[GRASS-SVN] r55851 - grass-addons/grass6/general/g.name.sequence
svn_grass at osgeo.org
Wed Apr 17 03:48:45 PDT 2013
Author: hamish
Date: 2013-04-17 03:48:45 -0700 (Wed, 17 Apr 2013)
New Revision: 55851
grass-addons/grass6/general/g.name.sequence/description.html
cosmetics
Modified: grass-addons/grass6/general/g.name.sequence/description.html
--- grass-addons/grass6/general/g.name.sequence/description.html 2013-04-17 10:38:46 UTC (rev 55850)
+++ grass-addons/grass6/general/g.name.sequence/description.html 2013-04-17 10:48:45 UTC (rev 55851)
@@ -7,12 +7,12 @@
<h2>NOTES</h2>
-The sequence must remain postive and only support integers.
+The sequence must remain postive and only supports integer values.
The module will exit with an error if the <b>padding</b> value is not
wide enough.
-A padding width of "0" can be used to indicate no padding should be used.
+A padding width of "0" can be used to indicate no zero-padding should be used.
The <b>skip</b> value can be a negative to decrement instead of increment
- the series. In this case the <b>min</b> value should be larger than the
+ the series, in this case the <b>min</b> value should be larger than the
<b>max</b> value.
@@ -20,7 +20,7 @@
Prints <tt>day.001,day.002,...,day.365</tt>:
<div class="code"><pre>
-g.name.sequence min=1 max=365 base="day." pad=3
+g.name.sequence min=1 max=365 base="day." pad=3
</pre></div>
<p>
