[GRASS-SVN] r55919 - in grass/trunk: gui/wxpython gui/wxpython/animation gui/wxpython/core gui/wxpython/dbmgr gui/wxpython/gcp gui/wxpython/gmodeler gui/wxpython/gui_core gui/wxpython/iclass gui/wxpython/lmgr gui/wxpython/location_wizard gui/wxpython/mapdisp gui/wxpython/mapswipe gui/wxpython/modules gui/wxpython/nviz gui/wxpython/psmap gui/wxpython/rlisetup gui/wxpython/vdigit gui/wxpython/vnet gui/wxpython/web_services gui/wxpython/wxplot tools
Fri Apr 19 06:48:40 PDT 2013
Author: wenzeslaus
Date: 2013-04-19 06:48:40 -0700 (Fri, 19 Apr 2013)
New Revision: 55919
Added:
   grass/trunk/gui/wxpython/animation/__init__.py
   grass/trunk/gui/wxpython/core/__init__.py
   grass/trunk/gui/wxpython/dbmgr/__init__.py
   grass/trunk/gui/wxpython/gcp/__init__.py
   grass/trunk/gui/wxpython/gmodeler/__init__.py
   grass/trunk/gui/wxpython/gui_core/__init__.py
   grass/trunk/gui/wxpython/iclass/__init__.py
   grass/trunk/gui/wxpython/lmgr/__init__.py
   grass/trunk/gui/wxpython/location_wizard/__init__.py
   grass/trunk/gui/wxpython/mapdisp/__init__.py
   grass/trunk/gui/wxpython/mapswipe/__init__.py
   grass/trunk/gui/wxpython/modules/__init__.py
   grass/trunk/gui/wxpython/nviz/__init__.py
   grass/trunk/gui/wxpython/psmap/__init__.py
   grass/trunk/gui/wxpython/rlisetup/__init__.py
   grass/trunk/gui/wxpython/vdigit/__init__.py
   grass/trunk/gui/wxpython/vnet/__init__.py
   grass/trunk/gui/wxpython/web_services/__init__.py
   grass/trunk/gui/wxpython/wxplot/__init__.py
   grass/trunk/tools/create_python_init_file.py
Removed:
   grass/trunk/gui/wxpython/create__init__.py
   grass/trunk/gui/wxpython/Makefile
wxGUI: python package init files now part of source code (not in created my make, script for creation is in tools)
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile	2013-04-19 13:31:31 UTC (rev 55918)
+++ grass/trunk/gui/wxpython/Makefile	2013-04-19 13:48:40 UTC (rev 55919)
@@ -34,7 +34,6 @@
 $(PYDSTDIRS): %: | $(ETCDIR)
 	$(MKDIR) $@
-	$(call run_grass,$(PYTHON) create__init__.py $@)
 $(DSTDIRS): %: | $(ETCDIR)
 	$(MKDIR) $@
Added: grass/trunk/gui/wxpython/animation/__init__.py
--- grass/trunk/gui/wxpython/animation/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/animation/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,12 @@
+all = [
+    'nviztask',
+    'temporal_manager',
+    'dialogs',
+    'mapwindow',
+    'g.gui.animation',
+    'controller',
+    'anim',
+    'toolbars',
+    'utils',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/animation/__init__.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
Added: grass/trunk/gui/wxpython/core/__init__.py
--- grass/trunk/gui/wxpython/core/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/core/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,16 @@
+all = [
+    'debug',
+    'gcmd',
+    'treemodel',
+    'ws',
+    'menutree',
+    'gconsole',
+    'events',
+    'render',
+    'units',
+    'settings',
+    'workspace',
+    'utils',
+    'globalvar',
+    'giface',
Property changes on: grass/trunk/gui/wxpython/core/__init__.py
   + text/x-python
   + native
Deleted: grass/trunk/gui/wxpython/create__init__.py
--- grass/trunk/gui/wxpython/create__init__.py	2013-04-19 13:31:31 UTC (rev 55918)
+++ grass/trunk/gui/wxpython/create__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -1,33 +0,0 @@
-#!/usr/bin/env python
-import os
-import sys
-import glob
-def main(path):
-    if not os.path.exists(path) or not os.path.isdir(path):
-        print >> sys.stderr, "'%s' is not a directory" % path
-        return 1
-    modules = []
-    for f in glob.glob(os.path.join(os.path.basename(path), '*.py')):
-        if f[-5:-3] == '__':
-            continue
-        modules.append(os.path.splitext(os.path.basename(f))[0])
-    fd = open(os.path.join(path, '__init__.py'), 'w')
-    try:
-        fd.write('all = [%s' % os.linesep)
-        for m in modules:
-            fd.write("    '%s',%s" % (m, os.linesep))
-        fd.write('    ]%s' % os.linesep)
-    finally:
-        fd.close()
-    return 0
-if __name__ == "__main__":
-    if len(sys.argv) < 2:
