[GRASS-SVN] r55909 - grass/trunk/vector/v.clean
svn_grass at osgeo.org
Fri Apr 19 01:07:15 PDT 2013
Author: mmetz
Date: 2013-04-19 01:07:14 -0700 (Fri, 19 Apr 2013)
New Revision: 55909
grass/trunk/vector/v.clean/main.c
v.clean: enable -c flag also for lines
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2013-04-19 07:42:44 UTC (rev 55908)
+++ grass/trunk/vector/v.clean/main.c 2013-04-19 08:07:14 UTC (rev 55909)
@@ -347,18 +347,18 @@
switch (tools[i]) {
case TOOL_BREAK:
- if (flag.combine->answer && (otype & GV_BOUNDARY)) {
- G_message(_("Tool: Split boundaries"));
- split_lines(&Out, GV_BOUNDARY, pErr);
+ if (flag.combine->answer && (otype & GV_LINES)) {
+ G_message(_("Tool: Split lines"));
+ split_lines(&Out, otype, pErr);
G_message(_("Tool: Break lines at intersections"));
Vect_break_lines(&Out, otype, pErr);
if (flag.combine->answer) {
G_message(_("Tool: Remove duplicates"));
Vect_remove_duplicates(&Out, otype, pErr);
- if (otype & GV_BOUNDARY) {
- G_message(_("Tool: Merge boundaries"));
- Vect_merge_lines(&Out, GV_BOUNDARY, NULL, pErr);
+ if (otype & GV_LINES) {
+ G_message(_("Tool: Merge lines"));
+ Vect_merge_lines(&Out, otype, NULL, pErr);
break;
@@ -392,9 +392,9 @@
int nmod;
do {
@@ -405,9 +405,9 @@
nmod =
Vect_clean_small_angles_at_nodes(&Out, otype, pErr);
} while (nmod > 0);
break;
@@ -427,6 +427,10 @@
G_message(_("Tool: Remove small areas"));
count =
Vect_remove_small_areas(&Out, threshs[i], pErr, &size);
+ if (flag.combine->answer && count > 0) {
+ G_message(_("Tool: Merge boundaries"));
+ Vect_merge_lines(&Out, GV_BOUNDARY, NULL, pErr);
break;
case TOOL_RMSA:
G_message(_("Tool: Remove small angles at nodes"));
@@ -437,9 +441,9 @@
else {
int nmod;
while ((nmod =
Vect_clean_small_angles_at_nodes(&Out, otype, pErr)) > 0) {
@@ -450,9 +454,9 @@
break;
