[GRASS-SVN] r55751 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Apr 13 07:35:59 PDT 2013
Author: mmetz
Date: 2013-04-13 07:35:59 -0700 (Sat, 13 Apr 2013)
New Revision: 55751
grass/trunk/lib/vector/Vlib/cindex.c
Vlib: use custom bsearch for Vect_cidx_find_next()
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2013-04-13 14:22:47 UTC (rev 55750)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2013-04-13 14:35:59 UTC (rev 55751)
@@ -23,8 +23,6 @@
#include "local_proto.h"
-static int cmp_cat(const void *pa, const void *pb);
static void check_status(const struct Map_info *Map)
if (!Map->plus.cidx_up_to_date)
@@ -242,17 +240,35 @@
return 1;
-/* Compare by cat */
+/* search for first occurence of cat in cat index, starting at first */
+static int ci_search_cat(struct Cat_index *ci, int first, int cat)
- int *p1 = (int *)pa;
- int *p2 = (int *)pb;
+ int lo, hi, mid;
+ lo = first;
+ if (lo < 0)
+ lo = 0;
+ if (ci->cat[lo][0] > cat)
+ return -1;
+ if (ci->cat[lo][0] == cat)
+ return lo;
- if (*p1 < p2[0])
+ hi = ci->n_cats - 1;
+ if (first > hi)
return -1;
- if (*p1 > p2[0])
- return 1;
- return 0;
+ /* deferred test for equality */
+ while (lo < hi) {
+ mid = (lo + hi) >> 1;
+ if (ci->cat[mid][0] < cat)
+ lo = mid + 1;
+ else
+ hi = mid;
+ return lo;
+ return -1;
@@ -272,7 +288,7 @@
int Vect_cidx_find_next(const struct Map_info *Map, int field_index, int cat,
int type_mask, int start_index, int *type, int *id)
- int *catp, cat_index;
+ int cat_index;
struct Cat_index *ci;
G_debug(3,
@@ -285,37 +301,15 @@
if (field_index >= Map->plus.n_cidx)
G_fatal_error(_("Layer index out of range"));
- if (start_index < 0)
- start_index = 0;
- if (start_index >= Map->plus.cidx[field_index].n_cats)
- return -1; /* outside range */
- /* pointer to beginning of searched part of category index */
+ /* pointer to category index */
ci = &(Map->plus.cidx[field_index]);
- /* calc with pointers is using sizeof(int) !!! */
- catp = bsearch(&cat, (int *)ci->cat + start_index * 3,
- (size_t) ci->n_cats - start_index,
- 3 * sizeof(int), cmp_cat);
+ cat_index = ci_search_cat(ci, start_index, cat);
+ G_debug(3, "cat_index = %d", cat_index);
- G_debug(3, "catp = %p", catp);
- if (!catp)
+ if (cat_index < 0)
return -1;
- /* get index from pointer, the difference between pointers is using sizeof(int) !!! */
- cat_index = (catp - (int *)ci->cat) / 3;
- G_debug(4, "cat_index = %d", cat_index);
- /* Go down to the first if multiple */
- while (cat_index > start_index) {
- if (ci->cat[cat_index - 1][0] != cat) {
- break;
- cat_index--;
do {
G_debug(3, " cat_index = %d", cat_index);
if (ci->cat[cat_index][0] == cat && ci->cat[cat_index][1] & type_mask) {
@@ -332,7 +326,7 @@
- \brief Gind all line/area id's for given category
+ \brief Find all line/area id's for given category
\param Map pointer to Map_info structure
\param layer layer number
