[GRASS-SVN] r55916 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Fri Apr 19 06:21:38 PDT 2013
Author: annakrat
Date: 2013-04-19 06:21:37 -0700 (Fri, 19 Apr 2013)
New Revision: 55916
grass/trunk/gui/wxpython/modules/vclean.py
wxGUI/vclean: whitespace changes (remove tabs, pep8 compliance)
Modified: grass/trunk/gui/wxpython/modules/vclean.py
--- grass/trunk/gui/wxpython/modules/vclean.py 2013-04-19 12:39:08 UTC (rev 55915)
+++ grass/trunk/gui/wxpython/modules/vclean.py 2013-04-19 13:21:37 UTC (rev 55916)
@@ -27,431 +27,430 @@
from core.debug import Debug
from core.settings import UserSettings
class VectorCleaningFrame(wx.Frame):
- def __init__(self, parent, id = wx.ID_ANY, title = _('Set up vector cleaning tools'),
- style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
+ def __init__(self, parent, id=wx.ID_ANY, title=_('Set up vector cleaning tools'),
+ style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
**kwargs):
Dialog for interactively defining vector cleaning tools
- wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
- self.parent = parent # GMFrame
+ wx.Frame.__init__(self, parent, id, title, style=style, **kwargs)
+ self.parent = parent # GMFrame
if self.parent:
self.log = self.parent.GetLogWindow()
else:
self.log = None
# grass command
self.cmd = 'v.clean'
# statusbar
self.CreateStatusBar()
- # icon
+ # icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
- self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
# input map to clean
self.inmap = ''
# cleaned output map
self.outmap = ''
- self.ftype = ''
+ self.ftype = ''
# cleaning tools
self.toolslines = {}
self.tool_desc_list = [
_('break lines/boundaries'),
_('remove duplicates'),
_('remove dangles'),
_('change boundary dangles to lines'),
_('remove bridges'),
- _('change bridges to lines'),
- _('snap lines/boundaries'),
- _('remove duplicate area centroids'),
- _('break polygons'),
- _('prune lines/boundaries'),
- _('remove small areas'),
- _('remove lines/boundaries of zero length'),
- _('remove small angles at nodes')
+ _('change bridges to lines'),
+ _('snap lines/boundaries'),
+ _('remove duplicate area centroids'),
+ _('break polygons'),
+ _('prune lines/boundaries'),
+ _('remove small areas'),
+ _('remove lines/boundaries of zero length'),
+ _('remove small angles at nodes')
self.tool_list = [
'break',
'rmdupl',
'rmdangle',
'chdangle',
'rmbridge',
- 'chbridge',
- 'snap',
- 'rmdac',
- 'bpol',
- 'prune',
- 'rmarea',
- 'rmline',
- 'rmsa'
- self.ftype = [
- 'point',
- 'line',
- 'boundary',
- 'centroid',
- 'area',
- 'face']
- self.n_ftypes = len(self.ftype)
- self.tools_string = ''
- self.thresh_string = ''
- self.ftype_string = ''
- self.SetStatusText(_("Set up vector cleaning tools"))
- self.elem = 'vector'
- self.ctlabel = _('Choose cleaning tools and set thresholds')
+ 'chbridge',
+ 'snap',
+ 'rmdac',
+ 'bpol',
+ 'prune',
+ 'rmarea',
+ 'rmline',
+ 'rmsa'
+ self.ftype = [
+ 'point',
+ 'line',
+ 'boundary',
+ 'centroid',
+ 'area',
+ 'face']
+ self.n_ftypes = len(self.ftype)
+ self.tools_string = ''
+ self.thresh_string = ''
+ self.ftype_string = ''
+ self.SetStatusText(_("Set up vector cleaning tools"))
+ self.elem = 'vector'
+ self.ctlabel = _('Choose cleaning tools and set thresholds')
# top controls
- self.inmaplabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label= _('Select input vector map:'))
- self.selectionInput = Select(parent = self.panel, id = wx.ID_ANY,
- size = globalvar.DIALOG_GSELECT_SIZE,
- type = 'vector')
- self.ftype_check = {}
- ftypeBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label = _(' Feature type: '))
