[GRASS-SVN] r55790 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Apr 14 04:21:25 PDT 2013
Author: mmetz
Date: 2013-04-14 04:21:25 -0700 (Sun, 14 Apr 2013)
New Revision: 55790
grass/trunk/lib/vector/Vlib/intersect.c
Vlib: Vect_line_intersection() describe bug, clean up code, add 2.5D support
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2013-04-14 10:04:08 UTC (rev 55789)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2013-04-14 11:21:25 UTC (rev 55790)
@@ -163,12 +163,18 @@
t = ay1;
ay1 = by1;
by1 = t;
+ t = az1;
+ az1 = bz1;
+ bz1 = t;
t = ax2;
ax2 = bx2;
bx2 = t;
t = ay2;
ay2 = by2;
by2 = t;
+ t = az2;
+ az2 = bz2;
+ bz2 = t;
d = D;
@@ -637,13 +643,27 @@
APnts = APoints;
BPnts = BPoints;
+ /* BUG
+ * sometimes aline is broken by bline in aline1,2
+ * then aline1 is broken by aline2 in aline3,4, this should not happen
+ * then aline3 or aline4 is broken by the same bline in aline5,6
+ * then aline5 is broken by aline6 in aline7,8, this should not happen
+ * then aline7 or aline8 is broken by the same bline in aline9,10
+ * etc ad infinitum
+ * this can be avoided by not breaking aline fragments again with bline
+ * followed by Vect_clean_small_angles_at_nodes()
/* RE (representation error).
* RE thresh above is nonsense of course, the RE threshold should be based on
* number of significant digits for double (IEEE-754) which is 15 or 16 and exponent.
* The number above is in fact not required threshold, and will not work
* for example: equator length is 40.075,695 km (8 digits), units are m (+3)
* and we want precision in mm (+ 3) = 14 -> minimum rethresh may be around 0.001
- * ?Maybe all nonsense? */
+ * ?Maybe all nonsense?
+ * Use rounding error of the unit in the least place ?
+ * max of x, y
+ * rethresh = pow(2, log2(max) - 53) */
/* Warning: This function is also used to intersect the line by itself i.e. APoints and
* BPoints are identical. I am not sure if it is clever, but it seems to work, but
@@ -728,54 +748,37 @@
if (BPoints->x[i] <= BPoints->x[i + 1]) {
rect.boundary[0] = BPoints->x[i];
rect.boundary[3] = BPoints->x[i + 1];
- box.W = BPoints->x[i];
- box.E = BPoints->x[i + 1];
else {
rect.boundary[0] = BPoints->x[i + 1];
rect.boundary[3] = BPoints->x[i];
- box.W = BPoints->x[i + 1];
- box.E = BPoints->x[i];
if (BPoints->y[i] <= BPoints->y[i + 1]) {
rect.boundary[1] = BPoints->y[i];
rect.boundary[4] = BPoints->y[i + 1];
- box.S = BPoints->y[i];
- box.N = BPoints->y[i + 1];
else {
rect.boundary[1] = BPoints->y[i + 1];
rect.boundary[4] = BPoints->y[i];
- box.S = BPoints->y[i + 1];
- box.N = BPoints->y[i];
if (BPoints->z[i] <= BPoints->z[i + 1]) {
rect.boundary[2] = BPoints->z[i];
rect.boundary[5] = BPoints->z[i + 1];
- box.B = BPoints->z[i];
- box.T = BPoints->z[i + 1];
else {
rect.boundary[2] = BPoints->z[i + 1];
rect.boundary[5] = BPoints->z[i];
- box.B = BPoints->z[i + 1];
- box.T = BPoints->z[i];
- box.N += rethresh;
- box.S -= rethresh;
- box.E += rethresh;
- box.W -= rethresh;
- box.T += rethresh;
- box.B -= rethresh;
+ box.W = rect.boundary[0] - rethresh;
+ box.S = rect.boundary[1] - rethresh;
+ box.B = rect.boundary[2] - rethresh;
+ box.E = rect.boundary[3] + rethresh;
+ box.N = rect.boundary[4] + rethresh;
+ box.T = rect.boundary[5] + rethresh;
if (Vect_box_overlap(&abbox, &box)) {
RTreeInsertRect(&rect, i + 1, MyRTree); /* B line segment numbers in rtree start from 1 */
@@ -808,8 +811,16 @@
rect.boundary[2] = APoints->z[i + 1];
rect.boundary[5] = APoints->z[i];
- j = RTreeSearch(MyRTree, &rect, (void *)cross_seg, &i); /* A segment number from 0 */
+ if (Vect_box_overlap(&abbox, &box)) {
+ j = RTreeSearch(MyRTree, &rect, (void *)cross_seg, &i); /* A segment number from 0 */
/* Free RTree */
@@ -826,6 +837,7 @@
/* Snap breaks to nearest vertices within RE threshold */
/* Calculate distances along segments */
for (i = 0; i < n_cross; i++) {
/* 1. of A seg */
seg = cross[i].segment[0];
curdist =
@@ -1030,7 +1042,7 @@
* break on vertex is always on first segment of this vertex (used below)
last = -1;
- for (i = 1; i < n_cross; i++) {
+ for (i = 0; i < n_cross; i++) {
if (use_cross[i] == 0)
continue;
if (last == -1) { /* set first alive */
@@ -1112,13 +1124,36 @@
Points->y[j]);
+ last_seg = seg;
+ last_x = cross[i].x;
+ last_y = cross[i].y;
+ last_z = 0;
+ /* calculate last_z */
+ if (Points->z[last_seg] == Points->z[last_seg + 1]) {
+ last_z = Points->z[last_seg + 1];
+ else if (last_x == Points->x[last_seg] &&
+ last_y == Points->y[last_seg]) {
+ last_z = Points->z[last_seg];
+ else if (last_x == Points->x[last_seg + 1] &&
+ last_y == Points->y[last_seg + 1]) {
+ else {
+ dist = dist2(Points->x[last_seg],
+ Points->x[last_seg + 1],
+ Points->y[last_seg],
+ Points->y[last_seg + 1]);
+ last_z = (Points->z[last_seg] * sqrt(cross[i].distance[current]) +
+ Points->z[last_seg + 1] * (sqrt(dist) - sqrt(cross[i].distance[current]))) /
+ sqrt(dist);
/* add current cross or end point */
- Vect_append_point(XLines[k], cross[i].x, cross[i].y, 0.0);
+ Vect_append_point(XLines[k], cross[i].x, cross[i].y, last_z);
G_debug(2, " append cross / last point: %f %f", cross[i].x,
cross[i].y);
- last_seg = seg;
- last_x = cross[i].x;
- last_y = cross[i].y, last_z = 0;
/* Check if line is degenerate */
if (dig_line_degenerate(XLines[k]) > 0) {
