[GRASS-SVN] r55950 - grass/trunk
svn_grass at osgeo.org
Tue Apr 23 02:41:10 PDT 2013
Author: hamish
Date: 2013-04-23 02:41:10 -0700 (Tue, 23 Apr 2013)
New Revision: 55950
grass/trunk/configure
sync autoconf2.13'd ./configure for preliminary support for OpenCL (#1446)
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-04-23 09:40:21 UTC (rev 55949)
+++ grass/trunk/configure 2013-04-23 09:41:10 UTC (rev 55950)
@@ -67,6 +67,8 @@
ac_help="$ac_help
--with-openmp support OpenMP functionality (default: no)"
ac_help="$ac_help
+ --with-opencl support OpenCL functionality (default: no)"
+ac_help="$ac_help
--with-gdal[=path/gdal-config]
enable GDAL/OGR support (gdal-config with path,
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
@@ -208,6 +210,11 @@
ac_help="$ac_help
--with-openmp-libs=DIRS OpenMP library files are in DIRS"
ac_help="$ac_help
+ --with-opencl-includes=DIRS
+ OpenCL include files are in DIRS"
+ac_help="$ac_help
+ --with-opencl-libs=DIRS OpenCL library files are in DIRS"
+ac_help="$ac_help
--with-x use the X Window System"
ac_help="$ac_help
--enable-largefile enable support for large files (LFS)"
@@ -743,7 +750,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:747: checking host system type" >&5
+echo "configure:754: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -766,7 +773,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:770: checking for $ac_word" >&5
+echo "configure:777: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -793,7 +800,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:797: checking for $ac_word" >&5
+echo "configure:804: checking for $ac_word" >&5
@@ -841,7 +848,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:845: checking for $ac_word" >&5
+echo "configure:852: checking for $ac_word" >&5
@@ -870,7 +877,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:874: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -881,12 +888,12 @@
cat > conftest.$ac_ext << EOF
-#line 885 "configure"
+#line 892 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -912,19 +919,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:916: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:921: checking whether we are using GNU C" >&5
+echo "configure:928: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:928: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -942,7 +949,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:946: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -971,10 +978,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:975: checking for Cygwin environment" >&5
+echo "configure:982: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 978 "configure"
+#line 985 "configure"
int main() {
@@ -985,7 +992,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1001,17 +1008,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1005: checking for mingw32 environment" >&5
+echo "configure:1012: checking for mingw32 environment" >&5
-#line 1008 "configure"
+#line 1015 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1015: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1029,7 +1036,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1033: checking for executable suffix" >&5
+echo "configure:1040: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1048,23 +1055,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1052: checking for full floating-point support" >&5
+echo "configure:1059: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1057: checking whether "cc -mieee" works" >&5
+echo "configure:1064: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1061 "configure"
+#line 1068 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1068: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1080,7 +1087,7 @@
else
-#line 1084 "configure"
+#line 1091 "configure"
#include <float.h>
@@ -1094,7 +1101,7 @@
EOF
-if { (eval echo configure:1098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1107,14 +1114,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1111: checking for full floating-point support with -mieee" >&5
+echo "configure:1118: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1118 "configure"
+#line 1125 "configure"
#include <float.h>
@@ -1128,7 +1135,7 @@
EOF
-if { (eval echo configure:1132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1165,7 +1172,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1169: checking for $ac_word" >&5
+echo "configure:1176: checking for $ac_word" >&5
case "$pwd" in
@@ -1203,7 +1210,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1207: checking for source directory" >&5
+echo "configure:1214: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1214,7 +1221,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1218: checking for build directory" >&5
+echo "configure:1225: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1282,7 +1289,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1286: checking for $ac_word" >&5
+echo "configure:1293: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1341,7 +1348,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1345: checking for MacOSX App" >&5
+echo "configure:1352: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1353,7 +1360,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX architectures" >&5
+echo "configure:1364: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1382,7 +1389,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1386: checking for MacOSX SDK" >&5
+echo "configure:1393: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1392,7 +1399,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1436,7 +1443,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1440: checking how to build libraries" >&5
+echo "configure:1447: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1864,6 +1871,16 @@
+# Check whether --with-opencl or --without-opencl was given.
+if test "${with_opencl+set}" = set; then
+ withval="$with_opencl"
+else
+ with_opencl=no
+fi
# Check whether --with-gdal or --without-gdal was given.
if test "${with_gdal+set}" = set; then
withval="$with_gdal"
@@ -2287,6 +2304,23 @@
+# Check whether --with-opencl-includes or --without-opencl-includes was given.
+if test "${with_opencl_includes+set}" = set; then
+ withval="$with_opencl_includes"
+fi
+# Check whether --with-opencl-libs or --without-opencl-libs was given.
+if test "${with_opencl_libs+set}" = set; then
+ withval="$with_opencl_libs"
+fi
# Put this early on so CPPFLAGS and LDFLAGS have any additional dirs
# With includes option
@@ -2296,7 +2330,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2300: checking for additional include dirs" >&5
+echo "configure:2334: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2319,7 +2353,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2323: checking for additional library dirs" >&5
+echo "configure:2357: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2353,7 +2387,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2357: checking for a BSD compatible install" >&5
+echo "configure:2391: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2406,7 +2440,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2410: checking for $ac_word" >&5
+echo "configure:2444: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2437,13 +2471,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2441: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2475: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2447 "configure"
+#line 2481 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2454,7 +2488,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2479,7 +2513,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2483: checking for $ac_word" >&5
+echo "configure:2517: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2519,7 +2553,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2523: checking for $ac_word" >&5
+echo "configure:2557: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2550,7 +2584,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2554: checking for $ac_word" >&5
+echo "configure:2588: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2588,7 +2622,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2592: checking for $ac_word" >&5
+echo "configure:2626: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2617,7 +2651,7 @@
-echo "configure:2621: checking for $ac_word" >&5
+echo "configure:2655: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2648,7 +2682,7 @@
-echo "configure:2652: checking for $ac_word" >&5
+echo "configure:2686: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2677,7 +2711,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2681: checking for $ac_word" >&5
+echo "configure:2715: checking for $ac_word" >&5
case "$PERL" in
@@ -2708,7 +2742,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2712: checking how to run the C preprocessor" >&5
+echo "configure:2746: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2721,13 +2755,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2725 "configure"
+#line 2759 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2738,13 +2772,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2742 "configure"
+#line 2776 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2782: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2755,13 +2789,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2759 "configure"
+#line 2793 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2799: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2785,10 +2819,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2789: checking for ANSI C header files" >&5
+echo "configure:2823: checking for ANSI C header files" >&5
-#line 2792 "configure"
+#line 2826 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2796,7 +2830,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2813,7 +2847,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2817 "configure"
+#line 2851 "configure"
#include <string.h>
EOF
@@ -2831,7 +2865,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2835 "configure"
+#line 2869 "configure"
#include <stdlib.h>
EOF
@@ -2852,7 +2886,7 @@
else
-#line 2856 "configure"
+#line 2890 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2863,7 +2897,7 @@
exit (0); }
EOF
-if { (eval echo configure:2867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2890,15 +2924,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2894: checking for $ac_hdr" >&5
+echo "configure:2928: checking for $ac_hdr" >&5
-#line 2897 "configure"
+#line 2931 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2936: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2927,15 +2961,15 @@
do
-echo "configure:2931: checking for $ac_hdr" >&5
+echo "configure:2965: checking for $ac_hdr" >&5
-#line 2934 "configure"
+#line 2968 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2964,15 +2998,15 @@
do
-echo "configure:2968: checking for $ac_hdr" >&5
+echo "configure:3002: checking for $ac_hdr" >&5
-#line 2971 "configure"