+ self.inmaplabel = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_('Select input vector map:'))
+ self.selectionInput = Select(parent=self.panel, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE,
+ type='vector')
+ self.ftype_check = {}
+ ftypeBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+ label=_(' Feature type: '))
self.ftypeSizer = wx.StaticBoxSizer(ftypeBox, wx.HORIZONTAL)
- self.outmaplabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = _('Select output vector map:'))
- self.selectionOutput = Select(parent = self.panel, id = wx.ID_ANY,
- type = 'vector')
- self.overwrite = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
- label = _('Allow output files to overwrite existing files'))
- self.overwrite.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
+ self.outmaplabel = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_('Select output vector map:'))
+ self.selectionOutput = Select(parent=self.panel, id=wx.ID_ANY,
+ type='vector')
+ self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
+ label=_('Allow output files to overwrite existing files'))
+ self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
# cleaning tools
- self.ct_label = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = self.ctlabel)
+ self.ct_label = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=self.ctlabel)
self.ct_panel = self._toolsPanel()
- # buttons to manage cleaning tools
- self.btn_add = wx.Button(parent = self.panel, id = wx.ID_ADD)
- self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_REMOVE)
- self.btn_moveup = wx.Button(parent = self.panel, id = wx.ID_UP)
- self.btn_movedown = wx.Button(parent = self.panel, id = wx.ID_DOWN)
+ # buttons to manage cleaning tools
+ self.btn_add = wx.Button(parent=self.panel, id=wx.ID_ADD)
+ self.btn_remove = wx.Button(parent=self.panel, id=wx.ID_REMOVE)
+ self.btn_moveup = wx.Button(parent=self.panel, id=wx.ID_UP)
+ self.btn_movedown = wx.Button(parent=self.panel, id=wx.ID_DOWN)
# add one tool as default
self.AddTool()
- self.selected = -1
+ self.selected = -1
# Buttons
- self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
- self.btn_run = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("&Run"))
+ self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
+ self.btn_run = wx.Button(parent=self.panel, id=wx.ID_ANY, label=_("&Run"))
self.btn_run.SetDefault()
- self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY)
- self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
- self.btn_help = wx.Button(parent = self.panel, id = wx.ID_HELP)
+ self.btn_clipboard = wx.Button(parent=self.panel, id=wx.ID_COPY)
+ self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
+ self.btn_help = wx.Button(parent=self.panel, id=wx.ID_HELP)
# bindings
self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnCleaningRun)
- self.btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
+ self.btn_clipboard.Bind(wx.EVT_BUTTON, self.OnCopy)
self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
self.btn_add.Bind(wx.EVT_BUTTON, self.OnAddTool)
self.btn_remove.Bind(wx.EVT_BUTTON, self.OnClearTool)
self.btn_moveup.Bind(wx.EVT_BUTTON, self.OnMoveToolUp)
self.btn_movedown.Bind(wx.EVT_BUTTON, self.OnMoveToolDown)
# layout
self._layout()
self.SetMinSize(self.GetBestSize())
self.CentreOnScreen()
def _layout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
# input output
- inSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ inSizer = wx.GridBagSizer(hgap=5, vgap=5)
- inSizer.Add(item = self.inmaplabel, pos = (0, 0),
