[GRASS-SVN] r55956 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Tue Apr 23 07:47:34 PDT 2013
Author: zarch
Date: 2013-04-23 07:47:33 -0700 (Tue, 23 Apr 2013)
New Revision: 55956
grass/trunk/lib/python/script/core.py
>From tab to space
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2013-04-23 13:12:51 UTC (rev 55955)
+++ grass/trunk/lib/python/script/core.py 2013-04-23 14:47:33 UTC (rev 55956)
@@ -46,10 +46,10 @@
cwd = None, env = None, universal_newlines = False,
startupinfo = None, creationflags = 0):
- if shell == None:
- shell = (sys.platform == "win32")
+ if shell == None:
+ shell = (sys.platform == "win32")
- subprocess.Popen.__init__(self, args, bufsize, executable,
+ subprocess.Popen.__init__(self, args, bufsize, executable,
stdin, stdout, stderr,
preexec_fn, close_fds, shell,
cwd, env, universal_newlines,
@@ -73,8 +73,8 @@
# GRASS-oriented interface to subprocess module
_popen_args = ["bufsize", "executable", "stdin", "stdout", "stderr",
- "preexec_fn", "close_fds", "cwd", "env",
- "universal_newlines", "startupinfo", "creationflags"]
+ "preexec_fn", "close_fds", "cwd", "env",
+ "universal_newlines", "startupinfo", "creationflags"]
def decode(string):
enc = locale.getdefaultlocale()[1]
@@ -86,11 +86,11 @@
def _make_val(val):
if isinstance(val, types.StringType) or \
isinstance(val, types.UnicodeType):
- return val
+ return val
if isinstance(val, types.ListType):
- return ",".join(map(_make_val, val))
+ return ",".join(map(_make_val, val))
if isinstance(val, types.TupleType):
- return _make_val(list(val))
+ return _make_val(list(val))
return str(val)
def get_commands():
@@ -157,20 +157,20 @@
args = [prog]
if overwrite:
- args.append("--o")
+ args.append("--o")
if quiet:
- args.append("--q")
+ args.append("--q")
if verbose:
- args.append("--v")
+ args.append("--v")
if flags:
if '-' in flags:
raise ScriptError("'-' is not a valid flag")
- args.append("-%s" % flags)
+ args.append("-%s" % flags)
for opt, val in options.iteritems():
- if val != None:
- if opt[0] == '_':
- opt = opt[1:]
- args.append("%s=%s" % (opt, _make_val(val)))
+ if val != None:
+ if opt[0] == '_':
+ opt = opt[1:]
+ args.append("%s=%s" % (opt, _make_val(val)))
return args
def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
@@ -203,10 +203,10 @@
options = {}
popts = {}
for opt, val in kwargs.iteritems():
- if opt in _popen_args:
- popts[opt] = val
- else:
- options[opt] = val
+ if opt in _popen_args:
+ popts[opt] = val
+ else:
+ options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
@@ -348,7 +348,7 @@
args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
if env == None:
- env = os.environ
+ env = os.environ
os.execvpe(prog, args, env)
# interface to g.message
@@ -447,22 +447,22 @@
options = {}
flags = {}
for line in lines:
- line = line.rstrip('\r\n')
- if not line:
- break
- try:
- [var, val] = line.split('=', 1)
- except:
- raise SyntaxError("invalid output from g.parser: %s" % line)
+ line = line.rstrip('\r\n')
+ if not line:
+ break
+ try:
+ [var, val] = line.split('=', 1)
+ except:
+ raise SyntaxError("invalid output from g.parser: %s" % line)
- if var.startswith('flag_'):
- flags[var[5:]] = bool(int(val))
- elif var.startswith('opt_'):
- options[var[4:]] = val
- elif var in ['GRASS_OVERWRITE', 'GRASS_VERBOSE']:
- os.environ[var] = val
- else:
+ if var.startswith('flag_'):
+ flags[var[5:]] = bool(int(val))
+ elif var.startswith('opt_'):
+ options[var[4:]] = val
+ elif var in ['GRASS_OVERWRITE', 'GRASS_VERBOSE']:
+ os.environ[var] = val
+ else:
return (options, flags)
@@ -470,9 +470,9 @@
"""!Interface to g.parser, intended to be run from the top-level, e.g.:
@code
- if __name__ == "__main__":
- options, flags = grass.parser()
- main()
+ if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
@endcode
Thereafter, the global variables "options" and "flags" will be
@@ -491,10 +491,10 @@
argv = sys.argv[:]
name = argv[0]
if not os.path.isabs(name):
- if os.sep in name or (os.altsep and os.altsep in name):
- argv[0] = os.path.abspath(name)
- else:
- argv[0] = os.path.join(sys.path[0], name)
+ if os.sep in name or (os.altsep and os.altsep in name):
+ argv[0] = os.path.abspath(name)
+ else:
+ argv[0] = os.path.join(sys.path[0], name)
p = Popen(['g.parser', '-s'] + argv, stdout = PIPE)
s = p.communicate()[0]
@@ -579,12 +579,12 @@
lines = s.splitlines()
for line in lines:
- kv = line.split(sep, 1)
- k = kv[0].strip()
- if len(kv) > 1:
- v = kv[1].strip()
- else:
- v = dflt
+ kv = line.split(sep, 1)
+ k = kv[0].strip()
+ if len(kv) > 1:
+ v = kv[1].strip()
+ else:
+ v = dflt
if val_type:
result[k] = val_type(v)
@@ -660,7 +660,7 @@
def compare_key_value_text_files(filename_a, filename_b, sep=":",
val_sep=",", precision=0.000001):
- !Compare two key-value text two files
+ !Compare two key-value text two files
This method will print a warning in case keys that are present in the first file
are not present in the second one.