-        sys.exit("usage: %s path/to/gui_modules" % sys.argv[0])
-    sys.exit(main(sys.argv[1]))
Added: grass/trunk/gui/wxpython/dbmgr/__init__.py
--- grass/trunk/gui/wxpython/dbmgr/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/dbmgr/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,8 @@
+all = [
+    'g.gui.dbmgr',
+    'sqlbuilder',
+    'vinfo',
+    'manager',
+    'base',
+    'dialogs',
Property changes on: grass/trunk/gui/wxpython/dbmgr/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/gcp/__init__.py
--- grass/trunk/gui/wxpython/gcp/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gcp/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,5 @@
+all = [
+    'manager',
+    'mapdisplay',
+    'toolbars',
Property changes on: grass/trunk/gui/wxpython/gcp/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/gmodeler/__init__.py
--- grass/trunk/gui/wxpython/gmodeler/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gmodeler/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,10 @@
+all = [
+    'preferences',
+    'g.gui.gmodeler',
+    'menudata',
+    'model',
+    'pystc',
+    'dialogs',
+    'toolbars',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/gmodeler/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/gui_core/__init__.py
--- grass/trunk/gui/wxpython/gui_core/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/gui_core/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,16 @@
+all = [
+    'query',
+    'widgets',
+    'preferences',
+    'menu',
+    'dialogs',
+    'mapwindow',
+    'mapdisp',
+    'gselect',
+    'ghelp',
+    'prompt',
+    'goutput',
+    'forms',
+    'toolbars',
+    'treeview',
Property changes on: grass/trunk/gui/wxpython/gui_core/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/iclass/__init__.py
--- grass/trunk/gui/wxpython/iclass/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/iclass/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,9 @@
+all = [
+    'digit',
+    'plots',
+    'dialogs',
+    'g.gui.iclass',
+    'toolbars',
+    'statistics',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/iclass/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/lmgr/__init__.py
--- grass/trunk/gui/wxpython/lmgr/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/lmgr/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,8 @@
+all = [
+    'layertree',
+    'menudata',
+    'toolbars',
+    'pyshell',
+    'frame',
+    'giface',
Property changes on: grass/trunk/gui/wxpython/lmgr/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/location_wizard/__init__.py
--- grass/trunk/gui/wxpython/location_wizard/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/location_wizard/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,5 @@
+all = [
+    'wizard',
+    'base',
+    'dialogs',
Property changes on: grass/trunk/gui/wxpython/location_wizard/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/mapdisp/__init__.py
--- grass/trunk/gui/wxpython/mapdisp/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/mapdisp/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,9 @@
+all = [
+    'overlays',
+    'main',
+    'statusbar',
+    'mapwindow',
+    'toolbars',
+    'frame',
+    'gprint',
Property changes on: grass/trunk/gui/wxpython/mapdisp/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/mapswipe/__init__.py
--- grass/trunk/gui/wxpython/mapswipe/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/mapswipe/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,7 @@
+all = [
+    'g.gui.mapswipe',
+    'dialogs',
+    'mapwindow',
+    'toolbars',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/mapswipe/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/modules/__init__.py
--- grass/trunk/gui/wxpython/modules/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/modules/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,7 @@
+all = [
+    'mcalc_builder',
+    'extensions',
+    'vclean',
+    'colorrules',
+    'histogram',
Property changes on: grass/trunk/gui/wxpython/modules/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/nviz/__init__.py
