[GRASS-SVN] r55888 - grass/trunk/mswindows
Thu Apr 18 03:43:21 PDT 2013
Author: hamish
Date: 2013-04-18 03:43:21 -0700 (Thu, 18 Apr 2013)
New Revision: 55888
   grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
cmd terminal was removed so remove it from the tooltip; minimize the dos box (merge from devbr6)
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2013-04-18 10:42:42 UTC (rev 55887)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2013-04-18 10:43:21 UTC (rev 55888)
@@ -632,7 +632,7 @@
 	SetShellVarContext current
 	CreateShortCut "$DESKTOP\${GRASS_BASE}.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
-	"$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD terminal"
+	"$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI"
 	;Create the Windows Start Menu Shortcuts
 	SetShellVarContext all
@@ -640,7 +640,7 @@
 	CreateDirectory "$SMPROGRAMS\${GRASS_BASE}"
 	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\${GRASS_BASE} GUI.lnk" "$INSTALL_DIR\${GRASS_COMMAND}.bat" "-wx"\
-	"$INSTALL_DIR\etc\gui\icons\grass.ico" "" SW_SHOWMINIMIZED "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console"
 	CreateShortCut "$SMPROGRAMS\${GRASS_BASE}\${GRASS_BASE} GUI with MSYS.lnk" "$INSTALL_DIR\${GRASS_COMMAND}_msys.bat" "-wx"\
 	"$INSTALL_DIR\etc\gui\icons\grass_msys.ico" "" SW_SHOWNORMAL "" "Launch GRASS ${VERSION_NUMBER} with wxGUI and MSYS UNIX console"