+#line 3005 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3001,15 +3035,15 @@
do
-echo "configure:3005: checking for $ac_hdr" >&5
+echo "configure:3039: checking for $ac_hdr" >&5
-#line 3008 "configure"
+#line 3042 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3038,15 +3072,15 @@
do
-echo "configure:3042: checking for $ac_hdr" >&5
+echo "configure:3076: checking for $ac_hdr" >&5
-#line 3045 "configure"
+#line 3079 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3084: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3072,10 +3106,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3076: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3110: checking whether time.h and sys/time.h may both be included" >&5
-#line 3079 "configure"
+#line 3113 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3084,7 +3118,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3088: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3122: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3104,10 +3138,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3108: checking for off_t" >&5
+echo "configure:3142: checking for off_t" >&5
-#line 3111 "configure"
+#line 3145 "configure"
#if STDC_HEADERS
@@ -3134,10 +3168,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3138: checking for uid_t in sys/types.h" >&5
+echo "configure:3172: checking for uid_t in sys/types.h" >&5
-#line 3141 "configure"
+#line 3175 "configure"
EOF
@@ -3165,10 +3199,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3169: checking return type of signal handlers" >&5
+echo "configure:3203: checking return type of signal handlers" >&5
-#line 3172 "configure"
+#line 3206 "configure"
#include <signal.h>
@@ -3185,7 +3219,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3189: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3203,10 +3237,10 @@
-echo "configure:3207: checking for Cygwin environment" >&5
+echo "configure:3241: checking for Cygwin environment" >&5
-#line 3210 "configure"
+#line 3244 "configure"
int main() {
@@ -3217,7 +3251,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3255: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3235,10 +3269,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3239: checking for $ac_func" >&5
+echo "configure:3273: checking for $ac_func" >&5
-#line 3242 "configure"
+#line 3276 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3261,7 +3295,7 @@
; return 0; }
EOF
-if { (eval echo configure:3265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3287,10 +3321,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3291: checking for $ac_func" >&5
+echo "configure:3325: checking for $ac_func" >&5
-#line 3294 "configure"
+#line 3328 "configure"
@@ -3313,7 +3347,7 @@
; return 0; }
EOF
-if { (eval echo configure:3317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3339,10 +3373,10 @@
for ac_func in drand48
do
-echo "configure:3343: checking for $ac_func" >&5
+echo "configure:3377: checking for $ac_func" >&5
-#line 3346 "configure"
+#line 3380 "configure"
@@ -3365,7 +3399,7 @@
; return 0; }
EOF
-if { (eval echo configure:3369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3391,10 +3425,10 @@
for ac_func in putenv setenv
do
-echo "configure:3395: checking for $ac_func" >&5
+echo "configure:3429: checking for $ac_func" >&5
-#line 3398 "configure"
+#line 3432 "configure"
@@ -3417,7 +3451,7 @@
; return 0; }
EOF
-if { (eval echo configure:3421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3443,10 +3477,10 @@
for ac_func in nanosleep
do
-echo "configure:3447: checking for $ac_func" >&5
+echo "configure:3481: checking for $ac_func" >&5
-#line 3450 "configure"
+#line 3484 "configure"
@@ -3469,7 +3503,7 @@
; return 0; }
EOF
-if { (eval echo configure:3473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3494,13 +3528,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3498: checking whether setpgrp takes no argument" >&5
+echo "configure:3532: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3504 "configure"
+#line 3538 "configure"
#ifdef HAVE_UNISTD_H
@@ -3520,7 +3554,7 @@
EOF
-if { (eval echo configure:3524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3548,16 +3582,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3552: checking for long long int" >&5
+echo "configure:3586: checking for long long int" >&5
-#line 3554 "configure"
+#line 3588 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3561: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3595: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3577,7 +3611,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3581: checking for W11" >&5
+echo "configure:3615: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3605,7 +3639,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3609: checking for X" >&5
+echo "configure:3643: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3665,12 +3699,12 @@
# First, try using that file with no special directory specified.
-#line 3669 "configure"
+#line 3703 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3674: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3739,14 +3773,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3743 "configure"
+#line 3777 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3851,17 +3885,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3855: checking whether -R must be followed by a space" >&5
+echo "configure:3889: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3858 "configure"
+#line 3892 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3877,14 +3911,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3881 "configure"
+#line 3915 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3916,13 +3950,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3920: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3954: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3926 "configure"
+#line 3960 "configure"
@@ -3933,7 +3967,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3954,13 +3988,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3958: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3992: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3964 "configure"
+#line 3998 "configure"
@@ -3971,7 +4005,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3999,10 +4033,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4003: checking for gethostbyname" >&5
+echo "configure:4037: checking for gethostbyname" >&5
-#line 4006 "configure"
+#line 4040 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4025,7 +4059,7 @@
; return 0; }
EOF
-if { (eval echo configure:4029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4045,13 +4079,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4049: checking for gethostbyname in -lnsl" >&5
+echo "configure:4083: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4055 "configure"
+#line 4089 "configure"
@@ -4062,7 +4096,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4091,10 +4125,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4095: checking for connect" >&5
+echo "configure:4129: checking for connect" >&5
-#line 4098 "configure"
+#line 4132 "configure"
which can conflict with char connect(); below. */
@@ -4117,7 +4151,7 @@
; return 0; }
EOF
-if { (eval echo configure:4121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4137,13 +4171,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4141: checking for connect in -lsocket" >&5
+echo "configure:4175: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4147 "configure"
+#line 4181 "configure"
@@ -4154,7 +4188,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4177,10 +4211,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4181: checking for remove" >&5
+echo "configure:4215: checking for remove" >&5
-#line 4184 "configure"
+#line 4218 "configure"
which can conflict with char remove(); below. */
@@ -4203,7 +4237,7 @@
; return 0; }
EOF
-if { (eval echo configure:4207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4223,13 +4257,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4227: checking for remove in -lposix" >&5
+echo "configure:4261: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4233 "configure"
+#line 4267 "configure"
@@ -4240,7 +4274,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4244: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4263,10 +4297,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4267: checking for shmat" >&5
+echo "configure:4301: checking for shmat" >&5
-#line 4270 "configure"
+#line 4304 "configure"
which can conflict with char shmat(); below. */
@@ -4289,7 +4323,7 @@
; return 0; }
EOF
-if { (eval echo configure:4293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4309,13 +4343,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4313: checking for shmat in -lipc" >&5
+echo "configure:4347: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4319 "configure"
+#line 4353 "configure"
@@ -4326,7 +4360,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4358,13 +4392,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4362: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4396: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4368 "configure"
+#line 4402 "configure"
@@ -4375,7 +4409,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4415,12 +4449,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4419: checking for library containing cuserid" >&5
+echo "configure:4453: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4424 "configure"
+#line 4458 "configure"
@@ -4431,7 +4465,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4442,7 +4476,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4446 "configure"
+#line 4480 "configure"
@@ -4453,7 +4487,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4479,10 +4513,10 @@
for ac_func in asprintf
do
-echo "configure:4483: checking for $ac_func" >&5
+echo "configure:4517: checking for $ac_func" >&5
-#line 4486 "configure"
+#line 4520 "configure"
@@ -4505,7 +4539,7 @@
; return 0; }
EOF
-if { (eval echo configure:4509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4543: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4532,10 +4566,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4536: checking for atan" >&5
+echo "configure:4570: checking for atan" >&5
-#line 4539 "configure"
+#line 4573 "configure"
which can conflict with char atan(); below. */
@@ -4558,7 +4592,7 @@
; return 0; }
EOF
-if { (eval echo configure:4562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4576,13 +4610,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4580: checking for atan in -lm" >&5
+echo "configure:4614: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4586 "configure"
+#line 4620 "configure"
@@ -4593,7 +4627,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4620,10 +4654,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4624: checking for dlsym" >&5
+echo "configure:4658: checking for dlsym" >&5
-#line 4627 "configure"
+#line 4661 "configure"
which can conflict with char dlsym(); below. */
