[GRASS-SVN] r55905 - grass-promo/grasslecture/20130416_Trento_G7
Thu Apr 18 20:58:20 PDT 2013
Author: ychemin
Date: 2013-04-18 20:58:20 -0700 (Thu, 18 Apr 2013)
New Revision: 55905
Added:
   grass-promo/grasslecture/20130416_Trento_G7/architecture_implementation.png
   grass-promo/grasslecture/20130416_Trento_G7/chain1.png
   grass-promo/grasslecture/20130416_Trento_G7/chain2.png
   grass-promo/grasslecture/20130416_Trento_G7/sltemporaletb.png
   grass-promo/grasslecture/20130416_Trento_G7/Makefile
   grass-promo/grasslecture/20130416_Trento_G7/crowdsourceET.tex
Final version from the FEM talk
Modified: grass-promo/grasslecture/20130416_Trento_G7/Makefile
--- grass-promo/grasslecture/20130416_Trento_G7/Makefile	2013-04-19 00:31:57 UTC (rev 55904)
+++ grass-promo/grasslecture/20130416_Trento_G7/Makefile	2013-04-19 03:58:20 UTC (rev 55905)
@@ -3,8 +3,8 @@
 FILE=crowdsourceET
-SVGFILES = $(shell ls *.svg)
-SVGPDF = $(patsubst %.svg, %.pdf, $(SVGFILES))
+#SVGFILES = $(shell ls *.svg)
+#SVGPDF = $(patsubst %.svg, %.pdf, $(SVGFILES))
 all: $(FILE).pdf
Added: grass-promo/grasslecture/20130416_Trento_G7/architecture_implementation.png
(Binary files differ)
Property changes on: grass-promo/grasslecture/20130416_Trento_G7/architecture_implementation.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-promo/grasslecture/20130416_Trento_G7/chain1.png
Property changes on: grass-promo/grasslecture/20130416_Trento_G7/chain1.png
Added: grass-promo/grasslecture/20130416_Trento_G7/chain2.png
Property changes on: grass-promo/grasslecture/20130416_Trento_G7/chain2.png
Modified: grass-promo/grasslecture/20130416_Trento_G7/crowdsourceET.tex
--- grass-promo/grasslecture/20130416_Trento_G7/crowdsourceET.tex	2013-04-19 00:31:57 UTC (rev 55904)
+++ grass-promo/grasslecture/20130416_Trento_G7/crowdsourceET.tex	2013-04-19 03:58:20 UTC (rev 55905)
@@ -279,7 +279,59 @@
 \end{block}
 \end{frame}
+\subsection{Blueprint}
+\begin{frame}[fragile]{Blueprint}
+\begin{center}
+ \includegraphics[width=8cm]{chain0}
+\end{center}
+\begin{itemize}
+ \item GDAL+[C+OpenMP]
+ \item GRASSGIS+pyGRASS+[C+OpenMP]
+\end{itemize}
+\end{frame}
+\subsection{GDAL}
+\begin{frame}[fragile]{HPC GDAL framework}
+\begin{columns}[l]
+\column[t]{0.6\textwidth}
+\begin{center}
+ GDAL+[C+OpenMP]
+ \includegraphics[width=7.5cm]{chain2}
+\end{center}
+\column[t]{0.4\textwidth}
+\begin{center}
+ OpenMP distribution
+ \includegraphics[width=5cm]{chain1}
+\end{center}
+\end{columns}
+\end{frame}
+\subsection{GRASS GIS}
+\begin{frame}[fragile]{GRASS GIS framework}
+\begin{center}
+ \includegraphics[width=7.5cm]{architecture_implementation}
+\end{center}
+\begin{block}{metaModule concept}
+{\bf pyGRASS:} vertical integration of GRASS GIS modules\\
+{\bf GRASS GIS modules:} [C+OpenMP] any multi-core PC \\
+{\bf GRASS GIS modules:} [C+MPIch?] in FEM - GISCluster \\
+{\bf GRASS GIS modules:} [C+CUDA/GPGPU?] in FEM - Tesla
+\end{block}
+\end{frame}
 \begin{frame}[fragile]{Chain processing}
 The development of pyGRASS is maturing,\\
@@ -291,6 +343,25 @@
 \end{frame}
+\begin{frame}[fragile]{Initial results of ET Models comparison}
+\begin{center}
+ Average ET for Sri Lanka, Daily 2000-2012 (mm/d, daily, 12.3 years)
+ \includegraphics[width=12cm]{sltemporaletb}
+\end{center}
+\begin{block}{Comparison}
+\begin{itemize}
+ \item ETo \& ETpot (rad) are similar, expected.
+ \item ETa models are not so similar, expected.
+ \item ETo \& ETpot (rad) are higher than ETa models, expected.
+\end{itemize}
+\end{block}
+\end{frame}
 \subsection{MOD 16}
 \begin{frame}[fragile]{MOD16 MODIS product}
@@ -334,7 +405,6 @@
 \end{frame}
-\subsection{Year 1}
 \begin{frame}[fragile]{set up for year 1: Kick the geek}
@@ -355,7 +425,6 @@
 \end{frame}
-\subsection{Year 2}
 \begin{frame}[fragile]{set up for year 2: Bring the bee}
@@ -377,7 +446,6 @@
 \end{frame}
-\subsection{Year 3}
 \begin{frame}[fragile]{set up for year 3: Ubergeek upgrade}
Added: grass-promo/grasslecture/20130416_Trento_G7/sltemporaletb.png
Property changes on: grass-promo/grasslecture/20130416_Trento_G7/sltemporaletb.png
