[GRASS-SVN] r55885 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Thu Apr 18 03:33:40 PDT 2013
Author: jradinger
Date: 2013-04-18 03:33:39 -0700 (Thu, 18 Apr 2013)
New Revision: 55885
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Changed sql queries to loop over lists of
1) segments
2) sourcepoints
3) barriers (adapted query for last barrier)
to a grass.read_command("db.select"..) command
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-04-18 09:45:54 UTC (rev 55884)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-04-18 10:33:39 UTC (rev 55885)
@@ -162,6 +162,7 @@
import time
import sqlite3
import math #for function sqrt()
+import csv
# import required grass modules
import grass.script as grass
@@ -174,12 +175,9 @@
import numpy
from scipy import stats
from scipy import optimize
-#import matplotlib.pyplot as plt
-#import matplotlib as mpl
tmp_map_rast = None
tmp_map_vect = None
@@ -515,7 +513,7 @@
#Adding columns and coordinates to source points
grass.run_command("v.db.addcolumn",
map = "source_points_%d" % os.getpid(),
- columns = "X DOUBLE, Y DOUBLE, Segment INT, Strahler INT")
+ columns = "X DOUBLE, Y DOUBLE, segment INT, Strahler INT")
grass.run_command("v.to.db",
type = "point",
@@ -535,7 +533,7 @@
grass.run_command("v.what.rast",
raster = "river_raster_cat_tmp_%d" % os.getpid(),
- column = "Segment")
+ column = "segment")
#Adding information of Strahler stream order to source points
@@ -560,22 +558,43 @@
mapcalc_list_B = []
- # Loop over Segments
- for Segment in sorted(list(set(db.execute('SELECT Segment FROM source_points_%d ORDER BY Segment ASC' % os.getpid())))):
- grass.debug(_("This is segment nr.: " +str(Segment)))
- segment_cat = str(Segment[0])
+ ########## Loop over segments ############
+ # Extract Segments-Info to loop over
+ segment_list = grass.read_command("db.select", flags="c", sql= "SELECT segment FROM source_points_%d" % os.getpid()).split("\n")[:-1] # remove last (empty line)
+ segment_list = map(int, segment_list)
+ segment_list = sorted(list(set(segment_list)))
+ for j in segment_list:
+ segment_cat = str(j)
+ grass.debug(_("This is segment nr.: " +str(segment_cat)))
mapcalc_list_A = []
# Loop over Source points
- source_points_loop = db.execute('SELECT cat, X, Y, prob, Strahler FROM source_points_%d WHERE Segment=?' % os.getpid(), (str(Segment[0]),))
- for cat,X,Y,prob,Strahler in source_points_loop:
- grass.debug(_("Start looping over source points"))
+ source_points_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, X, Y, prob, Strahler FROM source_points_%d WHERE segment=%d" % (os.getpid(),int(j))).split("\n")[:-1] # remove last (empty line)
+ source_points_list = list(csv.reader(source_points_list,delimiter="|"))
+ for k in source_points_list:
+ cat = int(k[0])
+ X = float(k[1])
+ Y = float(k[2])
+ prob = float(k[3])
+ Strahler = int(k[4])
coors = str(X)+","+str(Y)
- grass.debug(_("Source point coors:"+coors+" in segment nr: " +str(Segment)))
+ # Progress bar
+ # add here progressbar
+ # Debug messages
+ grass.debug(_("Start looping over source points"))
+ grass.debug(_("Source point coors:"+coors+" in segment nr: " +str(segment_cat)))
#Select dispersal parameters
SO = 'SO='+str(Strahler)
@@ -583,8 +602,9 @@
grass.debug(_("This is "+str(SO)))
sigma_stat = fishmove.rx(i,'sigma_stat',1,1,SO,1)
sigma_mob = fishmove.rx(i,'sigma_mob',1,1,SO,1)
+ grass.debug(_("Dispersal parameters: prob="+str(prob)+", sigma_stat="+str(sigma_stat)+", sigma_mob="+str(sigma_mob)+", p="+str(p)))
# Getting maximum distance (cutting distance) based on truncation criterion
def func(x,sigma_stat,sigma_mob,m,truncation,p):
return p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob) - truncation
@@ -628,7 +648,7 @@
