[GRASS-SVN] r55786 - grass/trunk/raster/r.solute.transport
svn_grass at osgeo.org
Sun Apr 14 02:40:58 PDT 2013
Author: neteler
Date: 2013-04-14 02:40:58 -0700 (Sun, 14 Apr 2013)
New Revision: 55786
grass/trunk/raster/r.solute.transport/r.solute.transport.html
r.solute.transport: r.mapcalc white space fixes; HTML cosmetics
Modified: grass/trunk/raster/r.solute.transport/r.solute.transport.html
--- grass/trunk/raster/r.solute.transport/r.solute.transport.html 2013-04-14 09:38:54 UTC (rev 55785)
+++ grass/trunk/raster/r.solute.transport/r.solute.transport.html 2013-04-14 09:40:58 UTC (rev 55786)
@@ -102,17 +102,17 @@
# The area is 200m x 100m with a cell size of 1m x 1m
grass.run_command("g.region", res=1, res3=1, t=10, b=0, n=100, s=0, w=0, e=200)
-grass.run_command("r.mapcalc", expression="phead=if(col() == 1 , 50, 40)")
-grass.run_command("r.mapcalc", expression="phead=if(col() ==200 , 45 + row()/40, phead)")
-grass.run_command("r.mapcalc", expression="status=if(col() == 1 || col() == 200 , 2, 1)")
-grass.run_command("r.mapcalc", expression="well=if((row() == 50 && col() == 175) || (row() == 10 && col() == 135) , -0.001, 0)")
-grass.run_command("r.mapcalc", expression="hydcond=0.00005")
-grass.run_command("r.mapcalc", expression="recharge=0")
-grass.run_command("r.mapcalc", expression="top_conf=20")
-grass.run_command("r.mapcalc", expression="bottom=0")
-grass.run_command("r.mapcalc", expression="poros=0.17")
-grass.run_command("r.mapcalc", expression="syield=0.0001")
-grass.run_command("r.mapcalc", expression="null=0.0")
+grass.run_command("r.mapcalc", expression="phead = if(col() == 1 , 50, 40)")
+grass.run_command("r.mapcalc", expression="phead = if(col() ==200 , 45 + row()/40, phead)")
+grass.run_command("r.mapcalc", expression="status = if(col() == 1 || col() == 200 , 2, 1)")
+grass.run_command("r.mapcalc", expression="well = if((row() == 50 && col() == 175) || (row() == 10 && col() == 135) , -0.001, 0)")
+grass.run_command("r.mapcalc", expression="hydcond = 0.00005")
+grass.run_command("r.mapcalc", expression="recharge = 0")
+grass.run_command("r.mapcalc", expression="top_conf = 20")
+grass.run_command("r.mapcalc", expression="bottom = 0")
+grass.run_command("r.mapcalc", expression="poros = 0.17")
+grass.run_command("r.mapcalc", expression="syield = 0.0001")
+grass.run_command("r.mapcalc", expression="null = 0.0")
grass.message(_("Compute a steady state groundwater flow"))
@@ -121,11 +121,11 @@
recharge="recharge", output="gwresult_conf", dt=8640000000000, type="confined")
grass.message(_("generate the transport data"))
-grass.run_command("r.mapcalc", expression="c=if(col() == 15 && row() == 75 , 500.0, 0.0)")
-grass.run_command("r.mapcalc", expression="cs=if(col() == 15 && row() == 75 , 0.0, 0.0)")
-grass.run_command("r.mapcalc", expression="tstatus=if(col() == 1 || col() == 200 , 3, 1)")
-grass.run_command("r.mapcalc", expression="diff=0.0000001")
-grass.run_command("r.mapcalc", expression="R=1.0")
+grass.run_command("r.mapcalc", expression="c = if(col() == 15 && row() == 75 , 500.0, 0.0)")
+grass.run_command("r.mapcalc", expression="cs = if(col() == 15 && row() == 75 , 0.0, 0.0)")
+grass.run_command("r.mapcalc", expression="tstatus = if(col() == 1 || col() == 200 , 3, 1)")
+grass.run_command("r.mapcalc", expression="diff = 0.0000001")
+grass.run_command("r.mapcalc", expression="R = 1.0")
# Compute the initial state
grass.run_command("r.solute.transport", solver="bicgstab", top="top_conf",\
@@ -139,8 +139,6 @@
bottom="bottom", phead="gwresult_conf", status="tstatus", hc_x="hydcond", hc_y="hydcond",\
rd="R", cs="cs", q="well", nf="poros", output="stresult_conf_" + str(dt + 1), dt=864000, diff_x="diff",\
diff_y="diff", c="stresult_conf_" + str(dt), al=0.1, at=0.01)
</pre></div>
<h2>SEE ALSO</h2>