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 1)
- inSizer.Add(item = self.selectionInput, pos = (1, 0),
+ inSizer.Add(item=self.inmaplabel, pos=(0, 0),
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border=1)
+ inSizer.Add(item=self.selectionInput, pos=(1, 0),
- self.ftype_check = [
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('point')),
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('line')),
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('boundary')),
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('centroid')),
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('area')),
- wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('face'))
+ self.ftype_check = [
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('point')),
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('line')),
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('boundary')),
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('centroid')),
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('area')),
+ wx.CheckBox(parent=self.panel, id=wx.ID_ANY, label=_('face'))
- typeoptSizer = wx.BoxSizer(wx.HORIZONTAL)
- for num in range(0, self.n_ftypes):
- type_box = self.ftype_check[num]
- typeoptSizer.Add(item = type_box, flag = wx.ALIGN_LEFT, border = 1)
+ typeoptSizer = wx.BoxSizer(wx.HORIZONTAL)
+ for num in range(0, self.n_ftypes):
+ type_box = self.ftype_check[num]
+ typeoptSizer.Add(item=type_box, flag=wx.ALIGN_LEFT, border=1)
- self.ftypeSizer.Add(item = typeoptSizer,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = 2)
+ self.ftypeSizer.Add(item=typeoptSizer,
+ flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=2)
- outSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ outSizer = wx.GridBagSizer(hgap=5, vgap=5)
- outSizer.Add(item = self.outmaplabel, pos = (0, 0),
- outSizer.Add(item = self.selectionOutput, pos = (1, 0),
+ outSizer.Add(item=self.outmaplabel, pos=(0, 0),
+ outSizer.Add(item=self.selectionOutput, pos=(1, 0),
replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
- replaceSizer.Add(item = self.overwrite, proportion = 1,
- flag = wx.ALL | wx.EXPAND, border = 1)
+ replaceSizer.Add(item=self.overwrite, proportion=1,
+ flag=wx.ALL | wx.EXPAND, border=1)
- outSizer.Add(item = replaceSizer, pos = (2, 0),
+ outSizer.Add(item=replaceSizer, pos=(2, 0),
# tools selection
- bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ bodySizer = wx.GridBagSizer(hgap=5, vgap=5)
- bodySizer.Add(item = self.ct_label, pos = (0, 0), span = (1, 2),
- flag = wx.ALL, border = 5)
+ bodySizer.Add(item=self.ct_label, pos=(0, 0), span=(1, 2),
+ flag=wx.ALL, border=5)
- bodySizer.Add(item = self.ct_panel, pos = (1, 0), span = (1, 2))
+ bodySizer.Add(item=self.ct_panel, pos=(1, 0), span=(1, 2))
- manageBoxSizer = wx.GridBagSizer(hgap = 10, vgap = 1)
- # start with row 1 for nicer layout
- manageBoxSizer.Add(item = self.btn_add, pos = (1, 0), border = 2, flag = wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item = self.btn_remove, pos = (2, 0), border = 2, flag = wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item = self.btn_moveup, pos = (3, 0), border = 2, flag = wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item = self.btn_movedown, pos = (4, 0), border = 2, flag = wx.ALL | wx.EXPAND)
+ manageBoxSizer = wx.GridBagSizer(hgap=10, vgap=1)
+ # start with row 1 for nicer layout
+ manageBoxSizer.Add(item=self.btn_add, pos=(1, 0), border=2, flag=wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item=self.btn_remove, pos=(2, 0), border=2, flag=wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item=self.btn_moveup, pos=(3, 0), border=2, flag=wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item=self.btn_movedown, pos=(4, 0), border=2, flag=wx.ALL | wx.EXPAND)