--- grass/trunk/gui/wxpython/nviz/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/nviz/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,9 @@
+all = [
+    'preferences',
+    'main',
+    'mapwindow',
+    'tools',
+    'wxnviz',
+    'workspace',
+    'animation',
Property changes on: grass/trunk/gui/wxpython/nviz/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/psmap/__init__.py
--- grass/trunk/gui/wxpython/psmap/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/psmap/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,9 @@
+all = [
+    'g.gui.psmap',
+    'menudata',
+    'dialogs',
+    'instructions',
+    'toolbars',
+    'utils',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/psmap/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/rlisetup/__init__.py
--- grass/trunk/gui/wxpython/rlisetup/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/rlisetup/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,6 @@
+all = [
+    'g.gui.rlisetup',
+    'wizard',
+    'functions',
+    'frame',
Property changes on: grass/trunk/gui/wxpython/rlisetup/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/vdigit/__init__.py
--- grass/trunk/gui/wxpython/vdigit/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,10 @@
+all = [
+    'preferences',
+    'main',
+    'wxdigit',
+    'dialogs',
+    'mapwindow',
+    'wxdisplay',
+    'g.gui.vdigit',
+    'toolbars',
Property changes on: grass/trunk/gui/wxpython/vdigit/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/vnet/__init__.py
--- grass/trunk/gui/wxpython/vnet/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/vnet/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,5 @@
+all = [
+    'widgets',
+    'dialogs',
+    'toolbars',
Property changes on: grass/trunk/gui/wxpython/vnet/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/web_services/__init__.py
--- grass/trunk/gui/wxpython/web_services/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/web_services/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,5 @@
+all = [
+    'widgets',
+    'cap_interface',
+    'dialogs',
Property changes on: grass/trunk/gui/wxpython/web_services/__init__.py
   + text/x-python
   + native
Added: grass/trunk/gui/wxpython/wxplot/__init__.py
--- grass/trunk/gui/wxpython/wxplot/__init__.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/wxplot/__init__.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,7 @@
+all = [
+    'scatter',
+    'base',
+    'dialogs',
+    'profile',
+    'histogram',
Property changes on: grass/trunk/gui/wxpython/wxplot/__init__.py
   + text/x-python
   + native
Copied: grass/trunk/tools/create_python_init_file.py (from rev 55906, grass/trunk/gui/wxpython/create__init__.py)
--- grass/trunk/tools/create_python_init_file.py	                        (rev 0)
+++ grass/trunk/tools/create_python_init_file.py	2013-04-19 13:48:40 UTC (rev 55919)
@@ -0,0 +1,50 @@
+#!/usr/bin/env python
+Script for creating an __init__.py file for a package.
+Adds all modules (*.py files) in a directory into an __init__.py file.
+Overwrites existing __init__.py file in a directory.
+(C) 2011-2013 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Martin Landa <landa.martin gmail.com>
+ at author Vaclav Petras <wenzeslaus gmail.com>
+import os
+import sys
+import glob
+def main(path):
+    if not os.path.exists(path) or not os.path.isdir(path):
+        print >> sys.stderr, "'%s' is not a directory" % path
+        return 1
+    modules = []
+    pattern = os.path.join(path, '*.py')
+    for f in glob.glob(pattern):
+        if f[-5:-3] == '__':
+            continue
+        modules.append(os.path.splitext(os.path.basename(f))[0])
+    fd = open(os.path.join(path, '__init__.py'), 'w')
+    try:
+        fd.write('all = [%s' % os.linesep)
+        for m in modules:
+            fd.write("    '%s',%s" % (m, os.linesep))
+        fd.write('    ]%s' % os.linesep)
+    finally:
+        fd.close()
+    return 0
+if __name__ == "__main__":
+    if len(sys.argv) < 2:
+        sys.exit("usage: %s path/to/package/directory" % sys.argv[0])
+    sys.exit(main(sys.argv[1]))