@@ -674,7 +674,7 @@
c: 1,2,3,4,5
d : hello,8,0.1
\endcode
@param filename_a name of the first key-value text file
@param filenmae_b name of the second key-value text file
@param sep character that separates the keys and values, default is ":"
@@ -685,7 +685,7 @@
dict_a = _text_to_key_value_dict(filename_a, sep)
dict_b = _text_to_key_value_dict(filename_b, sep)
missing_keys = 0
# We compare matching keys
@@ -743,9 +743,9 @@
s = read_command("g.region", flags='p')
kv = parse_key_val(s, ':')
if kv['projection'].split(' ')[1] == '3':
- return True
+ return True
else:
- return False
+ return False
def region(region3d = False, complete = False):
"""!Returns the output from running "g.region -g", as a
@@ -775,7 +775,7 @@
'rows3', 'cols3', 'cells3', 'depths']:
if k not in reg:
continue
- reg[k] = int(reg[k])
+ reg[k] = int(reg[k])
return reg
@@ -867,10 +867,10 @@
def del_temp_region():
"""!Unsets WIND_OVERRIDE and removes any region named by it."""
try:
- name = os.environ.pop('WIND_OVERRIDE')
- run_command("g.remove", quiet = True, region = name)
+ name = os.environ.pop('WIND_OVERRIDE')
+ run_command("g.remove", quiet = True, region = name)
except:
- pass
+ pass
# interface to g.findfile
@@ -929,16 +929,16 @@
mapset = None
for line in read_command("g.list", type = type).splitlines():
- if line == "":
- continue
- if dashes_re.match(line):
- continue
- m = mapset_re.search(line)
- if m:
- mapset = m.group(1)
+ if line == "":
+ continue
+ if dashes_re.match(line):
+ continue
+ m = mapset_re.search(line)
+ if m:
+ mapset = m.group(1)
if mapset not in result.keys():
result[mapset] = []
- continue
+ continue
if mapset:
result[mapset].extend(line.split())
@@ -947,7 +947,7 @@
def _concat(xs):
result = []
for x in xs:
- result.extend(x)
+ result.extend(x)
return result
def list_pairs(type):
@@ -966,7 +966,7 @@
@return list of tuples (map, mapset)
return _concat([[(map, mapset) for map in maps]
- for mapset, maps in list_grouped(type).iteritems()])
+ for mapset, maps in list_grouped(type).iteritems()])
def list_strings(type):
"""!List of elements as strings.
@@ -1132,9 +1132,9 @@
"""!Return the verbosity level selected by GRASS_VERBOSE"""
vbstr = os.getenv('GRASS_VERBOSE')
if vbstr:
- return int(vbstr)
+ return int(vbstr)
else:
- return 2
+ return 2
## various utilities, not specific to GRASS
@@ -1149,10 +1149,10 @@
name = os.path.basename(path)
if not ext:
- return name
+ return name
fs = name.rsplit('.', 1)
if len(fs) > 1 and fs[1].lower() == ext:
- name = fs[0]
+ name = fs[0]
return name
# find a program (replacement for "which")
@@ -1168,13 +1168,13 @@
nuldev = file(os.devnull, 'w+')
try:
- ret = call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
+ ret = call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
if ret == 0:
found = True
else:
found = False
except:
- found = False
+ found = False
nuldev.close()
return found
@@ -1188,9 +1188,9 @@
@param path path to file to remove
try:
- os.remove(path)
+ os.remove(path)
except:
- pass
+ pass
# try to remove a directory, without complaints
@@ -1201,9 +1201,9 @@
@param path path to directory to remove
try:
- os.rmdir(path)
+ os.rmdir(path)
except:
- shutil.rmtree(path, ignore_errors = True)
+ shutil.rmtree(path, ignore_errors = True)
def float_or_dms(s):
"""!Convert DMS to float.