@@ -4646,7 +4680,7 @@
; return 0; }
EOF
-if { (eval echo configure:4650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4664,13 +4698,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4668: checking for dlsym in -ldl" >&5
+echo "configure:4702: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4674 "configure"
+#line 4708 "configure"
@@ -4681,7 +4715,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4708,10 +4742,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4712: checking for iconv" >&5
+echo "configure:4746: checking for iconv" >&5
-#line 4715 "configure"
+#line 4749 "configure"
which can conflict with char iconv(); below. */
@@ -4734,7 +4768,7 @@
; return 0; }
EOF
-if { (eval echo configure:4738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4752,13 +4786,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4756: checking for iconv in -liconv" >&5
+echo "configure:4790: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4762 "configure"
+#line 4796 "configure"
@@ -4769,7 +4803,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4788,13 +4822,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4792: checking for iconv in -lgiconv" >&5
+echo "configure:4826: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4798 "configure"
+#line 4832 "configure"
@@ -4805,7 +4839,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4824,10 +4858,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4828: checking for libiconv" >&5
+echo "configure:4862: checking for libiconv" >&5
-#line 4831 "configure"
+#line 4865 "configure"
which can conflict with char libiconv(); below. */
@@ -4850,7 +4884,7 @@
; return 0; }
EOF
-if { (eval echo configure:4854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4868,13 +4902,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4872: checking for libiconv in -liconv" >&5
+echo "configure:4906: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4878 "configure"
+#line 4912 "configure"
@@ -4885,7 +4919,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4904,13 +4938,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4908: checking for libiconv in -lgiconv" >&5
+echo "configure:4942: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4914 "configure"
+#line 4948 "configure"
@@ -4921,7 +4955,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4958,10 +4992,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4962: checking for socket" >&5
+echo "configure:4996: checking for socket" >&5
-#line 4965 "configure"
+#line 4999 "configure"
which can conflict with char socket(); below. */
@@ -4984,7 +5018,7 @@
; return 0; }
EOF
-if { (eval echo configure:4988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5002,13 +5036,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5006: checking for socket in -lsocket" >&5
+echo "configure:5040: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5012 "configure"
+#line 5046 "configure"
@@ -5019,7 +5053,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5067,7 +5101,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5071: checking for location of zlib includes" >&5
+echo "configure:5105: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5093,15 +5127,15 @@
do
-echo "configure:5097: checking for $ac_hdr" >&5
+echo "configure:5131: checking for $ac_hdr" >&5
-#line 5100 "configure"
+#line 5134 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5139: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5135,7 +5169,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5139: checking for location of zlib library" >&5
+echo "configure:5173: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5160,13 +5194,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5164: checking for deflate in -lz" >&5
+echo "configure:5198: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5170 "configure"
+#line 5204 "configure"
@@ -5177,7 +5211,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5225,7 +5259,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5229: checking for location of External PROJ.4 includes" >&5
+echo "configure:5263: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5251,15 +5285,15 @@
do
-echo "configure:5255: checking for $ac_hdr" >&5
+echo "configure:5289: checking for $ac_hdr" >&5
-#line 5258 "configure"
+#line 5292 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5296,7 +5330,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5300: checking External PROJ.4 version" >&5
+echo "configure:5334: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5304,7 +5338,7 @@
else
-#line 5308 "configure"
+#line 5342 "configure"
#include <stdio.h>
@@ -5316,7 +5350,7 @@
EOF
-if { (eval echo configure:5320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5341,7 +5375,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5345: checking for location of External PROJ.4 library" >&5
+echo "configure:5379: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5366,13 +5400,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5370: checking for pj_get_def in -lproj" >&5
+echo "configure:5404: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5376 "configure"
+#line 5410 "configure"
@@ -5383,7 +5417,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5417,7 +5451,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5421: checking for location of External PROJ.4 data files" >&5
+echo "configure:5455: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5441,14 +5475,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5445: checking for epsg" >&5
+echo "configure:5479: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5452: checking for $PROJSHARE/epsg" >&5
+echo "configure:5486: checking for $PROJSHARE/epsg" >&5
@@ -5480,7 +5514,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5484: checking for $ac_word" >&5
+echo "configure:5518: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5520,7 +5554,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5524: checking whether to use regex" >&5
+echo "configure:5558: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5540,7 +5574,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5544: checking for location of regex includes" >&5
+echo "configure:5578: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5566,15 +5600,15 @@
do
-echo "configure:5570: checking for $ac_hdr" >&5
+echo "configure:5604: checking for $ac_hdr" >&5
-#line 5573 "configure"
+#line 5607 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5578: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5612: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5608,7 +5642,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5612: checking for location of regex library" >&5
+echo "configure:5646: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5633,10 +5667,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5637: checking for regcomp" >&5
+echo "configure:5671: checking for regcomp" >&5
-#line 5640 "configure"
+#line 5674 "configure"
which can conflict with char regcomp(); below. */
@@ -5659,7 +5693,7 @@
; return 0; }
EOF
-if { (eval echo configure:5663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5686,13 +5720,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5690: checking for regcomp in -lregex" >&5
+echo "configure:5724: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5696 "configure"
+#line 5730 "configure"
@@ -5703,7 +5737,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5753,7 +5787,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5757: checking whether to use Readline" >&5
+echo "configure:5791: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5774,7 +5808,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5778: checking for location of Readline includes" >&5
+echo "configure:5812: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5800,15 +5834,15 @@
do
-echo "configure:5804: checking for $ac_hdr" >&5
+echo "configure:5838: checking for $ac_hdr" >&5
-#line 5807 "configure"
+#line 5841 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5846: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5844,15 +5878,15 @@
do
-echo "configure:5848: checking for $ac_hdr" >&5
+echo "configure:5882: checking for $ac_hdr" >&5
-#line 5851 "configure"
+#line 5885 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5886,7 +5920,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5890: checking for location of Readline library" >&5
+echo "configure:5924: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5911,13 +5945,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5915: checking for readline in -lreadline" >&5
+echo "configure:5949: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5921 "configure"
+#line 5955 "configure"
@@ -5928,7 +5962,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5963,13 +5997,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5967: checking for add_history in -lhistory" >&5
+echo "configure:6001: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 5973 "configure"
+#line 6007 "configure"
@@ -5980,7 +6014,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6022,7 +6056,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6026: checking whether to use GDAL" >&5
+echo "configure:6060: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6040,7 +6074,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6044: checking for $ac_word" >&5
+echo "configure:6078: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6095,14 +6129,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6099 "configure"
+#line 6133 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6111,14 +6145,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6115 "configure"
+#line 6149 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6150,7 +6184,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6154: checking whether to use libLAS" >&5
+echo "configure:6188: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6167,7 +6201,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6171: checking for $ac_word" >&5
+echo "configure:6205: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6215,14 +6249,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6219 "configure"
+#line 6253 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6230,14 +6264,14 @@
rm -rf conftest*
-#line 6234 "configure"
+#line 6268 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6269,7 +6303,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6273: checking whether to use NetCDF" >&5
+echo "configure:6307: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6286,7 +6320,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6290: checking for $ac_word" >&5
+echo "configure:6324: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6333,14 +6367,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6337 "configure"
+#line 6371 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6348,14 +6382,14 @@
rm -rf conftest*
-#line 6352 "configure"
