[GRASS-SVN] r55780 - grass/trunk/scripts/r.fillnulls
Sun Apr 14 02:10:17 PDT 2013
Author: neteler
Date: 2013-04-14 02:10:17 -0700 (Sun, 14 Apr 2013)
New Revision: 55780
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
r.fillnulls: fix v.surf.rst call ('zcol' removed)
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2013-04-14 08:55:58 UTC (rev 55779)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2013-04-14 09:10:17 UTC (rev 55780)
@@ -261,7 +261,7 @@
             # launch v.surf.rst
             tmp_rmaps.append(holename + '_dem')
             if grass.run_command('v.surf.rst', quiet = quiet, input = holename, elev = holename + '_dem',
-                                 zcol = 'value', tension = tension, smooth = smooth,
+                                 tension = tension, smooth = smooth,
                                  segmax = segmax, npmin = npmin) != 0:
                 # GTC Hole is NULL area in a raster map
                 grass.fatal(_("Failed to fill hole %s") % cat)
