[GRASS-SVN] r55880 - grass/branches/releasebranch_6_4/mswindows
svn_grass at osgeo.org
Thu Apr 18 01:21:18 PDT 2013
Author: hellik
Date: 2013-04-18 01:21:18 -0700 (Thu, 18 Apr 2013)
New Revision: 55880
grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
add option to download and install MSVCRT by winGRASS-standalone installer (fix #1428)
Modified: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2013-04-18 08:08:18 UTC (rev 55879)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2013-04-18 08:21:18 UTC (rev 55880)
@@ -952,6 +952,90 @@
+Function DownloadInstallMSRuntime
+ IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
+ StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_These system libraries from Microsoft are needed for programs"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ built with Microsoft's Visual C++ compiler, such as Python and"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ GDAL which ship with GRASS, since MS does not include them by"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ default. You might already have them installed by other software,"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ if so you don't need to install them again, but if not GRASS will"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ fail to start and you will see errors like 'Missing MSVCR71.dll"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ or MSVCP100.dll'.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$TEMP\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue and install the runtimes, or Cancel"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ to skip the download and complete the GRASS"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME.$\r$\n"
+ MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
+ download:
+ SetShellVarContext current
+ InitPluginsDir
+ NSISdl::download "$HTTP_PATH/$ARCHIVE_NAME" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" download_ok download_failed
+ download_ok:
+ InitPluginsDir
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
+ Pop $0
+ StrCmp $0 "success" untar_ok untar_failed
+ untar_ok:
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe /q"
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe /q"
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe /q"
+ CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extralib"
+ Delete "$TEMP\$ARCHIVE_NAME"
+ Delete "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ Goto end
+ download_failed:
+ DetailPrint "$0" ;print error message to log
+ MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
+ Goto end
+ cancel_download:
+ MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
+ Goto end
+ untar_failed:
+ end:
+FunctionEnd
+Section /O "Important Microsoft Runtime DLLs" SecMSRuntime
+ ;Set the size (in KB) of the archive file
+ StrCpy $ARCHIVE_SIZE_KB 12521
+ ;Set the size (in KB) of the unpacked archive file
+ AddSize 13500
+ StrCpy $HTTP_PATH "http://download.osgeo.org/osgeo4w/release/msvcrt/"
+ StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-7.tar.bz2"
+ StrCpy $EXTENDED_ARCHIVE_NAME "Microsoft Visual C++ Redistributable Packages"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "install_msruntime"
+ Call DownloadInstallMSRuntime
+SectionEnd
;Uninstaller Section
Section "Uninstall"
@@ -985,6 +1069,7 @@
;Installer Section Descriptions
!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecMSRuntime} "Some software included in this installer (e.g. GDAL, Python) may need Microsoft's Visual C++ redistributable system libraries.$\r$\nDownload and install the Redistributable Package"
!insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
!insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
!insertmacro MUI_FUNCTION_DESCRIPTION_END