+#line 6386 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6359: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6386,7 +6420,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6390: checking whether to use GEOS" >&5
+echo "configure:6424: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6404,7 +6438,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6408: checking for $ac_word" >&5
+echo "configure:6442: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6452,15 +6486,15 @@
do
-echo "configure:6456: checking for $ac_hdr" >&5
+echo "configure:6490: checking for $ac_hdr" >&5
-#line 6459 "configure"
+#line 6493 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6498: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6499,13 +6533,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6503: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6537: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6509 "configure"
+#line 6543 "configure"
@@ -6516,7 +6550,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6560,7 +6594,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6564: checking whether to use TIFF" >&5
+echo "configure:6598: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6580,7 +6614,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6584: checking for location of TIFF includes" >&5
+echo "configure:6618: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6606,15 +6640,15 @@
do
-echo "configure:6610: checking for $ac_hdr" >&5
+echo "configure:6644: checking for $ac_hdr" >&5
-#line 6613 "configure"
+#line 6647 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6648,7 +6682,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6652: checking for location of TIFF library" >&5
+echo "configure:6686: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6679,13 +6713,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6683: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6717: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6689 "configure"
+#line 6723 "configure"
@@ -6696,7 +6730,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6715,13 +6749,13 @@
-echo "configure:6719: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6753: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6725 "configure"
+#line 6759 "configure"
@@ -6732,7 +6766,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6751,13 +6785,13 @@
-echo "configure:6755: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6789: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6761 "configure"
+#line 6795 "configure"
@@ -6768,7 +6802,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6787,13 +6821,13 @@
-echo "configure:6791: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6825: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6797 "configure"
+#line 6831 "configure"
@@ -6804,7 +6838,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6823,13 +6857,13 @@
-echo "configure:6827: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6861: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6833 "configure"
+#line 6867 "configure"
@@ -6840,7 +6874,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6859,13 +6893,13 @@
-echo "configure:6863: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6897: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6869 "configure"
+#line 6903 "configure"
@@ -6876,7 +6910,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6895,13 +6929,13 @@
-echo "configure:6899: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6933: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6905 "configure"
+#line 6939 "configure"
@@ -6912,7 +6946,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6931,13 +6965,13 @@
-echo "configure:6935: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6969: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6941 "configure"
+#line 6975 "configure"
@@ -6948,7 +6982,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7046,7 +7080,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7050: checking whether to use PNG" >&5
+echo "configure:7084: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7065,7 +7099,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7069: checking for location of PNG includes" >&5
+echo "configure:7103: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7091,15 +7125,15 @@
do
-echo "configure:7095: checking for $ac_hdr" >&5
+echo "configure:7129: checking for $ac_hdr" >&5
-#line 7098 "configure"
+#line 7132 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7103: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7133,7 +7167,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7137: checking for location of PNG library" >&5
+echo "configure:7171: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7158,13 +7192,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7162: checking for png_read_image in -lpng" >&5
+echo "configure:7196: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7168 "configure"
+#line 7202 "configure"
@@ -7175,7 +7209,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7217,7 +7251,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7221: checking whether to use PostgreSQL" >&5
+echo "configure:7255: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7244,7 +7278,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7248: checking for location of PostgreSQL includes" >&5
+echo "configure:7282: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7270,15 +7304,15 @@
do
-echo "configure:7274: checking for $ac_hdr" >&5
+echo "configure:7308: checking for $ac_hdr" >&5
-#line 7277 "configure"
+#line 7311 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7282: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7316,7 +7350,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7320: checking for location of PostgreSQL library" >&5
+echo "configure:7354: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7345,13 +7379,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7349: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7383: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7355 "configure"
+#line 7389 "configure"
@@ -7362,7 +7396,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7381,13 +7415,13 @@
-echo "configure:7385: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7419: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7391 "configure"
+#line 7425 "configure"
@@ -7398,7 +7432,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7402: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7417,13 +7451,13 @@
-echo "configure:7421: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7455: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7427 "configure"
+#line 7461 "configure"
@@ -7434,7 +7468,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7453,13 +7487,13 @@
-echo "configure:7457: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7491: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7463 "configure"
+#line 7497 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7470,7 +7504,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7527,13 +7561,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7531: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7565: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7537 "configure"
+#line 7571 "configure"
@@ -7544,7 +7578,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7566,13 +7600,13 @@
-echo "configure:7570: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7604: checking for PQcmdTuples in -lpq" >&5
-#line 7576 "configure"
+#line 7610 "configure"
@@ -7583,7 +7617,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7626,7 +7660,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7630: checking whether to use MySQL" >&5
+echo "configure:7664: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7646,7 +7680,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7650: checking for location of MySQL includes" >&5
+echo "configure:7684: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7672,15 +7706,15 @@
do
-echo "configure:7676: checking for $ac_hdr" >&5
+echo "configure:7710: checking for $ac_hdr" >&5
-#line 7679 "configure"
+#line 7713 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7717,7 +7751,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7721: checking for location of MySQL library" >&5
+echo "configure:7755: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7748,13 +7782,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7752: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7786: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7758 "configure"
+#line 7792 "configure"
@@ -7765,7 +7799,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7784,13 +7818,13 @@
-echo "configure:7788: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7822: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7794 "configure"
+#line 7828 "configure"
@@ -7801,7 +7835,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7820,13 +7854,13 @@
-echo "configure:7824: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7858: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7830 "configure"
+#line 7864 "configure"
@@ -7837,7 +7871,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7856,13 +7890,13 @@
-echo "configure:7860: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7894: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7866 "configure"
+#line 7900 "configure"
@@ -7873,7 +7907,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7892,13 +7926,13 @@
-echo "configure:7896: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7930: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7902 "configure"
+#line 7936 "configure"
@@ -7909,7 +7943,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7913: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7928,13 +7962,13 @@
-echo "configure:7932: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7966: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7938 "configure"
+#line 7972 "configure"
@@ -7945,7 +7979,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7964,13 +7998,13 @@
-echo "configure:7968: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8002: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7974 "configure"
+#line 8008 "configure"
@@ -7981,7 +8015,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8000,13 +8034,13 @@
-echo "configure:8004: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8038: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8010 "configure"
+#line 8044 "configure"
@@ -8017,7 +8051,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8107,7 +8141,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8111: checking for $ac_word" >&5
+echo "configure:8145: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8156,10 +8190,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8160: checking for mysql_server_init" >&5
+echo "configure:8194: checking for mysql_server_init" >&5
-#line 8163 "configure"
