[GRASS-SVN] r55818 - in grass/trunk: lib/python/temporal temporal/t.rast.list temporal/t.rast.mapcalc temporal/t.rast.out.vtk temporal/t.rast.to.rast3 temporal/t.rename temporal/t.support temporal/t.vect.observe.strds
Mon Apr 15 16:18:28 PDT 2013
Author: huhabla
Date: 2013-04-15 16:18:27 -0700 (Mon, 15 Apr 2013)
New Revision: 55818
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/lib/python/temporal/temporal_granularity.py
   grass/trunk/temporal/t.rast.list/t.rast.list.py
   grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
   grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
   grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh
   grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
   grass/trunk/temporal/t.rename/test.t.rename.sh
   grass/trunk/temporal/t.support/test.t.support.sh
   grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
Better handling of space time dataset granularity
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -172,7 +172,8 @@
            Return True if success or False otherwise
         # Check unit
-        units = ["years", "months", "days", "hours", "minutes", "seconds"]
+        units = ["year", "years", "month", "months", "day", "days", "hour",
+                 "hours", "minute", "minutes", "second", "seconds"]
         if unit not in units:
             return False
         return True
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -223,6 +223,11 @@
         temporal_type = self.get_temporal_type()
+        check = check_granularity_string(granularity, temporal_type)
+        if not check:
+            core.fatal(_("Wrong granularity: \"%s\"") % str(granularity))
         if temporal_type == "absolute":
             self.set_time_to_absolute()
@@ -680,26 +685,40 @@
            In case more map information are needed, use the select()
            method for each listed object.
-           @param gran: The granularity to be used, if None the granularity of
+           @param gran: The granularity string to be used, if None the granularity of
                         the space time dataset is used.
+                        Absolute time has
+                        the format "number unit", relative time has the format "number".
+                        The unit in case of absolute time can be one of "second, seconds,
+                        minute, minutes, hour, hours, day, days, week, weeks, month, months,
+                        year, years". The unit of the relative time granule is always the
+                        space time dataset unit and can not be changed.
            @param dbif: The database interface to be used
            @return ordered object list, in case nothing found None is returned
         dbif, connect = init_dbif(dbif)
         obj_list = []
         if gran is None:
             gran = self.get_granularity()
+        check = check_granularity_string(gran, self.get_temporal_type())
+        if not check:
+            core.fatal(_("Wrong granularity: \"%s\"") % str(gran))
         start, end = self.get_valid_time()
+        if start is None or end is None:
+            return None
         # Time instances and mixed time
         is_irregular = False
-        # We need to adjust the end time in case the the dataset ha no
+        # We need to adjust the end time in case the the dataset has no
         # interval time, so we can catch time instances at the end
         if self.get_map_time() != "interval":
             is_irregular = True
@@ -715,8 +734,11 @@
             else:
                 next = start + gran
-            where = "(start_time <= '%s' and end_time >= '%s')" % (start, next)
+            # First we search for intervals that are are equal the granule or contain it
+            where = create_temporal_relation_sql_where_statement(
+                    start=start, end=next, use_start=False, use_during=False,
+                    use_overlap=False, use_contain=True, use_equal=True,
+                    use_follows=False, use_precedes=False)
             rows = self.get_registered_maps("id", where, "start_time", dbif)
             found_gap = False
@@ -731,8 +753,8 @@
                 maplist = []
                 for row in rows:
-                    # Take the first map
-                    map = self.get_new_map_instance(rows[0]["id"])
+                    map = self.get_new_map_instance(row["id"])
                     if self.is_time_absolute():
                         map.set_absolute_time(start, next)
@@ -744,33 +766,50 @@
                 obj_list.append(copy.copy(maplist))
             else:
-                # We truely found a gap and maybe a time instance
+                # We may found a gap or a gap after a time instance
                 found_gap = True
-                # Searching for time instances with start time in the current
-                # granule
-                where = "(start_time = '%s')" % (start)
+                # Searching for time instances and intervals that are during the
+                # current granule or overlapping it
+                        start=start, end=next, use_start=True, use_during=True,
+                        use_overlap=True, use_contain=False, use_equal=False,
+                rows = self.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
-                rows = self.get_registered_maps("id", where, "start_time", dbif)
                 if rows is not None and len(rows) != 0:
+                    # No gap if we found something in the granule with intervaltime
                     if len(rows) > 1:
                         core.warning(_("More than one map found in a granule. "
                                        "Temporal granularity seems to be invalid or"
                                        " the chosen granularity is not a greatest "
                                        "common divider of all time instances "
                                        "in the dataset."))
