[GRASS-SVN] r55899 - grass/branches/releasebranch_6_4/gui/wxpython/gmodeler
svn_grass at osgeo.org
Thu Apr 18 06:51:06 PDT 2013
Author: annakrat
Date: 2013-04-18 06:51:06 -0700 (Thu, 18 Apr 2013)
New Revision: 55899
grass/branches/releasebranch_6_4/gui/wxpython/gmodeler/frame.py
wxGUI/modeler: make random layout (avoid hidden actions), fix removing by right click (merge from trunk, r55898)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gmodeler/frame.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gmodeler/frame.py 2013-04-18 13:44:35 UTC (rev 55898)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gmodeler/frame.py 2013-04-18 13:51:06 UTC (rev 55899)
@@ -27,6 +27,7 @@
import tempfile
import copy
import re
+import random
if __name__ == "__main__":
sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'wxpython'))
@@ -71,6 +72,7 @@
self.baseTitle = title
self.modelFile = None # loaded model
self.modelChanged = False
+ self.randomness = 40 # random layout
self.cursors = {
"default" : wx.StockCursor(wx.CURSOR_ARROW),
@@ -149,6 +151,10 @@
evthandler.SetPreviousHandler(item.GetEventHandler())
item.SetEventHandler(evthandler)
+ def _randomShift(self):
+ """!Returns random value to shift layout"""
+ return random.randint(-self.randomness, self.randomness)
def GetCanvas(self):
"""!Get canvas"""
return self.canvas
@@ -633,7 +639,9 @@
# add action to canvas
x, y = self.canvas.GetNewShapePos()
- action = ModelAction(self.model, cmd = cmd, x = x, y = y,
+ action = ModelAction(self.model, cmd = cmd,
+ x = x + self._randomShift(),
+ y = y + self._randomShift(),
id = self.model.GetNextId())
overwrite = self.model.GetProperties().get('overwrite', None)
if overwrite is not None:
@@ -669,7 +677,8 @@
width, height = self.canvas.GetSize()
- data = ModelData(self, x = width/2, y = height/2)
+ data = ModelData(self, x = width/2 + self._randomShift(),
+ y = height/2 + self._randomShift())
dlg = ModelDataDialog(parent = self, shape = data)
data.SetPropDialog(dlg)
@@ -714,7 +723,8 @@
"""!Process action data"""
if params: # add data items
- x = [width/2 + 200, width/2 - 200]
+ x = width/2 - 200 + self._randomShift()
for p in params['params']:
if p.get('prompt', '') in ('raster', 'vector', 'raster3d') and \
(p.get('value', None) or \
@@ -742,7 +752,7 @@
data = ModelData(self, value = p.get('value', ''),
prompt = p.get('prompt', ''),
- x = x.pop(), y = height/2)
+ x = x, y = y)
self._addEvent(data)
self.canvas.diagram.AddShape(data)
data.Show(True)
@@ -973,7 +983,7 @@
self.SetDiagram(self.diagram)
self.diagram.SetCanvas(self)
- self.SetScrollbars(20, 20, 1000/20, 1000/20)
+ self.SetScrollbars(20, 20, 2000/20, 2000/20)
self.Bind(wx.EVT_CHAR, self.OnChar)
@@ -989,9 +999,14 @@
self.parent.ModelChanged()
diagram = self.GetDiagram()
- for shape in diagram.GetShapeList():
- if not shape.Selected():
- continue
+ shapes = [shape for shape in diagram.GetShapeList() if shape.Selected()]
+ self.RemoveShapes(shapes)
+ def RemoveShapes(self, shapes):
+ """!Removes shapes"""
+ self.parent.ModelChanged()
+ diagram = self.GetDiagram()
+ for shape in shapes:
remList, upList = self.parent.GetModel().RemoveItem(shape)
shape.Select(False)
diagram.RemoveShape(shape)
@@ -1004,7 +1019,7 @@
item.Update()
self.Refresh()
def GetNewShapePos(self):
"""!Determine optimal position for newly added object
@@ -1018,7 +1033,7 @@
yBox = shape.GetBoundingBoxMin()[1] / 2
if yBox > 0 and y < yNew + yBox and y > yNew - yBox:
yNew += yBox * 3
return xNew, yNew
class ModelEvtHandler(ogl.ShapeEvtHandler):
@@ -1249,7 +1264,7 @@
for s in toUnselect:
s.Select(False, dc)
canvas.Refresh(False)
def OnAddPoint(self, event):
@@ -1280,7 +1295,7 @@
def OnRemove(self, event):
"""!Remove shape
- self.frame.GetCanvas().RemoveSelected()
+ self.frame.GetCanvas().RemoveShapes([self.GetShape()])
self.frame.itemPanel.Update()
class VariablePanel(wx.Panel):