+#line 8197 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8185,7 +8219,7 @@
; return 0; }
EOF
-if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8237,7 +8271,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8241: checking whether to use SQLite" >&5
+echo "configure:8275: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8257,7 +8291,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8261: checking for location of SQLite includes" >&5
+echo "configure:8295: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8283,15 +8317,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8287: checking for $ac_hdr" >&5
+echo "configure:8321: checking for $ac_hdr" >&5
-#line 8290 "configure"
+#line 8324 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8334,7 +8368,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8338: checking for location of SQLite library" >&5
+echo "configure:8372: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8363,13 +8397,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8367: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8401: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8373 "configure"
+#line 8407 "configure"
@@ -8380,7 +8414,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8399,13 +8433,13 @@
-echo "configure:8403: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8437: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8409 "configure"
+#line 8443 "configure"
@@ -8416,7 +8450,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8435,13 +8469,13 @@
-echo "configure:8439: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8473: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8445 "configure"
+#line 8479 "configure"
@@ -8452,7 +8486,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8471,13 +8505,13 @@
-echo "configure:8475: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8509: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8481 "configure"
+#line 8515 "configure"
@@ -8488,7 +8522,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8557,7 +8591,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8561: checking whether to use FFMPEG" >&5
+echo "configure:8595: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8577,7 +8611,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8581: checking for location of FFMPEG includes" >&5
+echo "configure:8615: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8603,15 +8637,15 @@
do
-echo "configure:8607: checking for $ac_hdr" >&5
+echo "configure:8641: checking for $ac_hdr" >&5
-#line 8610 "configure"
+#line 8644 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8647,15 +8681,15 @@
do
-echo "configure:8651: checking for $ac_hdr" >&5
+echo "configure:8685: checking for $ac_hdr" >&5
-#line 8654 "configure"
+#line 8688 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8691,15 +8725,15 @@
do
-echo "configure:8695: checking for $ac_hdr" >&5
+echo "configure:8729: checking for $ac_hdr" >&5
-#line 8698 "configure"
+#line 8732 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8742,7 +8776,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8746: checking for location of FFMPEG library" >&5
+echo "configure:8780: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8769,13 +8803,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8773: checking for av_free in -lavutil" >&5
+echo "configure:8807: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8779 "configure"
+#line 8813 "configure"
@@ -8786,7 +8820,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8805,13 +8839,13 @@
-echo "configure:8809: checking for av_free in -lavutil" >&5
+echo "configure:8843: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8815 "configure"
+#line 8849 "configure"
@@ -8822,7 +8856,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8867,13 +8901,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8871: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8905: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8877 "configure"
+#line 8911 "configure"
@@ -8884,7 +8918,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8903,13 +8937,13 @@
-echo "configure:8907: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8941: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8913 "configure"
+#line 8947 "configure"
@@ -8920,7 +8954,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8965,13 +8999,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8969: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9003: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 8975 "configure"
+#line 9009 "configure"
@@ -8982,7 +9016,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:8986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9001,13 +9035,13 @@
-echo "configure:9005: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9039: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9011 "configure"
+#line 9045 "configure"
@@ -9018,7 +9052,7 @@
; return 0; }
EOF
-if { (eval echo configure:9022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9077,7 +9111,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9081: checking whether to use OpenGL" >&5
+echo "configure:9115: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9111,7 +9145,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9115: checking for location of OpenGL includes" >&5
+echo "configure:9149: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9137,15 +9171,15 @@
do
-echo "configure:9141: checking for $ac_hdr" >&5
+echo "configure:9175: checking for $ac_hdr" >&5
-#line 9144 "configure"
+#line 9178 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9183: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9179,7 +9213,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9183: checking for location of OpenGL library" >&5
+echo "configure:9217: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9208,13 +9242,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9212: checking for glBegin in -lGL" >&5
+echo "configure:9246: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9218 "configure"
+#line 9252 "configure"
@@ -9225,7 +9259,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9244,13 +9278,13 @@
-echo "configure:9248: checking for glBegin in -lGL" >&5
+echo "configure:9282: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9254 "configure"
+#line 9288 "configure"
@@ -9261,7 +9295,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9280,13 +9314,13 @@
-echo "configure:9284: checking for glBegin in -lGL" >&5
+echo "configure:9318: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9290 "configure"
+#line 9324 "configure"
@@ -9297,7 +9331,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9316,13 +9350,13 @@
-echo "configure:9320: checking for glBegin in -lGL" >&5
+echo "configure:9354: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9326 "configure"
+#line 9360 "configure"
@@ -9333,7 +9367,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9395,13 +9429,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9399: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9433: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9405 "configure"
+#line 9439 "configure"
@@ -9412,7 +9446,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9431,13 +9465,13 @@
-echo "configure:9435: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9469: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9441 "configure"
+#line 9475 "configure"
@@ -9448,7 +9482,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9495,10 +9529,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9499: checking for glXCreatePbuffer" >&5
+echo "configure:9533: checking for glXCreatePbuffer" >&5
-#line 9502 "configure"
+#line 9536 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9521,7 +9555,7 @@
; return 0; }
EOF
-if { (eval echo configure:9525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9558,10 +9592,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9562: checking for glXCreateGLXPixmap" >&5
+echo "configure:9596: checking for glXCreateGLXPixmap" >&5
-#line 9565 "configure"
+#line 9599 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9584,7 +9618,7 @@
; return 0; }
EOF
-if { (eval echo configure:9588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9627,7 +9661,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9631: checking for location of OpenGL framework" >&5
+echo "configure:9665: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9651,15 +9685,15 @@
do
-echo "configure:9655: checking for $ac_hdr" >&5
+echo "configure:9689: checking for $ac_hdr" >&5
-#line 9658 "configure"
+#line 9692 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9663: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9695,10 +9729,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9699: checking for glBegin" >&5
+echo "configure:9733: checking for glBegin" >&5
-#line 9702 "configure"
+#line 9736 "configure"
which can conflict with char glBegin(); below. */
@@ -9721,7 +9755,7 @@
; return 0; }
EOF
-if { (eval echo configure:9725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9758,10 +9792,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9762: checking for gluBeginCurve" >&5
+echo "configure:9796: checking for gluBeginCurve" >&5
-#line 9765 "configure"
+#line 9799 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9784,7 +9818,7 @@
; return 0; }
EOF
-if { (eval echo configure:9788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9832,7 +9866,7 @@
-echo "configure:9836: checking for location of OpenGL includes" >&5
+echo "configure:9870: checking for location of OpenGL includes" >&5
@@ -9858,15 +9892,15 @@
do
-echo "configure:9862: checking for $ac_hdr" >&5
+echo "configure:9896: checking for $ac_hdr" >&5
-#line 9865 "configure"
+#line 9899 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9904: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9900,7 +9934,7 @@
-echo "configure:9904: checking for location of OpenGL library" >&5
+echo "configure:9938: checking for location of OpenGL library" >&5
@@ -9925,18 +9959,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9929: checking for OpenGL library" >&5
+echo "configure:9963: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9933 "configure"
+#line 9967 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9960,18 +9994,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9964: checking for GLU library" >&5
+echo "configure:9998: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9968 "configure"
+#line 10002 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10020,7 +10054,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10024: checking whether to use ODBC" >&5
+echo "configure:10058: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10039,7 +10073,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10043: checking for location of ODBC includes" >&5
+echo "configure:10077: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10065,15 +10099,15 @@
do