                     maplist = []
+                    count = 0
                     for row in rows:
+                        if count == 0:
+                            if row["end_time"] is not None or row["start_time"] != start:
+                                found_gap = False
+                        count += 1
-                            map.set_absolute_time(start, None)
+                                map.set_absolute_time(start, next)
+                            else:
+                                map.set_absolute_time(start, None)
                         elif self.is_time_relative():
-                            map.set_relative_time(start, None,
+                                map.set_relative_time(start, next,
                                                   self.get_relative_time_unit())
+                            else:
+                                map.set_relative_time(start, None,
+                                                  self.get_relative_time_unit())
                         maplist.append(copy.copy(map))
@@ -802,6 +841,7 @@
         if connect:
             dbif.close()
         if obj_list:
             return obj_list
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -132,19 +132,19 @@
             if len(inc) < 2:
                 core.error(_("Wrong increment format: %s") % (increment))
                 return None
-            if inc[1].find("seconds") >= 0:
+            if inc[1].find("seconds") >= 0 or inc[1].find("second") >= 0:
                 seconds = mult * int(inc[0])
-            elif inc[1].find("minutes") >= 0:
+            elif inc[1].find("minutes") >= 0 or inc[1].find("minute") >= 0:
                 minutes = mult * int(inc[0])
-            elif inc[1].find("hours") >= 0:
+            elif inc[1].find("hours") >= 0 or inc[1].find("hour") >= 0:
                 hours = mult * int(inc[0])
-            elif inc[1].find("days") >= 0:
+            elif inc[1].find("days") >= 0 or inc[1].find("day") >= 0:
                 days = mult * int(inc[0])
-            elif inc[1].find("weeks") >= 0:
+            elif inc[1].find("weeks") >= 0 or inc[1].find("week") >= 0:
                 weeks = mult * int(inc[0])
-            elif inc[1].find("months") >= 0:
+            elif inc[1].find("months") >= 0 or inc[1].find("month") >= 0:
                 months = mult * int(inc[0])
-            elif inc[1].find("years") >= 0:
+            elif inc[1].find("years") >= 0 or inc[1].find("year") >= 0:
                 years = mult * int(inc[0])
             else:
@@ -277,19 +277,19 @@
             granlist.append(granpart.strip().split(" "))
         for inc in granlist:
                 has_seconds = True
                 has_minutes = True
                 has_hours = True
                 has_days = True
                 has_weeks = True
                 has_months = True
                 has_years = True
             else:
                 core.error(_("Wrong granularity format: %s") % (granularity))
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -444,7 +444,7 @@
-def list_maps_of_stds(type, input, columns, order, where, separator, method, header):
+def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
     """! List the maps of a space time dataset using diffetent methods
         @param type: The type of the maps raster, raster3d or vector
@@ -467,6 +467,8 @@
             - "gran": List map using the granularity of the space time dataset,
                       columns are identical to deltagaps
         @param header: Set True to print column names
+        @param gran The user defined granule to be used if method=gran is set, in case gran=None the
+            granule of the space time dataset is used
     mapset = core.gisenv()["MAPSET"]
@@ -475,12 +477,14 @@
     else:
         id = input + "@" + mapset
+    dbif, connected = init_dbif(None)
     sp = dataset_factory(type, id)
-    if not sp.is_in_db():
+    if not sp.is_in_db(dbif=dbif):
         core.fatal(_("Dataset <%s> not found in temporal database") % (id))
-    sp.select()
+    sp.select(dbif=dbif)
     if separator is None or separator == "":
         separator = "\t"
@@ -492,11 +496,14 @@
         else:
             columns = "id,name,mapset,start_time,end_time"
         if method == "deltagaps":
-            maps = sp.get_registered_maps_as_objects_with_gaps(where, None)
+            maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