- bodySizer.Add(item = manageBoxSizer, pos = (1, 2),
- flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
+ bodySizer.Add(item=manageBoxSizer, pos=(1, 2),
+ flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
bodySizer.AddGrowableCol(2)
# standard buttons
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(self.btn_close,
- flag = wx.LEFT | wx.RIGHT, border = 5)
+ flag=wx.LEFT | wx.RIGHT, border=5)
btnSizer.Add(self.btn_run,
btnSizer.Add(self.btn_clipboard,
btnSizer.Add(self.btn_help,
# put it all together
- sizer.Add(item = inSizer, proportion = 0,
- flag = wx.ALL | wx.EXPAND, border = 5)
- sizer.Add(item = self.ftypeSizer, proportion = 0,
+ sizer.Add(item=inSizer, proportion=0,
+ flag=wx.ALL | wx.EXPAND, border=5)
- sizer.Add(item = outSizer, proportion = 0,
+ sizer.Add(item=self.ftypeSizer, proportion=0,
- sizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
- style = wx.LI_HORIZONTAL), proportion = 0,
- flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = bodySizer, proportion = 1,
+ sizer.Add(item=outSizer, proportion=0,
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
+ sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
+ style=wx.LI_HORIZONTAL), proportion=0,
+ flag=wx.EXPAND | wx.ALL, border=5)
+ sizer.Add(item=bodySizer, proportion=1,
+ sizer.Add(item=btnSizer, proportion=0,
+ flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
self.panel.SetAutoLayout(True)
self.panel.SetSizer(sizer)
sizer.Fit(self.panel)
self.Layout()
def _toolsPanel(self):
- ct_panel = scrolled.ScrolledPanel(parent = self.panel, id = wx.ID_ANY,
- size = (500, 240),
- style = wx.SUNKEN_BORDER)
+ ct_panel = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY,
+ size=(500, 240),
+ style=wx.SUNKEN_BORDER)
- self.ct_sizer = wx.GridBagSizer(vgap = 2, hgap = 4)
+ self.ct_sizer = wx.GridBagSizer(vgap=2, hgap=4)
ct_panel.SetSizer(self.ct_sizer)
ct_panel.SetAutoLayout(True)
- return ct_panel
+ return ct_panel
def OnAddTool(self, event):
"""!Add tool button pressed"""
- self.AddTool()
+ self.AddTool()
def AddTool(self):
snum = len(self.toolslines.keys())
- num = snum + 1
- # tool number
- tool_no = wx.StaticText(parent = self.ct_panel, id = 3000+num,
- label = str(num)+'.')
- # tool
- tool_cbox = wx.ComboBox(parent = self.ct_panel, id = 1000+num,
- size = (300, -1), choices = self.tool_desc_list,
- style = wx.CB_DROPDOWN |
- wx.CB_READONLY | wx.TE_PROCESS_ENTER)
- self.Bind(wx.EVT_COMBOBOX, self.OnSetTool, tool_cbox)
- # threshold
- txt_ctrl = wx.TextCtrl(parent = self.ct_panel, id = 2000+num, value = '0.00',
- size = (100,-1),
- style = wx.TE_NOHIDESEL)
- self.Bind(wx.EVT_TEXT, self.OnThreshValue, txt_ctrl)
+ num = snum + 1
+ # tool number
+ tool_no = wx.StaticText(parent=self.ct_panel, id=3000 + num,
+ label=str(num) + '.')
+ # tool
+ tool_cbox = wx.ComboBox(parent=self.ct_panel, id=1000 + num,
+ size=(300, -1), choices=self.tool_desc_list,
+ style=wx.CB_DROPDOWN |
+ wx.CB_READONLY | wx.TE_PROCESS_ENTER)
+ self.Bind(wx.EVT_COMBOBOX, self.OnSetTool, tool_cbox)
+ # threshold
+ txt_ctrl = wx.TextCtrl(parent=self.ct_panel, id=2000 + num, value='0.00',
+ size=(100, -1),
+ style=wx.TE_NOHIDESEL)
+ self.Bind(wx.EVT_TEXT, self.OnThreshValue, txt_ctrl)
- # select
- select = wx.CheckBox(parent = self.ct_panel, id = num)
- select.SetValue(False)
- self.Bind(wx.EVT_CHECKBOX, self.OnSelect, select)
+ # select
+ select = wx.CheckBox(parent=self.ct_panel, id=num)