-echo "configure:10069: checking for $ac_hdr" >&5
+echo "configure:10103: checking for $ac_hdr" >&5
-#line 10072 "configure"
+#line 10106 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10077: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10107,7 +10141,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10111: checking for location of ODBC library" >&5
+echo "configure:10145: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10132,13 +10166,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10136: checking for SQLConnect in -lodbc" >&5
+echo "configure:10170: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10142 "configure"
+#line 10176 "configure"
@@ -10149,7 +10183,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10174,13 +10208,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10178: checking for SQLConnect in -liodbc" >&5
+echo "configure:10212: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10184 "configure"
+#line 10218 "configure"
@@ -10191,7 +10225,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10216,11 +10250,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10220: checking for ODBC library" >&5
+echo "configure:10254: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10224 "configure"
+#line 10258 "configure"
#include <windows.h>
#include <sql.h>
@@ -10228,7 +10262,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10277,7 +10311,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10281: checking whether to use FFTW" >&5
+echo "configure:10315: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10296,7 +10330,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10300: checking for location of FFTW includes" >&5
+echo "configure:10334: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10322,15 +10356,15 @@
do
-echo "configure:10326: checking for $ac_hdr" >&5
+echo "configure:10360: checking for $ac_hdr" >&5
-#line 10329 "configure"
+#line 10363 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10368: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10358,15 +10392,15 @@
do
-echo "configure:10362: checking for $ac_hdr" >&5
+echo "configure:10396: checking for $ac_hdr" >&5
-#line 10365 "configure"
+#line 10399 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10394,15 +10428,15 @@
do
-echo "configure:10398: checking for $ac_hdr" >&5
+echo "configure:10432: checking for $ac_hdr" >&5
-#line 10401 "configure"
+#line 10435 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10406: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10448,7 +10482,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10452: checking for location of FFTW library" >&5
+echo "configure:10486: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10473,13 +10507,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10477: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10511: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10483 "configure"
+#line 10517 "configure"
@@ -10490,7 +10524,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10515,13 +10549,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10519: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10553: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10525 "configure"
+#line 10559 "configure"
@@ -10532,7 +10566,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10557,13 +10591,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10561: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10595: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10567 "configure"
+#line 10601 "configure"
@@ -10574,7 +10608,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10631,7 +10665,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10635: checking whether to use BLAS" >&5
+echo "configure:10669: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10652,7 +10686,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10656: checking for location of BLAS includes" >&5
+echo "configure:10690: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10672,7 +10706,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10676: checking for location of BLAS library" >&5
+echo "configure:10710: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10698,15 +10732,15 @@
do
-echo "configure:10702: checking for $ac_hdr" >&5
+echo "configure:10736: checking for $ac_hdr" >&5
-#line 10705 "configure"
+#line 10739 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10744: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10741,13 +10775,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10745: checking for dnrm2_ in -lblas" >&5
+echo "configure:10779: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10751 "configure"
+#line 10785 "configure"
@@ -10758,7 +10792,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10777,13 +10811,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10781: checking for dnrm2_ in -lblas" >&5
+echo "configure:10815: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10787 "configure"
+#line 10821 "configure"
@@ -10794,7 +10828,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10838,13 +10872,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10842: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10876: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10848 "configure"
+#line 10882 "configure"
@@ -10855,7 +10889,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10870,13 +10904,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10874: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10908: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10880 "configure"
+#line 10914 "configure"
@@ -10887,7 +10921,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10902,13 +10936,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10906: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10940: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10912 "configure"
+#line 10946 "configure"
@@ -10919,7 +10953,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10965,16 +10999,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10969: checking for sgemm in $vlib_flags" >&5
+echo "configure:11003: checking for sgemm in $vlib_flags" >&5
-#line 10971 "configure"
+#line 11005 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10992,13 +11026,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10996: checking for sgemm_ in -lblas" >&5
+echo "configure:11030: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11002 "configure"
+#line 11036 "configure"
@@ -11009,7 +11043,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11024,13 +11058,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11028: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11062: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11034 "configure"
+#line 11068 "configure"
@@ -11041,7 +11075,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11056,13 +11090,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11060: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11094: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11066 "configure"
+#line 11100 "configure"
@@ -11073,7 +11107,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11107,13 +11141,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11111: checking for acosp in -lsunmath" >&5
+echo "configure:11145: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11117 "configure"
+#line 11151 "configure"
@@ -11124,7 +11158,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11139,13 +11173,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11143: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11177: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11149 "configure"
+#line 11183 "configure"
@@ -11156,7 +11190,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11186,13 +11220,13 @@
# Generic BLAS library
-echo "configure:11190: checking for sgemm_ in -lblas" >&5
+echo "configure:11224: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11196 "configure"
+#line 11230 "configure"
@@ -11203,7 +11237,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11242,7 +11276,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11246: checking whether to use LAPACK" >&5
+echo "configure:11280: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11267,7 +11301,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11271: checking for location of LAPACK includes" >&5
+echo "configure:11305: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11287,7 +11321,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11291: checking for location of LAPACK library" >&5
+echo "configure:11325: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11313,15 +11347,15 @@
do
-echo "configure:11317: checking for $ac_hdr" >&5
+echo "configure:11351: checking for $ac_hdr" >&5
-#line 11320 "configure"
+#line 11354 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11359: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11353,10 +11387,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11357: checking for dsegv_" >&5
+echo "configure:11391: checking for dsegv_" >&5
-#line 11360 "configure"
+#line 11394 "configure"
which can conflict with char dsegv_(); below. */
@@ -11379,7 +11413,7 @@
; return 0; }
EOF
-if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11406,13 +11440,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11410: checking for desgv_ in -llapack" >&5
+echo "configure:11444: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11416 "configure"
+#line 11450 "configure"
@@ -11423,7 +11457,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11455,13 +11489,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11459: checking for dgesv_ in -llapack" >&5
+echo "configure:11493: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11465 "configure"
+#line 11499 "configure"
@@ -11472,7 +11506,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11491,13 +11525,13 @@
-echo "configure:11495: checking for dgesv_ in -llapack" >&5
+echo "configure:11529: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11501 "configure"
+#line 11535 "configure"
@@ -11508,7 +11542,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11564,7 +11598,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11568: checking whether to use Cairo" >&5
+echo "configure:11602: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11596,7 +11630,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11600: checking for location of cairo includes" >&5
+echo "configure:11634: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11622,15 +11656,15 @@
do
-echo "configure:11626: checking for $ac_hdr" >&5
+echo "configure:11660: checking for $ac_hdr" >&5
-#line 11629 "configure"
+#line 11663 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11666,7 +11700,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11670: checking for location of cairo library" >&5
+echo "configure:11704: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11686,7 +11720,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11690: checking for cairo linking flags" >&5