         elif method == "delta":
-            maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+            maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
         elif method == "gran":
-            maps = sp.get_registered_maps_as_objects_by_granularity(None)
+            if gran is not None and gran != "":
+                maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
+            else:
+                maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
         if header:
             string = ""
@@ -561,7 +568,7 @@
         if method == "comma":
             columns = "id"
-        rows = sp.get_registered_maps(columns, where, order, None)
+        rows = sp.get_registered_maps(columns, where, order, dbif)
         if rows:
@@ -602,7 +609,8 @@
                         count += 1
                     print output
+    if connected:
+        dbif.close()
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -24,8 +24,42 @@
 from datetime_math import *
+def check_granularity_string(granularity, temporal_type):
+    """!Check if the granularity string is valid
+        @param granularity The granularity string
+        @param temporal_type The temporal type of the granularity relative or absolute
+        @return True if valid, False if invalid
+    temporal_type
+    if granularity is None:
+        return False
+    if temporal_type == "absolute":
+        num, unit = granularity.split(" ")
+        if unit not in ["second", "seconds", "minute", "minutes", "hour",
+                        "hours", "day", "days", "week", "weeks", "month",
+                        "months", "year", "years"]:
+            return False
+        try:
+            integer = int(num)
+        except:
+            return False
+    elif temporal_type == "relative":
+        try:
+            integer = int(granularity)
+        except:
+            return False
+    else:
+        return False
+    return True
 def compute_relative_time_granularity(maps):
     """!Compute the relative time granularity
@@ -216,17 +250,35 @@
         granularity = ulist[0]
     if use_seconds:
-        return "%i seconds" % granularity
+        if granularity == 1:
+            return "%i second" % granularity
+        else:
+            return "%i seconds" % granularity
     elif use_minutes:
-        return "%i minutes" % granularity
+            return "%i minute" % granularity
+        else:
+            return "%i minutes" % granularity
     elif use_hours:
-        return "%i hours" % granularity
+            return "%i hour" % granularity
+        else:
+            return "%i hours" % granularity
     elif use_days:
-        return "%i days" % granularity
+            return "%i day" % granularity
+        else:
+            return "%i days" % granularity
     elif use_months:
-        return "%i months" % granularity
+            return "%i month" % granularity
+        else:
+            return "%i months" % granularity
     elif use_years:
-        return "%i years" % granularity
+            return "%i year" % granularity
+        else:
+            return "%i years" % granularity
     return None
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -59,6 +59,14 @@
 #%end
 #%option
+#% key: granule
+#% type: string
+#% description: The granule to be used for listing. The granule must be specified as string eg.: absolute time "1 months" or relative time "1"
+#% required: no
+#% multiple: no
+#%end
+#%option
 #% key: separator
 #% type: string
 #% description: Separator character between the columns, default is tabular "\t"
@@ -85,13 +93,14 @@
     where = options["where"]
     separator = options["separator"]
     method = options["method"]
+    granule = options["granule"]
     header = flags["h"]
     # Make sure the temporal database exists
     tgis.init()
     tgis.list_maps_of_stds(
-        "strds", input, columns, order, where, separator, method, header)
+        "strds", input, columns, order, where, separator, method, header, granule)
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
--- grass/trunk/temporal/t.rast.list/test.t.rast.list.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rast.list/test.t.rast.list.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -68,22 +68,25 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs0 title="A test with input files" descr="A test with input files"
