasebranch_6_4/display/d.colortable/main.c 2013-04-13 09:50:36 UTC (rev 55727)
+++ grass/branches/releasebranch_6_4/display/d.colortable/main.c 2013-04-13 09:58:32 UTC (rev 55728)
@@ -46,12 +46,14 @@
int atcat;
int white, black;
int atcol, atline;
- int count;
+ int count, offset;
int t, b, l, r;
int fp, new_colr;
int x_box[5], y_box[5];
struct GModule *module;
struct Option *opt1, *opt2, *opt3, *opt4;
+ struct Flag *skip_null;
/* Initialize the GIS calls */
G_gisinit(argv[0]);
@@ -85,6 +87,11 @@
opt4->options = "1-1000";
opt4->description = _("Number of columns to appear in the color table");
+ skip_null = G_define_flag();
+ skip_null->key = 'n';
+ skip_null->description =
+ _("Don't draw a collar showing the NULL color in FP maps");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -255,14 +262,21 @@
x_box[2] = (dots_per_col - 6);
x_box[4] = (6 - dots_per_col);
- G_debug(1, "dots_per_line: %d", dots_per_line);
+ G_debug(1, "dots_per_line: %d dmin=%.2f dmax=%.2f",
+ dots_per_line, dmin, dmax);
+ if (skip_null->answer)
+ offset = 1;
+ else
+ offset = 4;
for (r = 0; r < dots_per_line - 6; r++) {
- if (r <= 4)
+ if ((r <= 4) && !skip_null->answer)
G_set_d_null_value(&dval, 1);
else
dval =
- dmin + (r - 1) * (dmax - dmin) / (dots_per_line - 6 - 5);
+ dmin + r*(dmax - dmin) / (dots_per_line - 6 - offset);
D_d_color(dval, &colors);
R_move_abs(cur_dot_col + 3, (cur_dot_row - 3) - r);
R_polygon_rel(x_box, y_box, 5);