# MAIN PART: leptokurtic probability density kernel based on fishmove
grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
- grass.debug(_("Dispersal parameters: prob="+str(prob)+", sigma_stat="+str(sigma_stat)+", sigma_mob="+str(sigma_mob)+", p="+str(p)))
def cdf(x):
return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob
@@ -711,26 +731,32 @@
distance_from_point = "distance_from_point_tmp_%d" % os.getpid(),
overwrite = True)
- #Getting distance of barriers from segment and information if barrier is involved/affected
+ #Getting distance of barriers and information if barrier is involved/affected
map = "barriers_%d" % os.getpid(),
raster = "distance_upstream_point_tmp_%d" % os.getpid(),
column = "dist")
- ### ! Delete the creation of the column affected_barriers in barriers point
- #To find out if a loop over the affected barriers is the last loop (find the upstream most barrier)
- db.execute('SELECT MAX(dist) FROM barriers_%d WHERE dist > 0 ORDER BY dist' % os.getpid())
- last_barrier = db.fetchone()[0]
# Loop over the affected barriers (from most downstream barrier to most upstream barrier)
# Initally affected = all barriers where density > 0
- for new_X,new_Y,dist,permeability_col in db.execute('SELECT new_X, new_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist' % (permeability_col,os.getpid())):
+ barriers_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, new_X, new_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist" % (permeability_col,os.getpid())).split("\n")[:-1] # remove last (empty line)
+ barriers_list = list(csv.reader(barriers_list,delimiter="|"))
+ #if affected barriers then define the last loop (find the upstream most barrier)
+ if barriers_list:
+ last_barrier = float(barriers_list[-1][3])
+ for l in barriers_list:
+ cat = int(l[0])
+ new_X = float(l[1])
+ new_Y = float(l[2])
+ dist = float(l[3])
+ permeability = float(l[4])
coors_barriers = str(new_X)+","+str(new_Y)
- permeability = float(permeability_col)
- grass.debug(_("Starting with calculating barriers-effect (barrier-coors: "+coors_barriers+")"))
+ grass.debug(_("Starting with calculating barriers-effect (coors_barriers: "+coors_barriers+")"))
#Defining upstream the barrier
grass.run_command("r.stream.basins",
@@ -738,6 +764,8 @@
dirs = "flow_direction_tmp_%d" % os.getpid(),
coors = coors_barriers,
basins = "upstream_barrier_tmp_%d" % os.getpid())
+ grass.run_command("r.null", map="density_"+str(cat), setnull="0")
#Getting density upstream barrier only
grass.mapcalc("$upstream_barrier_density = if($upstream_barrier, $density, null())",
@@ -789,7 +817,7 @@
grass.debug(_("sum_inv_distance_downstream_barrier: "+str(sum_inv_distance_downstream_barrier)))
- #Calculation Kernel Density downstream the barrier
+ #Calculation Density downstream the barrier
grass.mapcalc("$downstream_barrier_density = ($density_for_downstream/$sum_inv_distance_downstream_barrier)/$distance_downstream_barrier",
downstream_barrier_density = "downstream_barrier_density_tmp_%d" % os.getpid(),
density_for_downstream=density_for_downstream,
@@ -817,6 +845,7 @@
#If the barrier in the loop was impermeable (permeability=0)
#than no more upstream barriers need to be considered --> break
if permeability == 0:
+ grass.run_command("r.null", map="density_"+str(cat), null="0")
break
@@ -843,7 +872,7 @@
mapcalc_string_B_removal = ",".join(mapcalc_list_B)
# Final raster map, Final map is sum of all
- # density maps (for each segement), All contirbuting maps (string_B_removal) are deleted
+ # density maps (for each segement), All contributing maps (string_B_removal) are deleted
# in the end.
grass.mapcalc("$density_final = $mapcalc_string_B_aggregate",
density_final = "density_final_%d" % os.getpid(),