+ select.SetValue(False)
+ self.Bind(wx.EVT_CHECKBOX, self.OnSelect, select)
- # start with row 1 and col 1 for nicer layout
- self.ct_sizer.Add(item = tool_no, pos = (num, 1),
- flag = wx.ALIGN_CENTER_VERTICAL, border = 5)
- self.ct_sizer.Add(item = tool_cbox, pos = (num, 2),
- flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
- self.ct_sizer.Add(item = txt_ctrl, pos = (num, 3),
- self.ct_sizer.Add(item = select, pos = (num, 4),
- flag = wx.ALIGN_CENTER | wx.RIGHT)
+ # start with row 1 and col 1 for nicer layout
+ self.ct_sizer.Add(item=tool_no, pos=(num, 1),
+ flag=wx.ALIGN_CENTER_VERTICAL, border=5)
+ self.ct_sizer.Add(item=tool_cbox, pos=(num, 2),
+ flag=wx.ALIGN_CENTER | wx.RIGHT, border=5)
+ self.ct_sizer.Add(item=txt_ctrl, pos=(num, 3),
+ self.ct_sizer.Add(item=select, pos=(num, 4),
+ flag=wx.ALIGN_CENTER | wx.RIGHT)
- self.toolslines[num] = {
- 'tool_desc' : '' ,
- 'tool' : '' ,
- 'thresh' : '0.00' }
+ self.toolslines[num] = {'tool_desc': '',
+ 'tool': '',
+ 'thresh': '0.00'}
self.ct_panel.Layout()
self.ct_panel.SetupScrolling()
def OnClearTool(self, event):
"""!Remove tool button pressed"""
id = self.selected
- if id > 0:
- self.FindWindowById(id+1000).SetValue('')
- self.toolslines[id]['tool_desc'] = ''
- self.toolslines[id]['tool'] = ''
- self.SetStatusText(_("%s. cleaning tool removed, will be ignored") % id)
- else:
- self.SetStatusText(_("Please select a cleaning tool to remove"))
+ if id > 0:
+ self.FindWindowById(id + 1000).SetValue('')
+ self.toolslines[id]['tool_desc'] = ''
+ self.toolslines[id]['tool'] = ''
+ self.SetStatusText(_("%s. cleaning tool removed, will be ignored") % id)
+ else:
+ self.SetStatusText(_("Please select a cleaning tool to remove"))
def OnMoveToolUp(self, event):
"""!Move up tool button pressed"""
id = self.selected
- if id > 1:
- id_up = id - 1
- this_toolline = self.toolslines[id]
- up_toolline = self.toolslines[id_up]
- self.FindWindowById(id_up).SetValue(True)
- self.FindWindowById(id_up+1000).SetValue(this_toolline['tool_desc'])
- self.FindWindowById(id_up+2000).SetValue(this_toolline['thresh'])
- self.toolslines[id_up] = this_toolline
- self.FindWindowById(id).SetValue(False)
- self.FindWindowById(id+1000).SetValue(up_toolline['tool_desc'])
- self.FindWindowById(id+2000).SetValue(up_toolline['thresh'])
- self.toolslines[id] = up_toolline
- self.selected = id_up
- self.SetStatusText(_("%s. cleaning tool moved up") % id)
- elif id == 1:
- self.SetStatusText(_("1. cleaning tool can not be moved up "))
- elif id == -1:
- self.SetStatusText(_("Please select a cleaning tool to move up"))
+ if id > 1:
+ id_up = id - 1
+ this_toolline = self.toolslines[id]
+ up_toolline = self.toolslines[id_up]
+ self.FindWindowById(id_up).SetValue(True)
+ self.FindWindowById(id_up + 1000).SetValue(this_toolline['tool_desc'])
+ self.FindWindowById(id_up + 2000).SetValue(this_toolline['thresh'])
+ self.toolslines[id_up] = this_toolline
+ self.FindWindowById(id).SetValue(False)
+ self.FindWindowById(id + 1000).SetValue(up_toolline['tool_desc'])
+ self.FindWindowById(id + 2000).SetValue(up_toolline['thresh'])
+ self.toolslines[id] = up_toolline
+ self.selected = id_up
+ self.SetStatusText(_("%s. cleaning tool moved up") % id)
+ elif id == 1:
+ self.SetStatusText(_("1. cleaning tool can not be moved up "))
+ elif id == -1:
+ self.SetStatusText(_("Please select a cleaning tool to move up"))
def OnMoveToolDown(self, event):
"""!Move down tool button pressed"""
id = self.selected
- if id > 0 and id < snum:
- id_down = id + 1
- down_toolline = self.toolslines[id_down]
- self.FindWindowById(id_down).SetValue(True)
- self.FindWindowById(id_down+1000).SetValue(this_toolline['tool_desc'])
- self.FindWindowById(id_down+2000).SetValue(this_toolline['thresh'])
- self.toolslines[id_down] = this_toolline
- self.FindWindowById(id+1000).SetValue(down_toolline['tool_desc'])
- self.FindWindowById(id+2000).SetValue(down_toolline['thresh'])
- self.toolslines[id] = down_toolline
- self.selected = id_down
- self.SetStatusText(_("%s. cleaning tool moved down") % id)
- elif id == snum:
- self.SetStatusText(_("Last cleaning tool can not be moved down "))
- elif id == -1:
- self.SetStatusText(_("Please select a cleaning tool to move down"))
+ if id > 0 and id < snum:
+ id_down = id + 1
+ down_toolline = self.toolslines[id_down]
+ self.FindWindowById(id_down).SetValue(True)
+ self.FindWindowById(id_down + 1000).SetValue(this_toolline['tool_desc'])
+ self.FindWindowById(id_down + 2000).SetValue(this_toolline['thresh'])
+ self.toolslines[id_down] = this_toolline
+ self.FindWindowById(id + 1000).SetValue(down_toolline['tool_desc'])
+ self.FindWindowById(id + 2000).SetValue(down_toolline['thresh'])
+ self.toolslines[id] = down_toolline
+ self.selected = id_down
+ self.SetStatusText(_("%s. cleaning tool moved down") % id)
+ elif id == snum:
+ self.SetStatusText(_("Last cleaning tool can not be moved down "))
+ elif id == -1:
+ self.SetStatusText(_("Please select a cleaning tool to move down"))
def OnSetTool(self, event):
"""!Tool was defined"""
id = event.GetId()
- tool_no = id-1000
- num = self.FindWindowById(id).GetCurrentSelection()
+ tool_no = id - 1000
+ num = self.FindWindowById(id).GetCurrentSelection()
- self.toolslines[tool_no]['tool_desc'] = self.tool_desc_list[num]
- self.toolslines[tool_no]['tool'] = self.tool_list[num]
+ self.toolslines[tool_no]['tool_desc'] = self.tool_desc_list[num]
+ self.toolslines[tool_no]['tool'] = self.tool_list[num]
- self.SetStatusText( str(tool_no) + '. ' + _("cleaning tool: '%s'") % (self.tool_list[num]))
+ self.SetStatusText(str(tool_no) + '. ' + _("cleaning tool: '%s'") % (self.tool_list[num]))
def OnThreshValue(self, event):
"""!Threshold value was entered"""
id = event.GetId()
- num = id-2000
- self.toolslines[num]['thresh'] = self.FindWindowById(id).GetValue()
+ num = id - 2000
+ self.toolslines[num]['thresh'] = self.FindWindowById(id).GetValue()
- self.SetStatusText(_("Threshold for %(num)s. tool '%(tool)s': %(thresh)s") % \
- { 'num' : num,
- 'tool' : self.toolslines[num]['tool'],
- 'thresh' : self.toolslines[num]['thresh'] })
+ self.SetStatusText(_("Threshold for %(num)s. tool '%(tool)s': %(thresh)s") % \
+ {'num': num,
+ 'tool': self.toolslines[num]['tool'],
+ 'thresh': self.toolslines[num]['thresh']})
def OnSelect(self, event):
"""!Tool was selected"""
id = event.GetId()
- if self.selected > -1 and self.selected != id:
- win = self.FindWindowById(self.selected)
- win.SetValue(False)
+ if self.selected > -1 and self.selected != id:
+ win = self.FindWindowById(self.selected)
+ win.SetValue(False)
- if self.selected != id:
- else:
+ if self.selected != id:
+ else:
def OnDone(self, cmd, returncode):
"""!Command done"""
self.SetStatusText('')
def OnCleaningRun(self, event):
"""!Builds options and runs v.clean
self.GetCmdStrings()
err = list()
for p, name in ((self.inmap, _('Name of input vector map')),
(self.outmap, _('Name for output vector map')),
@@ -462,61 +461,61 @@
if err:
GError(_("Some parameters not defined. Operation "
"canceled.\n\n%s") % '\n'.join(err),
- parent = self)
+ parent=self)
return
- self.SetStatusText(_("Executing selected cleaning operations..."))