 # The @test
-t.register type=rast --o -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast --o -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 month"
 t.rast.list    separator=" | " method=comma     input=precip_abs0
 t.rast.list -h input=precip_abs0
 t.rast.list -h separator=" | " method=cols      input=precip_abs0
 t.rast.list -h separator=" | " method=delta     input=precip_abs0
 t.rast.list -h separator=" | " method=deltagaps input=precip_abs0
 t.rast.list -h separator=" | " method=gran      input=precip_abs0
+t.rast.list -h separator=" | " method=gran      input=precip_abs0 gran="2 months"
+t.rast.list -h separator=" | " method=gran      input=precip_abs0 gran="1 day"
-t.register type=rast --o input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=rast --o input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 month"
-# ERROR: no interval time
+t.rast.list -h separator=" | " method=gran      input=precip_abs0 gran="6 days"
 t.register type=rast --o -i input=precip_abs0 file="${n2}"
@@ -92,18 +95,24 @@
 t.register type=rast --o -i input=precip_abs0 file="${n3}"
 t.register type=rast --o -i input=precip_abs0 file="${n4}"
 t.register type=rast --o -i input=precip_abs0 file="${n5}"
@@ -112,6 +121,8 @@
+t.rast.list -h separator=" | " method=gran      input=precip_abs0 gran="8 months"
+t.rast.list -h separator=" | " method=gran      input=precip_abs0 gran="13 days"
 t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.remove type=strds input=precip_abs0
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -16,29 +16,29 @@
 t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
 t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+t.register -i --o type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
 t.register --o type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.info precip_abs1
 t.info precip_abs2
 # The first @test
-t.rast.mapcalc --o --v -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
+t.rast.mapcalc --o -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
            expression=" precip_abs1 + precip_abs2" base=new_prec \
            method=equal nprocs=5
 t.info type=strds input=precip_abs3
-t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
+t.rast.mapcalc --o -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
            expression=" (precip_abs1 + precip_abs2) / precip_abs2" base=new_prec \
 t.info type=strds input=precip_abs4
-t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+t.rast.mapcalc --o -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
            expression=" (precip_abs1 + precip_abs2) * null()" base=new_prec \
-t.rast.mapcalc --o --v -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+t.rast.mapcalc --o -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
Modified: grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh
--- grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -32,17 +32,17 @@
 # The first @test
 mkdir /tmp/test1
-t.register -i type=rast input=precip_abs1 file="${n1}"
+t.register -i --o type=rast input=precip_abs1 file="${n1}"
 t.rast.out.vtk input=precip_abs1 expdir=/tmp/test1
 ls -al /tmp/test1
 mkdir /tmp/test2
-t.register -i type=rast input=precip_abs2 file="${n1}"
+t.register -i --o type=rast input=precip_abs2 file="${n1}"
 t.rast.out.vtk input=precip_abs2 expdir=/tmp/test2 elevation=elevation
 ls -al /tmp/test2
 mkdir /tmp/test3
-t.register -i type=rast input=precip_abs3 file="${n1}"
+t.register -i --o type=rast input=precip_abs3 file="${n1}"
 t.rast.out.vtk -g input=precip_abs3 expdir=/tmp/test3 elevation=elevation
 ls -al /tmp/test3
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2013-04-15 23:18:27 UTC (rev 55818)
@@ -84,37 +84,38 @@
     if sp.is_time_absolute():
         unit = granularity.split(" ")[1]
-        granularity = int(granularity.split(" ")[0])
+        granularity = float(granularity.split(" ")[0])
+        print "Gran from stds %0.15f"%(granularity)
-        if unit == "years":
-            bottom = start.year - 1900
-            top = granularity * num_maps
-        elif unit == "months":
-            bottom = (start.year - 1900) * 12 + start.month
+        if unit == "years" or unit == "year":
+            bottom = float(start.year - 1900)
+            top = float(granularity * num_maps)
+        elif unit == "months" or unit == "month":
+            bottom = float((start.year - 1900) * 12 + start.month)