+echo "configure:11724: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11702,10 +11736,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11706: checking for cairo_create" >&5
+echo "configure:11740: checking for cairo_create" >&5
-#line 11709 "configure"
+#line 11743 "configure"
which can conflict with char cairo_create(); below. */
@@ -11728,7 +11762,7 @@
; return 0; }
EOF
-if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11762,10 +11796,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11766: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11800: checking for cairo_xlib_surface_create_with_xrender_format" >&5
cat > conftest.$ac_ext <<EOF
-#line 11769 "configure"
+#line 11803 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11788,7 +11822,7 @@
; return 0; }
EOF
-if { (eval echo configure:11792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11821,10 +11855,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11825: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11859: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11828 "configure"
+#line 11862 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11847,7 +11881,7 @@
; return 0; }
EOF
-if { (eval echo configure:11851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11889,7 +11923,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11893: checking whether to use FreeType" >&5
+echo "configure:11927: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11908,7 +11942,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11912: checking for location of FreeType includes" >&5
+echo "configure:11946: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11934,15 +11968,15 @@
do
-echo "configure:11938: checking for $ac_hdr" >&5
+echo "configure:11972: checking for $ac_hdr" >&5
-#line 11941 "configure"
+#line 11975 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11980: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11976,7 +12010,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11980: checking for location of FreeType library" >&5
+echo "configure:12014: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12001,13 +12035,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12005: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12039: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12011 "configure"
+#line 12045 "configure"
@@ -12018,7 +12052,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12059,7 +12093,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12063: checking whether to use NLS" >&5
+echo "configure:12097: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12079,10 +12113,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12083: checking for gettext" >&5
+echo "configure:12117: checking for gettext" >&5
-#line 12086 "configure"
+#line 12120 "configure"
which can conflict with char gettext(); below. */
@@ -12105,7 +12139,7 @@
; return 0; }
EOF
-if { (eval echo configure:12109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12123,13 +12157,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12127: checking for gettext in -lintl" >&5
+echo "configure:12161: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12133 "configure"
+#line 12167 "configure"
@@ -12140,7 +12174,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12175,7 +12209,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12179: checking whether to use C++" >&5
+echo "configure:12213: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12191,7 +12225,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12195: checking for $ac_word" >&5
+echo "configure:12229: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12220,7 +12254,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12224: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12258: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12231,12 +12265,12 @@
cat > conftest.$ac_ext << EOF
-#line 12235 "configure"
+#line 12269 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12262,19 +12296,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12266: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12300: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12271: checking whether we are using GNU C++" >&5
+echo "configure:12305: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12278: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12292,7 +12326,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12296: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12330: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12320,58 +12354,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 12334 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12342: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 12352 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12359: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -12384,7 +12367,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12388: checking whether to use openDWG" >&5
+echo "configure:12371: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12404,7 +12387,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12408: checking for location of openDGW includes" >&5
+echo "configure:12391: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12430,15 +12413,15 @@
do
-echo "configure:12434: checking for $ac_hdr" >&5
+echo "configure:12417: checking for $ac_hdr" >&5
-#line 12437 "configure"
+#line 12420 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12425: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12472,7 +12455,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12476: checking for location of openDWG library" >&5
+echo "configure:12459: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12513,7 +12496,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12517: checking whether to use POSIX threads" >&5
+echo "configure:12500: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12533,7 +12516,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12537: checking for location of POSIX threads includes" >&5
+echo "configure:12520: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12559,15 +12542,15 @@
do
-echo "configure:12563: checking for $ac_hdr" >&5
+echo "configure:12546: checking for $ac_hdr" >&5
-#line 12566 "configure"
+#line 12549 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12571: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12601,7 +12584,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12605: checking for location of POSIX threads library" >&5
+echo "configure:12588: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12626,10 +12609,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12630: checking for pthread_create" >&5
+echo "configure:12613: checking for pthread_create" >&5
-#line 12633 "configure"
+#line 12616 "configure"
which can conflict with char pthread_create(); below. */
@@ -12652,7 +12635,7 @@
; return 0; }
EOF
-if { (eval echo configure:12656: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12679,13 +12662,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12683: checking for pthread_create in -lpthread" >&5
+echo "configure:12666: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12689 "configure"
+#line 12672 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12696,7 +12679,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12746,7 +12729,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12750: checking whether to use OpenMP" >&5
+echo "configure:12733: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12767,7 +12750,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12771: checking for location of OpenMP includes" >&5
+echo "configure:12754: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12793,15 +12776,15 @@
do
-echo "configure:12797: checking for $ac_hdr" >&5
+echo "configure:12780: checking for $ac_hdr" >&5
-#line 12800 "configure"
+#line 12783 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12805: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12839,7 +12822,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12843: checking for location of OpenMP library" >&5
+echo "configure:12826: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12864,10 +12847,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12868: checking for GOMP_parallel_start" >&5
+echo "configure:12851: checking for GOMP_parallel_start" >&5
-#line 12871 "configure"
+#line 12854 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12890,7 +12873,7 @@
; return 0; }
EOF
-if { (eval echo configure:12894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12917,13 +12900,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12921: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12904: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12927 "configure"
+#line 12910 "configure"
@@ -12934,7 +12917,7 @@
; return 0; }
EOF
-if { (eval echo configure:12938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13003,6 +12986,183 @@
# Done checking OpenMP
+# Enable OpenCL option
+echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
+echo "configure:12994: checking whether to use OpenCL" >&5
+echo "$ac_t"""$with_opencl"" 1>&6
+case "$with_opencl" in
+ "no") USE_OPENCL= ;;
+ "yes") USE_OPENCL="1" ;;
+ *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
+esac
+OCLINCPATH=
+OCLLIBPATH=
+OCLLIB=
+if test -n "$USE_OPENCL"; then
+# With OpenCL includes directory
+echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
+echo "configure:13014: checking for location of OpenCL includes" >&5
+case "$with_opencl_includes" in
+y | ye | yes | n | no)
+ { echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_opencl_includes" 1>&6
+if test -n "$with_opencl_includes" ; then
+ for dir in $with_opencl_includes; do
+ if test -d "$dir"; then
+ OCLINCPATH="$OCLINCPATH -I$dir"
+ else
+ { echo "configure: error: *** OpenCL includes directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$OCLINCPATH $CPPFLAGS"
+for ac_hdr in CL/cl.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:13039: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 13042 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:13047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate OpenCL includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+# With OpenCL library directory
+echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
+echo "configure:13081: checking for location of OpenCL library" >&5
+case "$with_OpenCL_libs" in
+ { echo "configure: error: *** You must supply a directory to --with-OpenCL-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_OpenCL_libs" 1>&6
+if test -n "$with_OpenCL_libs"; then
+ for dir in $with_OpenCL_libs; do
+ OCLLIBPATH="$OCLLIBPATH -L$dir"
+ else
+ { echo "configure: error: *** OpenCL library directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
+# FIXME: -L${OCLLIBPATH} is not being added to the gcc conftest.c command. why not? (trac #1943?)
