[GRASS-SVN] r55763 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Apr 13 11:58:13 PDT 2013
Author: martinl
Date: 2013-04-13 11:58:13 -0700 (Sat, 13 Apr 2013)
New Revision: 55763
grass/trunk/lib/vector/Vlib/read_pg.c
vlib(pg): optimize V2_read_line_pg()
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2013-04-13 18:57:08 UTC (rev 55762)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2013-04-13 18:58:13 UTC (rev 55763)
@@ -311,7 +311,7 @@
struct line_cats *line_c, int line)
#ifdef HAVE_POSTGRES
- int type, fid;
+ int fid;
struct Format_info_pg *pg_info;
struct P_line *Line;
@@ -335,14 +335,15 @@
if (!line_p && !line_c)
return Line->type;
- if (line_p != NULL)
- Vect_reset_line(line_p);
- if (line_c != NULL)
+ if (line_c) {
Vect_reset_cats(line_c);
- if (line_c)
Vect_cat_set(line_c, 1, (int) Line->offset);
+ if (!line_p)
+ return Line->type;
+ Vect_reset_line(line_p);
if (Line->type == GV_CENTROID && !pg_info->toposchema_name) {
/* simple features access: get centroid from sidx */
return get_centroid(Map, line, line_p);
@@ -353,25 +354,21 @@
fid = Line->offset;
else
fid = pg_info->offset.array[Line->offset];
+ /* read feature */
get_feature(pg_info, fid, Line->type);
+ /* check sf type */
if (pg_info->cache.sf_type == SF_NONE) {
G_warning(_("Feature %d without geometry skipped"), line);
return -1;
+ if (0 > (int)pg_info->cache.sf_type) /* -1 || - 2 */
+ return -1;
- type = (int)pg_info->cache.sf_type;
- if (type < 0) /* -1 || - 2 */
- return type;
+ Vect_append_points(line_p, pg_info->cache.lines[0], GV_FORWARD);
- if (Line->type == GV_BOUNDARY && type == GV_LINE)
- type = GV_BOUNDARY; /* feature is read as GV_LINE (linestring), force GV_BOUNDARY */
- if (line_p)
- Vect_append_points(line_p, pg_info->cache.lines[0], GV_FORWARD);
- return type;
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
return -1;
