[GRASS-SVN] r55843 - in grass-addons/grass6/general: . g.region.grow
svn_grass at osgeo.org
Wed Apr 17 01:54:00 PDT 2013
Author: hamish
Date: 2013-04-17 01:54:00 -0700 (Wed, 17 Apr 2013)
New Revision: 55843
Added:
grass-addons/grass6/general/g.region.grow/
grass-addons/grass6/general/g.region.grow/Makefile
grass-addons/grass6/general/g.region.grow/description.html
grass-addons/grass6/general/g.region.grow/g.region.grow
+ wrapper script to grow (or shrink) region in all directions by a fixed amount
Copied: grass-addons/grass6/general/g.region.grow/Makefile (from rev 55245, grass-addons/grass6/general/g.region.point/Makefile)
--- grass-addons/grass6/general/g.region.grow/Makefile (rev 0)
+++ grass-addons/grass6/general/g.region.grow/Makefile 2013-04-17 08:54:00 UTC (rev 55843)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = g.region.grow
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/general/g.region.grow/description.html
--- grass-addons/grass6/general/g.region.grow/description.html (rev 0)
+++ grass-addons/grass6/general/g.region.grow/description.html 2013-04-17 08:54:00 UTC (rev 55843)
@@ -0,0 +1,34 @@
+<h2>DESCRIPTION</h2>
+<em>g.region.grow</em> expands or contracts the current region bounds by
+a fixed amount in all four cardinal directions.
+<h2>NOTES</h2>
+Units are the current location's map units. Negative values for the
+<b>expand</b> option cause the region to be shrunk by that amount
+instead of grown. Options follow the usage of the <em>g.region</em>
+module, see its help page for information about usage of the flags.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+g.region.grow -p expand=-10
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>
+</em><br>
+<h2>AUTHOR</h2>
+Hamish Bowman, Dunedin, New Zealand
+<br>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/general/g.region.grow/description.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass6/general/g.region.grow/g.region.grow
--- grass-addons/grass6/general/g.region.grow/g.region.grow (rev 0)
+++ grass-addons/grass6/general/g.region.grow/g.region.grow 2013-04-17 08:54:00 UTC (rev 55843)
@@ -0,0 +1,84 @@
+#!/bin/sh
+# MODULE: g.region.grow
+# AUTHOR(S): Hamish Bowman, Dunedin, New Zealand
+# PURPOSE: Grow (or shrink) the current region in all directions
+# by a set amount.
+# COPYRIGHT: (C) 2013 Hamish Bowman, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%Module
+#% description: Expands (or contracts) the current geographic region in all directions by a fixed amount.
+#% keywords: general, region
+#%End
+#%option
+#% key: expand
+#% type: double
+#% label: Amount to expand the region by
+#% description: Negative values shrink the region instead.
+#% required: yes
+#%end
+#%Flag
+#% key: a
+#% description: Align region to resolution (default = align to bounds)
+#%End
+#%Flag
+#% key: p
+#% description: Print the resulting region
+#%End
+#%Flag
+#% key: g
+#% description: Print the resulting region in shell script style
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+if [ "$GIS_FLAG_A" -eq 1 ] ; then
+ eval `g.region -g`
+ ALIGN_FLAG="-a ewres=$ewres nsres=$nsres"
+else
+ ALIGN_FLAG=""
+fi
+if [ "$GIS_FLAG_P" -eq 1 ] ; then
+ PRINT_FLAG="-p"
+else
+ PRINT_FLAG=""
+fi
+if [ "$GIS_FLAG_G" -eq 1 ] ; then
+ SHELL_FLAG="-g"
+else
+ SHELL_FLAG=""
+fi
+SIGN=`echo "$GIS_OPT_EXPAND" | cut -c1`
+ABSVAL=`echo "$GIS_OPT_EXPAND" | sed -e 's/^-//'`
+if [ "$SIGN" = "-" ] ; then
+ g.region $ALIGN_FLAG $PRINT_FLAG $SHELL_FLAG \
+ n=n-"$ABSVAL" s=s+"$ABSVAL" w=w+"$ABSVAL" e=e-"$ABSVAL"
+else
+ n=n+"$ABSVAL" s=s-"$ABSVAL" w=w-"$ABSVAL" e=e+"$ABSVAL"
+fi
Property changes on: grass-addons/grass6/general/g.region.grow/g.region.grow
Added: svn:executable
+ text/x-sh
+ native
