[GRASS-SVN] r55959 - grass/trunk
svn_grass at osgeo.org
Tue Apr 23 14:38:03 PDT 2013
Author: hamish
Date: 2013-04-23 14:38:03 -0700 (Tue, 23 Apr 2013)
New Revision: 55959
grass/trunk/configure
OpenCL on Mac uses a different header.. (#1446), autoconf2.13'd
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-04-23 21:37:31 UTC (rev 55958)
+++ grass/trunk/configure 2013-04-23 21:38:03 UTC (rev 55959)
@@ -13029,21 +13029,68 @@
fi
+if test -n "$MACOSX_APP" ; then
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$OCLINCPATH $CPPFLAGS"
+for ac_hdr in OpenCL/opencl.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:13041: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 13044 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:13049: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate OpenCL includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+else
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$OCLINCPATH $CPPFLAGS"
for ac_hdr in CL/cl.h
do
-echo "configure:13039: checking for $ac_hdr" >&5
+echo "configure:13086: checking for $ac_hdr" >&5
-#line 13042 "configure"
+#line 13089 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13047: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13072,12 +13119,13 @@
+fi
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13081: checking for location of OpenCL library" >&5
+echo "configure:13129: checking for location of OpenCL library" >&5
case "$with_OpenCL_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-OpenCL-libs." 1>&2; exit 1; }
@@ -13102,13 +13150,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13106: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13154: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lOpenCL $LIBS"
-#line 13112 "configure"
+#line 13160 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13119,7 +13167,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13173,7 +13221,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13177: checking for special C compiler options needed for large files" >&5
+echo "configure:13225: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13181,7 +13229,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13185 "configure"
+#line 13233 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13197,7 +13245,7 @@
; return 0; }
EOF
-if { (eval echo configure:13201: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13249: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13206,7 +13254,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13210 "configure"
+#line 13258 "configure"
@@ -13222,7 +13270,7 @@
; return 0; }
EOF
-if { (eval echo configure:13226: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13274: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13242,11 +13290,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13246: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13294: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13250 "configure"
+#line 13298 "configure"
@@ -13262,14 +13310,14 @@
; return 0; }
EOF
-if { (eval echo configure:13266: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13314: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13273 "configure"
+#line 13321 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13287,7 +13335,7 @@
; return 0; }
EOF
-if { (eval echo configure:13291: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13306,11 +13354,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13310: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13358: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13314 "configure"
+#line 13362 "configure"
@@ -13326,14 +13374,14 @@
; return 0; }
EOF
-if { (eval echo configure:13330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13378: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13337 "configure"
+#line 13385 "configure"
#define _LARGE_FILES 1
@@ -13351,7 +13399,7 @@
; return 0; }
EOF
-if { (eval echo configure:13355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13370,25 +13418,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13374: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13422: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13378 "configure"
+#line 13426 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13385: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13433: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13392 "configure"
+#line 13440 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13397,7 +13445,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13418,25 +13466,25 @@
fi
-echo "configure:13422: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13470: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13426 "configure"
+#line 13474 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13433: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13481: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13440 "configure"
+#line 13488 "configure"
#include <stdio.h>
@@ -13445,7 +13493,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13449: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13497: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13468,18 +13516,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13472: checking for fseeko" >&5
+echo "configure:13520: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13476 "configure"
+#line 13524 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13496,10 +13544,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13500: checking if system supports Large Files at all" >&5
+echo "configure:13548: checking if system supports Large Files at all" >&5
-#line 13503 "configure"
+#line 13551 "configure"
#include <stdio.h>
@@ -13531,7 +13579,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13560,7 +13608,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13564: checking whether to use wxWidgets" >&5
+echo "configure:13612: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13581,7 +13629,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13585: checking for $ac_word" >&5
+echo "configure:13633: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13629,7 +13677,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13633: checking wxWidgets version" >&5
+echo "configure:13681: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13652,15 +13700,15 @@
do
-echo "configure:13656: checking for $ac_hdr" >&5
+echo "configure:13704: checking for $ac_hdr" >&5
-#line 13659 "configure"
+#line 13707 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