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$OCLLIBPATH $LDFLAGS"
+echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
+echo "configure:13106: checking for clGetPlatformInfo in -lOpenCL" >&5
+ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lOpenCL $LIBS"
+#line 13112 "configure"
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char clGetPlatformInfo();
+int main() {
+clGetPlatformInfo()
+; return 0; }
+EOF
+if { (eval echo configure:13123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=yes"
+else
+ rm -rf conftest*
+ eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+ OCLLIB="$OCLLIB -lOpenCL "
+else
+LDFLAGS=${ac_save_ldflags}
+ { echo "configure: error: *** Unable to locate OpenCLfunctions library." 1>&2; exit 1; }
+fi
+# expanded symbol check: yes? no?
+#LOC_CHECK_FUNC(clGetPlatformInfo,OpenCL functions,OCLLIB,,,,,[
+#LOC_CHECK_LIBS(OpenCL,clGetPlatformInfo,OpenCL,$OCLLIBPATH,OCLLIB,,,)
+fi # $USE_OPENCL
+# Done checking OpenCL
# Enable LFS (from cdr-tools)
# Check whether --enable-largefile or --disable-largefile was given.
if test "${enable_largefile+set}" = set; then
@@ -13013,7 +13173,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13017: checking for special C compiler options needed for large files" >&5
+echo "configure:13177: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13021,7 +13181,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13025 "configure"
+#line 13185 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13037,7 +13197,7 @@
; return 0; }
EOF
-if { (eval echo configure:13041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13201: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13046,7 +13206,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13050 "configure"
+#line 13210 "configure"
@@ -13062,7 +13222,7 @@
; return 0; }
EOF
-if { (eval echo configure:13066: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13226: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13082,11 +13242,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13086: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13246: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13090 "configure"
+#line 13250 "configure"
@@ -13102,14 +13262,14 @@
; return 0; }
EOF
-if { (eval echo configure:13106: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13266: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13113 "configure"
+#line 13273 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13127,7 +13287,7 @@
; return 0; }
EOF
-if { (eval echo configure:13131: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13291: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13146,11 +13306,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13150: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13310: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13154 "configure"
+#line 13314 "configure"
@@ -13166,14 +13326,14 @@
; return 0; }
EOF
-if { (eval echo configure:13170: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13177 "configure"
+#line 13337 "configure"
#define _LARGE_FILES 1
@@ -13191,7 +13351,7 @@
; return 0; }
EOF
-if { (eval echo configure:13195: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13210,25 +13370,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13214: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13374: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13218 "configure"
+#line 13378 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13225: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13385: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13232 "configure"
+#line 13392 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13237,7 +13397,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13241: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13258,25 +13418,25 @@
fi
-echo "configure:13262: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13422: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13266 "configure"
+#line 13426 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13273: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13433: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13280 "configure"
+#line 13440 "configure"
#include <stdio.h>
@@ -13285,7 +13445,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13289: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13308,18 +13468,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13312: checking for fseeko" >&5
+echo "configure:13472: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13316 "configure"
+#line 13476 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13336,10 +13496,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13340: checking if system supports Large Files at all" >&5
+echo "configure:13500: checking if system supports Large Files at all" >&5
-#line 13343 "configure"
+#line 13503 "configure"
#include <stdio.h>
@@ -13371,7 +13531,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13375: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13400,7 +13560,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13404: checking whether to use wxWidgets" >&5
+echo "configure:13564: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13421,7 +13581,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13425: checking for $ac_word" >&5
+echo "configure:13585: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13469,7 +13629,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13473: checking wxWidgets version" >&5
+echo "configure:13633: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13492,15 +13652,15 @@
do
-echo "configure:13496: checking for $ac_hdr" >&5
+echo "configure:13656: checking for $ac_hdr" >&5
-#line 13499 "configure"
+#line 13659 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13827,6 +13987,10 @@
s%@OMPLIB@%$OMPLIB%g
s%@OMPCFLAGS@%$OMPCFLAGS%g
s%@USE_OPENMP@%$USE_OPENMP%g
+s%@OCLINCPATH@%$OCLINCPATH%g
+s%@OCLLIBPATH@%$OCLLIBPATH%g
+s%@OCLLIB@%$OCLLIB%g
+s%@USE_OPENCL@%$USE_OPENCL%g
s%@USE_LARGEFILES@%$USE_LARGEFILES%g
s%@WX_CONFIG@%$WX_CONFIG%g
s%@WXVERSION@%$WXVERSION%g
@@ -14147,6 +14311,8 @@
echo " OGR support: `if test -n "${USE_OGR}" ; then echo yes ; else echo no ; fi`"
+echo " OpenCL support: `if test -n "${USE_OPENCL}" ; then echo yes ; else echo no ; fi`"
echo " OpenGL support: `if test -n "${USE_OPENGL}" ; then echo yes ; else echo no ; fi`"
echo " OpenMP support: `if test -n "${USE_OPENMP}" ; then echo yes ; else echo no ; fi`"
