[GRASS-SVN] r55936 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Sat Apr 20 10:17:12 PDT 2013
Author: zarch
Date: 2013-04-20 10:17:12 -0700 (Sat, 20 Apr 2013)
New Revision: 55936
grass/trunk/lib/python/pygrass/vector/__init__.py
Add a new parameter in the write method of the Vector class, to allow user to manage directly the category
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2013-04-20 15:34:46 UTC (rev 55935)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2013-04-20 17:17:12 UTC (rev 55936)
@@ -104,9 +104,25 @@
raise GrassError("Vect_rewind raise an error.")
@must_be_open
- def write(self, geo_obj, attrs=None):
- """Write geometry features and attributes
+ def write(self, geo_obj, attrs=None, set_cats=True):
+ """Write geometry features and attributes.
+ Parameters
+ geo_obj : geometry GRASS object
+ A geometry grass object define in grass.pygrass.vector.geometry.
+ attrs: list, optional
+ A list with the values that will be insert in the attribute table.
+ set_cats, bool, optional
+ If True, the category of the geometry feature is set using the
+ default layer of the vector map and a progressive category value
+ (default), otherwise the c_cats attribute of the geometry object
+ will be used.
+ Examples
Open a new vector map ::
>>> new = VectorTopo('newvect')
@@ -123,6 +139,7 @@
>>> new.open('w', tab_name='newvect', tab_cols=cols)
import a geometry feature ::
>>> from grass.pygrass.vector.geometry import Point
create two points ::
@@ -132,8 +149,8 @@
then write the two points on the map, with ::
- >>> new.write2(point0, ('pub', ))
- >>> new.write2(point1, ('resturnat', ))
+ >>> new.write(point0, ('pub', ))
+ >>> new.write(point1, ('resturnat', ))
close the vector map ::
@@ -165,7 +182,8 @@
cur.execute(self.table.columns.insert_str, attr)
cur.close()
- libvect.Vect_cat_set(geo_obj.c_cats, self.layer, self.n_lines)
+ if set_cats:
+ libvect.Vect_cat_set(geo_obj.c_cats, self.layer, self.n_lines)
result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
geo_obj.c_points, geo_obj.c_cats)
if result == -1:
