[GRASS-SVN] r55925 - grass/trunk/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Sat Apr 20 02:36:20 PDT 2013
Author: zarch
Date: 2013-04-20 02:36:19 -0700 (Sat, 20 Apr 2013)
New Revision: 55925
grass/trunk/lib/python/pygrass/modules/grid/grid.py
Add debug option, and fix the mapset of inputs
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-04-20 09:33:04 UTC (rev 55924)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-04-20 09:36:19 UTC (rev 55925)
@@ -12,6 +12,7 @@
from grass.pygrass.gis import Mapset, Location, make_mapset
from grass.pygrass.modules import Module
+from grass.pygrass.functions import get_mapset_raster
from split import split_region_tiles
from patch import patch_map
@@ -90,7 +91,7 @@
>>> grd.run()
def __init__(self, cmd, width=None, height=None, overlap=0, processes=None,
- split=False, *args, **kargs):
+ split=False, debug=False, *args, **kargs):
kargs['run_'] = False
self.mset = Mapset()
self.module = Module(cmd, *args, **kargs)
@@ -104,6 +105,7 @@
self.inlist = None
if split:
self.split()
+ self.debug = debug
def clean_location(self):
"""Remove all created mapsets."""
@@ -146,14 +148,27 @@
works.append((bbox, inms, self.msetstr % (row, col), cmd))
return works
+ def define_mapset_inputs(self):
+ for inmap in self.module.inputs:
+ inm = self.module.inputs[inmap]
+ if inm.type == 'raster' and inm.value:
+ if '@' not in inm.value:
+ mset = get_mapset_raster(inm.value)
+ inm.value = inm.value + '@%s' % mset
def run(self, patch=True, clean=True):
"""Run the GRASS command."""
self.module.flags.overwrite = True
- pool = mltp.Pool(processes=self.processes)
- result = pool.map_async(cmd_exe, self.get_works())
- result.wait()
- if not result.successful():
- raise RuntimeError
+ self.define_mapset_inputs()
+ if self.debug:
+ for wrk in self.get_works():
+ cmd_exe(wrk)
+ else:
+ pool = mltp.Pool(processes=self.processes)
+ result = pool.map_async(cmd_exe, self.get_works())
+ result.wait()
+ if not result.successful():
+ raise RuntimeError
if patch:
self.patch()