         else:
-            bottom = tgis.time_delta_to_relative_time(start - reftime)
-            days = 0
-            hours = 0
-            minutes = 0
-            seconds = 0
-            if unit == "days":
-                days = granularity
-            if unit == "hours":
-                hours = granularity
-            if unit == "minutes":
-                minutes = granularity
-            if unit == "seconds":
-                seconds = granularity
+            bottom = float(tgis.time_delta_to_relative_time(start - reftime))
+            days = 0.0
+            hours = 0.0
+            minutes = 0.0
+            seconds = 0.0
+            if unit == "days" or unit == "day":
+                days = float(granularity)
+            if unit == "hours" or unit == "hour":
+                hours = float(granularity)
+            if unit == "minutes" or unit == "minute":
+                minutes = float(granularity)
+            if unit == "seconds" or unit == "second":
+                seconds = float(granularity)
-            granularity = days + hours / 24.0 + minutes / \
-                1440.0 + seconds / 86400.0
+            granularity = float(days + hours / 24.0 + minutes / \
+                1440.0 + seconds / 86400.0)
     else:
         unit = sp.get_relative_time_unit()
         bottom = start
-    top = bottom + granularity * num_maps
+    top = float(bottom + granularity * float(num_maps))
     ret = grass.run_command("g.region", t=top, b=bottom, tbres=granularity)
     if ret != 0:
Modified: grass/trunk/temporal/t.rename/test.t.rename.sh
--- grass/trunk/temporal/t.rename/test.t.rename.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.rename/test.t.rename.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -12,16 +12,16 @@
 # We need to create three space time dataset
 t.create --v --o type=strds temporaltype=absolute output=precip_abs1 \
 	title="Test" descr="This is the 1 test strds" semantictype=sum
-t.register -i input=precip_abs1 maps=prec_1,prec_2 \
+t.register -i --o input=precip_abs1 maps=prec_1,prec_2 \
 	start="2001-01-01" increment="1 seconds"
 t.create --v --o type=strds temporaltype=absolute output=precip_abs2 \
 	title="Test" descr="This is the 2 test strds" semantictype=sum
-t.register input=precip_abs2 maps=prec_1,prec_2
+t.register --o input=precip_abs2 maps=prec_1,prec_2
 t.create --v --o type=strds temporaltype=absolute output=precip_abs3 \
 	title="Test" descr="This is the 3 test strds" semantictype=sum
-t.register input=precip_abs3 maps=prec_1,prec_2
+t.register --o input=precip_abs3 maps=prec_1,prec_2
 t.info precip_abs1
Modified: grass/trunk/temporal/t.support/test.t.support.sh
--- grass/trunk/temporal/t.support/test.t.support.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.support/test.t.support.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -16,10 +16,10 @@
 # @test Register the maps in two space time datasets
 t.create --v --o type=strds temporaltype=absolute output=precip_abs1 title="Test" descr="This is the 1 test strds" semantictype=sum
-t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
+t.register -i --o input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
 t.create --v --o type=strds temporaltype=absolute output=precip_abs2 title="Test" descr="This is the 2 test strds" semantictype=sum
-t.register -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.register -i --o input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.create --v --o type=strds temporaltype=relative output=precip_rel1 title="Test" descr="This is the 1 test strds" semantictype=min
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh	2013-04-15 22:06:58 UTC (rev 55817)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh	2013-04-15 23:18:27 UTC (rev 55818)
@@ -2,6 +2,10 @@
 # Here we test the limit of the number of layers
 # @preprocess
 # The region setting should work for UTM and LL test locations
+# temporary disabled test for performance reason
+exit
 g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
 MAP_LIST="map_list.txt"
@@ -18,7 +22,7 @@
 v.random --o output=prec n=5 seed=1
-t.register -i input=precip_abs1  file=${MAP_LIST} start="2001-01-01 00:00:00" increment="1 hours"
+t.register -i --o input=precip_abs1  file=${MAP_LIST} start="2001-01-01 00:00:00" increment="1 hours"
 # The @test
 t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column="test_val"