+ self.SetStatusText(_("Executing selected cleaning operations..."))
if self.log:
- cmd = [ self.cmd,
- 'input=%s' % self.inmap,
- 'output=%s' % self.outmap,
- 'tool=%s' % self.tools_string,
- 'thres=%s' % self.thresh_string ]
+ cmd = [self.cmd,
+ 'input=%s' % self.inmap,
+ 'output=%s' % self.outmap,
+ 'tool=%s' % self.tools_string,
+ 'thres=%s' % self.thresh_string]
if self.ftype_string:
cmd.append('type=%s' % self.ftype_string)
- if self.overwrite.IsChecked():
- cmd.append('--overwrite')
- self.log.RunCmd(cmd, onDone = self.OnDone)
+ if self.overwrite.IsChecked():
+ cmd.append('--overwrite')
+ self.log.RunCmd(cmd, onDone=self.OnDone)
self.parent.Raise()
else:
- overwrite = True
- else:
- overwrite = False
- RunCommand(self.cmd,
- input = self.inmap,
- output = self.outmap,
- type = self.ftype_string,
- tool = self.tools_string,
- thresh = self.thresh_string,
- overwrite = overwrite)
+ overwrite = True
+ else:
+ overwrite = False
+ RunCommand(self.cmd,
+ input=self.inmap,
+ output=self.outmap,
+ type=self.ftype_string,
+ tool=self.tools_string,
+ thresh=self.thresh_string,
+ overwrite=overwrite)
def OnClose(self, event):
self.Destroy()
def OnHelp(self, event):
"""!Show GRASS manual page"""
RunCommand('g.manual',
- quiet = True,
- parent = self,
- entry = self.cmd)
+ quiet=True,
+ parent=self,
+ entry=self.cmd)
def OnCopy(self, event):
"""!Copy the command"""
cmddata = wx.TextDataObject()
- # get tool and thresh strings
- self.GetCmdStrings()
+ # get tool and thresh strings
+ self.GetCmdStrings()
cmdstring = '%s' % (self.cmd)
# list -> string
cmdstring += ' input=%s output=%s type=%s tool=%s thres=%s' % \
- (self.inmap, self.outmap, self.ftype_string, self.tools_string, self.thresh_string)
- cmdstring += ' --overwrite'
+ (self.inmap, self.outmap, self.ftype_string, self.tools_string, self.thresh_string)
+ cmdstring += ' --overwrite'
cmddata.SetText(cmdstring)
if wx.TheClipboard.Open():
wx.TheClipboard.SetData(cmddata)
@@ -524,32 +523,31 @@
self.SetStatusText(_("Vector cleaning command copied to clipboard"))
def GetCmdStrings(self):
- # feature types
- first = 1
+ # feature types
+ first = 1
for num in range(0, self.n_ftypes - 1):
- if self.ftype_check[num].IsChecked():
- if first:
- self.ftype_string = '%s' % self.ftype[num]
- first = 0
- else:
- self.ftype_string += ',%s' % self.ftype[num]
- # cleaning tools
- first = 1
+ if self.ftype_check[num].IsChecked():
+ if first:
+ self.ftype_string = '%s' % self.ftype[num]
+ first = 0
+ else:
+ self.ftype_string += ',%s' % self.ftype[num]
+ # cleaning tools
+ first = 1
for num in range(1, snum + 1):
- if self.toolslines[num]['tool']:
- if first:
- self.tools_string = '%s' % self.toolslines[num]['tool']
- self.thresh_string = '%s' % self.toolslines[num]['thresh']
- first = 0
- else:
- self.tools_string += ',%s' % self.toolslines[num]['tool']
- self.thresh_string += ',%s' % self.toolslines[num]['thresh']
+ if self.toolslines[num]['tool']:
+ if first:
+ self.tools_string = '%s' % self.toolslines[num]['tool']
+ self.thresh_string = '%s' % self.toolslines[num]['thresh']
+ first = 0
+ else:
+ self.tools_string += ',%s' % self.toolslines[num]['tool']
+ self.thresh_string += ',%s' % self.toolslines[num]['thresh']
- self.inmap = self.selectionInput.GetValue()
- self.outmap = self.selectionOutput.GetValue()
+ self.inmap = self.selectionInput.GetValue()
+ self.outmap = self.selectionOutput.GetValue()
